Hi everyone,
I updated my manjaro installation and sound is only working on front speakers. I tested it with windows so it is not a hardware issue. It was also working before the latest update. I don’t even know where to start debugging. I tried several things from this forum, which were for older issues, but this one seems different.
$ inxi -Fazy
Kernel: 5.10.13-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=45ce70ae-e979-41fd-8e1b-372b93d8c809 rw quiet apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: MPG Z490 GAMING EDGE WIFI (MS-7C79)
v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.30 date: 10/12/2020
Info: 10-Core model: Intel Core i9-10850K bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 5 microcode: E2
L2 cache: 20 MiB
bogomips: 144040
Speed: 1376 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 1376 2: 1269
3: 1193 4: 1286 5: 1260 6: 1295 7: 4438 8: 1240 9: 1333 10: 4092 11: 4723
12: 1265 13: 1240 14: 1241 15: 2682 16: 1255 17: 859 18: 1275 19: 1287
20: 2959
Device-1: NVIDIA GK110B [GeForce GTX 780 Ti] vendor: Gigabyte driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:100a
class ID: 0300
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 780 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:06c8 class ID: 0403
Device-2: NVIDIA GK110 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e1a
class ID: 0403
Device-3: Ruision UVC Camera type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-2:2 chip ID: fefe:4321 class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.10.13-2-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:06f0 class ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: 3000 bus ID: 03:00.0 chip ID: 10ec:8125 class ID: 0200
Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-14:6
chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 953.87 GiB used: 250.44 GiB (26.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: TM8PS7001T
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 7B0
ID-1: / raw size: 80 GiB size: 78.24 GiB (97.81%) used: 27.71 GiB (35.4%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 80 GiB size: 78.24 GiB (97.81%) used: 8.89 GiB (11.4%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0f482a10-ebf3-4d35-8681-e747d58e68d9
ID-4: /var raw size: 35.3 GiB size: 34.5 GiB (97.72%)
used: 12.08 GiB (35.0%) fs: ext4 dev: /dev/sda9 maj-min: 8:9
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 22%
Processes: 433 Uptime: 44m wakeups: 0 Memory: 31.28 GiB
used: 4.34 GiB (13.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1378 lib: 401 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.00
