I am having constant audio problems with my Audio Interface, a Focusrite Scarlett Solo 2nd gen. Even after a clean install with packages updated.
I am using Manjaro KDE on the latest LTS Linux kernel (5.10) with all the default packages updated.
I am having the following problems:
- Audio drops out or gets distorted when I click the “Audio Devices” button on my panel.
- Audio randomly drops out and the audio interface disappear from the list of audio devices. It only returns after a reboot.
- Audio is sometimes pitched differently.
- Other people sometimes hear me pitched differently.
- When the audio device disappears, applications using audio crash.
Output of `inxi --admin --verbosity=7 --filter --no-host --width`
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bfea158e-dd7f-4d5e-b9cb-bfc8a7f736a5 rw quiet apparmor=1
security=apparmor resume=UUID=8402b99e-0536-415b-8060-a4144bc895a6
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 4402 date: 06/28/2021
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 3.9 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: Discharging
RAM: total: 31.34 GiB used: 3.04 GiB (9.7%)
Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201016 cache:
L2: 3 MiB bogomips: 88827
Speed: 2873 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2873 2: 2880 3: 2872 4: 2878 5: 2879 6: 3599 7: 2879 8: 2881 9: 2878
10: 2876 11: 2878 12: 3599
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1b80 class-ID: 0300
Device-2: Valve 3D Camera type: USB driver: uvcvideo bus-ID: 2-1.1:8
chip-ID: 28de:2400 class-ID: 0e02 serial: <filter>
Device-3: MacroSilicon USB Video type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-2.3:4
chip-ID: 534d:2109 class-ID: 0300
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 7680x1440 s-dpi: 107 s-size: 1824x342mm (71.8x13.5")
s-diag: 1856mm (73.1")
Monitor-1: HDMI-0 res: 2560x1440 hz: 100 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-2 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-4 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Valve Valve VR Radio type: USB driver: cdc_acm,hid-generic,usbhid
bus-ID: 1-1.3.2:8 chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-4: Valve Valve VR Radio & HMD Mic type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3.3:9
chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
Device-5: Focusrite-Novation Scarlett Solo USB type: USB
driver: snd-usb-audio bus-ID: 1-2:3 chip-ID: 1235:8205 class-ID: 0102
Device-6: MacroSilicon USB Video type: USB
Device-7: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 5-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.79 TiB used: 42.36 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 1B2QEXM7 temp: 45.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT512MX100SSD1
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MU02 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31500341AS
size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC1H scheme: MBR
ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 10.74 GiB (17.2%)
fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
uuid: bfea158e-dd7f-4d5e-b9cb-bfc8a7f736a5
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
label: NO_LABEL uuid: EFD7-7EC9
ID-3: /home raw-size: 136.38 GiB size: 133.18 GiB (97.65%)
used: 31.63 GiB (23.7%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:4
label: N/A uuid: 3402714b-f842-4853-b684-b4f5362c75e6
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 8402b99e-0536-415b-8060-a4144bc895a6
ID-1: /dev/nvme0n1p1 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: 00CF-3355
ID-2: /dev/nvme0n1p2 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:8 size: 930.9 GiB fs: ntfs label: N/A
uuid: A818D16B18D13950
ID-4: /dev/nvme0n1p4 maj-min: 259:9 size: 508 MiB fs: ntfs label: N/A
uuid: D8FCA553FCA52CA6
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: HDD 2TB
uuid: 7E70E38670E3440D
ID-7: /dev/sdb1 maj-min: 8:17 size: 476.94 GiB fs: ntfs label: SSD 500GB
uuid: 01D6EA87CEB6F670
ID-8: /dev/sdc1 maj-min: 8:33 size: 1.36 TiB fs: ntfs label: HDD 1,5TB
uuid: 01D4AC3B758B5320
Hub-2: 1-1:2 info: Valve ports: 3 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 28de:2613 class-ID: 0900
Hub-3: 1-1.3:4 info: Microchip (formerly SMSC) Hub ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2744 class-ID: 0900
Device-1: 1-1.3.1:6 info: Valve Index HMD type: HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 28de:2300 class-ID: 0300 serial: <filter>
Device-2: 1-1.3.2:8 info: Valve Valve VR Radio
type: HID,Abstract (modem),CDC-Data driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 28de:2102 class-ID: 0a00
serial: <filter>
Device-3: 1-1.3.3:9 info: Valve Valve VR Radio & HMD Mic type: HID,Audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
Device-4: 1-1.3.5:10 info: Microchip (formerly SMSC) Hub Controller
type: Hub driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:2740 class-ID: 0000
Device-5: 1-2:3 info: Focusrite-Novation Scarlett Solo USB type: Audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-6: 1-5:5 info: Logitech G513 RGB MECHANICAL GAMING KEYBOARD
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c33c class-ID: 0300
serial: <filter>
Device-7: 1-6:7 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-1:7 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.2
speed: 5 Gb/s chip-ID: 0424:5744 class-ID: 0900
Device-1: 2-1.1:8 info: Valve 3D Camera type: Video driver: uvcvideo
interfaces: 2 rev: 3.2 speed: 5 Gb/s power: 800mA chip-ID: 28de:2400
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-7: 3-2:2 info: Fresco Logic USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 1d5c:5011 class-ID: 0900
Device-1: 3-2.3:4 info: MacroSilicon USB Video type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 534d:2109 class-ID: 0300
Device-2: 3-4:3 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-9: 4-2:3 info: Fresco Logic USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 1d5c:5001 class-ID: 0900
Hub-10: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 5-2:3 info: Microsoft Wireless XBox Controller Dongle
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Hub-11: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 44.4 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 36%
Processes: 271 Uptime: 13m wakeups: 2 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1202 lib: 323 flatpak: 0 Shell: Zsh
v: 5.8 running-in: konsole inxi: 3.3.06
How can I fix these problems? What logs do I need to provide to help fix the problem?
