I don’t mean to beat this topic to death with another post, but I’ve searched the forum for a possible solution. Nothing worked. It’s just a nuisance I want to resolve once and for all. I’m experiencing audio delay issue. I’ve had this issue since the first day I installed Manjaro. It’s nothing new.
When I plug in headphones, the audio is fine without any delay through headphones. But the audio through laptop’s speakers are a bit delayed.
If I play an audio file that reads “I am just happy to be back”, because of the initial delay, I only hear “happy to be back”.
Any help to resolve this issue is greatly appreciated! Thanks.
i’m not the expert but there are various issues with tiger-lake audio. if you use the search function of manjaro with “tiger lake audio” a lot of different issues will occur. a second thing you might try is to uninstall pipewire and use pulse insead.
Quick question! There seems to be many parts and pieces of pipewire such as pipewire-alsa, pipewire-audio, pipewire-media-session, pipewire-pulse, gst-plugin-pipewire, etc…
When I try to remove the main file “pipewire” only in Package Manager, I get the message “Failed to prepare transaction. Could not satify dependencies.” Can you tell me how I can successfully remove pipewire as you recommended without causing problem with something else?
I think removing pipewire is worth a shot to see if it solves my problem with the audio delay. If it doesn’t work, then I can move on to the next possible solution.
Quick question! For optional dependencies, there were 5 options. I didn’t know which one to select. So, I picked the first option (1: pulseaudio-equalizer: Graphical equalizer). Please see below. Then I received a message that said “* removing pipewire-pulse breaks dependency ‘pulseaudio-bluetooth’ required by gnome-bluetooth-3.0”. I pressed “N” for “NO” as I didn’t want to have a bluetooth problem. Would it be correct to assume that the installation was not complete and not finalized because I selected “NO” at the end? Or the last part was only pertaining to the bluetooth option? Thanks.
Preparing…
Checking dependencies…
To remove (1):
manjaro-pipewire 20221015-2 extra
Total removed size: 1.6 kB
Apply transaction ? [y/N] y
Authenticating as: BIZDIK (atici)
Password:
Removing manjaro-pipewire (20221015-2)… [1/1]
Running post-transaction hooks…
Arming ConditionNeedsUpdate… [1/2]
Refreshing PackageKit… [2/2]
Preparing…
Password:
Synchronizing package databases…
Choose optional dependencies for pulseaudio:
2: pulseaudio-jack: Jack support
3: pulseaudio-lirc: IR (lirc) support
4: pulseaudio-rtp: RTP and RAOP support
5: pulseaudio-zeroconf: Zeroconf support
Enter a selection (default=none): 1
Checking afdko dependencies…
Resolving dependencies…
Checking inter-conflicts…
Error: Failed to prepare transaction:
could not satisfy dependencies:
Edit build files : [e]
Apply transaction ? [e/y/N] N
nikgnomic, thank you so much for your help! I did as you suggested and everything finalized and went well. I don’t mean to be a downer but, this didn’t solve the problem with the audio delay!
The audio through headphones and even through “bluetooth speaker” come out fine without any delay, This is absolutely and logically beyond me as to why the audio through headsets and even “external” bluetooth comes out without any delay, but through the internal laptop’s speaker’s there is a delay. This is absolutely mind-boggling about Manjaro.
I can’t make logical sense of this either (so far)
There should not be any delay between audio from internal speakers and headphone jack because they are coming from the same audio device and probably using a shared audio channel
Please post more information about audio devices detected in ALSA
As you suggested, I updated system BIOS to E17M1IMS.119. Unfortunately, it still didn’t solve the audio delay issue with the laptop’s internal speaker.
Yep, this time, the also-info script has so much information.
Sorry for the delay to respond! I just noticed your posting. I’ve tried anything and everything, suggested here as well as things I found in my google search to resolve this issue. Unfortunately, nothing has worked so far!
It absolutely makes no sense whatsoever as you would expect to have an audio delay from an outside source like headphones when you plug it in, not from an internal speaker! But it is the opposite here! It’s mind-boggling.
I recently opened a call regarding MSI GP76 11800h. The likely cause for what you call delay might be a smart amplifier that needs better initialization. As a workaround I found that nonstop playing a long wav file (i use birds twittering in a park). That way the amplifier doesn’t go to power save / noise cancelling.
I tried everything from here and what I found on google and nothing solved the delay problem. My laptop is MSI Creator Z16, so it look like the problem is with MSI machines maybe.
