Hi, i have a problem with my sound card from my laptop, it can’t play any sound just a continuous weird one, I’ll put the inxi -Fazy result. I’m sure my audio card is a Realtek but it shows Intel Sunrise point, the device 2 is just an external USB audio device, no problem with it.
Thank any one who can help me. (I’m kinda new on Linux and even more on Manjaro so any help would be appreciated)
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9ee30c64-5008-47e6-adcb-d78c999957fd rw quiet splash apparmor=1
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: X542URR v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X542URR v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: X542URR.310 date: 10/29/2021
ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Unknown
serial: N/A status: N/A
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3400 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 3400 2: 3400 3: 3400 4: 3400 5: 3400 6: 3400
7: 3400 8: 3400 bogomips: 28808
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-2
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 930MX] vendor: ASUSTeK driver: nouveau
v: kernel alternate: nvidia_drm,nvidia non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134e
class-ID: 0302
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: HDMI-A-2 model: HP M22f FHD serial: <filter> built: 2021
res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51")
diag: 561mm (22.1") ratio: 15:9, 16:10 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-4.2:6 v: kernel chip-ID: 1b3f:2008
alternate: snd_soc_skl class-ID: 0300 bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Device-2: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 13d3:3496 class-ID: e001
Local Storage: total: 476.94 GiB used: 12.4 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS30512GTTD
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 13.2 scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%) used: 12.4 GiB (2.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 52.0 C pch: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Processes: 264 Uptime: 27m wakeups: 1 Memory: 7.65 GiB used: 2.59 GiB (33.9%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1245 libs: 310
tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.23
