Problem
I have a machine that does not boot from the Grub menu when using the default kernel but does boot into the fallback kernel configuration.
Partial Solution
I can get the default kernel configuration to boot if I remove the microcode images. i.e. initrd /boot/initramfs-6.12-x86_64.img
works;
initrd /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
does not work.
Questions
- Does my partial solution simply indicate an incompatibility between the kernel and the motherboard, and if so, could the problem be with mhwd not detecting a needed module?
- Is there a different set of configuration changes I should look at?
- Since everything seems to be functioning fine, if I chose to go forward without the microcode images, is there a configuration I can add so that those microcode images are not added to the default grub configuration when new kernels are built?
Background
First, this is not my primary Manjaro rig (summary shown in my profile), but an older machine that I recently migrated over to Manjaro. Also, this is not a problem for this rig that is unique to the 6.12 kernel since I also had this issue on 6.11 and 6.6. I completely wiped the two drives on this Rog and installed a fresh Manjaro, using non-free Nvidia drivers. I’ve done very few modifications to the original install. Before I discovered my “partial solution”, I did try some different mkinitcpio hook variations, including trying the systemd hook. The current configuration is this:
HOOKS=(base udev autodetect kms modconf block keyboard keymap consolefont plymouth resume filesystems fsck)
I investigated numerous threads regarding booting only to fallback, but none helped or really applied to this situation.
This is a low level issue for me (because my primary machine is fine) so don’t waste any bandwidth looking into this unless you are interested or can quickly point me somewhere to do additional research on my end. I debated with myself on whether to create this thread on the member hub or here in support, so move to the hub if that makes more sense.
Thanks in advance for any help.
System Information
Host: joeb-rogstrixg Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 14.2.1 clocksource: tsc avail: acpi_pm
root=UUID=f2d573e8-30f3-4e0a-80dc-9bd0956da421 rw
resume=UUID=8d34d25c-2af5-496d-baa3-1f6abe1fe4a5 udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: ASUSTeK product: ROG Strix GL12CX_GL12CX v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GL12CX v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: GL12CX.313
date: 02/08/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
serial: 00-00-00-00 charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.54 GiB used: 1.93 GiB (12.4%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M378A1K43CB2-CTD
serial: 710F9AC6
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
serial: 710F9DB1
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xD2
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/8300 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 57616
fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: ASUSTeK driver: nvidia
v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,Unknown-2 bus-ID: 01:00.0 chip-ID: 10de:1f02
class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x292mm (20.87x11.50")
s-diag: 605mm (23.82") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 size-res: N/A modes: N/A
Monitor-2: Unknown-1 size-res: N/A modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 driver: nvidia v: 550.135 device-ID: 10de:1f02
surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: ee:ce:b2:a0:85:72
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: 04:92:26:e0:40:69
IP v4: 10.0.0.171/24 type: dynamic noprefixroute scope: global
broadcast: 10.0.0.255
IP v6: 2601:602:9601:57c0::9247/128 type: dynamic noprefixroute
scope: global
IP v6: 2601:602:9601:57c0:1668:e4b2:23f1:8614/64
IP v6: fe80::f549:dd8d:1500:2709/64 type: noprefixroute scope: link
WAN IP: 73.109.131.90
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Local Storage: total: 1.38 TiB used: 22.59 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: BTNH83410332512A fw-rev: 002C temp: 27.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: Z8JNK0JNS fw-rev: A8S0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 440.8 GiB size: 432.81 GiB (98.19%) used: 12.06 GiB (2.8%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
uuid: f2d573e8-30f3-4e0a-80dc-9bd0956da421
ID-2: /boot/efi raw-size: 4.88 GiB size: 4.87 GiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4065-8655
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 10.54 GiB (1.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Home
uuid: 22aae47d-cf26-41be-aed3-dbf151f70e35
ID-1: swap-1 type: partition size: 31.25 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8d34d25c-2af5-496d-baa3-1f6abe1fe4a5
Device-1: 1-6:2 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-10:3 info: ASUSTek ITE Device(8910) type: keyboard
driver: usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0b05:1866 class-ID: 0301
Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 30.0 C pch: 40.0 C mobo: N/A gpu: nvidia
temp: 33 C
Fan Speeds (rpm): cpu: 2800 gpu: nvidia fan: 20%
Packages: pm: pacman pkgs: 1185 libs: 324 tools: pamac pm: flatpak pkgs: 0
1: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
3: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
4: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
5: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
6: https://mirror.init7.net/manjaro/stable/$repo/$arch
7: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
8: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
Processes:
CPU top: 5 of 262
1: cpu: 7.0% command: firefox pid: 1129 mem: 479.8 MiB (3.0%)
2: cpu: 3.0% command: firefox pid: 1405 mem: 247.6 MiB (1.5%)
3: cpu: 1.2% command: kwin_x11 pid: 807 mem: 177.3 MiB (1.1%)
4: cpu: 0.8% command: Xorg pid: 647 mem: 73.2 MiB (0.4%)
5: cpu: 0.7% command: zsh pid: 1716 mem: 9.71 MiB (0.0%)
Memory top: 5 of 262
1: mem: 479.8 MiB (3.0%) command: firefox pid: 1129 cpu: 7.0%
2: mem: 366.4 MiB (2.3%) command: plasmashell pid: 823 cpu: 0.5%
3: mem: 247.6 MiB (1.5%) command: firefox pid: 1405 cpu: 3.0%
4: mem: 177.3 MiB (1.1%) command: kwin_x11 pid: 807 cpu: 1.2%
5: mem: 171.7 MiB (1.0%) command: konsole pid: 1702 cpu: 0.4%
Processes: 262 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
Update on my research:
My testing with different mkintcpio.conf modifications, specifically to HOOKS, didn’t go anywhere but thanks @andreas85 for taking a look. It’s possible that I need to add something to the MODULES array, but I don’t know what. I do see a NVIDIA error from dmesg, 26.264812] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
which I overlooked including in this post (I had seen this message days earlier). I remember at the time adding this to mkinitcpio: MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
, but that did not help and I commented it out.
I managed to get the default boot to work by manually removing the microcode images. So now both the default and fallback images work as long as the microcode images are not present. I think the solution for this machine hardware is not to include the microcode images and of course not to use the microcode hook. If that’s the case, then I would still like an answer to one of my questions: how do i prevent mhwd from including the microcode images in the default when new kernels are built?
