Hello everyone!
Until the last update I was still able to somehow use Pulseeffects with Pipewire to get a compressor effect that took out the loud audio parts when watching movies.
Since the update pulseeffects has been removed from my system, so that option seems to be gone.
Does anyone know how to get a compressor effect under pipewire?
Thank you!
Beer
Pulseeffects change the name, now it’s EasyEffects. Check out in menu, should be there.
yeah, but new version with new name should be installed
Settings location changed:
I had to manually move over the configuration of pulseeffects to the new easyeffects:
cp -rpd ~/.config/PulseEffects ~/.config/easyeffects
and then I had to add the plugins myself (it did not load them automatically, neither after restarting it).
The settings of my preset were simply ignored: I had to set all values again, plugin by plugin.
If I set a plugin to “Bypass”, the next time I start the app (even when the service is still running) that plugin is activated again - that is: the bypas…
and apparently is no longer compatible:
That’s because PulseEffects was using Gstreamer plugins, EasyEffects is using Pipewire plugins. The old presets no longer are compatible.
You need to re-configure the effects you were using.
Found it! Thank you very much for your help!
Cheers Beer
Thank you for the additional information. I re-created my compressor settings and it is working great
system
Closed
1 August 2021 15:32
6
