Thank you, i somehow missed that.
the output of inxi -zv8 is as follows:
$ inxi -zv8
Kernel: 6.12.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=511f8130-444a-4983-ab68-31f56cf1aa24 rw quiet splash nomodeset
udev.log_priority=3 bluetooth.disable_ertm=1
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Desktop System: Gigabyte product: B460HD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B460 HD3 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F6 date: 12/20/2023
System RAM: total: 32 GiB available: 31.27 GiB used: 7.88 GiB (25.2%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2933 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMW16GX4M2C3200C16
serial: N/A
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
serial: N/A
Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 5 microcode: 0x100
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4599 min/max: 800/4800 scaling: driver: intel_cpufreq
governor: performance cores: 1: 4599 2: 4599 3: 4599 4: 4599 5: 4599 6: 4599
7: 4599 8: 4599 9: 4599 10: 4599 11: 4599 12: 4599 13: 4599 14: 4599
15: 4599 16: 4599 bogomips: 92838
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt invpcid lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse
pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
xsaves xtopology xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: retbleed mitigation: Enhanced IBRS
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: Gigabyte driver: nvidia
v: 575.64.05 non-free: 550-570.xx+ status: current (as of 2025-04)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2803 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch d-rect: 1920x1080 display-ID: 0
Monitor-1: DP-2 pos: primary model: Dell U2417H serial: <filter>
built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
y: 0.059 white: x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: 1920x1080, 1600x1200, 1280x1024,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: HDMI-A-2 pos: primary model: Kamvas Pro 16 built: 2021 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 345x195mm (13.58x7.68") diag: 396mm (15.6")
ratio: 16:9 modes: 1920x1080, 1600x1200, 1280x1024, 1360x850, 1024x768,
800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: nvidia v: 575.64.05 device-ID: 10de:2803
surfaces: N/A
Device-1: Intel Comet Lake PCH-V cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA AD106M High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bd
class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.12.40-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Local Storage: total: 931.52 GiB used: 490.8 GiB (52.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721050CLA662
tech: HDD rpm: 7200 serial: <filter> fw-rev: A41A scheme: GPT
ID-1: / raw-size: 465.47 GiB size: 457.09 GiB (98.20%)
used: 310.38 GiB (67.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 511f8130-444a-4983-ab68-31f56cf1aa24
used: 320 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ABC3-4CB9
ID-3: /mnt/sdb1 raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 180.42 GiB (39.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 51dc2b6e-2f31-4136-8dec-1b1e1bda080b
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-5:3 info: Evision RGB Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:505b class-ID: 0301
Device-3: 1-6:4 info: C-Media Blue Snowball type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-4: 1-7:5 info: N/A type: mouse driver: uclogic,usbhid interfaces: 2
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 256c:006d class-ID: 0301
Device-5: 1-10:6 info: Logitech G502 X type: mouse,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 046d:c099 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 41.0 C mobo: 33.0 C
Fan Speeds (rpm): N/A
Packages: 1786 pm: pacman pkgs: 1763 libs: 513 tools: pamac,yay pm: flatpak
pkgs: 23
1: https://manjaro.kurdy.org/unstable/$repo/$arch
2: https://mirror.easyname.at/manjaro/unstable/$repo/$arch
3: https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
4: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
5: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
6: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
7: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
8: http://ossmirror.mycloud.services/os/linux/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 394
1: cpu: 14.5% command: C:\Program pid: 6784 mem: 616.9 MiB (1.9%)
2: cpu: 10.6% command: konsole pid: 17076 mem: 321.8 MiB (1.0%)
3: cpu: 10.5% command: pamac-manager pid: 5787 mem: 319.7 MiB (0.9%)
4: cpu: 9.6% command: steam pid: 3575 mem: 250.9 MiB (0.7%)
5: cpu: 7.3% command: C:\Program pid: 6821 mem: 401.5 MiB (1.2%)
Memory top: 5 of 394
1: mem: 799.6 MiB (2.4%) command: firefox pid: 1434 cpu: 4.3%
2: mem: 616.9 MiB (1.9%) command: C:\Program pid: 6784 cpu: 14.5%
3: mem: 567.0 MiB (1.7%) command: steamwebhelper pid: 3836 cpu: 4.9%
4: mem: 511.3 MiB (1.5%) command: firefox pid: 2052 cpu: 2.4%
5: mem: 485.9 MiB (1.5%) command: plasmashell pid: 1201 cpu: 0.5%
Processes: 394 Power: uptime: 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil
Compilers: clang: 20.1.8 gcc: 15.1.1 alt: 13 Shell: Zsh v: 5.9
default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.38
Thank you, and i apologise.
