Hello Manjaro Community,
I need your help to troubleshoot my current issue about the audio input.
I am somewhat reopening this topic:
Audio Issues (Microphone not working)
I have noticed this issue only yesterday. I am not sure when this problem could have possibly arisen the first time, but I may suppose after an update maybe.
I am using the same distro and configuration since long time, and so far I never had a similar issue.
Specifically, the system do not recognize anymore the INPUT AUDIO/SOUND. The output audio seems to work well, no issues here, with the internal speaker, with bluetooth devices, or HDMI devices connected.
The problem is that my internal microphone is not getting recognized anymore. In the setting panel I see “No Input Device”
Here a screenshot of what the Setting panel shows:
Here some possible helpful commands outputs:
$ cat /etc/*-release
Manjaro Linux
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="24.0.3"
DISTRIB_CODENAME="Wynsdey"
DISTRIB_DESCRIPTION="Manjaro Linux"
Manjaro Linux
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="32;1;24;144;200"
HOME_URL="https://manjaro.org/"
DOCUMENTATION_URL="https://wiki.manjaro.org/"
SUPPORT_URL="https://forum.manjaro.org/"
BUG_REPORT_URL="https://docs.manjaro.org/reporting-bugs/"
PRIVACY_POLICY_URL="https://manjaro.org/privacy-policy/"
LOGO=manjarolinux
pacman -Q sof-firmware alsa-utils alsa-tools pipewire pulseaudio pulseaudio-alsa pulseaudio-jack
sof-firmware 2024.03-1
alsa-utils 1.2.12-1
alsa-tools 1.2.11-1
pipewire 1:1.0.7-2
pulseaudio 17.0-3
pulseaudio-alsa 1:1.2.12-1
pulseaudio-jack 17.0-3
$ inxi -vSAazy
Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=2de0e9b0-1b5d-4807-9787-adb8fd2e5db3 rw quiet
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell with: plank
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.34-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.7 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active (root, process) with:
tools: pacat,pactl,pavucontrol
$ sudo lspci -vDk
0000:00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
Subsystem: Dell Device 07a0
Flags: bus master, fast devsel, latency 0
Memory at ec24c000 (32-bit, non-prefetchable) [size=16K]
0000:00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Flags: bus master, fast devsel, latency 32, IRQ 136
Memory at ec248000 (64-bit, non-prefetchable) [size=16K]
Memory at ec220000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_soc_avs
$ amixer scontents
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 32378 [49%] [on]
Front Right: Playback 32378 [49%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 65536
Front Left: Capture 58937 [90%] [on]
Front Right: Capture 58937 [90%] [on]
pacmd list-cards
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xec248000 irq 136"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d70"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 38733, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#3: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#4: Monitor of Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-headphone-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "LG HDR 4K"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
$ sudo dmesg | egrep -i '(snd|sound|sof|hda|alsa)'
egrep: warning: egrep is obsolescent; using grep -E
[ 0.011222] ACPI: SSDT 0x000000007A0B9B10 000141 (v02 INTEL HdaDsp 00000000 INTL 20160422)
[ 0.085559] software IO TLB: area num 4.
[ 0.476505] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.516064] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.516066] software IO TLB: mapped [mem 0x0000000066f48000-0x000000006af48000] (64MB)
[ 6.556029] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.796483] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3246: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 6.796490] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.796493] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 6.796496] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 6.796498] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 6.796499] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 6.796502] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1a
[ 6.796503] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 6.915085] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 6.915141] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 6.915191] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 6.915238] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
I am lost.
Side_Note:
I do also see that on the keyboard my “disable-microphone” via hardware is enable, which means that the microphone should be disable, but I cannot restore the function with Fn+F4 … no idea why! but it is definitely related since it was working before.
I am thankful for anyone that will help me to get out from this digital mute state.
Thank you in advance! ![]()
