Hey there.
I experience delay about 0.5 sec on audio playback with bluetooth headphones. They work perfectly fine with android phone.
Any ideas how I can fix it?
Installed pulseaudio-modules-bt and set to a2dp, it didn’t help.
Hey there.
You could try this:
pavucontrol,
go to the Output Devices tab.It definitely works, but looks like a crutch to me, also I have problems with synchronizing offset and video.
But thanks for the input, I’d love to see any other ideas
Yeah, there’s probably a better solution.
Use this command to find the Name and Port for the Blueetooth audio card in PulseAudio
pactl list cards | grep -Pzo '.*bluez_card(.*\n)*'
Then use the card name to set the latency to 250000 micro-seconds (250mS)
pactl set-port-latency-offset <NAME> <PORT> 250000
The value for latency may need to be increased if there are any audio glitches
Bluetooth headset - ArchWiki
A2DP Bluetooth audio choppy sound
