Audio Broken after latest updates
Hi guys, I have a broken audio after installing latest updates to my system. I tried installing/re-installing both pulse audio and pipewire but the problem remains the same.
The strange thing is that when i restart the service or restart the system the audio is available for a few minutes (at lest 1 minute) then it dis-appears. I can see the volume controls and my devices detected.
Here are some details about the system and configs:
System: HP OMEN 16 with Nvidia 3060
OS: Manjaro Gnome (22.0.0)
uname -r: 5.15.81-1-MANJARO
systemctl --user status pipewire
pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: active (running) since Wed 2022-12-07 16:27:34 PKT; 16min ago
TriggeredBy: â—Ź pipewire.socket
   Main PID: 3912 (pipewire)
      Tasks: 2 (limit: 38057)
     Memory: 11.6M
        CPU: 494ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─3912 /usr/bin/pipewire
Dec 07 16:27:34 awakeelsOmen16 systemd[3896]: Started PipeWire Multimedia Service.
Dec 07 16:27:34 awakeelsOmen16 pipewire[3912]: mod.rt: Can't find xdg-portal: (null)
Dec 07 16:27:34 awakeelsOmen16 pipewire[3912]: mod.rt: found session bus but no portal
This ===> mod.rt: Can’t find xdg-portal: (null)appears after a few minutes
systemctl --user status pipewire-pulse
pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
     Active: active (running) since Wed 2022-12-07 16:27:34 PKT; 18min ago
TriggeredBy: â—Ź pipewire-pulse.socket
   Main PID: 3917 (pipewire-pulse)
     Memory: 13.7M
        CPU: 650ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─3917 /usr/bin/pipewire-pulse
Dec 07 16:27:34 awakeelsOmen16 systemd[3896]: Started PipeWire PulseAudio.
Dec 07 16:27:34 awakeelsOmen16 pipewire-pulse[3917]: mod.rt: Can't find xdg-portal: (null)
Dec 07 16:27:34 awakeelsOmen16 pipewire-pulse[3917]: mod.rt: found session bus but no portal
Dec 07 16:27:34 awakeelsOmen16 pipewire-pulse[3935]: 536870912
inxi -Fazy
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=823ed1c7-c2b1-4cfa-8c88-49c300e2593b rw quiet splash apparmor=1
    security=apparmor resume=UUID=93054114-2b4a-4090-8fbe-5505d1a36383
    udev.log_priority=3
  Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: HP product: OMEN by HP Laptop 16-b0xxx v: N/A
  Mobo: HP model: 88F4 v: 86.39 serial: <superuser required> UEFI: AMI
    v: F.30 date: 03/19/2022
  ID-1: BAT0 charge: 62.0 Wh (100.0%) condition: 62.0/70.1 Wh (88.4%)
    volts: 17.0 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 93
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x42
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1004 high: 1291 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1043 2: 1039 3: 1087
    4: 867 5: 1008 6: 957 7: 912 8: 1162 9: 853 10: 801 11: 1148 12: 801
    13: 1291 14: 888 15: 1099 16: 1117 bogomips: 73744
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Hewlett-Packard driver: nvidia v: 525.60.11
    alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
    chip-ID: 10de:2520 class-ID: 0300
  Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
    bus-ID: 3-6:3 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 144 dpi: 137
    size: 355x199mm (13.98x7.83") diag: 407mm (16.02") modes: N/A
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel UHD Graphics (TGL GT1)
    direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:43c8 class-ID: 0401
  Device-2: NVIDIA GA106 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
    bus-ID: 0000:2d:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: br-0797b58383a2 state: down mac: <filter>
  IF-ID-2: br-7371d4a24f15 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-3: br-e2e87e02ab92 state: down mac: <filter>
  IF-ID-4: docker0 state: down mac: <filter>
  IF-ID-5: veth2b5c043 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: veth47f71e4 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-7: veth6097d05 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-8: veth767a826 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-9: veth82b886d state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-10: vethc3d8ed0 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-11: vethdfe7b65 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-14:4
    chip-ID: 8087:0026 class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 123 GiB (25.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    lanes: 4 type: SSD serial: <filter> rev: AGHA4101 temp: 49.9 C scheme: GPT
  ID-1: / raw-size: 141.31 GiB size: 138.03 GiB (97.68%)
    used: 122.98 GiB (89.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    used: 19.5 MiB (6.5%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 42.0 C mobo: N/A
  Processes: 422 Uptime: 20m wakeups: 3 Memory: 31 GiB used: 5.63 GiB (18.2%)
  Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: 1503 pm: pacman pkgs: 1491 libs: 351
  tools: gnome-software,pamac pm: flatpak pkgs: 0 pm: snap pkgs: 12 Shell: Zsh
  v: 5.9 running-in: gnome-terminal inxi: 3.3.23
amixer --card=0
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
amixer --card=1
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 82 [94%] [-3.75dB] [on]
  Front Right: Playback 82 [94%] [-3.75dB] [on]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 77 [89%] [-7.50dB] [off]
  Front Right: Playback 77 [89%] [-7.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 3 [100%] [30.00dB]
  Front Right: 3 [100%] [30.00dB]
  Mono: Playback [off]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Dmic0',0
  Limits: Capture 0 - 70
  Front Left: Capture 62 [89%] [12.00dB] [on]
  Front Right: Capture 62 [89%] [12.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
  Front Left: Capture 50 [71%] [0.00dB]
  Front Right: Capture 50 [71%] [0.00dB]
Simple mixer control 'PGA1.0 1 Master',0
  Limits: Playback 0 - 32
  Mono:
  Front Left: Playback 32 [100%] [0.00dB]
  Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
  Limits: Capture 0 - 80
  Front Left: Capture 50 [62%] [0.00dB]
  Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA30.0 30',0
  Mono:
Simple mixer control 'PGA31.0 31',0
  Mono:
Simple mixer control 'PGA7.0 7 Master',0
  Mono:
Simple mixer control 'PGA8.0 8 Master',0
  Mono:
Simple mixer control 'PGA9.0 9 Master',0
  Mono:
Any help would be appreciated!
Thanks
Same happens with the Pulseaudio as well, the sound come out for a few minutes then vanishes. I can see the animation bars playing while i play a video on youtube but can’t hear a thing.
here is the alsa info: http://alsa-project.org/db/?f=96fe78f35d384bccff4ab1c20cde8ea98cbe7717
I started having the same problem two days ago…after updating system…
Frustrating.
There have been a lot of similar reports in the last few days about audio problems after latest stable branch updates. The issue affects ALSA audio for Intel Skylake (6th gen) to TigerLake (11th gen) systems with LTS kernels v5.10 and v5.15
A lot of users have confirmed that the best, simple solution for this is to install kernel v6.0 using either Manjaro Settings Manager GUI tool, or copy/paste this to terminal
sudo mhwd-kernel -i linux60
I think my problem is probably related also!
Hope there’s a solution soon… It’s really important for me!
EDIT: linux60 (with ibt=off parameter to avoid the problem with my nvidia hybrid card) made the trick.
Hope 515 will be repaired soon.
