Hello, a couple of weeks ago I tried playing Lego Lord of the Rings with protontricks and after about 7 minutes of playing the system audio cut off, and having to reboot to get it working again. Now every time I start up my computer, after a seemingly random amount of time the audio and microphone cut out and a popping crackling static is the only thing I can hear.
It still persists even after I had uninstalled the game and reinstalled PulseAudio and ALSA several times. When I checked the sound output I still saw that there was still audio going through but I just can’t hear it. Also the static gets louder and quieter based on things I do; for example, I was playing a game with a top-down board and the static changed volume whenever I panned my view of the board.
Here is my ALSA information
Here is my inxi
information:
System: Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=276af773-5810-431f-a8b2-b82bb13ba543 rw quiet apparmor=1
security=apparmor udev.log_priority=3 pci=nomsi,noaer
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <filter> UEFI: American Megatrends v: P1.10 date: 06/12/2020
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: N/A microcode: 8701021 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86276
Speed: 2039 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2039 2: 3220 3: 2196 4: 2196 5: 1970
6: 2195 7: 2199 8: 2195 9: 1962 10: 3298 11: 1959 12: 2191
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus ID: 0b:00.0 chip ID: 1002:7340 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: Radeon RX 5500 XT (NAVI14 DRM 3.40.0 5.10.15-1-MANJARO LLVM 11.0.1) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 0b:00.1 chip ID: 1002:ab38 class ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 0d:00.4 chip ID: 1022:1487 class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: f000
bus ID: 07:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 301.55 GiB (32.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 211070WD temp: 43.9 C
scheme: GPT
Partition: ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%) used: 301.55 GiB (32.9%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 51.8 C mobo: N/A gpu: amdgpu temp: 61.0 C mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 302 Uptime: 1h 23m wakeups: 0 Memory: 15.56 GiB used: 6.13 GiB (39.4%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 1817 pacman: 1797 lib: 459 flatpak: 11 snap: 9 Shell: Bash v: 5.1.0
running in: yakuake inxi: 3.3.01
If Nickgnomic is reading this, sorry for not responding on my previous topic since I realized I wasn't being specific enough and I realized the problem was bigger than I thought.
