Hello forum users,
I have issues with my build-in microphone which has very loud static noise. (At first I thought it wasn’t working at all, but it is connected and actually records/plays back my voice.)
So I followed this Arch Wiki entry about Static noise in microphone recording. My sound card is hw:1,0
. The wiki says the following:
Determine sampling rate of the sound card (2/5)
We aim to find the highest sample rate supported by the
hw:0,0
sound card using a trial-and-error procedure starting from a low value. When the top value is reached, we got a warning message:arecord -f dat -r 60000 -D hw:0,0 -d 5 test.wav Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 60000 Hz, Stereo Warning: rate is not accurate (requested = 60000Hz, got = 44100Hz) please, try the plug plugin
Observe the
got = 44100Hz
. This is the maximum sampling rate of our card.
Since it says trial-and-error from a low value, I used the arecord
-command with different values. However: the got = xzy Hz
keeps changing upwards and I don’t know which value to use for my /etc/pulse/daemon.conf
(that’s described further in the wiki)!
Is it normal for the value to keep changing? And what is meant by “plug plugin”? And of course, what (else) can I do to stop the noise?
It’s really unsettling, as I’m still new to Linux in general and I have close to zero knowledge about audio issues. I’ll post my terminal output with changing got = xzy Hz
below.
Any help is appreciated! Thanks in advance!
Greetings, Ena
Some outputs of arecord -f dat -r (test value) -D hw:1,0 -d 5 test.wav
$ arecord --list-devices
**** Liste der Hardware-Geräte (CAPTURE) ****
Karte 1: PCH [HDA Intel PCH], Gerät 0: 92HD95 Analog [92HD95 Analog]
Sub-Geräte: 0/1
Sub-Gerät #0: subdevice #0
$ arecord -f dat -r 6000 -D hw:1,0 -d 5 test.wav
Aufnahme: WAVE 'test.wav' : Signed 16 bit Little Endian, Rate: 6000 Hz, stereo
Warnung: Rate ist nicht exakt (angefordert: 6000 Hz, unterstützt: 44100 Hz)
probieren Sie bitte das plug-Plugin:
### This is the Warning section from the wiki. It translates to "Warning: rate is not accurate (requested = 6000Hz, got = 44100Hz). please, try the plug plugin"
$ arecord -f dat -r 70000 -D hw:1,0 -d 5 test.wav
Aufnahme: WAVE 'test.wav' : Signed 16 bit Little Endian, Rate: 70000 Hz, stereo
Warnung: Rate ist nicht exakt (angefordert: 70000 Hz, unterstützt: 88200 Hz)
$ arecord -f dat -r 90000 -D hw:1,0 -d 5 test.wav
Aufnahme: WAVE 'test.wav' : Signed 16 bit Little Endian, Rate: 90000 Hz, stereo
$ aplay test.wav
Wiedergabe: WAVE 'test.wav' : Signed 16 bit Little Endian, Rate: 88200 Hz, stereo
### Why does this even work with 90000? And why does it playback with 88200 Hz?
$ arecord -f dat -r 100000 -D hw:1,0 -d 5 test.wav
Aufnahme: WAVE 'test.wav' : Signed 16 bit Little Endian, Rate: 100000 Hz, stereo
Warnung: Rate ist nicht exakt (angefordert: 100000 Hz, unterstützt: 192000 Hz)
