I have another topic here that explains how I’m trying to get music to play for an old game that uses MIDI for its soundtrack. I’ve managed to figure out how to get it started as a daemon but I’m not sure what is happening when I run the command. Things aren’t working properly. This is the output of fluidsynth --audio-driver=pulseaudio /usr/share/soundfonts/FluidR3_GM.sf2
ALSA lib pcm_dsnoop.c:566:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
FluidSynth runtime version 2.3.2
Copyright (C) 2000-2023 Peter Hanappe and others.
Distributed under the LGPL license.
SoundFont(R) is a registered trademark of Creative Technology Ltd.
fluidsynth: warning: Failed to set thread to high priority
fluidsynth: Using PulseAudio driver
Type 'help' for help topics.
I looked into setting thread as a high priority here and found a similar problem and output posted here.
I also messed around trying to turn jack server
on as well.
Before going any further I figured I’d ask here and see if anyone might be able to help me figure out what direction to head in.
Here’s my inxi output.
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F21 date: 02/08/2018
System RAM: available: 15.57 GiB used: 5.8 GiB (37.3%)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1947 high: 3690 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1362 2: 1476
3: 1550 4: 1550 5: 3200 6: 2789 7: 1550 8: 1550 9: 1550 10: 3690 11: 1550
12: 1550 bogomips: 76669
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300
Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 046d:0894
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1060
3GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control
Server-3: PipeWire v: 0.3.70 status: off with: 1: pipewire-media-session
status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Local Storage: total: 698.65 GiB used: 505.39 GiB (72.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 209.55 GiB (92.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 295.83 GiB (69.3%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-1: /dev/sdb1 maj-min: 8:17 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Device-1: 1-2:2 info: Logitech CrystalCam type: video,audio
chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Device-1: 3-3:2 info: Ducky One 3̠ type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 342 Uptime: 9h 11m wakeups: 0 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 2076 pm: pacman pkgs: 2067 libs: 518 tools: gnome-software,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 9 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.27
Any help would be appreciated. Thank you.
