After rebooting, softwares (like firefox) freeze at launch.
If I use something like systemctl --user restart wireplumber pipewire pipewire-pulse it solves problem.
Then audio youtube videos will either play on laptop speaker for rest of boot session, or play on hdmi audio output.
Movie video files will only be playable with mpv and play on hdmi audio output. Other players like vlc will crash.
inxi --admin --verbosity=5 --filter --no-host --width:
Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=8c481e9c-b894-4c30-a2cf-e39922154238 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: MEDION product: Deputy P60 v: N/A
Mobo: MEDION model: NPxxRNx1 v: 1.0 serial: <superuser required>
part-nu: ML-210008 40086205 uuid: <superuser required> UEFI: INSYDE
v: 1.07.04RME5_00011 date: 09/20/2023
ID-1: BAT0 charge: 45.9 Wh (100.0%) condition: 45.9/52.5 Wh (87.3%)
volts: 16.5 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: full
System RAM: total: 16 GiB available: 15.34 GiB used: 9.34 GiB (60.9%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMAG68EXNSA051N serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x435
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: CLEVO/KAPOK driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-09) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:28a0 class-ID: 0300
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:2 chip-ID: 04f2:b729
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: H24F8 built: 2024
res: 1920x1080 dpi: 81 gamma: 1.2 size: 600x330mm (23.62x12.99")
diag: 609mm (24") ratio: 16:9, 15:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x0910 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 7.49 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.135 device-ID: 10de:28a0
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Graphics
(ADL GT2) driver: mesa intel v: 24.2.7-arch1.1 device-ID: 8086:46a3
surfaces: xcb,xlib
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA AD107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.11.10-2-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 476.94 GiB used: 340.51 GiB (71.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: E19-512G-SSD-BICS5
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFM61.0 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 340.51 GiB (72.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 8c481e9c-b894-4c30-a2cf-e39922154238
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4649-7E59
ID-1: swap-1 type: file size: 20 GiB used: 8.8 MiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 333 Power: uptime: 2h 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1849 pm: pacman pkgs: 1803 libs: 510 tools: octopi,pamac,yay
pm: flatpak pkgs: 46 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
pactl list cards:
Card #53
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA NVidia at 0x76000000 irq 17"
api.alsa.card.name = "HDA NVidia"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
device.description = "AD107 High Definition Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
device.plugged.usec = "2552277"
device.product.id = "0x22be"
device.product.name = "AD107 High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
media.class = "Audio/Device"
factory.id = "15"
client.id = "52"
object.id = "53"
object.serial = "53"
object.path = "alsa:acp:NVidia"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x76000000 irq 17"
alsa.mixer_name = "Nvidia GPU a7 HDMI/DP"
alsa.components = "HDA:10de00a7,10de0000,00100100"
alsa.id = "NVidia"
device.string = "1"
Profiles:
off: Éteint (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Sortie Stéréo numérique (HDMI) (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo-extra1: Sortie Digital Stereo (HDMI 2) (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Sortie Digital Stereo (HDMI 3) (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Sortie Digital Stereo (HDMI 4) (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround: Sortie Surround numérique 5.1 (HDMI) (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Sortie Digital Surround 7.1 (HDMI) (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround-extra1: Sortie Digital Surround 5.1 (HDMI 2) (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Sortie Digital Surround 7.1 (HDMI 2) (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Sortie Digital Surround 5.1 (HDMI 3) (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Sortie Digital Surround 7.1 (HDMI 3) (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Sortie Digital Surround 5.1 (HDMI 4) (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Sortie Digital Surround 7.1 (HDMI 4) (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #54
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "HDA Intel PCH at 0x6203140000 irq 170"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "pci"
device.description = "Audio interne"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "2675797"
device.product.id = "0x51c8"
device.product.name = "Alder Lake PCH-P High Definition Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
factory.id = "15"
client.id = "52"
object.id = "54"
object.serial = "54"
object.path = "alsa:acp:PCH"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x6203140000 irq 170"
alsa.mixer_name = "Realtek ALC256"
alsa.components = "HDA:10ec0256,1558a550,00100002 HDA:8086281c,80860101,00100000"
alsa.id = "PCH"
device.string = "0"
Profiles:
output:analog-stereo+input:analog-stereo: Duplex stéréo analogique (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Sortie Stéréo analogique (sinks: 1, sources: 0, priority: 6500, available: yes)
output:hdmi-stereo+input:analog-stereo: Sortie Stéréo numérique (HDMI) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 5965, available: yes)
output:hdmi-stereo: Sortie Stéréo numérique (HDMI) (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1+input:analog-stereo: Sortie Digital Stereo (HDMI 2) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Sortie Digital Stereo (HDMI 3) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Sortie Digital Stereo (HDMI 4) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Sortie Digital Surround 5.1 (HDMI 2) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Sortie Digital Surround 7.1 (HDMI 2) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Sortie Digital Surround 5.1 (HDMI 3) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Sortie Digital Surround 7.1 (HDMI 3) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Sortie Digital Surround 5.1 (HDMI 4) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Sortie Digital Surround 7.1 (HDMI 4) + Entrée Stéréo analogique (sinks: 1, sources: 1, priority: 665, available: no)
input:analog-stereo: Entrée Stéréo analogique (sinks: 0, sources: 1, priority: 65, available: yes)
pro-audio: Pro Audio (sinks: 5, sources: 1, priority: 1, available: yes)
Active Profile: output:hdmi-stereo+input:analog-stereo
Ports:
analog-input-internal-mic: Microphone interne (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-output-speaker: Haut-parleurs (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
Properties:
port.type = "speaker"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Casque audio (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "headphones"
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 5"
card.profile.port = "4"
device.product.name = "H24F8"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
card.profile.port = "5"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 7, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 7"
card.profile.port = "6"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 8, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 8"
card.profile.port = "7"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
