Hello to all and Good Year to All
I have a problem with audio…everytime i restart the pc i must rais the level in Alsamixer to hear the sound.
It’s like don’t memory the last config.Down You see the screen i see when i start Alsamixer after restarting the pc…i must raise the headphone line to hear the music…everytime i restart the pc.
Can Somebody help me? Thanks.
Have a nice day.
is the alsa-restore
sevice enabled and active??
systemctl status alsa-restore.service
Thanks for replaying,
i’ve done the command You sent me and come s up:
~ systemctl status alsa-restore.service
● alsa-restore.service - Save/Restore Sound Card State
Loaded: loaded (/usr/lib/systemd/system/alsa-restore.service; static)
Active: active (exited) since Tue 2022-01-04 09:31:11 CET; 1h 30min ago
Process: 756 ExecStart=/usr/bin/alsactl restore (code=exited, status=0/SUCCESS)
Main PID: 756 (code=exited, status=0/SUCCESS)
CPU: 1ms
gen 04 09:31:11 corsair-z490aorusmaster systemd[1]: Starting Save/Restore Sound Card State…
gen 04 09:31:11 corsair-z490aorusmaster systemd[1]: Finished Save/Restore Sound Card State.
Hope is all ok.
refer to this link → Speakers volume drop to zero after reboot / Laptop Issues / Arch Linux Forums
comment out “load-module module-device-restore” in /etc/pulse/default.pa
and reboot
Thanks, i will do it .
Thanks for helps.
Find the control in alsamixer for Auto-Mute Mode and change it to Disabled
(control is not shown in screenshot but will be in additional controls hidden in overflow on right side of window)
The Headphone output might turn on automatically or may need to be turned on manually
And save the settings so they they are restored correctly when system is booted
sudo alsactl store
i’ve find it, disabled right now.
I will see when i restarted…hopes it’s ok.
Thanks
Good morning to All,
i’ve tryed the 2 solutions:
1- comment out “load-module module-device-restore” in /etc/pulse/default.pa
and reboot
2- in Alsamixer Auto-Mute Mode and change it to Disabled
both didn’t work…
Strange …this happens only with Intel…on AMD Ryzen…same Manjaro …everything ok.
