I wanted to use hardware acceleration on Google Chrome, so I followed several tips such as arch wiki’s hardware acceleration article and howto tips on the forum. However, I must do something wrong — videos with audio does not play; both for videos on web and videos in my computer. If I mute the audio or turn off the audio track then the video plays very well. That’s why I think this is an audio decoder problem.
KDE Plasma Version: 5.24.5
KDE Frameworks Version: 5.93.0
Qt Version: 5.15.3
Kernel Version: 5.17.6-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 12 × AMD Ryzen 5 3600 6-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1080/PCIe/SSE2
The graphics driver is nonfree NVIDIA driver installed with MHWD.
provide formated output from: inxi -Fazy
and did you checked this link:
UPDATE This guide is severely out of date as Google has changed a lot since I last updated it.
However, one might test only these flags:
--enable-features=VaapiVideoEncoder,VaapiVideoDecodeLinuxGL
--enable-gpu
Difficulty: ★★☆☆☆
Requirements:
Google Chrome >=88
Brave >= 1.19
Vivaldi >=3.6
Opera >=74
For Chromium and Firefox, see their corresponding Arch Wiki articles:
Chromium: Hardware video acceleration
Firefox: Hardware video acceleration
Kernel: 5.17.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=f91c67e7-fb6a-46b5-93b2-1ce147feda0a rw quiet apparmor=1
security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M Steel Legend serial: <filter>
UEFI: American Megatrends v: P2.90 date: 11/27/2019
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2433 high: 3600 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 3600 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 86268
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,DP-3 empty: DP-2,DVI-D-1,HDMI-A-1 bus-ID: 07:00.0
chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right model: Dell U2414H
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: not-matched mapped: DP-4 pos: primary,left res: 1920x1080
hz: 60 dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
bus-ID: 07:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-a6cbac740942 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 931.52 GiB used: 115.93 GiB (12.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 32.9 C scheme: GPT
SMART: yes health: PASSED on: 5d 6h cycles: 959
read-units: 5,173,127 [2.64 TB] written-units: 3,659,174 [1.87 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD4
family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 023 temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 113d 12h cycles: 1178
written: 12.69 TiB
ID-1: / raw-size: 200.88 GiB size: 196.67 GiB (97.90%)
used: 115.9 GiB (58.9%) fs: ext4 block-size: 4096 B dev: /dev/sda6
maj-min: 8:6
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 27.7 MiB (29.2%) fs: vfat block-size: 512 B dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 38.5 C mobo: 37.0 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1664 fan-3: 0 fan-4: 897 fan-5: 0
gpu: nvidia fan: 21%
Power: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.26
Processes: 319 Uptime: 37m wakeups: 6 Memory: 31.28 GiB
used: 3.81 GiB (12.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1723 lib: 423 flatpak: 0
Shell: Zsh (sudo) v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.15
I followed that tutorial to enable the hardware acceleration, but removing created Chrome config file does not solve this problem.
so play a video on your pc and check logs for some possible hints with ksystemlog
app
also try running chrome from terminal and play a video and check in terminal
Double click to play a video on my pc makes the following logs:
22. 5. 12. 오전 5:25 plasmashell kf.kio.core: The recently-used.xbel is not an XBEL file, overwriting.
22. 5. 12. 오전 5:25 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56442, resource id: 39846055, major code: 18 (ChangeProperty), minor code: 0
22. 5. 12. 오전 5:25 systemd Started mpv Media Player - Multimedia player.
22. 5. 12. 오전 5:26 kernel [UFW BLOCK] IN=enp5s0 OUT= MAC=01:00:5e:00:00:01:88:36:6c:1b:93:ac:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58827 DF PROTO=2
Playing a video on Chrome does not make any message in the terminal.
And I found an interesting fact that pulseaudio -k
temporarily solves the problem but only for currently focusing window or Chrome tab.
nothing in logs… also noticed, what kind of a kernel are you running, latest in manjaro stable is 5.17.1-3 …
I use 5.17.6-2-MANJARO (64-bit)
yes i can see that, but are you on stable branch? did you downloaded the kernel from system settings/ kernels … you could try switching to 5.15 LTS kernel… also you could install pipewire by installing manjaro-pipewire
package… if you get any pulse dependencies, uninstall them first, install pipewire, reboot and check audio
Yes I downloaded kernel from System Settings and am on unstable branch. I’ll try pipewire
manjaro-pipewire works perfectly! Thank you for your advice.
Update solution
sudo pacman -R manjaro-pulse
sudo pacman -R pulseaudio-alsa pulseaudio-bluetooth pulseaudio-ctl pulseaudio-zeroconf
sudo pacman -R plasma-pa
sudo pacman -S manjaro-pipewire
sudo pacman -S plasma-pa
you can try this to completely get rid of pulseaudio
system
Closed
14 May 2022 17:49
12
