I have an issue since I switched to a new GPU (RX 7900 XTX, had a 1070 Nvidia before). Whenever GPU’s load is at 100%, the sound starts breaking up. It’s not a typical stutter, but 5+ second breaks every half a minute or so.
I assumed it’s the same error as the one I had over HDMI, so I applied the same solution (commenting wireplumber code suspending audio after 5+ seconds of idle), and it stopped audio from not playing immediatelly after hitting “play”, but it revealed this audio-breaking-up issue. It’s 100% related to GPU and audio over DisplayPort, because it doesn’t happen when using a headset (I won’t be able to check if it happens over HDMI for at least a month - don’t ask, please - but I’ll check if sound cable from sound card to screen speakers input helps sometime over next week).
I understand the GPU’s purpose is to render frames, and if it struggles with that, audio isn’t a priority. Is there a setting I could change to make it a priority? I’d rather have 5 fps less than loosing 20% of a conversation when having a voice call while gaming. It’d be also helpful to get a log letting me pinpoint the cause.
The solution I mentioned:
--- /usr/share/wireplumber/scripts/node/suspend-node.lua 2024-12-03 03:21:41.000000000 +0100
+++ suspend-node.lua 2025-02-02 17:11:17.403779417 +0100
@@ -34,32 +34,32 @@
sources[id] = nil
end
- -- Add a timeout source if idle for at least 5 seconds
- if new_state == "idle" or new_state == "error" then
- -- honor "session.suspend-timeout-seconds" if specified
- local timeout =
- tonumber(node.properties["session.suspend-timeout-seconds"]) or 5
- if timeout == 0 then
- return
- end
- -- add idle timeout; multiply by 1000, timeout_add() expects ms
- sources[id] = Core.timeout_add(timeout * 1000, function()
- -- Suspend the node
- -- but check first if the node still exists
- if (node:get_active_features() & Feature.Proxy.BOUND) ~= 0 then
- log:info(node, "was idle for a while; suspending ...")
- node:send_command("Suspend")
- end
- -- Unref the source
- sources[id] = nil
- -- false (== G_SOURCE_REMOVE) destroys the source so that this
- -- function does not get fired again after 5 seconds
- return false
- end)
- end
+ -- -- Add a timeout source if idle for at least 5 seconds
+ -- if new_state == "idle" or new_state == "error" then
+ -- -- honor "session.suspend-timeout-seconds" if specified
+ -- local timeout =
+ -- tonumber(node.properties["session.suspend-timeout-seconds"]) or 5
+ -- if timeout == 0 then
+ -- return
+ -- end
+ -- -- add idle timeout; multiply by 1000, timeout_add() expects ms
+ -- sources[id] = Core.timeout_add(timeout * 1000, function()
+ -- -- Suspend the node
+ -- -- but check first if the node still exists
+ -- if (node:get_active_features() & Feature.Proxy.BOUND) ~= 0 then
+ -- log:info(node, "was idle for a while; suspending ...")
+ -- node:send_command("Suspend")
+ -- end
+ -- -- Unref the source
+ -- sources[id] = nil
+ -- -- false (== G_SOURCE_REMOVE) destroys the source so that this
+ -- -- function does not get fired again after 5 seconds
+ -- return false
+ -- end)
+ -- end
end
}:register ()
Anyone who was looking for the above fix, you need to restart services after:
systemctl --user restart pipewire pipewire-pulse wireplumber
My hardware (inxi -Fazy):
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f54aa98f-0686-45c4-8bc3-6d95ca77e027 rw quiet
udev.log_priority=3 nospec_store_bypass_disable tsx=on tsx_async_abort=off
mitigations=off zswap.enabled=0 amdgpu.ppfeaturemask=0xffffffff
Desktop: i3 v: 4.24 with: i3bar tools: avail: i3lock,xautolock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: A620M GAMING X v: -CF
serial: <superuser required>
Mobo: Gigabyte model: A620M GAMING X v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 03/10/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4388 min/max: 400/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4388 2: 4388 3: 4388
4: 4388 5: 4388 6: 4388 7: 4388 8: 4388 9: 4388 10: 4388 11: 4388 12: 4388
13: 4388 14: 4388 15: 4388 16: 4388 bogomips: 134205
Type: spec_rstack_overflow status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: ASUSTeK TUF Gaming driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: SunplusIT USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:8
chip-ID: 0806:0806 class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.15 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 mapped: DisplayPort-0 model: Philips PHL BDM4065
serial: <filter> built: 2015 res: mode: 3840x2160 hz: 60 scale: 100% (1)
dpi: 111 gamma: 1.2 size: 878x485mm (34.57x19.09") diag: 1003mm (39.5")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: api: clinfo,vulkaninfo gpu: corectrl wl: swaymsg
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: SunplusIT USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
Device-4: YZ 2.4G Wireless headset driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.2:5
chip-ID: 7545:0897 class-ID: 0300
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd
Local Storage: total: 2.38 TiB used: 1.26 TiB (52.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EFRX-68AX9N0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-1: / raw-size: 103.79 GiB size: 103.74 GiB (99.95%)
used: 54.67 GiB (52.7%) fs: xfs block-size: 512 B dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 199 MiB size: 198.8 MiB (99.89%)
used: 152 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
used: 1.07 TiB (59.9%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17
Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 31.08 GiB used: 371 MiB (1.2%) priority: 100
comp: lzo avail: lzo-rle,lz4,lz4hc,zstd,deflate,842 max-streams: 16
dev: /dev/zram0
System Temperatures: cpu: 48.1 C mobo: 30.0 C gpu: amdgpu temp: 56.0 C
mem: 68.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 8.55 GiB (27.5%)
Processes: 361 Power: uptime: 2d 21h 12m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.41 GiB services: upowerd
Packages: pm: pacman pkgs: 1941 libs: 415 tools: pamac,yay Compilers:
clang: 19.1.7 gcc: 14.2.1 alt: 12 Shell: Zsh v: 5.9 running-in: tmux:
inxi: 3.3.37
