help, i installed manjaro a couple of weeks ago, i am running dual boot, chromebook and manjaro linux, and my audio isnt working.
Please post your system Info’s:
inxi --admin --verbosity=5 --filter --no-host --width
What did you try’d yet?
al Storage: total: 58.24 GiB used: 16.52 GiB (28.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4064
size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: Removable
tech: SSD serial: fw-rev: 0x8 scheme: GPT
ID-1: / raw-size: 24.61 GiB size: 24.06 GiB (97.75%) used: 16.5 GiB (68.6%)
fs: ext4 dev: /dev/mmcblk0p13 maj-min: 259:5 label: N/A
uuid: 50450159-a1ad-4363-bbe6-ef1523b57f17
ID-2: /boot/efi raw-size: 32 MiB size: 31.9 MiB (99.75%)
used: 15.7 MiB (49.1%) fs: vfat dev: /dev/mmcblk0p12 maj-min: 259:4
label: EFI-SYSTEM uuid: BAB0-E754
System Temperatures: cpu: 74.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 189 Power: uptime: 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: shutdown
avail: reboot,suspend,test_resume image: 1.46 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Packages: 1195 pm: pacman pkgs: 1182 libs: 326 tools: pamac pm: flatpak
pkgs: 13 Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
here it is
- You missed a lot input, select it from the bottom and move your mouse to the Top, dont miss the text, the terminal window will scroll up then.
- Inserte the input in this forum and mark everything and press </> button, that it will show as code.
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=50450159-a1ad-4363-bbe6-ef1523b57f17 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: HP product: Bloog v: rev4 serial: <superuser required>
Chassis: type: 9 serial: <superuser required>
Mobo: HP model: Bloog v: rev4 serial: <superuser required> part-nu: sku68
UEFI: coreboot v: Google_Bloog.11297.440.0 date: 01/24/2024
ID-1: BAT0 charge: 30.8 Wh (83.2%) condition: 37.0/47.4 Wh (78.1%) volts: 8.0
min: 7.7 model: 333-1D- GH02047 type: Li-ion serial: <filter>
status: discharging cycles: 667
System RAM: total: 4 GiB available: 3.69 GiB used: 1.95 GiB (52.8%)
Array-1: capacity: N/A slots: 4 modules: 4 EC: None max-module-size: N/A
Device-1: Channel-0-DIMM-0 type: LPDDR4 detail: synchronous size: 1024 MiB
speed: 2400 MT/s volts: N/A width (bits): data: 16 total: 16
manufacturer: Samsung part-no: K4F8E304HB-MGCJ serial: N/A
Device-2: Channel-1-DIMM-0 type: LPDDR4 detail: synchronous size: 1024 MiB
Device-3: Channel-2-DIMM-0 type: LPDDR4 detail: synchronous size: 1024 MiB
Device-4: Channel-3-DIMM-0 type: LPDDR4 detail: synchronous size: 1024 MiB
Info: model: Intel Pentium Silver N5030 bits: 64 type: MCP
arch: Goldmont Plus level: v2 built: 2017 process: Intel 14nm family: 6
model-id: 0x7A (122) stepping: 8 microcode: 0x24
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 224 KiB desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1382 min/max: 800/3100 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1382 2: 1382 3: 1382 4: 1382 bogomips: 8756
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: SW loop, KVM: SW loop
Device-1: Intel GeminiLake [UHD Graphics 605] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3184 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
Monitor-2: eDP-1 model: AU Optronics 0x723c built: 2017 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 605 (GLK 3)
device-ID: 8086:3184 memory: 1.8 GiB unified: yes
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 605 (GLK 3) driver: mesa intel v: 24.2.4-arch1.0.1
device-ID: 8086:3184 surfaces: xcb,xlib
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 01:00.0
chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:b00c
Local Storage: total: 58.24 GiB used: 16.52 GiB (28.4%)
tech: SSD serial: <filter> fw-rev: 0x8 scheme: GPT
ID-1: / raw-size: 24.61 GiB size: 24.06 GiB (97.75%) used: 16.51 GiB (68.6%)
System Temperatures: cpu: 70.0 C mobo: N/A
Processes: 192 Power: uptime: 18m states: freeze,mem,disk suspend: deep
When possible edit your posting instead double post… remove the third/fourth posting to clean this Topic.
Gives others a better overview.
This Kernel is EOL (End of Live).
You can change Kernels in Settings>Manjaro Settings Manager>Kernel
Do you see any Sound Device in KDE? What did you try yet?
Type Alsamixer
in terminal is also worth to look at.
If i remember correct, sof-firmware
should be installed for Intel Onboard Sound.
Check if you have installed this package, if not then install it.
can you tell me which kernels aren’t in eol?
the command sof-firmware doesn’t work for me, tried alsamixer, it was at 100 volume on master
6.1 LTS, 6.6 LTS and the rolling release kernel 6.11
https://www.kernel.org/category/releases.html
That wasnt a command, its just the package.
You can search/install it with pamac, if you like.
Settings>Add/Remove Software
Did you choose your correct soundcard with f6?
And what is KDE GUI (Pavucontrol) giving you for options? Right click on the speaker icon>configure audio device.
Does it detect your soundcard there? Try to play around with your settings, maybe your soundcard is just muted.
