I’ve been trying to solve a problem where the audio works for some brief moment, but then “suddenly” it starts to make a high buzzing noise.
This only happens when I use an jack plug headset, not happens with an usb headset.
More context is needed – lots of it – in your issue description, rather than simply indicating a problem. With any luck, others will then have something to work with if they decide to offer help.
Edit your first post to include as much detail as possible to give those who might wish to help a reasonable place to start.
Please also provide your system information as described (below).
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a
at their disposal – instead, please help others to make informed suggestions based on information you provide.
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
| inxi man pages | (manual) |
--color=0 to the long-form command, or…inxi -zv8c0
