Audio from the speakers in the headphones
Good morning,
I hope you can help me solve an annoying problem with audio. Although I have tried numerous solutions, none of them solve the problem: basically at headphones plugged on jack I also hear the audio from the notebook speakers. Without headphones everything works properly, but if I plug in headphones I also hear audio from the speakers.
The kernel installed is: 6.11.2-4-MANJARO.
Moderator edit: Removed pictures of terminal outputs. In the future, please copy&paste the content and use proper formatting: [HowTo] Post command output and file content as formatted text
This is my notebook: “HP Spectre x360 16” 2-in-1 Laptop PC 16-aa0002nl".
Thank you
Welcome to the Manjaro community.
More system information will likely be useful:
inxi --admin --verbosity=8 --filter --no-host --width
Please post that in accordance with the Moderator link previously given. Good luck.
Hello,
here they are:
  Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.11-x86_64
    root=UUID=7e1e0ede-41c3-4804-8736-dd5cb2cd9074 rw rootflags=subvol=@ quiet
    cryptdevice=UUID=4fa7a601-d6db-4acf-aefb-c54066635d15:luks-4fa7a601-d6db-4acf-aefb-c54066635d15
    root=/dev/mapper/luks-4fa7a601-d6db-4acf-aefb-c54066635d15 splash
    apparmor=1 security=apparmor
    resume=/dev/mapper/luks-5897c51d-56c2-49a0-8239-cb003b8797e4
    udev.log_priority=3
  Desktop: GNOME v: 46.5 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 2-in-1 Laptop 16-aa0xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 8C16 v: 85.35 serial: <superuser required>
    part-nu: 9D1Q8EA#ABZ uuid: <superuser required> UEFI: AMI v: F.10
    date: 04/10/2024
  ID-1: BAT0 charge: 82.0 Wh (100.0%) condition: 82.0/83.0 Wh (98.7%)
    volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 2
  Device-1: hid-0018:04F3:422C.0003-battery model: ELAN2513:00 04F3:422C
    serial: N/A charge: N/A status: N/A
  Device-2: hid-34:88:5d:43:70:5d-battery model: Keyboard K380 serial: N/A
    charge: N/A status: discharging
  System RAM: total: 32 GiB available: 30.72 GiB used: 7.83 GiB (25.5%)
  Device-1: Bottom - on board type: LPDDR5 detail: synchronous size: 16 GiB
    speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5 width (bits): data: 16
    total: 16 manufacturer: Samsung part-no: K3KL9L90CM-MGCT serial: N/A
  Device-2: Bottom - on board type: LPDDR5 detail: synchronous size: 16 GiB
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x1F
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: 24 MiB note: check
  Speed (MHz): avg: 400 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 131824
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 4 (7nm+)
    built: 2023+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:7d55 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x41a6 built: 2022 res: 2880x1800 dpi: 213
    gamma: 1.2 chroma: red: x: 0.686 y: 0.318 green: x: 0.239 y: 0.714 blue:
    x: 0.137 y: 0.043 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 2880x1800
  EDID-Warnings: 1: parse_edid: unknown flag 2 2: parse_edid: unknown tag 112
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 15 GiB unified: yes display-ID: :0.0
  Device-1: Intel Meteor Lake IPU vendor: Hewlett-Packard driver: intel-ipu6
    alternate: intel_ipu6 bus-ID: 00:05.0 chip-ID: 8086:7d19 class-ID: 0480
  Device-2: Intel Meteor Lake-P HD Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
    driver: iwlwifi v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 1
    bus-ID: 01:00.0 chip-ID: 8086:272b class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0036 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
    lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0000
  Device-1: luks-242782ca-81d0-4f06-ac52-d7a9a27137fd maj-min: 254:2
    type: LUKS dm: dm-2 size: 894.24 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 894.25 GiB
  Device-2: luks-00e419e3-5545-40a5-af1e-4dddf2be06f9 maj-min: 254:3
    type: LUKS dm: dm-3 size: 953.85 GiB
  Components:
  p-1: sdb1 maj-min: 8:17 size: 953.87 GiB
  Device-3: luks-4fa7a601-d6db-4acf-aefb-c54066635d15 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.85 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.85 TiB
  Device-4: luks-5897c51d-56c2-49a0-8239-cb003b8797e4 maj-min: 254:1
    type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
  Local Storage: total: 3.67 TiB used: 1.04 TiB (28.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 1.86 TiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: HP01AP40 temp: 26.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: ICY BOX IB-247-C31
    size: 894.25 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.1 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A serial: <filter>
    fw-rev: 2210 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SKC600MS1024G
    size: 953.87 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 0202 scheme: GPT
  ID-1: / raw-size: 1.85 TiB size: 1.85 TiB (100.00%) used: 73.56 GiB (3.9%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-4fa7a601-d6db-4acf-aefb-c54066635d15 label: N/A
    uuid: 7e1e0ede-41c3-4804-8736-dd5cb2cd9074
    used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 92CE-871A
  ID-3: /home raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
    used: 73.56 GiB (3.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-4: /run/media/marco/VMware raw-size: 894.24 GiB size: 893.8 GiB (99.95%)
    used: 614.08 GiB (68.7%) fs: xfs dev: /dev/dm-2 maj-min: 254:2
    mapped: luks-242782ca-81d0-4f06-ac52-d7a9a27137fd label: VMware
    uuid: 7665759f-03fd-49e7-8a98-861edb13232e
  ID-5: /run/media/marco/VirtualBox raw-size: 953.85 GiB
    size: 953.39 GiB (99.95%) used: 379.28 GiB (39.8%) fs: xfs dev: /dev/dm-3
    maj-min: 254:3 mapped: luks-00e419e3-5545-40a5-af1e-4dddf2be06f9
    label: VirtualBox uuid: d8ae6926-469b-4fc8-8a5e-ac9081850e5c
  ID-6: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
    used: 0 KiB (0.0%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  ID-7: /var/cache raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
  ID-8: /var/log raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
    dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-5897c51d-56c2-49a0-8239-cb003b8797e4 label: swap
    uuid: bd3ad032-2116-4a5c-ac11-a51009fd41dc
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 2-2:2 info: VIA Labs VL817 SATA Adaptor type: mass storage
    driver: uas interfaces: 1 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 2109:0715 class-ID: 0806
    serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:016c class-ID: ff00 serial: <filter>
  Hub-4: 3-5:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 3-5.1:5 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-6: 3-5.2:6 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-7: 3-5.3:7 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-5.3.2:8 info: Logitech Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-2: 3-10:4 info: Intel type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-10: 4-1.1:3 info: Genesys Logic Hub ports: 4 rev: 3.2
  Hub-11: 4-1.2:4 info: Genesys Logic Hub ports: 4 rev: 3.2
  Device-1: 4-1.4:5 info: JMicron / USA External type: mass storage
    driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 152d:a580 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Packages: 1550 pm: dpkg pkgs: 4 pm: pacman pkgs: 1499 libs: 374
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 37 pm: snap pkgs: 10
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mega.nz/linux/repo/Arch_Extra/$arch
    2: https://releases.warp.dev/linux/pacman/$repo/$arch
    1: https://mirror.init7.net/manjaro/stable/$repo/$arch
    2: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    3: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    8: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 574
  1: cpu: 10.5% command: gnome-shell pid: 2533 mem: 332.0 MiB (1.0%)
  2: cpu: 9.7% command: brave pid: 8190 mem: 334.2 MiB (1.0%)
  3: cpu: 8.9% command: brave pid: 8178 mem: 303.6 MiB (0.9%)
  4: cpu: 8.4% command: brave pid: 8104 mem: 499.9 MiB (1.5%)
  5: cpu: 5.8% command: brave pid: 8146 mem: 144.3 MiB (0.4%)
  Memory top: 5 of 574
  1: mem: 671.3 MiB (2.1%) command: telegram-desktop pid: 2802 cpu: 0.6%
  2: mem: 499.9 MiB (1.5%) command: brave pid: 8104 cpu: 8.4%
  3: mem: 334.2 MiB (1.0%) command: brave pid: 8190 cpu: 9.7%
  4: mem: 332.0 MiB (1.0%) command: gnome-shell pid: 2533 cpu: 10.5%
  5: mem: 310.5 MiB (0.9%) command: rambox pid: 5695 cpu: 1.2%
  Processes: 574 Power: uptime: 7m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 12.27 GiB services: gsd-power, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.36
Thank you
I suggest check ALSA audio settings
alsamixer --card=1
Look for ALSA control Auto-Mute Mode and change it to Enabled if it is shown as Disabled
This control is usually set to Enabled by default
Archwiki has information about how to disable Auto-Mute Mode on startup
but it could also be enabled with:
sudo amixer -c 1 sset "Auto-Mute Mode" Enabled
I’d look at those wireplumber settings. I’d guess it’s set for simultaneous output, but I’d sort of expect plugging a wired set in would physically disconnect the internal speakers?
The setting on alsamixer was already active.
I would appreciate understanding what I should change in the wireplumber.conf file.
Thank you.
  GNU nano 8.2                                                wireplumber.conf
## The WirePlumber configuration
context.spa-libs = {
  ## SPA factory name to library mappings
  ## Used to find SPA factory names. It maps a SPA factory name regular
  ## expression to a library name that should contain that factory.
  ## Syntax:
  ## <factory-name regex> = <library-name>
  api.alsa.*      = alsa/libspa-alsa
  api.bluez5.*    = bluez5/libspa-bluez5
  api.v4l2.*      = v4l2/libspa-v4l2
  api.libcamera.* = libcamera/libspa-libcamera
  audio.convert.* = audioconvert/libspa-audioconvert
  support.*       = support/libspa-support
context.modules = [
  ## PipeWire modules to load.
  ## These modules are loaded before a connection to pipewire is attempted.
  ## This section should be kept minimal and load only the modules that are
  ## necessary for the protocol to work.
  ## If ifexists is given, the module is ignored when it is not found.
  ## If nofail is given, module initialization failures are ignored.
  ## Syntax:
  ##    name = <module-name>
  ##    [ args = { <key> = <value> ... } ]
  ##    [ flags = [ ifexists | nofail ] ]
  # Uses RTKit to boost the data thread priority. Also allows clamping
  # of utilisation when using the Completely Fair Scheduler on Linux.
                                                            [ Lette 865 righe ]
^G Guida         ^O Salva         ^F Cerca         ^K Taglia        ^T Esegui        ^C Posizione     M-U Annulla      M-A Set Mark
^X Esci          ^R Inserisci     ^\ Sostituisci   ^U Incolla       ^J Giustifica    ^/ Vai a riga    M-E Ripeti       M-6 Copia
ALSA patch for this system was added to kernel 6.12-rc4
LKML: Linus Torvalds: Linux 6.12-rc4
christoph.plattner (1):
ALSA: hda: Sound support for HP Spectre x360 16 inch model 2024
sound/pci/hda/patch_realtek.c - Linux source code v6.12-rc4
Branch compare for Manjaro - linux612
stable : 6.12.0rc2-2
testing : 6.12.0rc5-1
unstable : 6.12.0rc6-1
phoronix.com - Linux 6.12-rc6 Released
Linux 6.12 stable will be out in 2~3 weeks depending upon how this cycle ultimately plays out.
Morning! Did you already try with LTS Kernel?
Good,
I will wait for the release of the new kernel and let you know.
Thank you.
I’d rather wait for a new kernel on a next-generation notebook.
