Audio not working on HP Victus 15L
Hey, new to Manjaro and did a fresh install today. I’ve installed it on a separate SSD from my Win11 M.2. Everything’s working great, apart from the audio. I’ve done some basic steps like install firmware via terminal, messed with alsamixer, but no luck. Audio is an intel based device. Thanks in advance for any advice!
inxi -Fazy
  Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=3f5d5a27-cae0-4f07-8f01-7d7b9a12812b rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Desktop System: HP product: Victus by HP 15L Gaming Desktop TG02-1xxx
    v: N/A serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: HP model: 8B3B v: A (SMVB) serial: <filter> part-nu: 9T744EA#ABU
    uuid: 45ac8603-09ab-dc06-9b37-fbe469f25a88 UEFI: AMI v: F.21 date: 10/24/2023
  Info: model: 13th Gen Intel Core i5-13400F socket: U3E1 bits: 64
    type: MST AMCP arch: Raptor Lake gen: core 13 level: v3 note: check
    built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xBF (191)
    stepping: 2 microcode: 0x35
  Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
    L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
  Speed (MHz): avg: 809 high: 863 min/max: 800/4600:3300
    base/boost: 4059/4600 scaling: driver: intel_pstate governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 838 4: 804 5: 800
    6: 800 7: 800 8: 806 9: 863 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
    16: 833 bogomips: 79888
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: NVIDIA GA106 [GeForce RTX 3050 OEM] vendor: Hewlett-Packard
    driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 8 link-max: lanes: 16 ports: active: none off: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2508 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Lenovo LEN L27q-10 serial: <filter> built: 2017
    res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: Unknown-1 size-res: N/A modes: 2560x1440
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050 OEM/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3050 OEM driver: nvidia v: 550.90.07 device-ID: 10de:2508
    surfaces: xcb,xlib
  Device-1: Intel Alder Lake-S HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    vendor: Hewlett-Packard driver: rtw89_8852be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 0bda:b85c
  Local Storage: total: 709.83 GiB used: 13.05 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL4512HBLU-00BH1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS3NHAV temp: 21.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 13.05 GiB (5.7%)
    fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
    used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 28.0 C mobo: N/A gpu: nvidia temp: 29 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
  Memory: total: 16 GiB available: 15.38 GiB used: 2.41 GiB (15.7%)
  Processes: 338 Power: uptime: 29m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1207 libs: 353 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Bash (su) v: 5.2.26 running-in: konsole inxi: 3.3.35
