Hi,
I have got a problem. Sound from my devices is distorted, especially low sounds. I think it might be a problem with my audio drivers. How to install them?
I ran a command:
sudo mhwd -i pci nonfree 0403
And the output was:
No config found for device: […] Multimedia controller nVidia Corporation
Can you help me?
Distorted audio is more likely to be due to excessive audio levels than a driver issue
Audio levels in PulseAudio Volume Control (pavucontrol ) can be set to > 100%
Some audio applications (e.g. VLC) also allow audio levels > 100%
Distortion at low-frequencies might be caused by over-boosting audio levels in a graphic equaliser or other Digital Signal Processing
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 2d:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
I helped me a lot - when I set down my volume to 85%, the problem disappeared. Thank you!
system
Closed
April 15, 2023, 10:48am
6
