Hi!
In audacious when trying to “Open Folder” and selecting a folder I get the error message “No files found”.
Opening single or multiple files from the same folder works.
I’ve discovered this today, perhaps it has to do with the latest update(s) in stable branch?
Here is the verbose output:
~$ audacious -V
INFO dbus-server.cc:1132 [name_acquired]: Owned D-Bus name (org.atheme.audacious) on session bus.
INFO main.cc:399 [main]: No remote session; starting up.
INFO probe-buffer.cc:30 [ProbeBuffer]: <0x558e68632af0> buffering enabled for /home/max/.config/audacious/config
INFO vfs.cc:105 [VFSFile]: <0x558e68632af0> open (mode r) /home/max/.config/audacious/config
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/gio.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/neon.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Transport/mms.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/asx3.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/m3u.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/cue.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/xspf.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/asx.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/audpl.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Container/pls.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/cdaudio-ng.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/wavpack.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/madplug.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/vorbis.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/modplug.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/vtx.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/flacng.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/amidi-plug.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/ffaudio.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/sndfile.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/openmpt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/aac-raw.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/tonegen.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/sid.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/xsf.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/metronom.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/psf2.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Input/console.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/jack-ng.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/oss4.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/alsa.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/filewriter.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/sdlout.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Output/pulse_audio.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/mixer.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/crossfade.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/echo.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/resample.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/stereo.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/sox-resampler.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/crystalizer.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/speed-pitch.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/voice_removal.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/bs2b.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/silence-removal.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Effect/compressor.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/skins-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/playlist-manager-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/scrobbler.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/song_change.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/qtui.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/cd-menu-items.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/lirc.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/lyricwiki-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/qthotkey.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/notify.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/search-tool-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/song-info-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/mpris2.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/delete-files.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/statusicon-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/General/albumart-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/blur_scope-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/gl-spectrum-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/vumeter-qt.so
INFO plugin-registry.cc:546 [plugin_register]: Register plugin: /usr/lib/audacious/Visualization/qt-spectrum.so
INFO plugin-init.cc:133 [start_required]: Starting selected output plugin PulseAudio Output.
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/Output/pulse_audio.so.
INFO probe-buffer.cc:30 [ProbeBuffer]: <0x558e68677900> buffering enabled for /home/max/.config/audacious/playlists/order
INFO vfs.cc:105 [VFSFile]: <0x558e68677900> open (mode r) /home/max/.config/audacious/playlists/order
INFO playlist-files.cc:49 [playlist_load]: Loading playlist file:///home/max/.config/audacious/playlists/1000.audpl.
INFO playlist-files.cc:62 [playlist_load]: Trying playlist plugin Audacious Playlists (audpl).
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/Container/audpl.so.
INFO probe-buffer.cc:30 [ProbeBuffer]: <0x558e68677940> buffering enabled for file:///home/max/.config/audacious/playlists/1000.audpl
INFO vfs.cc:105 [VFSFile]: <0x558e68677940> open (mode r) file:///home/max/.config/audacious/playlists/1000.audpl
INFO plugin-init.cc:187 [start_plugins]: Starting Audio CD Menu Items.
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/cd-menu-items.so.
INFO plugin-init.cc:187 [start_plugins]: Starting Lyrics.
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/lyricwiki-qt.so.
INFO plugin-init.cc:187 [start_plugins]: Starting MPRIS 2 Server.
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/mpris2.so.
INFO plugin-init.cc:133 [start_required]: Starting selected interface plugin Qt Interface.
INFO plugin-load.cc:64 [plugin_load]: Loading plugin: /usr/lib/audacious/General/qtui.so.
INFO interface.cc:70 [interface_load]: Loading Qt Interface.
INFO adder.cc:312 [add_folder]: Adding folder: file:///data/mp3/beets/MusicBrainz/Queen:%20(1974)%20Queen%20II
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/01%20Procession.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/02%20Father%20to%20Son.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/03%20White%20Queen%20%28As%20It%20Began%29.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/04%20Some%20Day%20One%20Day.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/05%20The%20Loser%20in%20the%20End.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/06%20Ogre%20Battle.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/07%20The%20Fairy%20Feller%E2%80%99s%20Master%E2%80%90Stroke.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/08%20Nevermore.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/09%20The%20March%20of%20the%20Black%20Queen.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/10%20Funny%20How%20Love%20Is.mp3
INFO adder.cc:142 [add_file]: Adding file: file:///data/mp3/beets/MusicBrainz/Queen%3A%20%281974%29%20Queen%20II/11%20Seven%20Seas%20of%20Rhye.mp3
INFO interface.cc:87 [interface_unload]: Unloading Qt Interface.
INFO plugin-init.cc:232 [stop_plugins]: Shutting down Audio CD Menu Items.
INFO plugin-init.cc:232 [stop_plugins]: Shutting down Lyrics.
INFO plugin-init.cc:232 [stop_plugins]: Shutting down MPRIS 2 Server.
INFO probe-buffer.cc:30 [ProbeBuffer]: <0x558e69216d20> buffering enabled for /home/max/.config/audacious/playlists/order
INFO vfs.cc:105 [VFSFile]: <0x558e69216d20> open (mode r) /home/max/.config/audacious/playlists/order
INFO plugin-init.cc:217 [stop_plugins]: Shutting down PulseAudio Output.
Can someone help with this?
Thanks and regards
