Hey there,
I recently started using manjaro gnome which was installed alongside windows. But it seems my audio is not functioning as it does in windows.
If I play any kind of video, where sound is a bit high it sounds too high and where the sound is low it sounds too low in manjaro. But if I play that same video in windows, the sound seems to be stable. Sound was set to maximum in both environment.
I don’t know if my explanation is making any sense to you. If it doesn’t make any sense, just ask me questions. I am kinda loving manjaro but this is the only problem thats bothering me so much, as I use youtube too much.
Can you post some hardware info ?
inxi -Fza
on console.
Maybe you need an autogain effect or similar?
Pipewire must be installed by default nowadays, so just install easyeffects and play a bit with the effects.
Example:
Here you go, all of it!
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ad83a4bb-867a-455b-806b-815a54fb13c1 rw quiet splash apparmor=1
security=apparmor resume=UUID=a5a4e3f7-258e-4ee5-8816-f6f809c5a75f
udev.log_priority=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: H61M-DS2 serial: <superuser required>
UEFI: American Megatrends v: F6 date: 09/30/2014
Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1786 high: 1965 min/max: 1600/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1643 2: 1761 3: 1965
4: 1776 bogomips: 26352
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL ~2023/24) arch: Fermi 2 pcie: gen: 2
speed: 5 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-0 res: 1920x1080 dpi: 102 size: 480x270mm (18.9x10.63")
diag: 551mm (21.68") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.02 TiB used: 50.93 GiB (4.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0326
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ABA100V
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5700 serial: <filter> rev: A720
scheme: GPT
ID-1: / raw-size: 20 GiB size: 19.52 GiB (97.59%) used: 18.22 GiB (93.4%)
fs: ext4 dev: /dev/sdb7 maj-min: 8:23
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb5 maj-min: 8:21
ID-3: /home raw-size: 254.5 GiB size: 249.45 GiB (98.01%)
used: 6.41 GiB (2.6%) fs: ext4 dev: /dev/sdb8 maj-min: 8:24
ID-1: swap-1 type: partition size: 2 GiB used: 224.8 MiB (11.0%)
priority: -2 dev: /dev/sdb6 maj-min: 8:22
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 248 Uptime: 2h 15m wakeups: 0 Memory: 3.8 GiB
used: 2.25 GiB (59.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1242 pacman: 1235 lib: 311 flatpak: 0
snap: 7 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.16
Ok, thank you for the suggestion. I will try this. But my question is why would I have to use sound effects. Isn’t my issue related to driver? Can’t I fix that by changing any drivers or stuff?
Well Windows and Linux have different drivers and handle sound differently. However, I cannot verify your issue, since it seems that this issue is very user specific. I don’t think it is the driver, but the sound system.
For understanding:
- ALSA is the basic sound system.
- Pulseaudio/Pipewire has advanced functionalities and work on top of ALSA.
So you can check the sound at:
# ALSA
alsamixer
# PULSEAUDIO/PIPEWIRE
pavucontrol
Normally there is a generic driver called snd_hda_intel
… if you want to get your hands dirty, then check the parameters at:
modinfo snd_hda_intel
and apply them temporary like this:
sudo rmmod -v snd_hda_intel
sudo modprobe -v snd_hda_intel option=value option=value option=value
But in general that is not needed if everything works.
