Hi,
I use a 2009 Dell Studio XPS. For the past several years (with many distros) my laptop speakers hadn’t worked. I was of the opinion that may be the speakers had given up and anyway I use the earphones most of the time.
However today suddenly the audio output came out of the speakers and I was overjoyed. However issue is that when I plug in my earphones, the audio doesn’t automatically switch to the earphones. I have to go into Audio settings and change the output device.
Although I’m happy that the speakers are working fine, I would like to have it in such a way that the audio switches to earphone when plugged in and via speakers when no earphones are plugged in.
What do I need to do to get this sorted?
You probably need to turn on the Auto-Mute Mode setting in ALSA
You can do this with alsamixer
in terminal
Use F6 to find correct audio device
→ to locate ‘Auto-Mute Mode’
↑ to change setting from Disabled to Enabled
Esc to exit
and use this command to save changes to ALSA settings
sudo alsactl store
Thanks but this didn’t work.
please post ALSA information
sudo alsa-info.sh --upload
and PulseAudio information
pacmd list-cards
ALSA information can be found here - http://alsa-project.org/db/?f=56c9ec376277260c76fee9c7faf9eec57db333d9
PulseAudio Info
viking@pradhyumna-studioxps1640 ~]$ pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xcfeec000 irq 33"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "aa20"
device.product.name = "RV635 HDMI Audio [Radeon HD 3650/3730/3750]"
device.string = "1"
device.description = "RV635 HDMI Audio [Radeon HD 3650/3730/3750]"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.card_name = "HDA Intel"
alsa.long_card_name = "HDA Intel at 0xfc400000 irq 31"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "293e"
device.product.name = "82801I (ICH9 Family) HD Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#2: Built-in Audio Analog Stereo
sources:
alsa_input.pci-0000_00_1b.0.analog-stereo/#4: Built-in Audio Analog Stereo
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#5: Monitor of Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones-2: Headphones 2 (priority 9800, latency offset 0 usec, available: unknown)
properties:
I’m having a very similar problem. (no past audio issues, but all of a sudden having dual-audio through my headphones and laptop speakers)
Pulse Audio: https://pastebin.com/BTsVwABW
Alsa Output: http://alsa-project.org/db/?f=110609f443f0034e19f912aa01c29f91186766ee
I’ve tried the Alsamixer adjustment, and even with the alsactl store, what seems to happen is that the Automute flag is automatically set to disable the second I unplug headphones, and does not re-enable when I plug them back in.
hardware summary for forum SEO
Studio XPS 1640
Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] RV635 HDMI Audio [Radeon HD 3650/3730/3750] [1002:aa20]
Subsystem: Dell Device [1028:0272]
Audio Codec - IDT 92HD73C1X5
The Product ID for this audio device [0272] matches to a Linux kernel patch:
patch_sigmatel.c - sound/pci/hda/patch_sigmatel.c - Linux source code
the model name to call the patch is above the linked patch on Line 1942
{ .id = STAC_DELL_M6_DMIC, .name = "dell-m6-dmic" },
Use this command to add this kernel patch to your system
echo 'options snd_hda_intel model=dell-m6-dmic' | sudo tee -a /etc/modprobe.d/alsa-hda.conf
then reboot system to reload ALSA with the patch
that should get the system to respect the auto-mute setting in ALSA
