A couple days ago I installed Manjaro KDE on a new computer.
Whenever I use an app that records my microphone (audacity, obs, discord, etc) the output audio is picked up. This is the case even if I turn my headset volume all the way down, so I know the issue isn’t that the sound physically escapes my headphones. I dual boot and I don’t have an issue like this on Windows.
Over the last couple of days I’ve looked endlessly for solutions online, but I couldn’t find anything that fixed the issue for me. I’m not sure if there’s anything I’ve messed up further as a result of this.
Here are the outputs of some commands that might be useful:
pacmd info:
Memory blocks currently allocated: 1, size: 63.9 KiB.
Memory blocks allocated during the whole lifetime: 303617, size: 522.3 MiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 0 B.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_00_1f.3.analog-stereo
Default source name: alsa_input.pci-0000_00_1f.3.analog-stereo
Memory blocks of type POOL: 1 allocated/149213 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/28307 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/132121 accumulated.
Memory blocks of type IMPORTED: 0 allocated/22283 accumulated.
26 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "15.0"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 8
argument: <device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 9
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = "Adds JACK sink/source ports when JACK is started"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
index: 12
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 14
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 24
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 25
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 28
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
2 sink(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
card: 0 <alsa_card.pci-0000_01_00.1>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 1"
alsa.id = "HDMI 1"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "7"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f8"
device.product.name = "TU104 HD Audio Controller"
device.string = "hdmi:1,1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo-extra1"
device.profile.description = "Digital Stereo (HDMI 2)"
device.description = "TU104 HD Audio Controller Digital Stereo (HDMI 2)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
properties:
device.product.name = "L2251x Wide
active port: <hdmi-output-1>
* index: 1
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 52057 / 79% / -6.00 dB, front-right: 52057 / 79% / -6.00 dB
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 2
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
card: 2 <alsa_card.pci-0000_00_1f.3>
module: 8
properties:
device.api = "alsa"
alsa.name = "ALC887-VD Analog"
alsa.id = "ALC887-VD Analog"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdf140000 irq 126"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a2f0"
device.product.name = "200 Series PCH HD Audio"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
ports:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
active port: <analog-output-headphones>
3 source(s) available.
index: 0
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 6
properties:
device.description = "Monitor of TU104 HD Audio Controller Digital Stereo (HDMI 2)"
device.class = "monitor"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
index: 2
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 1
module: 8
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
* index: 3
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 44652 / 68% / -10.00 dB, front-right: 44652 / 68% / -10.00 dB
balance 0.00
base volume: 6554 / 10% / -60.00 dB
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 1.00 .. 1837.50 ms
module: 8
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: yes)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
active port: <analog-input-front-mic>
5 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 21
properties:
application.name = "Login Session 2"
systemd-login.session = "2"
index: 3
driver: <protocol-native.c>
owner module: 14
properties:
application.name = "Plasma PA"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "35"
application.id = "org.kde.plasma-pa"
application.icon_name = "audio-card"
application.process.id = "949"
application.process.user = "tobil"
application.process.host = "tobi-ms7c08"
application.process.binary = "plasmashell"
application.language = "en_GB.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "80bbcc043ed04156ba558894d3a8e487"
application.process.session_id = "2"
index: 4
owner module: 14
properties:
application.process.id = "3642"
application.process.binary = "systemsettings5"
index: 160
owner module: 14
properties:
application.name = "Skype"
application.process.id = "9758"
application.process.binary = "skypeforlinux"
application.icon_name = "skypeforlinux"
index: 167
driver: <cli.c>
owner module: 28
properties:
application.name = "UNIX socket client"
2 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
device.description = "TU104 HD Audio Controller"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 38468, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo-extra1>
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1/#0: TU104 HD Audio Controller Digital Stereo (HDMI 2)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor/#0: Monitor of TU104 HD Audio Controller Digital Stereo (HDMI 2)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
index: 2
owner module: 8
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#2: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#3: Built-in Audio Analog Stereo
ports:
properties:
properties:
properties:
properties:
properties:
0 sink input(s) available.
0 source output(s) available.
0 cache entrie(s) available.
pa-info:
________________
> pulseaudio_ps_do
tobil 6129 0.9 0.0 1245312 15488 ? S<sl 11:54 0:34 /usr/bin/pulseaudio --daemonize=no --log-target=journal
tobil 12660 0.0 0.0 3184 872 pts/1 S+ 12:57 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
6129
________________
> pulseaudio --version
pulseaudio 15.0
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 170
Tile Size: 65472
User Name: tobil
Host Name: tobi-ms7c08
Server Name: pulseaudio
Server Version: 15.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_input.pci-0000_00_1f.3.analog-stereo
Cookie: 4454:7236
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
Module #1
Argument:
Usage counter: n/a
Properties:
Module #2
Argument:
Usage counter: n/a
Properties:
Module #3
Argument:
Usage counter: n/a
Properties:
Module #4
Argument:
Usage counter: n/a
Properties:
Module #5
Argument:
Usage counter: n/a
Properties:
Module #6
Argument: device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #8
Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #9
Argument: channels=2
Usage counter: n/a
Properties:
Module #10
Argument:
Usage counter: n/a
Properties:
Module #11
Argument:
Usage counter: n/a
Properties:
Module #12
Argument:
Usage counter: n/a
Properties:
Module #13
Argument:
Usage counter: n/a
Properties:
Module #14
Argument:
Usage counter: n/a
Properties:
Module #15
Argument:
Usage counter: n/a
Properties:
Module #16
Argument:
Usage counter: n/a
Properties:
Module #17
Argument:
Usage counter: n/a
Properties:
Module #18
Argument:
Usage counter: n/a
Properties:
Module #19
Argument:
Usage counter: n/a
Properties:
Module #20
Argument:
Usage counter: n/a
Properties:
Module #21
Argument:
Usage counter: n/a
Properties:
Module #22
Argument:
Usage counter: n/a
Properties:
Module #23
Argument:
Usage counter: n/a
Properties:
Module #24
Argument:
Usage counter: n/a
Properties:
Module #25
Argument:
Usage counter: n/a
Properties:
Module #28
Argument:
Usage counter: n/a
Properties:
Sink #0
State: SUSPENDED
Description: TU104 HD Audio Controller Digital Stereo (HDMI 2)
Driver: module-alsa-card.c
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.api = "alsa"
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "1"
device.bus = "pci"
Ports:
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, available)
Active Port: hdmi-output-1
Formats:
pcm
Sink #1
State: SUSPENDED
Description: Built-in Audio Analog Stereo
Owner Module: 8
Mute: no
Volume: front-left: 52057 / 79% / -6.00 dB, front-right: 52057 / 79% / -6.00 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
Ports:
analog-output-lineout: Line Out (type: Line, priority: 9000, not available)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, available)
Active Port: analog-output-headphones
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of TU104 HD Audio Controller Digital Stereo (HDMI 2)
Owner Module: 6
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1
Flags: DECIBEL_VOLUME LATENCY
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #2
State: SUSPENDED
Description: Monitor of Built-in Audio Analog Stereo
Owner Module: 8
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Source #3
State: SUSPENDED
Sample Specification: s16le 2ch 48000Hz
Owner Module: 8
Mute: no
Volume: front-left: 44652 / 68% / -10.00 dB, front-right: 44652 / 68% / -10.00 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Monitor of Sink: n/a
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, available)
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, not available)
analog-input-linein: Line In (type: Line, priority: 8100, not available)
Active Port: analog-input-front-mic
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 21
Properties:
Client #3
Driver: protocol-native.c
Owner Module: 14
Properties:
Client #4
Owner Module: 14
Properties:
Client #160
Owner Module: 14
Properties:
Client #171
Owner Module: 14
Properties:
application.name = "pactl"
application.process.id = "12665"
application.process.binary = "pactl"
application.language = "C"
Card #0
Owner Module: 6
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 38468, available: yes)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: output:hdmi-stereo-extra1
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
Card #2
Owner Module: 8
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
Properties:
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, available)
Properties:
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
### Allow including a default.pa.d directory, which if present, can be used
### for additional configuration snippets.
.nofail
.include /etc/pulse/default.pa.d
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
### Allow including a system.pa.d directory, which if present, can be used
.nofail
.include /etc/pulse/system.pa.d
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 10 Aug 25 12:30 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 3 Aug 25 12:05 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 11 Aug 25 12:05 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 12 Aug 25 11:57 /dev/snd/pcmC0D2c
crw-rw----+ 1 root audio 116, 6 Aug 25 11:57 /dev/snd/pcmC1D10p
crw-rw----+ 1 root audio 116, 7 Aug 25 11:57 /dev/snd/pcmC1D11p
crw-rw----+ 1 root audio 116, 2 Aug 25 11:57 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 4 Aug 25 11:57 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116, 5 Aug 25 11:57 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116, 1 Aug 25 10:51 /dev/snd/seq
crw-rw----+ 1 root audio 116, 14 Aug 25 10:43 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 13 Aug 25 10:43 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 9 Aug 25 10:43 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 8 Aug 25 10:43 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 33 Aug 25 10:43 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Aug 25 12:26 .
drwxr-xr-x 3 root root 360 Aug 25 12:26 ..
lrwxrwxrwx 1 root root 12 Aug 25 10:43 pci-0000:00:1f.3 -> ../controlC0
lrwxrwxrwx 1 root root 12 Aug 25 10:43 pci-0000:01:00.1 -> ../controlC1
________________
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 6129 tobil 18u CHR 116,9 0t0 478 /dev/snd/controlC1
pulseaudi 6129 tobil 23u CHR 116,9 0t0 478 /dev/snd/controlC1
pulseaudi 6129 tobil 24u CHR 116,14 0t0 488 /dev/snd/controlC0
pulseaudi 6129 tobil 37u CHR 116,14 0t0 488 /dev/snd/controlC0
pulseaudi 6129 tobil 42u CHR 116,14 0t0 488 /dev/snd/controlC0
________________
> jacks_do
card=0
numid=35,iface=CARD,name='Front Headphone Jack'
; type=BOOLEAN,access=r-------,values=1
: values=on
numid=31,iface=CARD,name='Front Mic Jack'
: values=on
numid=33,iface=CARD,name='Line Jack'
: values=off
numid=34,iface=CARD,name='Line Out Jack'
: values=off
numid=32,iface=CARD,name='Rear Mic Jack'
: values=off
card=1
numid=25,iface=CARD,name='HDMI/DP,pcm=10 Jack'
: values=off
numid=31,iface=CARD,name='HDMI/DP,pcm=11 Jack'
: values=off
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=on
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=off
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC887-VD Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
HDA NVidia
USB Stream Output
________________
> alsa_info_do
/usr/bin/alsa-info.sh: line 661: tree: command not found
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Wed Aug 25 11:57:58 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7C08
Product Version: 1.0
Firmware Version: 1.40
System SKU: Default string
Board Vendor: Micro-Star International Co., Ltd.
Board Name: H310M PRO-M2 PLUS (MS-7C08)
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:03/status 15
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C02:07/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/device:69/status 15
/sys/bus/acpi/devices/device:78/status 15
/sys/bus/acpi/devices/device:79/status 11
!!Kernel Information
Kernel release: 5.13.11-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.13.11-1-MANJARO
Library version: 1.2.5.1
Utilities version: 1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
1 [NVidia ]: HDA-Intel - HDA NVidia
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation 200 Series PCH HD Audio [8086:a2f0]
DeviceName: Onboard - Sound
01:00.1 Audio device [0403]: NVIDIA Corporation TU104 HD Audio Controller [10de:10f8] (rev a1)
Subsystem: NVIDIA Corporation Device [10de:1e89]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887-VD
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0887
Subsystem Id: 0x14629c08
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0
IO[1]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC887-VD Analog", type="Audio", device=0
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x3a 0x3a]
Converter: stream=1, channel=0
PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Converter: stream=0, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
Amp-In vals: [0x2e 0x2e]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC887-VD Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=2, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x4037c040: [N/A] CD at Ext N/A
Conn = Analog, Color = UNKNOWN
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00000036: IN OUT Detect Trigger
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00003736: IN OUT Detect Trigger
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19030: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Amp-In vals: [0x02 0x02]
Pincap 0x0000373e: IN OUT HP Detect Trigger
Pin Default 0x02a19040: [Jack] Mic at Ext Front
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181303f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x3, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4027c62b: [N/A] HP Out at Ext N/A
DefAssociation = 0x2, Sequence = 0xb
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 12
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x40 0x40]
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
Codec: Nvidia GPU 92 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0092
Subsystem Id: 0x10de1e89
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
*Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 1, ELDV = 1, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital: Enabled GenLevel
Digital category: 0x2
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xdf140000 irq 126'
Mixer name : 'Realtek ALC887-VD'
Components : 'HDA:10ec0887,14629c08,00100302'
Controls : 40
Simple ctrls : 21
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 58 [91%] [-6.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 2 [67%] [20.00dB]
Front Right: 2 [67%] [20.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 46 [100%] [30.00dB] [on]
Front Right: Capture 46 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Channel Mode',0
Capabilities: enum
Items: '2ch' '4ch' '6ch'
Item0: '2ch'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card NVidia
Card sysdefault:1 'NVidia'/'HDA NVidia at 0xdf080000 irq 17'
Mixer name : 'Nvidia GPU 92 HDMI/DP'
Components : 'HDA:10de0092,10de1e89,00100100'
Controls : 42
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Channel Mode'
value '2ch'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2ch'
item.1 '4ch'
item.2 '6ch'
control.2 {
iface MIXER
name 'Front Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.3 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.4 {
iface MIXER
name 'Surround Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.5 {
iface MIXER
name 'Surround Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
name 'Center Playback Volume'
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'LFE Playback Volume'
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.8 {
iface MIXER
name 'Center Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.10 {
iface MIXER
name 'Headphone Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.13 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.14 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.15 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.16 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.17 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.18 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.19 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.20 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.22 {
iface MIXER
name 'Capture Volume'
value.0 46
value.1 46
comment {
access 'read write'
type INTEGER
count 2
range '0 - 46'
dbmin -1600
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.23 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.24 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 46'
dbmin -1600
dbmax 3000
dbvalue.0 -1600
dbvalue.1 -1600
control.25 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.26 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 2
value.1 2
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 2000
dbvalue.1 2000
control.27 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'Master Playback Volume'
value 58
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -600
control.30 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface CARD
name 'Front Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.32 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.33 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface CARD
name 'Line Out Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.36 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.37 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.38 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.39 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.40 {
iface MIXER
name 'Digital Capture Volume'
value.0 60
value.1 60
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value '100008006d140001000400000000000030ae120a4c323235317820576964650a200907070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
type BYTES
count 95
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
acpi_pad
acpi_tad
aesni_intel
agpgart
cec
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
e1000e
ee1004
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
i2c_i801
i2c_nvidia_gpu
i2c_smbus
iTCO_vendor_support
iTCO_wdt
intel_cstate
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_tcc_cooling
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
loop
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
mxm_wmi
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
pcspkr
rapl
rfkill
roles
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_rawmidi
snd_seq
snd_seq_device
snd_seq_dummy
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
squashfs
syscopyarea
sysfillrect
sysimgblt
typec
typec_ucsi
ucsi_ccg
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x4037c040
0x12 0x411111f0
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19030
0x19 0x02a19040
0x1a 0x0181303f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4027c62b
0x1e 0x411111f0
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
inxi -Fxxz:
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: H310M PRO-M2 PLUS (MS-7C08) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 1.40 date: 01/06/2020
CPU: Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake note: check rev: A cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 34814
Speed: 1602 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1602 2: 2969 3: 3634 4: 3997 5: 2336 6: 3786
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2060] driver: nvidia v: 470.63.01 bus-ID: 01:00.0 chip-ID: 10de:1e89
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia resolution: 1680x1050~60Hz s-dpi: 90
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a2f0
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: kernel port: f000 bus-ID: 00:1f.6
chip-ID: 8086:15b8
Device-2: Realtek 802.11ac NIC type: USB driver: N/A bus-ID: 1-9:5 chip-ID: 0bda:c811
Drives: Local Storage: total: 1.13 TiB used: 160.61 GiB (13.9%)
ID-1: /dev/sda vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.57 GiB speed: 6.0 Gb/s serial: <filter>
ID-2: /dev/sdb vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 39.89 GiB used: 19.02 GiB (47.7%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 99.2 MiB used: 26.6 MiB (26.8%) fs: vfat dev: /dev/sda3
ID-3: /home size: 143.13 GiB used: 41.79 GiB (29.2%) fs: ext4 dev: /dev/sdb3
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda5
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Info: Processes: 300 Uptime: 2h 19m Memory: 15.57 GiB used: 4.92 GiB (31.6%) Init: systemd v: 248 Compilers: gcc: 11.1.0
Packages: 1516 pacman: 1509 flatpak: 7 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06
amixer:
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 52057 [79%] [on]
Front Right: Playback 52057 [79%] [on]
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 65536
Front Left: Capture 44652 [68%] [on]
Front Right: Capture 44652 [68%] [on]
arecord -Ll:
null
samplerate
speexrate
jack
oss
Open Sound System
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
HDA NVidia
USB Stream Output
Subdevices: 1/1
Subdevices: 1/1
