I have a Shure MV7 that has a USB connection that works as a microphone with a 3.5 mm jack for monitoring + hear the computer sound. On windows it works as expected, however on Manjaro every time I play any sound, the device will disappear and then reaper once the sound has stopped. Some times it is detected just as an input device after playing any sound and the option to set it as output will not reaper until pulseaudio -k and disconnecting the device and reconnecting it again.
I would appreciate any help with this!
$ pacmd list-cards
2 card(s) available.
index: 1
driver: <module-alsa-card.c>
owner module: 7
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdd148000 irq 134"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio (ThinkPad T480)"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#1: Monitor of Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
index: 6
owner module: 32
properties:
alsa.card = "1"
alsa.card_name = "Shure MV7"
alsa.long_card_name = "Shure Inc Shure MV7 at usb-0000:00:14.0-2, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:2:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/sound/card1"
udev.id = "usb-Shure_Inc_Shure_MV7-00"
device.bus = "usb"
device.vendor.id = "14ed"
device.vendor.name = "Shure Inc."
device.product.id = "1012"
device.product.name = "Shure MV7"
device.serial = "Shure_Inc_Shure_MV7"
device.string = "1"
device.description = "Shure MV7"
device.icon_name = "audio-card-usb"
profiles:
input:mono-fallback: Mono Input (priority 1, available: unknown)
input:multichannel-input: Multichannel Input (priority 1, available: unknown)
output:stereo-fallback: Stereo Output (priority 5100, available: unknown)
output:stereo-fallback+input:mono-fallback: Stereo Output + Mono Input (priority 5101, available: unknown)
output:stereo-fallback+input:multichannel-input: Stereo Output + Multichannel Input (priority 5101, available: unknown)
output:multichannel-output: Multichannel Output (priority 100, available: unknown)
output:multichannel-output+input:mono-fallback: Multichannel Output + Mono Input (priority 101, available: unknown)
output:multichannel-output+input:multichannel-input: Multichannel Duplex (priority 101, available: unknown)
active profile: <output:stereo-fallback+input:mono-fallback>
sinks:
alsa_output.usb-Shure_Inc_Shure_MV7-00.stereo-fallback/#5: Shure MV7 Stereo
sources:
alsa_output.usb-Shure_Inc_Shure_MV7-00.stereo-fallback.monitor/#11: Monitor of Shure MV7 Stereo
alsa_input.usb-Shure_Inc_Shure_MV7-00.mono-fallback/#12: Shure MV7 Mono
ports:
analog-input: Analog Input (priority 10000, latency offset 0 usec, available: unknown)
properties:
multichannel-input: Multichannel Input (priority 0, latency offset 0 usec, available: unknown)
properties:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
multichannel-output: Multichannel Output (priority 0, latency offset 0 usec, available: unknown)
properties:
$ inxi -Fazy
Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=fe5232f1-67a3-4b8a-b4bb-1b7c8d85e292 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20L5CTO1WW v: ThinkPad T480
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20L5CTO1WW v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: N24ET60W (1.35 ) date: 08/10/2020
ID-1: BAT0 charge: 17.6 Wh condition: 22.2/24.0 Wh (92%) volts: 12.3/11.5
model: SMP 01AV421 type: Li-poly serial: <filter> status: Unknown cycles: 76
ID-2: BAT1 charge: 54.4 Wh condition: 68.4/71.1 Wh (96%) volts: 12.6/11.2
model: LGC 01AV492 type: Li-ion serial: <filter> status: Unknown cycles: 375
Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: D6
L2 cache: 8192 KiB
bogomips: 32012
Speed: 700 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo ThinkPad T480 driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo ThinkPad T480
driver: N/A alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1d10
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-8:5 chip ID: 13d3:56a6 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
alternate: fbdev,intel,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Device-2: Shure Shure MV7 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-2:11 chip ID: 14ed:1012
Sound Server: ALSA v: k5.9.1-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e
v: kernel port: efa0 bus ID: 00:1f.6 chip ID: 8086:15d8
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
bus ID: 03:00.0 chip ID: 8086:24fd
Local Storage: total: 931.51 GiB used: 533.57 GiB (57.3%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 3B6Q scheme: GPT
ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 49.69 GiB (50.7%) fs: ext4 dev: /dev/sda6
System Temperatures: cpu: 51.0 C mobo: 49.0 C
Fan Speeds (RPM): cpu: 0
Processes: 258 Uptime: 25m Memory: 23.26 GiB used: 4.29 GiB (18.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1312 lib: 355
flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
. Below are the outputs of the two commands you just mentioned.
