Hey guys, maybe you can help me out with a problem.
I recently installed kdenlive. After the install, my sound did not work (I use usb-speakers).
I de-installed kdenlive, but it still didn’t work. I switched from usb audio output to hdmi output (my monitor has some build in speakers) and it worked.
Tried a few things in gnome-settings and turns out, that after I mute and unmute the system audio, my usb-speakers work just fine.
So now, in order to have sound, I have to go to settings, turn off the sound and turn it on again.
Does anyone have an idea, what the issue might be?
I also re-installed kdenlive, but as a flatpak.
inxi -Fazy ✔
Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=a6ab3443-d498-4764-8e14-bfe6677b5e57 rw quiet splash apparmor=1
security=apparmor resume=UUID=a8ee0b1c-caac-4205-9439-450b2783a982
udev.log_priority=3
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: Z690 AERO G DDR4 v: -CF
serial: <superuser required>
Mobo: Gigabyte model: Z690 AERO G DDR4 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F7
date: 01/27/2022
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x35
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1146 high: 2767 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 1802 7: 800 8: 1921 9: 840 10: 800 11: 2767 12: 800 13: 2220
14: 800 15: 800 16: 800 bogomips: 118000
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: none
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4680
class-ID: 0300
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 550.100 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: :1
note: <missing: xdpyinfo/xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.100
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3
chip-ID: 0414:a012 class-ID: 0300
API: ALSA v: k6.6.40-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0032
class-ID: e001
Report: rfkill ID: hci1 rfk-id: 2 state: down bt-service: enabled,running
Device-2: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.1:4 chip-ID: 0b05:190e
Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 2.27 TiB used: 248.06 GiB (10.7%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Western Digital
model: WDS100T2B0C size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 44.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Western Digital
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 41.9 C scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 28.82 GiB (60.4%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 408.05 GiB size: 400.57 GiB (98.17%)
used: 219.23 GiB (54.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 22.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 64 GiB note: est. available: 62.58 GiB used: 4.01 GiB (6.4%)
Processes: 370 Power: uptime: 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.02 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1484 pm: pacman pkgs: 1467 libs: 384 tools: gnome-software,pamac
pm: flatpak pkgs: 17 Compilers: N/A Shell: Zsh v: 5.9 running-in: tilix
inxi: 3.3.35
amixer --card=0 ✔
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
aplay -L ✔
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
hdmi:CARD=PCH,DEV=3
HDA Intel PCH, HDMI 3
HDMI Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, ASUS VG289Q1A
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
sysdefault:CARD=Audio
USB Audio, USB Audio
Default Audio Device
front:CARD=Audio,DEV=0
Front output / input
surround21:CARD=Audio,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Audio,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Audio,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audio,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audio,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audio,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audio,DEV=0
IEC958 (S/PDIF) Digital Audio Output
iec958:CARD=Audio,DEV=1
USB Audio, USB Audio #1
usbstream:CARD=Audio
USB Audio
USB Stream Output
