Asus WMI issue kernel 6.12 on a Asus UX3402ZA laptop
running 6.12.1 on the laptop the battery threshold charge limit setting is missing … its working fine on 6.11
as far as I can tell there’s something wrong with asus_wmi
[Sat Nov 23 14:55:38 2024] asus_wmi: ASUS WMI generic driver loaded
[Sat Nov 23 14:55:38 2024] asus_wmi: Initialization: 0x1
[Sat Nov 23 14:55:38 2024] asus_wmi: SFUN value: 0x21
[Sat Nov 23 14:55:38 2024] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[Sat Nov 23 14:55:38 2024] asus_wmi: Failed to set throttle thermal policy (retval): 0x0
[Sat Nov 23 14:55:38 2024] asus_wmi: Failed to set default thermal profile
[Sat Nov 23 14:55:38 2024] asus-nb-wmi asus-nb-wmi: probe with driver asus-nb-wmi failed with error -5
normal 6.11 boot of asus wmi:
[Sat Nov 23 15:18:29 2024] asus_wmi: ASUS WMI generic driver loaded
[Sat Nov 23 15:18:29 2024] asus_wmi: Initialization: 0x1
[Sat Nov 23 15:18:29 2024] asus_wmi: SFUN value: 0x21
[Sat Nov 23 15:18:29 2024] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[Sat Nov 23 15:18:29 2024] asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
[Sat Nov 23 15:18:29 2024] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input11
[Sat Nov 23 15:18:29 2024] asus_wmi: using asus-wmi for asus::kbd_backlight
[Sat Nov 23 15:18:29 2024] systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:asus::kbd_backlight...
[Sat Nov 23 15:18:29 2024] systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:asus::kbd_backlight.
PS: probably backlight of oled and keys are not working also since the driver fails…
dmesg:
[Sat Nov 23 14:55:32 2024] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[Sat Nov 23 14:55:32 2024] BIOS-provided physical RAM map:
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000000100000-0x000000002171afff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x000000002171b000-0x000000002171bfff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x000000002171c000-0x00000000282c0fff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000282c1000-0x00000000282c1fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000282c2000-0x00000000380b9fff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000380ba000-0x00000000409d6fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000409d7000-0x0000000040ac6fff] ACPI data
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000040ac7000-0x0000000040bcffff] ACPI NVS
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000040bd0000-0x000000004173afff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x000000004173b000-0x00000000417fefff] type 20
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000417ff000-0x00000000417fffff] usable
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000041800000-0x0000000047ffffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000048c00000-0x000000004f7fffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[Sat Nov 23 14:55:32 2024] BIOS-e820: [mem 0x0000000100000000-0x00000004b07fffff] usable
[Sat Nov 23 14:55:32 2024] NX (Execute Disable) protection: active
[Sat Nov 23 14:55:32 2024] APIC: Static calls initialized
[Sat Nov 23 14:55:32 2024] efi: EFI v2.8 by American Megatrends
[Sat Nov 23 14:55:32 2024] efi: ACPI=0x40ac6000 ACPI 2.0=0x40ac6014 TPMFinalLog=0x40b1b000 SMBIOS=0x41458000 SMBIOS 3.0=0x41457000 MEMATTR=0x3153f418 ESRT=0x2f9b4318
[Sat Nov 23 14:55:32 2024] efi: Remove mem77: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[Sat Nov 23 14:55:32 2024] e820: remove [mem 0xc0000000-0xcfffffff] reserved
[Sat Nov 23 14:55:32 2024] efi: Not removing mem78: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[Sat Nov 23 14:55:32 2024] efi: Not removing mem79: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[Sat Nov 23 14:55:32 2024] efi: Not removing mem80: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[Sat Nov 23 14:55:32 2024] efi: Not removing mem82: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[Sat Nov 23 14:55:32 2024] efi: Remove mem83: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[Sat Nov 23 14:55:32 2024] e820: remove [mem 0xff000000-0xffffffff] reserved
[Sat Nov 23 14:55:32 2024] SMBIOS 3.4.0 present.
[Sat Nov 23 14:55:32 2024] DMI: ASUSTeK COMPUTER INC. Zenbook UX3402ZA_UX3402ZA/UX3402ZA, BIOS UX3402ZA.310 12/14/2022
[Sat Nov 23 14:55:32 2024] DMI: Memory slots populated: 8/8
[Sat Nov 23 14:55:32 2024] tsc: Detected 2100.000 MHz processor
[Sat Nov 23 14:55:32 2024] tsc: Detected 2112.000 MHz TSC
[Sat Nov 23 14:55:32 2024] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[Sat Nov 23 14:55:32 2024] e820: remove [mem 0x000a0000-0x000fffff] usable
[Sat Nov 23 14:55:32 2024] last_pfn = 0x4b0800 max_arch_pfn = 0x400000000
[Sat Nov 23 14:55:32 2024] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
[Sat Nov 23 14:55:32 2024] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[Sat Nov 23 14:55:32 2024] last_pfn = 0x41800 max_arch_pfn = 0x400000000
[Sat Nov 23 14:55:32 2024] esrt: Reserving ESRT space from 0x000000002f9b4318 to 0x000000002f9b43c8.
[Sat Nov 23 14:55:32 2024] e820: update [mem 0x2f9b4000-0x2f9b4fff] usable ==> reserved
[Sat Nov 23 14:55:32 2024] Using GB pages for direct mapping
[Sat Nov 23 14:55:32 2024] Incomplete global flushes, disabling PCID
[Sat Nov 23 14:55:32 2024] Secure boot disabled
[Sat Nov 23 14:55:32 2024] RAMDISK: [mem 0x2c959000-0x2e5cdfff]
[Sat Nov 23 14:55:32 2024] ACPI: Early table checksum verification disabled
[Sat Nov 23 14:55:32 2024] ACPI: RSDP 0x0000000040AC6014 000024 (v02 _ASUS_)
[Sat Nov 23 14:55:32 2024] ACPI: XSDT 0x0000000040AC5728 00012C (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: FACP 0x0000000040ABC000 000114 (v06 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: DSDT 0x0000000040A4C000 06F03C (v02 _ASUS_ Notebook 01072009 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: FACS 0x0000000040BCE000 000040
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040ABD000 00740E (v02 DptfTb DptfTabl 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: FIDT 0x0000000040A4B000 00009C (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[Sat Nov 23 14:55:32 2024] ACPI: MSDM 0x0000000040A4A000 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A49000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A43000 005D0B (v02 CpuRef CpuSsdt  00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A40000 002AA1 (v02 SaSsdt SaSsdt   00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A3C000 0033D3 (v02 INTEL  IgfxSsdt 00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A2E000 00D337 (v02 INTEL  TcssSsdt 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: HPET 0x0000000040A2D000 000038 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: APIC 0x0000000040A2C000 0001DC (v05 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: MCFG 0x0000000040A2B000 00003C (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A25000 005D47 (v02 _ASUS_ AdlP_Rvp 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A23000 001F1A (v02 _ASUS_ Ther_Rvp 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: LPIT 0x0000000040A22000 0000CC (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A1E000 002A83 (v02 _ASUS_ PtidDevc 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A1B000 002357 (v02 _ASUS_ TbtTypeC 00000000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: DBGP 0x0000000040A1A000 000034 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: DBG2 0x0000000040A19000 000054 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A17000 001AC9 (v02 _ASUS_ UsbCTabl 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: NHLT 0x0000000040A15000 001B62 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: DMAR 0x0000000040A14000 000088 (v02 INTEL  EDK2     00000002      01000013)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A13000 000B35 (v02 INTEL  xh_adlLP 00000000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A0F000 003AEA (v02 SocGpe SocGpe   00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A0C000 002B2A (v02 SocCmn SocCmn   00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0x0000000040A0B000 000144 (v02 Intel  ADebTabl 00001000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: BGRT 0x0000000040A0A000 000038 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[Sat Nov 23 14:55:32 2024] ACPI: UEFI 0x0000000040AFD000 00063A (v01 INTEL  RstVmdE  00000000 INTL 00000000)
[Sat Nov 23 14:55:32 2024] ACPI: UEFI 0x0000000040AFC000 00005C (v01 INTEL  RstVmdV  00000000 INTL 00000000)
[Sat Nov 23 14:55:32 2024] ACPI: TPM2 0x0000000040A09000 00004C (v04 _ASUS_ Notebook 00000001 AMI  00000000)
[Sat Nov 23 14:55:32 2024] ACPI: PHAT 0x0000000040A08000 00060D (v00 _ASUS_ Notebook 00000005 MSFT 0100000D)
[Sat Nov 23 14:55:32 2024] ACPI: WSMT 0x0000000040A21000 000028 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[Sat Nov 23 14:55:32 2024] ACPI: FPDT 0x0000000040A07000 000044 (v01 _ASUS_ A M I    01072009 AMI  01000013)
[Sat Nov 23 14:55:32 2024] ACPI: Reserving FACP table memory at [mem 0x40abc000-0x40abc113]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving DSDT table memory at [mem 0x40a4c000-0x40abb03b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving FACS table memory at [mem 0x40bce000-0x40bce03f]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40abd000-0x40ac440d]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving FIDT table memory at [mem 0x40a4b000-0x40a4b09b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving MSDM table memory at [mem 0x40a4a000-0x40a4a054]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a49000-0x40a4938b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a43000-0x40a48d0a]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a40000-0x40a42aa0]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a3c000-0x40a3f3d2]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a2e000-0x40a3b336]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving HPET table memory at [mem 0x40a2d000-0x40a2d037]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving APIC table memory at [mem 0x40a2c000-0x40a2c1db]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving MCFG table memory at [mem 0x40a2b000-0x40a2b03b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a25000-0x40a2ad46]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a23000-0x40a24f19]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving LPIT table memory at [mem 0x40a22000-0x40a220cb]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a1e000-0x40a20a82]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a1b000-0x40a1d356]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving DBGP table memory at [mem 0x40a1a000-0x40a1a033]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving DBG2 table memory at [mem 0x40a19000-0x40a19053]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a17000-0x40a18ac8]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving NHLT table memory at [mem 0x40a15000-0x40a16b61]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving DMAR table memory at [mem 0x40a14000-0x40a14087]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a13000-0x40a13b34]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a0f000-0x40a12ae9]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a0c000-0x40a0eb29]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving SSDT table memory at [mem 0x40a0b000-0x40a0b143]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving BGRT table memory at [mem 0x40a0a000-0x40a0a037]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving UEFI table memory at [mem 0x40afd000-0x40afd639]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving UEFI table memory at [mem 0x40afc000-0x40afc05b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving TPM2 table memory at [mem 0x40a09000-0x40a0904b]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving PHAT table memory at [mem 0x40a08000-0x40a0860c]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving WSMT table memory at [mem 0x40a21000-0x40a21027]
[Sat Nov 23 14:55:32 2024] ACPI: Reserving FPDT table memory at [mem 0x40a07000-0x40a07043]
[Sat Nov 23 14:55:32 2024] No NUMA configuration found
[Sat Nov 23 14:55:32 2024] Faking a node at [mem 0x0000000000000000-0x00000004b07fffff]
[Sat Nov 23 14:55:32 2024] NODE_DATA(0) allocated [mem 0x4b07d52c0-0x4b07fffff]
[Sat Nov 23 14:55:32 2024] Zone ranges:
[Sat Nov 23 14:55:32 2024]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[Sat Nov 23 14:55:32 2024]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[Sat Nov 23 14:55:32 2024]   Normal   [mem 0x0000000100000000-0x00000004b07fffff]
[Sat Nov 23 14:55:32 2024]   Device   empty
[Sat Nov 23 14:55:32 2024] Movable zone start for each node
[Sat Nov 23 14:55:32 2024] Early memory node ranges
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x0000000000100000-0x000000002171afff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x000000002171c000-0x00000000282c0fff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x00000000282c2000-0x00000000380b9fff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x00000000417ff000-0x00000000417fffff]
[Sat Nov 23 14:55:32 2024]   node   0: [mem 0x0000000100000000-0x00000004b07fffff]
[Sat Nov 23 14:55:32 2024] Initmem setup node 0 [mem 0x0000000000001000-0x00000004b07fffff]
[Sat Nov 23 14:55:32 2024] On node 0, zone DMA: 1 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] On node 0, zone DMA: 96 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] On node 0, zone DMA32: 1 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] On node 0, zone DMA32: 38725 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] On node 0, zone Normal: 26624 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] On node 0, zone Normal: 30720 pages in unavailable ranges
[Sat Nov 23 14:55:32 2024] Reserving Intel graphics memory at [mem 0x4b800000-0x4f7fffff]
[Sat Nov 23 14:55:32 2024] ACPI: PM-Timer IO Port: 0x1808
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[Sat Nov 23 14:55:32 2024] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[Sat Nov 23 14:55:32 2024] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[Sat Nov 23 14:55:32 2024] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[Sat Nov 23 14:55:32 2024] ACPI: Using ACPI (MADT) for SMP configuration information
[Sat Nov 23 14:55:32 2024] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[Sat Nov 23 14:55:32 2024] e820: update [mem 0x2f468000-0x2f4c9fff] usable ==> reserved
[Sat Nov 23 14:55:32 2024] TSC deadline timer available
[Sat Nov 23 14:55:32 2024] CPU topo: Max. logical packages:   1
[Sat Nov 23 14:55:32 2024] CPU topo: Max. logical dies:       1
[Sat Nov 23 14:55:32 2024] CPU topo: Max. dies per package:   1
[Sat Nov 23 14:55:32 2024] CPU topo: Max. threads per core:   2
[Sat Nov 23 14:55:32 2024] CPU topo: Num. cores per package:    12
[Sat Nov 23 14:55:32 2024] CPU topo: Num. threads per package:  16
[Sat Nov 23 14:55:32 2024] CPU topo: Allowing 16 present CPUs plus 0 hotplug CPUs
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x2171b000-0x2171bfff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x282c1000-0x282c1fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x2f468000-0x2f4c9fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x2f9b4000-0x2f9b4fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x380ba000-0x409d6fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x409d7000-0x40ac6fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x40ac7000-0x40bcffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x40bd0000-0x4173afff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x4173b000-0x417fefff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x41800000-0x47ffffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x48000000-0x48bfffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x48c00000-0x4f7fffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0x4f800000-0xfdffffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[Sat Nov 23 14:55:32 2024] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[Sat Nov 23 14:55:32 2024] [mem 0x4f800000-0xfdffffff] available for PCI devices
[Sat Nov 23 14:55:32 2024] Booting paravirtualized kernel on bare hardware
[Sat Nov 23 14:55:32 2024] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[Sat Nov 23 14:55:32 2024] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[Sat Nov 23 14:55:32 2024] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[Sat Nov 23 14:55:32 2024] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
[Sat Nov 23 14:55:32 2024] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[Sat Nov 23 14:55:32 2024] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[Sat Nov 23 14:55:32 2024] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=a6552d15-6751-42f0-8709-cffd980026af rw rootflags=subvol=@ quiet apparmor=1 security=apparmor resume=UUID=3fc45252-2d9c-4a78-9d95-0a39a5458d90 udev.log_priority=3 mitigations=off audit=0 intel_iommu=on iommu=pt i915.mitigations=off pcie_aspm=force intel_pstate=active xe.enable_dpcd_backlight=2 xe.enable_dc=2 xe.disable_power_well=1 xe.enable_fbc=1 xe.enable_psr=2 xe.enable_dmc_wl=1 i915.force_probe=!46a6 xe.force_probe=46a6
[Sat Nov 23 14:55:32 2024] audit: disabled (until reboot)
[Sat Nov 23 14:55:32 2024] DMAR: IOMMU enabled
[Sat Nov 23 14:55:32 2024] PCIe ASPM is forcibly enabled
[Sat Nov 23 14:55:32 2024] Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64", will be passed to user space.
[Sat Nov 23 14:55:32 2024] random: crng init done
[Sat Nov 23 14:55:32 2024] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[Sat Nov 23 14:55:32 2024] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[Sat Nov 23 14:55:32 2024] Fallback order for Node 0: 0
[Sat Nov 23 14:55:32 2024] Built 1 zonelists, mobility grouping on.  Total pages: 4098135
[Sat Nov 23 14:55:32 2024] Policy zone: Normal
[Sat Nov 23 14:55:32 2024] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[Sat Nov 23 14:55:32 2024] software IO TLB: area num 16.
[Sat Nov 23 14:55:32 2024] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[Sat Nov 23 14:55:32 2024] ftrace: allocating 51316 entries in 201 pages
[Sat Nov 23 14:55:32 2024] ftrace: allocated 201 pages with 4 groups
[Sat Nov 23 14:55:32 2024] Dynamic Preempt: full
[Sat Nov 23 14:55:32 2024] rcu: Preemptible hierarchical RCU implementation.
[Sat Nov 23 14:55:32 2024] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
[Sat Nov 23 14:55:32 2024] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[Sat Nov 23 14:55:32 2024] 	Trampoline variant of Tasks RCU enabled.
[Sat Nov 23 14:55:32 2024] 	Rude variant of Tasks RCU enabled.
[Sat Nov 23 14:55:32 2024] 	Tracing variant of Tasks RCU enabled.
[Sat Nov 23 14:55:32 2024] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[Sat Nov 23 14:55:32 2024] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[Sat Nov 23 14:55:32 2024] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[Sat Nov 23 14:55:32 2024] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[Sat Nov 23 14:55:32 2024] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[Sat Nov 23 14:55:32 2024] NR_IRQS: 524544, nr_irqs: 2184, preallocated irqs: 16
[Sat Nov 23 14:55:32 2024] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[Sat Nov 23 14:55:32 2024] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[Sat Nov 23 14:55:32 2024] Console: colour dummy device 80x25
[Sat Nov 23 14:55:32 2024] printk: legacy console [tty0] enabled
[Sat Nov 23 14:55:32 2024] ACPI: Core revision 20240827
[Sat Nov 23 14:55:32 2024] hpet: HPET dysfunctional in PC10. Force disabled.
[Sat Nov 23 14:55:32 2024] APIC: Switch to symmetric I/O mode setup
[Sat Nov 23 14:55:32 2024] DMAR: Host address width 39
[Sat Nov 23 14:55:32 2024] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[Sat Nov 23 14:55:32 2024] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[Sat Nov 23 14:55:32 2024] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[Sat Nov 23 14:55:32 2024] DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[Sat Nov 23 14:55:32 2024] DMAR: RMRR base: 0x0000004b000000 end: 0x0000004f7fffff
[Sat Nov 23 14:55:32 2024] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[Sat Nov 23 14:55:32 2024] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[Sat Nov 23 14:55:32 2024] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[Sat Nov 23 14:55:32 2024] DMAR-IR: Enabled IRQ remapping in x2apic mode
[Sat Nov 23 14:55:32 2024] x2apic enabled
[Sat Nov 23 14:55:32 2024] APIC: Switched APIC routing to: cluster x2apic
[Sat Nov 23 14:55:32 2024] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1e71785e5dd, max_idle_ns: 440795244814 ns
[Sat Nov 23 14:55:32 2024] Calibrating delay loop (skipped), value calculated using timer frequency.. 4225.00 BogoMIPS (lpj=7040000)
[Sat Nov 23 14:55:32 2024] CPU0: Thermal monitoring enabled (TM1)
[Sat Nov 23 14:55:32 2024] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[Sat Nov 23 14:55:32 2024] CET detected: Indirect Branch Tracking enabled
[Sat Nov 23 14:55:32 2024] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[Sat Nov 23 14:55:32 2024] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[Sat Nov 23 14:55:32 2024] process: using mwait in idle threads
[Sat Nov 23 14:55:32 2024] Spectre V2 : User space: Vulnerable
[Sat Nov 23 14:55:32 2024] Speculative Store Bypass: Vulnerable
[Sat Nov 23 14:55:32 2024] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[Sat Nov 23 14:55:32 2024] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[Sat Nov 23 14:55:32 2024] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[Sat Nov 23 14:55:32 2024] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[Sat Nov 23 14:55:32 2024] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[Sat Nov 23 14:55:32 2024] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[Sat Nov 23 14:55:32 2024] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[Sat Nov 23 14:55:32 2024] x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
[Sat Nov 23 14:55:32 2024] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
[Sat Nov 23 14:55:32 2024] Freeing SMP alternatives memory: 40K
[Sat Nov 23 14:55:32 2024] pid_max: default: 32768 minimum: 301
[Sat Nov 23 14:55:32 2024] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[Sat Nov 23 14:55:32 2024] landlock: Up and running.
[Sat Nov 23 14:55:32 2024] Yama: becoming mindful.
[Sat Nov 23 14:55:32 2024] LSM support for eBPF active
[Sat Nov 23 14:55:32 2024] AppArmor: AppArmor initialized
[Sat Nov 23 14:55:32 2024] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:32 2024] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:32 2024] smpboot: CPU0: 12th Gen Intel(R) Core(TM) i5-1240P (family: 0x6, model: 0x9a, stepping: 0x3)
[Sat Nov 23 14:55:32 2024] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline,  AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[Sat Nov 23 14:55:32 2024] core: cpu_core PMU driver:
[Sat Nov 23 14:55:32 2024] ... version:                5
[Sat Nov 23 14:55:32 2024] ... bit width:              48
[Sat Nov 23 14:55:32 2024] ... generic registers:      8
[Sat Nov 23 14:55:32 2024] ... value mask:             0000ffffffffffff
[Sat Nov 23 14:55:32 2024] ... max period:             00007fffffffffff
[Sat Nov 23 14:55:32 2024] ... fixed-purpose events:   4
[Sat Nov 23 14:55:32 2024] ... event mask:             0001000f000000ff
[Sat Nov 23 14:55:32 2024] signal: max sigframe size: 3632
[Sat Nov 23 14:55:32 2024] Estimated ratio of average max frequency by base frequency (times 1024): 1706
[Sat Nov 23 14:55:32 2024] rcu: Hierarchical SRCU implementation.
[Sat Nov 23 14:55:32 2024] rcu: 	Max phase no-delay instances is 1000.
[Sat Nov 23 14:55:32 2024] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[Sat Nov 23 14:55:32 2024] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[Sat Nov 23 14:55:32 2024] smp: Bringing up secondary CPUs ...
[Sat Nov 23 14:55:32 2024] smpboot: x86: Booting SMP configuration:
[Sat Nov 23 14:55:32 2024] .... node  #0, CPUs:        #2  #4  #6  #8  #9 #10 #11 #12 #13 #14 #15
[Sat Nov 23 14:55:32 2024] core: cpu_atom PMU driver: PEBS-via-PT
[Sat Nov 23 14:55:32 2024] ... generic registers:      6
[Sat Nov 23 14:55:32 2024] ... fixed-purpose events:   3
[Sat Nov 23 14:55:32 2024] ... event mask:             000000070000003f
[Sat Nov 23 14:55:32 2024]   #1  #3  #5  #7
[Sat Nov 23 14:55:32 2024] smp: Brought up 1 node, 16 CPUs
[Sat Nov 23 14:55:32 2024] smpboot: Total of 16 processors activated (67611.00 BogoMIPS)
[Sat Nov 23 14:55:32 2024] Memory: 15925924K/16392540K available (18432K kernel code, 2671K rwdata, 14312K rodata, 4264K init, 4032K bss, 439364K reserved, 0K cma-reserved)
[Sat Nov 23 14:55:32 2024] devtmpfs: initialized
[Sat Nov 23 14:55:32 2024] x86/mm: Memory block size: 128MB
[Sat Nov 23 14:55:32 2024] ACPI: PM: Registering ACPI NVS region [mem 0x40ac7000-0x40bcffff] (1085440 bytes)
[Sat Nov 23 14:55:32 2024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[Sat Nov 23 14:55:32 2024] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:32 2024] pinctrl core: initialized pinctrl subsystem
[Sat Nov 23 14:55:32 2024] PM: RTC time: 12:55:31, date: 2024-11-23
[Sat Nov 23 14:55:32 2024] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[Sat Nov 23 14:55:32 2024] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[Sat Nov 23 14:55:32 2024] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[Sat Nov 23 14:55:32 2024] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[Sat Nov 23 14:55:32 2024] thermal_sys: Registered thermal governor 'fair_share'
[Sat Nov 23 14:55:32 2024] thermal_sys: Registered thermal governor 'bang_bang'
[Sat Nov 23 14:55:32 2024] thermal_sys: Registered thermal governor 'step_wise'
[Sat Nov 23 14:55:32 2024] thermal_sys: Registered thermal governor 'user_space'
[Sat Nov 23 14:55:32 2024] thermal_sys: Registered thermal governor 'power_allocator'
[Sat Nov 23 14:55:32 2024] cpuidle: using governor ladder
[Sat Nov 23 14:55:32 2024] cpuidle: using governor menu
[Sat Nov 23 14:55:32 2024] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[Sat Nov 23 14:55:32 2024] PCI: ECAM [mem 0xc0000000-0xce0fffff] (base 0xc0000000) for domain 0000 [bus 00-e0]
[Sat Nov 23 14:55:32 2024] PCI: Using configuration type 1 for base access
[Sat Nov 23 14:55:32 2024] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[Sat Nov 23 14:55:32 2024] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[Sat Nov 23 14:55:32 2024] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[Sat Nov 23 14:55:32 2024] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[Sat Nov 23 14:55:32 2024] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[Sat Nov 23 14:55:32 2024] ACPI: Added _OSI(Module Device)
[Sat Nov 23 14:55:32 2024] ACPI: Added _OSI(Processor Device)
[Sat Nov 23 14:55:32 2024] ACPI: Added _OSI(3.0 _SCP Extensions)
[Sat Nov 23 14:55:32 2024] ACPI: Added _OSI(Processor Aggregator Device)
[Sat Nov 23 14:55:32 2024] ACPI: 16 ACPI AML tables successfully acquired and loaded
[Sat Nov 23 14:55:32 2024] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[Sat Nov 23 14:55:32 2024] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[Sat Nov 23 14:55:32 2024] ACPI: Dynamic OEM Table Load:
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418BDC00 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418CD000 000560 (v02 PmRef  Cpu0Ist  00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E42321400 0001AB (v02 PmRef  Cpu0Psd  00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418CF800 0004BA (v02 PmRef  Cpu0Hwp  00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418B0000 001BAF (v02 PmRef  ApIst    00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418B6000 001038 (v02 PmRef  ApHwp    00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E423E0000 001349 (v02 PmRef  ApPsd    00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: SSDT 0xFFFF921E418C3000 000FBB (v02 PmRef  ApCst    00003000 INTL 20200717)
[Sat Nov 23 14:55:32 2024] ACPI: EC: EC started
[Sat Nov 23 14:55:32 2024] ACPI: EC: interrupt blocked
[Sat Nov 23 14:55:32 2024] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.LPCB.H_EC: Boot DSDT EC used to handle transactions
[Sat Nov 23 14:55:32 2024] ACPI: Interpreter enabled
[Sat Nov 23 14:55:32 2024] ACPI: PM: (supports S0 S3 S4 S5)
[Sat Nov 23 14:55:32 2024] ACPI: Using IOAPIC for interrupt routing
[Sat Nov 23 14:55:32 2024] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[Sat Nov 23 14:55:32 2024] PCI: Using E820 reservations for host bridge windows
[Sat Nov 23 14:55:32 2024] ACPI: Enabled 7 GPEs in block 00 to 7F
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.PEG0.PXP_: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.RP06.PXP_: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.XHCI.RHUB.HS10.BTRT: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.PAUD: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.I2C0.PXTC: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.CNVW.WRST: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.VMD0.PEG0.NVPR: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.VMD0.VOL0.V0PR: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.VMD0.VOL1.V1PR: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.VMD0.VOL2.V2PR: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.VMD0.VOL3.V3PR: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.TBT0: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.TBT1: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_SB_.PC00.D3C_: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_TZ_.FN00: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_TZ_.FN01: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_TZ_.FN02: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_TZ_.FN03: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \_TZ_.FN04: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: \PIN_: New power resource
[Sat Nov 23 14:55:32 2024] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
[Sat Nov 23 14:55:32 2024] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[Sat Nov 23 14:55:32 2024] acpi PNP0A08:00: _OSC: platform does not support [AER]
[Sat Nov 23 14:55:32 2024] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[Sat Nov 23 14:55:32 2024] PCI host bridge to bus 0000:00
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [mem 0x4f800000-0xbfffffff window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[Sat Nov 23 14:55:32 2024] pci_bus 0000:00: root bus resource [bus 00-e0]
[Sat Nov 23 14:55:32 2024] pci 0000:00:00.0: [8086:4621] type 00 class 0x060000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: [8086:46a6] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: BAR 0 [mem 0x603e000000-0x603effffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: BAR 2 [mem 0x4000000000-0x400fffffff 64bit pref]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit]: contains BAR 0 for 7 VFs
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0x1fffffff 64bit pref]
[Sat Nov 23 14:55:32 2024] pci 0000:00:02.0: VF BAR 2 [mem 0x00000000-0xdfffffff 64bit pref]: contains BAR 2 for 7 VFs
[Sat Nov 23 14:55:32 2024] pci 0000:00:04.0: [8086:461d] type 00 class 0x118000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:04.0: BAR 0 [mem 0x603f280000-0x603f29ffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:06.0: [8086:09ab] type 00 class 0x088000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0: [8086:466e] type 01 class 0x060400 PCIe Root Port
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0: PCI bridge to [bus 01-2a]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0:   bridge window [mem 0x60000000-0x6c1fffff]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0:   bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0: Overriding RP PIO Log Size to 4
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.0: PTM enabled (root), 4ns granularity
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2: [8086:462f] type 01 class 0x060400 PCIe Root Port
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2: PCI bridge to [bus 2b-54]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2:   bridge window [mem 0x52000000-0x5e1fffff]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2:   bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2: Overriding RP PIO Log Size to 4
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2: PME# supported from D0 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:07.2: PTM enabled (root), 4ns granularity
[Sat Nov 23 14:55:32 2024] pci 0000:00:08.0: [8086:464f] type 00 class 0x088000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:08.0: BAR 0 [mem 0x603f2dd000-0x603f2ddfff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:0a.0: BAR 0 [mem 0x603f2c0000-0x603f2c7fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0a.0: enabling Extended Tags
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.0: [8086:461e] type 00 class 0x0c0330 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.0: BAR 0 [mem 0x603f2b0000-0x603f2bffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.2: [8086:463e] type 00 class 0x0c0340 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.2: BAR 0 [mem 0x603f240000-0x603f27ffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.2: BAR 2 [mem 0x603f2dc000-0x603f2dcfff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.2: supports D1 D2
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.3: [8086:466d] type 00 class 0x0c0340 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.3: BAR 0 [mem 0x603f200000-0x603f23ffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.3: BAR 2 [mem 0x603f2db000-0x603f2dbfff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.3: supports D1 D2
[Sat Nov 23 14:55:32 2024] pci 0000:00:0d.3: PME# supported from D0 D1 D2 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:0e.0: [8086:467f] type 00 class 0x010400 PCIe Root Complex Integrated Endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:0e.0: BAR 0 [mem 0x603c000000-0x603dffffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0e.0: BAR 2 [mem 0x50000000-0x51ffffff]
[Sat Nov 23 14:55:32 2024] pci 0000:00:0e.0: BAR 4 [mem 0x603f100000-0x603f1fffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.0: [8086:51ed] type 00 class 0x0c0330 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.0: BAR 0 [mem 0x603f2a0000-0x603f2affff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.0: PME# supported from D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.2: [8086:51ef] type 00 class 0x050000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.2: BAR 0 [mem 0x603f2d0000-0x603f2d3fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.2: BAR 2 [mem 0x603f2da000-0x603f2dafff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.3: [8086:51f0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.3: BAR 0 [mem 0x603f2cc000-0x603f2cffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:15.0: [8086:51e8] type 00 class 0x0c8000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:15.1: [8086:51e9] type 00 class 0x0c8000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:16.0: [8086:51e0] type 00 class 0x078000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:16.0: BAR 0 [mem 0x603f2d7000-0x603f2d7fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:16.0: PME# supported from D3hot
[Sat Nov 23 14:55:32 2024] pci 0000:00:1c.0: [8086:51bf] type 01 class 0x060400 PCIe Root Port
[Sat Nov 23 14:55:32 2024] pci 0000:00:1c.0: PCI bridge to [bus 55]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1c.0:   bridge window [mem 0x6c300000-0x6c3fffff]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[Sat Nov 23 14:55:32 2024] pci 0000:00:1e.0: [8086:51a8] type 00 class 0x078000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1e.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1e.2: [8086:51aa] type 00 class 0x0c8000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1e.2: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.0: [8086:5182] type 00 class 0x060100 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.3: [8086:51c8] type 00 class 0x040100 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.3: BAR 0 [mem 0x603f2c8000-0x603f2cbfff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.3: BAR 4 [mem 0x603f000000-0x603f0fffff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.4: [8086:51a3] type 00 class 0x0c0500 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.4: BAR 0 [mem 0x603f2d4000-0x603f2d40ff 64bit]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.5: [8086:51a4] type 00 class 0x0c8000 conventional PCI endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[Sat Nov 23 14:55:32 2024] pci 0000:55:00.0: [1217:8621] type 00 class 0x080501 PCIe Endpoint
[Sat Nov 23 14:55:32 2024] pci 0000:55:00.0: BAR 0 [mem 0x6c301000-0x6c301fff]
[Sat Nov 23 14:55:32 2024] pci 0000:55:00.0: BAR 1 [mem 0x6c300000-0x6c3007ff]
[Sat Nov 23 14:55:32 2024] pci 0000:55:00.0: PME# supported from D3hot D3cold
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[Sat Nov 23 14:55:32 2024] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[Sat Nov 23 14:55:33 2024] Low-power S0 idle used by default for system suspend
[Sat Nov 23 14:55:33 2024] ACPI: EC: interrupt unblocked
[Sat Nov 23 14:55:33 2024] ACPI: EC: event unblocked
[Sat Nov 23 14:55:33 2024] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[Sat Nov 23 14:55:33 2024] ACPI: EC: GPE=0x6e
[Sat Nov 23 14:55:33 2024] ACPI: \_SB_.PC00.LPCB.H_EC: Boot DSDT EC initialization complete
[Sat Nov 23 14:55:33 2024] ACPI: \_SB_.PC00.LPCB.H_EC: EC: Used to handle transactions and events
[Sat Nov 23 14:55:33 2024] iommu: Default domain type: Passthrough (set via kernel command line)
[Sat Nov 23 14:55:33 2024] SCSI subsystem initialized
[Sat Nov 23 14:55:33 2024] libata version 3.00 loaded.
[Sat Nov 23 14:55:33 2024] ACPI: bus type USB registered
[Sat Nov 23 14:55:33 2024] usbcore: registered new interface driver usbfs
[Sat Nov 23 14:55:33 2024] usbcore: registered new interface driver hub
[Sat Nov 23 14:55:33 2024] usbcore: registered new device driver usb
[Sat Nov 23 14:55:33 2024] EDAC MC: Ver: 3.0.0
[Sat Nov 23 14:55:33 2024] efivars: Registered efivars operations
[Sat Nov 23 14:55:33 2024] NetLabel: Initializing
[Sat Nov 23 14:55:33 2024] NetLabel:  domain hash size = 128
[Sat Nov 23 14:55:33 2024] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[Sat Nov 23 14:55:33 2024] NetLabel:  unlabeled traffic allowed by default
[Sat Nov 23 14:55:33 2024] mctp: management component transport protocol core
[Sat Nov 23 14:55:33 2024] NET: Registered PF_MCTP protocol family
[Sat Nov 23 14:55:33 2024] PCI: Using ACPI for IRQ routing
[Sat Nov 23 14:55:33 2024] PCI: pci_cache_line_size set to 64 bytes
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x2171b000-0x23ffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x282c1000-0x2bffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x2f468000-0x2fffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x2f9b4000-0x2fffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x380ba000-0x3bffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x41800000-0x43ffffff]
[Sat Nov 23 14:55:33 2024] e820: reserve RAM buffer [mem 0x4b0800000-0x4b3ffffff]
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: vgaarb: bridge control possible
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[Sat Nov 23 14:55:33 2024] vgaarb: loaded
[Sat Nov 23 14:55:33 2024] clocksource: Switched to clocksource tsc-early
[Sat Nov 23 14:55:33 2024] VFS: Disk quotas dquot_6.6.0
[Sat Nov 23 14:55:33 2024] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[Sat Nov 23 14:55:33 2024] AppArmor: AppArmor Filesystem Enabled
[Sat Nov 23 14:55:33 2024] pnp: PnP ACPI init
[Sat Nov 23 14:55:33 2024] system 00:00: [io  0x0680-0x069f] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:00: [io  0x164e-0x164f] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:01: [io  0x1854-0x1857] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:02: [io  0x06a4] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:02: [io  0x06a0] has been reserved
[Sat Nov 23 14:55:33 2024] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[Sat Nov 23 14:55:33 2024] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[Sat Nov 23 14:55:33 2024] system 00:05: [io  0x2000-0x20fe] has been reserved
[Sat Nov 23 14:55:33 2024] pnp: PnP ACPI: found 7 devices
[Sat Nov 23 14:55:33 2024] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[Sat Nov 23 14:55:33 2024] NET: Registered PF_INET protocol family
[Sat Nov 23 14:55:33 2024] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[Sat Nov 23 14:55:33 2024] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[Sat Nov 23 14:55:33 2024] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:33 2024] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[Sat Nov 23 14:55:33 2024] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[Sat Nov 23 14:55:33 2024] TCP: Hash tables configured (established 131072 bind 65536)
[Sat Nov 23 14:55:33 2024] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[Sat Nov 23 14:55:33 2024] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:33 2024] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[Sat Nov 23 14:55:33 2024] NET: Registered PF_UNIX/PF_LOCAL protocol family
[Sat Nov 23 14:55:33 2024] NET: Registered PF_XDP protocol family
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0: bridge window [io  0x1000-0x0fff] to [bus 01-2a] add_size 1000
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2: bridge window [io  0x1000-0x0fff] to [bus 2b-54] add_size 1000
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: VF BAR 2 [mem 0x4020000000-0x40ffffffff 64bit pref]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: VF BAR 0 [mem 0x4010000000-0x4016ffffff 64bit]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0: bridge window [io  0x4000-0x4fff]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2: bridge window [io  0x5000-0x5fff]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:15.0: BAR 0 [mem 0x4017000000-0x4017000fff 64bit]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:15.1: BAR 0 [mem 0x4017001000-0x4017001fff 64bit]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:1e.0: BAR 0 [mem 0x4017002000-0x4017002fff 64bit]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:1e.2: BAR 0 [mem 0x4017003000-0x4017003fff 64bit]: assigned
[Sat Nov 23 14:55:33 2024] resource: avoiding allocation from e820 entry [mem 0x000a0000-0x000fffff]
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.5: BAR 0 [mem 0x4f800000-0x4f800fff]: assigned
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0: PCI bridge to [bus 01-2a]
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0:   bridge window [mem 0x60000000-0x6c1fffff]
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0:   bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2: PCI bridge to [bus 2b-54]
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2:   bridge window [mem 0x52000000-0x5e1fffff]
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2:   bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[Sat Nov 23 14:55:33 2024] pci 0000:00:1c.0: PCI bridge to [bus 55]
[Sat Nov 23 14:55:33 2024] pci 0000:00:1c.0:   bridge window [mem 0x6c300000-0x6c3fffff]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 8 [mem 0x4f800000-0xbfffffff window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:01: resource 1 [mem 0x60000000-0x6c1fffff]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:01: resource 2 [mem 0x6020000000-0x603bffffff 64bit pref]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:2b: resource 0 [io  0x5000-0x5fff]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:2b: resource 1 [mem 0x52000000-0x5e1fffff]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:2b: resource 2 [mem 0x6000000000-0x601bffffff 64bit pref]
[Sat Nov 23 14:55:33 2024] pci_bus 0000:55: resource 1 [mem 0x6c300000-0x6c3fffff]
[Sat Nov 23 14:55:33 2024] PCI: CLS 64 bytes, default 64
[Sat Nov 23 14:55:33 2024] DMAR: No ATSR found
[Sat Nov 23 14:55:33 2024] DMAR: No SATC found
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature fl1gp_support inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature pgsel_inv inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature nwfs inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature dit inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature sc_support inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: IOMMU feature dev_iotlb_support inconsistent
[Sat Nov 23 14:55:33 2024] DMAR: dmar0: Using Queued invalidation
[Sat Nov 23 14:55:33 2024] DMAR: dmar1: Using Queued invalidation
[Sat Nov 23 14:55:33 2024] Trying to unpack rootfs image as initramfs...
[Sat Nov 23 14:55:33 2024] pci 0000:00:02.0: Adding to iommu group 0
[Sat Nov 23 14:55:33 2024] pci 0000:00:00.0: Adding to iommu group 1
[Sat Nov 23 14:55:33 2024] pci 0000:00:04.0: Adding to iommu group 2
[Sat Nov 23 14:55:33 2024] pci 0000:00:06.0: Adding to iommu group 3
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.0: Adding to iommu group 4
[Sat Nov 23 14:55:33 2024] pci 0000:00:07.2: Adding to iommu group 5
[Sat Nov 23 14:55:33 2024] pci 0000:00:08.0: Adding to iommu group 6
[Sat Nov 23 14:55:33 2024] pci 0000:00:0a.0: Adding to iommu group 7
[Sat Nov 23 14:55:33 2024] pci 0000:00:0d.0: Adding to iommu group 8
[Sat Nov 23 14:55:33 2024] pci 0000:00:0d.2: Adding to iommu group 8
[Sat Nov 23 14:55:33 2024] pci 0000:00:0d.3: Adding to iommu group 8
[Sat Nov 23 14:55:33 2024] pci 0000:00:0e.0: Adding to iommu group 9
[Sat Nov 23 14:55:33 2024] pci 0000:00:14.0: Adding to iommu group 10
[Sat Nov 23 14:55:33 2024] pci 0000:00:14.2: Adding to iommu group 10
[Sat Nov 23 14:55:33 2024] pci 0000:00:14.3: Adding to iommu group 11
[Sat Nov 23 14:55:33 2024] pci 0000:00:15.0: Adding to iommu group 12
[Sat Nov 23 14:55:33 2024] pci 0000:00:15.1: Adding to iommu group 12
[Sat Nov 23 14:55:33 2024] pci 0000:00:16.0: Adding to iommu group 13
[Sat Nov 23 14:55:33 2024] pci 0000:00:1c.0: Adding to iommu group 14
[Sat Nov 23 14:55:33 2024] pci 0000:00:1e.0: Adding to iommu group 15
[Sat Nov 23 14:55:33 2024] pci 0000:00:1e.2: Adding to iommu group 15
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.0: Adding to iommu group 16
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.3: Adding to iommu group 16
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.4: Adding to iommu group 16
[Sat Nov 23 14:55:33 2024] pci 0000:00:1f.5: Adding to iommu group 16
[Sat Nov 23 14:55:33 2024] pci 0000:55:00.0: Adding to iommu group 17
[Sat Nov 23 14:55:33 2024] DMAR: Intel(R) Virtualization Technology for Directed I/O
[Sat Nov 23 14:55:33 2024] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[Sat Nov 23 14:55:33 2024] software IO TLB: mapped [mem 0x0000000028959000-0x000000002c959000] (64MB)
[Sat Nov 23 14:55:33 2024] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1e71785e5dd, max_idle_ns: 440795244814 ns
[Sat Nov 23 14:55:33 2024] platform rtc_cmos: registered platform RTC device (no PNP device found)
[Sat Nov 23 14:55:33 2024] Initialise system trusted keyrings
[Sat Nov 23 14:55:33 2024] Key type blacklist registered
[Sat Nov 23 14:55:33 2024] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[Sat Nov 23 14:55:33 2024] fuse: init (API version 7.41)
[Sat Nov 23 14:55:33 2024] integrity: Platform Keyring initialized
[Sat Nov 23 14:55:33 2024] integrity: Machine keyring initialized
[Sat Nov 23 14:55:33 2024] Key type asymmetric registered
[Sat Nov 23 14:55:33 2024] Asymmetric key parser 'x509' registered
[Sat Nov 23 14:55:33 2024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[Sat Nov 23 14:55:33 2024] io scheduler mq-deadline registered
[Sat Nov 23 14:55:33 2024] io scheduler kyber registered
[Sat Nov 23 14:55:33 2024] io scheduler bfq registered
[Sat Nov 23 14:55:33 2024] ledtrig-cpu: registered to indicate activity on CPUs
[Sat Nov 23 14:55:33 2024] pcieport 0000:00:07.0: PME: Signaling with IRQ 122
[Sat Nov 23 14:55:33 2024] pcieport 0000:00:07.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[Sat Nov 23 14:55:33 2024] pcieport 0000:00:07.2: PME: Signaling with IRQ 123
[Sat Nov 23 14:55:33 2024] pcieport 0000:00:07.2: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[Sat Nov 23 14:55:33 2024] pcieport 0000:00:1c.0: PME: Signaling with IRQ 124
[Sat Nov 23 14:55:33 2024] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[Sat Nov 23 14:55:33 2024] ACPI: AC: AC Adapter [ADP1] (on-line)
[Sat Nov 23 14:55:33 2024] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/PNP0C09:00/PNP0C0D:00/input/input0
[Sat Nov 23 14:55:33 2024] ACPI: button: Lid Switch [LID0]
[Sat Nov 23 14:55:33 2024] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[Sat Nov 23 14:55:33 2024] ACPI: button: Power Button [PWRB]
[Sat Nov 23 14:55:33 2024] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[Sat Nov 23 14:55:33 2024] ACPI: button: Power Button [PWRF]
[Sat Nov 23 14:55:33 2024] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.HEC.CFSP], AE_NOT_FOUND (20240827/psargs-332)
[Sat Nov 23 14:55:33 2024] ACPI Error: Aborting method \_SB.PC00.LPCB.H_EC.TFN1._FST due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
[Sat Nov 23 14:55:33 2024] acpi INTC1048:00: Get fan state failed
[Sat Nov 23 14:55:33 2024] thermal LNXTHERM:00: registered as thermal_zone0
[Sat Nov 23 14:55:33 2024] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[Sat Nov 23 14:55:33 2024] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[Sat Nov 23 14:55:33 2024] ACPI: battery: Slot [BAT0] (battery present)
[Sat Nov 23 14:55:33 2024] hpet_acpi_add: no address or irqs in _CRS
[Sat Nov 23 14:55:33 2024] Non-volatile memory driver v1.3
[Sat Nov 23 14:55:33 2024] Linux agpgart interface v0.103
[Sat Nov 23 14:55:33 2024] tpm_tis MSFT0101:00: 2.0 TPM (device-id 0xFC, rev-id 1)
[Sat Nov 23 14:55:33 2024] Freeing initrd memory: 29140K
[Sat Nov 23 14:55:33 2024] ACPI: bus type drm_connector registered
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[Sat Nov 23 14:55:33 2024] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[Sat Nov 23 14:55:33 2024] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sat Nov 23 14:55:33 2024] usb usb1: Product: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] usb usb1: Manufacturer: Linux 6.12.0-1-MANJARO xhci-hcd
[Sat Nov 23 14:55:33 2024] usb usb1: SerialNumber: 0000:00:0d.0
[Sat Nov 23 14:55:33 2024] hub 1-0:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 1-0:1.0: 1 port detected
[Sat Nov 23 14:55:33 2024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[Sat Nov 23 14:55:33 2024] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sat Nov 23 14:55:33 2024] usb usb2: Product: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] usb usb2: Manufacturer: Linux 6.12.0-1-MANJARO xhci-hcd
[Sat Nov 23 14:55:33 2024] usb usb2: SerialNumber: 0000:00:0d.0
[Sat Nov 23 14:55:33 2024] hub 2-0:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 2-0:1.0: 4 ports detected
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[Sat Nov 23 14:55:33 2024] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[Sat Nov 23 14:55:33 2024] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[Sat Nov 23 14:55:33 2024] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sat Nov 23 14:55:33 2024] usb usb3: Product: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] usb usb3: Manufacturer: Linux 6.12.0-1-MANJARO xhci-hcd
[Sat Nov 23 14:55:33 2024] usb usb3: SerialNumber: 0000:00:14.0
[Sat Nov 23 14:55:33 2024] hub 3-0:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 3-0:1.0: 12 ports detected
[Sat Nov 23 14:55:33 2024] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[Sat Nov 23 14:55:33 2024] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sat Nov 23 14:55:33 2024] usb usb4: Product: xHCI Host Controller
[Sat Nov 23 14:55:33 2024] usb usb4: Manufacturer: Linux 6.12.0-1-MANJARO xhci-hcd
[Sat Nov 23 14:55:33 2024] usb usb4: SerialNumber: 0000:00:14.0
[Sat Nov 23 14:55:33 2024] hub 4-0:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 4-0:1.0: 4 ports detected
[Sat Nov 23 14:55:33 2024] usbcore: registered new interface driver usbserial_generic
[Sat Nov 23 14:55:33 2024] usbserial: USB Serial support registered for generic
[Sat Nov 23 14:55:33 2024] rtc_cmos rtc_cmos: RTC can wake from S4
[Sat Nov 23 14:55:33 2024] rtc_cmos rtc_cmos: registered as rtc0
[Sat Nov 23 14:55:33 2024] rtc_cmos rtc_cmos: setting system clock to 2024-11-23T12:55:33 UTC (1732366533)
[Sat Nov 23 14:55:33 2024] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[Sat Nov 23 14:55:33 2024] intel_pstate: Intel P-state driver initializing
[Sat Nov 23 14:55:33 2024] intel_pstate: HWP enabled
[Sat Nov 23 14:55:33 2024] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[Sat Nov 23 14:55:33 2024] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[Sat Nov 23 14:55:33 2024] fbcon: Deferring console take-over
[Sat Nov 23 14:55:33 2024] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[Sat Nov 23 14:55:33 2024] hid: raw HID events driver (C) Jiri Kosina
[Sat Nov 23 14:55:33 2024] drop_monitor: Initializing network drop monitor service
[Sat Nov 23 14:55:33 2024] NET: Registered PF_INET6 protocol family
[Sat Nov 23 14:55:33 2024] Segment Routing with IPv6
[Sat Nov 23 14:55:33 2024] RPL Segment Routing with IPv6
[Sat Nov 23 14:55:33 2024] In-situ OAM (IOAM) with IPv6
[Sat Nov 23 14:55:33 2024] NET: Registered PF_PACKET protocol family
[Sat Nov 23 14:55:33 2024] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[Sat Nov 23 14:55:33 2024] microcode: Current revision: 0x00000435
[Sat Nov 23 14:55:33 2024] microcode: Updated early from: 0x00000421
[Sat Nov 23 14:55:33 2024] IPI shorthand broadcast: enabled
[Sat Nov 23 14:55:33 2024] sched_clock: Marking stable (1473426710, 25843652)->(1538828880, -39558518)
[Sat Nov 23 14:55:33 2024] registered taskstats version 1
[Sat Nov 23 14:55:33 2024] Loading compiled-in X.509 certificates
[Sat Nov 23 14:55:33 2024] Loaded X.509 cert 'Build time autogenerated kernel key: a1dd28a8f44eaa6ab9b6729cb0cec074a826a878'
[Sat Nov 23 14:55:33 2024] Demotion targets for Node 0: null
[Sat Nov 23 14:55:33 2024] Key type .fscrypt registered
[Sat Nov 23 14:55:33 2024] Key type fscrypt-provisioning registered
[Sat Nov 23 14:55:33 2024] AppArmor: AppArmor sha256 policy hashing enabled
[Sat Nov 23 14:55:33 2024] integrity: Loading X.509 certificate: UEFI:db
[Sat Nov 23 14:55:33 2024] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[Sat Nov 23 14:55:33 2024] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[Sat Nov 23 14:55:33 2024] integrity: Loaded X.509 cert 'Huaqin NBD2 Software Certificate: 4672fbfc31a0ada6417c929fb7a3c1ba'
[Sat Nov 23 14:55:33 2024] PM:   Magic number: 0:922:936
[Sat Nov 23 14:55:33 2024] RAS: Correctable Errors collector initialized.
[Sat Nov 23 14:55:33 2024] clk: Disabling unused clocks
[Sat Nov 23 14:55:33 2024] PM: genpd: Disabling unused power domains
[Sat Nov 23 14:55:33 2024] Freeing unused decrypted memory: 2028K
[Sat Nov 23 14:55:33 2024] Freeing unused kernel image (initmem) memory: 4264K
[Sat Nov 23 14:55:33 2024] Write protecting the kernel read-only data: 32768k
[Sat Nov 23 14:55:33 2024] Freeing unused kernel image (rodata/data gap) memory: 24K
[Sat Nov 23 14:55:33 2024] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[Sat Nov 23 14:55:33 2024] rodata_test: all tests were successful
[Sat Nov 23 14:55:33 2024] Run /init as init process
[Sat Nov 23 14:55:33 2024]   with arguments:
[Sat Nov 23 14:55:33 2024]     /init
[Sat Nov 23 14:55:33 2024]   with environment:
[Sat Nov 23 14:55:33 2024]     HOME=/
[Sat Nov 23 14:55:33 2024]     TERM=linux
[Sat Nov 23 14:55:33 2024]     BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64
[Sat Nov 23 14:55:33 2024] usb 3-3: new high-speed USB device number 2 using xhci_hcd
[Sat Nov 23 14:55:33 2024] usb 3-3: New USB device found, idVendor=03f0, idProduct=036b, bcdDevice= 6.11
[Sat Nov 23 14:55:33 2024] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:33 2024] usb 3-3: Product: HP USB-C Dock G5
[Sat Nov 23 14:55:33 2024] usb 3-3: Manufacturer: Microchip
[Sat Nov 23 14:55:33 2024] Setting dangerous option mitigations - tainting kernel
[Sat Nov 23 14:55:33 2024] Setting dangerous option force_probe - tainting kernel
[Sat Nov 23 14:55:33 2024] i915 0000:00:02.0: I915 probe blocked for Device ID 46a6.
[Sat Nov 23 14:55:33 2024] hub 3-3:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 3-3:1.0: 5 ports detected
[Sat Nov 23 14:55:33 2024] vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
[Sat Nov 23 14:55:33 2024] pci_bus 10000:e0: root bus resource [bus e0-ff]
[Sat Nov 23 14:55:33 2024] pci_bus 10000:e0: root bus resource [mem 0x50000000-0x51ffffff]
[Sat Nov 23 14:55:33 2024] pci_bus 10000:e0: root bus resource [mem 0x603f102000-0x603f1fffff 64bit]
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: [8086:464d] type 01 class 0x060400 PCIe Root Port
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: PCI bridge to [bus e1]
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0:   bridge window [io  0x0000-0x0fff]
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0:   bridge window [mem 0x50000000-0x500fffff]
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: PME# supported from D0 D3hot D3cold
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: PTM enabled (root), 4ns granularity
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: Adding to iommu group 9
[Sat Nov 23 14:55:33 2024] pci 10000:e0:06.0: Primary bus is hard wired to 0
[Sat Nov 23 14:55:33 2024] pci 10000:e1:00.0: [1344:5407] type 00 class 0x010802 PCIe Endpoint
[Sat Nov 23 14:55:33 2024] pci 10000:e1:00.0: BAR 0 [mem 0x50000000-0x50003fff 64bit]
[Sat Nov 23 14:55:33 2024] pci 10000:e1:00.0: enabling Extended Tags
[Sat Nov 23 14:55:33 2024] pci 10000:e1:00.0: Adding to iommu group 9
[Sat Nov 23 14:55:33 2024] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[Sat Nov 23 14:55:33 2024] usb 2-3: New USB device found, idVendor=03f0, idProduct=066b, bcdDevice= 6.11
[Sat Nov 23 14:55:33 2024] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:33 2024] usb 2-3: Product: HP USB-C Dock G5
[Sat Nov 23 14:55:33 2024] usb 2-3: Manufacturer: Microchip
[Sat Nov 23 14:55:33 2024] hub 2-3:1.0: USB hub found
[Sat Nov 23 14:55:33 2024] hub 2-3:1.0: 4 ports detected
[Sat Nov 23 14:55:34 2024] usb 3-6: new full-speed USB device number 3 using xhci_hcd
[Sat Nov 23 14:55:34 2024] usb 3-6: New USB device found, idVendor=04f3, idProduct=0c6e, bcdDevice= 8.00
[Sat Nov 23 14:55:34 2024] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:34 2024] usb 3-6: Product: ELAN:Fingerprint
[Sat Nov 23 14:55:34 2024] usb 3-6: Manufacturer: ELAN
[Sat Nov 23 14:55:34 2024] usb 3-3.2: new high-speed USB device number 4 using xhci_hcd
[Sat Nov 23 14:55:34 2024] pci 10000:e0:06.0: bridge window [mem 0x50000000-0x500fffff]: assigned
[Sat Nov 23 14:55:34 2024] pci 10000:e0:06.0: bridge window [io  size 0x1000]: can't assign; no space
[Sat Nov 23 14:55:34 2024] pci 10000:e0:06.0: bridge window [io  size 0x1000]: failed to assign
[Sat Nov 23 14:55:34 2024] pci 10000:e1:00.0: BAR 0 [mem 0x50000000-0x50003fff 64bit]: assigned
[Sat Nov 23 14:55:34 2024] pci 10000:e0:06.0: PCI bridge to [bus e1]
[Sat Nov 23 14:55:34 2024] pci 10000:e1:00.0: VMD: Default LTR value set by driver
[Sat Nov 23 14:55:34 2024] pcieport 10000:e0:06.0: can't derive routing for PCI INT D
[Sat Nov 23 14:55:34 2024] pcieport 10000:e0:06.0: PCI INT D: no GSI
[Sat Nov 23 14:55:34 2024] pcieport 10000:e0:06.0: PME: Signaling with IRQ 160
[Sat Nov 23 14:55:34 2024] nvme nvme0: pci function 10000:e1:00.0
[Sat Nov 23 14:55:34 2024] pcieport 10000:e0:06.0: can't derive routing for PCI INT A
[Sat Nov 23 14:55:34 2024] nvme 10000:e1:00.0: PCI INT A: no GSI
[Sat Nov 23 14:55:34 2024] usb 2-3.3: new SuperSpeed USB device number 3 using xhci_hcd
[Sat Nov 23 14:55:34 2024] nvme nvme0: 16/0/0 default/read/poll queues
[Sat Nov 23 14:55:34 2024]  nvme0n1: p1 p2 p3
[Sat Nov 23 14:55:34 2024] vmd 0000:00:0e.0: Bound to PCI domain 10000
[Sat Nov 23 14:55:34 2024] usb 2-3.3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 2.03
[Sat Nov 23 14:55:34 2024] usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:34 2024] usb 2-3.3: Product: USB3.2 Hub
[Sat Nov 23 14:55:34 2024] usb 2-3.3: Manufacturer: Generic
[Sat Nov 23 14:55:34 2024] hub 2-3.3:1.0: USB hub found
[Sat Nov 23 14:55:34 2024] hub 2-3.3:1.0: 4 ports detected
[Sat Nov 23 14:55:34 2024] raid6: skipped pq benchmark and selected avx2x4
[Sat Nov 23 14:55:34 2024] raid6: using avx2x2 recovery algorithm
[Sat Nov 23 14:55:34 2024] xor: automatically using best checksumming function   avx
[Sat Nov 23 14:55:34 2024] usb 2-3.4: new SuperSpeed USB device number 4 using xhci_hcd
[Sat Nov 23 14:55:34 2024] usb 2-3.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.01
[Sat Nov 23 14:55:34 2024] usb 2-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[Sat Nov 23 14:55:34 2024] usb 2-3.4: Product: USB 10/100/1000 LAN
[Sat Nov 23 14:55:34 2024] usb 2-3.4: Manufacturer: Realtek
[Sat Nov 23 14:55:34 2024] usb 2-3.4: SerialNumber: 000001
[Sat Nov 23 14:55:34 2024] Btrfs loaded, zoned=yes, fsverity=yes
[Sat Nov 23 14:55:34 2024] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[Sat Nov 23 14:55:34 2024] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[Sat Nov 23 14:55:34 2024] serio: i8042 KBD port at 0x60,0x64 irq 1
[Sat Nov 23 14:55:34 2024] sdhci: Secure Digital Host Controller Interface driver
[Sat Nov 23 14:55:34 2024] sdhci: Copyright(c) Pierre Ossman
[Sat Nov 23 14:55:34 2024] sdhci-pci 0000:55:00.0: SDHCI controller found [1217:8621] (rev 1)
[Sat Nov 23 14:55:34 2024] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[Sat Nov 23 14:55:34 2024] mmc0: SDHCI controller on PCI [0000:55:00.0] using ADMA
[Sat Nov 23 14:55:34 2024] Setting dangerous option enable_dc - tainting kernel
[Sat Nov 23 14:55:34 2024] Setting dangerous option disable_power_well - tainting kernel
[Sat Nov 23 14:55:34 2024] Setting dangerous option enable_fbc - tainting kernel
[Sat Nov 23 14:55:34 2024] Setting dangerous option enable_psr - tainting kernel
[Sat Nov 23 14:55:34 2024] Setting dangerous option enable_dmc_wl - tainting kernel
[Sat Nov 23 14:55:34 2024] Setting dangerous option force_probe - tainting kernel
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: vgaarb: deactivate vga console
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] Support for SR-IOV is not available
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] Found ALDERLAKE_P (device ID 46a6) display version 13.00 stepping D0
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] Using GuC firmware from i915/adlp_guc_70.bin version 70.29.2
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] Using HuC firmware from i915/tgl_huc.bin version 7.9.3
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs1 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs3 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs4 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs5 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs6 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vcs7 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vecs1 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vecs2 fused off
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] vecs3 fused off
[Sat Nov 23 14:55:34 2024] [drm] Initialized xe 1.1.0 for 0000:00:02.0 on minor 0
[Sat Nov 23 14:55:34 2024] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[Sat Nov 23 14:55:34 2024] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[Sat Nov 23 14:55:34 2024] usb 3-3.2: New USB device found, idVendor=03f0, idProduct=056b, bcdDevice= 0.06
[Sat Nov 23 14:55:34 2024] usb 3-3.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[Sat Nov 23 14:55:34 2024] usb 3-3.2: Product: USB Audio
[Sat Nov 23 14:55:34 2024] usb 3-3.2: Manufacturer: Generic
[Sat Nov 23 14:55:34 2024] usb 3-3.2: SerialNumber: 201604140001
[Sat Nov 23 14:55:34 2024] fbcon: xedrmfb (fb0) is primary device
[Sat Nov 23 14:55:34 2024] fbcon: Deferring console take-over
[Sat Nov 23 14:55:34 2024] xe 0000:00:02.0: [drm] fb0: xedrmfb frame buffer device
[Sat Nov 23 14:55:34 2024] usb 3-8: new high-speed USB device number 5 using xhci_hcd
[Sat Nov 23 14:55:35 2024] usb 3-8: New USB device found, idVendor=3277, idProduct=0010, bcdDevice= 0.03
[Sat Nov 23 14:55:35 2024] usb 3-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[Sat Nov 23 14:55:35 2024] usb 3-8: Product: USB2.0 FHD UVC WebCam
[Sat Nov 23 14:55:35 2024] usb 3-8: Manufacturer: Sonix Technology Co., Ltd.
[Sat Nov 23 14:55:35 2024] usb 3-3.3: new high-speed USB device number 6 using xhci_hcd
[Sat Nov 23 14:55:35 2024] usb 3-3.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 2.03
[Sat Nov 23 14:55:35 2024] usb 3-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:35 2024] usb 3-3.3: Product: USB2.1 Hub
[Sat Nov 23 14:55:35 2024] usb 3-3.3: Manufacturer: Generic
[Sat Nov 23 14:55:35 2024] hub 3-3.3:1.0: USB hub found
[Sat Nov 23 14:55:35 2024] hub 3-3.3:1.0: 5 ports detected
[Sat Nov 23 14:55:35 2024] usb 3-10: new full-speed USB device number 7 using xhci_hcd
[Sat Nov 23 14:55:35 2024] usb 3-10: New USB device found, idVendor=8087, idProduct=0033, bcdDevice= 0.00
[Sat Nov 23 14:55:35 2024] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Sat Nov 23 14:55:35 2024] usb 3-3.5: new full-speed USB device number 8 using xhci_hcd
[Sat Nov 23 14:55:35 2024] usb 3-3.5: New USB device found, idVendor=03f0, idProduct=046b, bcdDevice= 0.00
[Sat Nov 23 14:55:35 2024] usb 3-3.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Sat Nov 23 14:55:35 2024] usb 3-3.5: Product: HP USB-C Dock G5
[Sat Nov 23 14:55:35 2024] usb 3-3.5: Manufacturer: HP
[Sat Nov 23 14:55:35 2024] usb 3-3.5: SerialNumber: 11AD1D0AD9AD7D0431180B00
[Sat Nov 23 14:55:35 2024] usbcore: registered new interface driver usbhid
[Sat Nov 23 14:55:35 2024] usbhid: USB HID core driver
[Sat Nov 23 14:55:35 2024] input: Generic USB Audio Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.2/3-3.2:1.3/0003:03F0:056B.0001/input/input5
[Sat Nov 23 14:55:35 2024] usb 3-3.3.1: new full-speed USB device number 9 using xhci_hcd
[Sat Nov 23 14:55:35 2024] input: Generic USB Audio as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.2/3-3.2:1.3/0003:03F0:056B.0001/input/input6
[Sat Nov 23 14:55:35 2024] hid-generic 0003:03F0:056B.0001: input,hiddev96,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-0000:00:14.0-3.2/input3
[Sat Nov 23 14:55:35 2024] input: HP HP USB-C Dock G5 System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.5/3-3.5:1.2/0003:03F0:046B.0002/input/input9
[Sat Nov 23 14:55:35 2024] hid-generic 0003:03F0:046B.0002: input,hiddev97,hidraw1: USB HID v1.11 Device [HP HP USB-C Dock G5] on usb-0000:00:14.0-3.5/input2
[Sat Nov 23 14:55:35 2024] usb 3-3.3.1: New USB device found, idVendor=04d9, idProduct=fc6d, bcdDevice= 1.00
[Sat Nov 23 14:55:35 2024] usb 3-3.3.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[Sat Nov 23 14:55:35 2024] usb 3-3.3.1: Product: USB Gaming Mouse
[Sat Nov 23 14:55:35 2024] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.0/0003:04D9:FC6D.0003/input/input10
[Sat Nov 23 14:55:35 2024] hid-generic 0003:04D9:FC6D.0003: input,hidraw2: USB HID v1.10 Mouse [USB Gaming Mouse] on usb-0000:00:14.0-3.3.1/input0
[Sat Nov 23 14:55:35 2024] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.1/0003:04D9:FC6D.0004/input/input11
[Sat Nov 23 14:55:35 2024] hid-generic 0003:04D9:FC6D.0004: input,hidraw3: USB HID v1.10 Keyboard [USB Gaming Mouse] on usb-0000:00:14.0-3.3.1/input1
[Sat Nov 23 14:55:35 2024] input: USB Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.2/0003:04D9:FC6D.0005/input/input12
[Sat Nov 23 14:55:36 2024] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1:1.2/0003:04D9:FC6D.0005/input/input13
[Sat Nov 23 14:55:36 2024] hid-generic 0003:04D9:FC6D.0005: input,hiddev98,hidraw4: USB HID v1.10 Device [USB Gaming Mouse] on usb-0000:00:14.0-3.3.1/input2
[Sat Nov 23 14:55:36 2024] usb 3-3.3.2: new full-speed USB device number 10 using xhci_hcd
[Sat Nov 23 14:55:36 2024] usb 3-3.3.2: New USB device found, idVendor=0c45, idProduct=672e, bcdDevice= 1.03
[Sat Nov 23 14:55:36 2024] usb 3-3.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:36 2024] usb 3-3.3.2: Product: USB DEVICE
[Sat Nov 23 14:55:36 2024] usb 3-3.3.2: Manufacturer: SONiX
[Sat Nov 23 14:55:36 2024] input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.2/3-3.3.2:1.0/0003:0C45:672E.0006/input/input14
[Sat Nov 23 14:55:36 2024] hid-generic 0003:0C45:672E.0006: input,hidraw5: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-3.3.2/input0
[Sat Nov 23 14:55:36 2024] input: SONiX USB DEVICE Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.2/3-3.3.2:1.1/0003:0C45:672E.0007/input/input15
[Sat Nov 23 14:55:36 2024] input: SONiX USB DEVICE Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.2/3-3.3.2:1.1/0003:0C45:672E.0007/input/input16
[Sat Nov 23 14:55:36 2024] input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.3/3-3.3.2/3-3.3.2:1.1/0003:0C45:672E.0007/input/input17
[Sat Nov 23 14:55:36 2024] hid-generic 0003:0C45:672E.0007: input,hiddev99,hidraw6: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-3.3.2/input1
[Sat Nov 23 14:55:36 2024] usb 3-3.3.5: new high-speed USB device number 11 using xhci_hcd
[Sat Nov 23 14:55:36 2024] usb 3-3.3.5: New USB device found, idVendor=0bda, idProduct=1100, bcdDevice= 1.01
[Sat Nov 23 14:55:36 2024] usb 3-3.3.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[Sat Nov 23 14:55:36 2024] usb 3-3.3.5: Product: HID Device
[Sat Nov 23 14:55:36 2024] usb 3-3.3.5: Manufacturer: Realtek
[Sat Nov 23 14:55:36 2024] hid-generic 0003:0BDA:1100.0008: hiddev100,hidraw7: USB HID v1.11 Device [Realtek HID Device] on usb-0000:00:14.0-3.3.5/input0
[Sat Nov 23 14:55:36 2024] PM: Image not found (code -22)
[Sat Nov 23 14:55:36 2024] BTRFS: device fsid a6552d15-6751-42f0-8709-cffd980026af devid 1 transid 219435 /dev/nvme0n1p2 (259:2) scanned by mount (364)
[Sat Nov 23 14:55:36 2024] BTRFS info (device nvme0n1p2): first mount of filesystem a6552d15-6751-42f0-8709-cffd980026af
[Sat Nov 23 14:55:36 2024] BTRFS info (device nvme0n1p2): using crc32c (crc32c-intel) checksum algorithm
[Sat Nov 23 14:55:36 2024] BTRFS info (device nvme0n1p2): using free-space-tree
[Sat Nov 23 14:55:36 2024] systemd[1]: systemd 256.8-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[Sat Nov 23 14:55:36 2024] systemd[1]: Detected architecture x86-64.
[Sat Nov 23 14:55:36 2024] systemd[1]: Hostname set to <memememe>.
[Sat Nov 23 14:55:37 2024] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[Sat Nov 23 14:55:37 2024] systemd-ssh-generator[412]: Binding SSH to AF_UNIX socket /run/ssh-unix-local/socket.
[Sat Nov 23 14:55:37 2024] systemd-ssh-generator[412]: → connect via 'ssh .host' locally
[Sat Nov 23 14:55:37 2024] systemd[1]: Queued start job for default target Graphical Interface.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Virtual Machine and Container Slice.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice CUPS Slice.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/dirmngr.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/getty.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/gpg-agent.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/keyboxd.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/modprobe.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice Slice /system/systemd-fsck.
[Sat Nov 23 14:55:37 2024] systemd[1]: Created slice User and Session Slice.
[Sat Nov 23 14:55:37 2024] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[Sat Nov 23 14:55:37 2024] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[Sat Nov 23 14:55:37 2024] systemd[1]: Expecting device /dev/disk/by-uuid/3fc45252-2d9c-4a78-9d95-0a39a5458d90...
[Sat Nov 23 14:55:37 2024] systemd[1]: Expecting device /dev/disk/by-uuid/86D0-5890...
[Sat Nov 23 14:55:37 2024] systemd[1]: Expecting device /dev/disk/by-uuid/a6552d15-6751-42f0-8709-cffd980026af...
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Login Prompts.
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Local Integrity Protected Volumes.
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Remote File Systems.
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Slice Units.
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Local Verity Protected Volumes.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on LVM2 poll daemon socket.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on Process Core Dump Socket.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on Credential Encryption/Decryption.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on Journal Socket (/dev/log).
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on Journal Sockets.
[Sat Nov 23 14:55:37 2024] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[Sat Nov 23 14:55:37 2024] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on udev Control Socket.
[Sat Nov 23 14:55:37 2024] systemd[1]: Listening on udev Kernel Socket.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting Huge Pages File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting POSIX Message Queue File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting Kernel Debug File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting Kernel Trace File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Create List of Static Device Nodes...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Module configfs...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Module dm_mod...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Module drm...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Module fuse...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Module loop...
[Sat Nov 23 14:55:37 2024] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load Kernel Modules...
[Sat Nov 23 14:55:37 2024] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Remount Root and Kernel File Systems...
[Sat Nov 23 14:55:37 2024] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load udev Rules from Credentials...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Coldplug All udev Devices...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Virtual Console Setup...
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted Huge Pages File System.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted POSIX Message Queue File System.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted Kernel Debug File System.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted Kernel Trace File System.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Create List of Static Device Nodes.
[Sat Nov 23 14:55:37 2024] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Module configfs.
[Sat Nov 23 14:55:37 2024] systemd[1]: modprobe@drm.service: Deactivated successfully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Module drm.
[Sat Nov 23 14:55:37 2024] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Module fuse.
[Sat Nov 23 14:55:37 2024] loop: module loaded
[Sat Nov 23 14:55:37 2024] device-mapper: uevent: version 1.0.3
[Sat Nov 23 14:55:37 2024] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting FUSE Control File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounting Kernel Configuration File System...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[Sat Nov 23 14:55:37 2024] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Module dm_mod.
[Sat Nov 23 14:55:37 2024] systemd[1]: modprobe@loop.service: Deactivated successfully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Module loop.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load udev Rules from Credentials.
[Sat Nov 23 14:55:37 2024] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted FUSE Control File System.
[Sat Nov 23 14:55:37 2024] systemd[1]: Mounted Kernel Configuration File System.
[Sat Nov 23 14:55:37 2024] i2c_dev: i2c /dev entries driver
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Virtual Console Setup.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Remount Root and Kernel File Systems.
[Sat Nov 23 14:55:37 2024] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Load/Save OS Random Seed...
[Sat Nov 23 14:55:37 2024] vboxdrv: loading out-of-tree module taints kernel.
[Sat Nov 23 14:55:37 2024] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Create System Users...
[Sat Nov 23 14:55:37 2024] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[Sat Nov 23 14:55:37 2024] vboxdrv: Found 16 processor cores/threads
[Sat Nov 23 14:55:37 2024] vboxdrv: TSC mode is Invariant, tentative frequency 2111999894 Hz
[Sat Nov 23 14:55:37 2024] vboxdrv: Successfully loaded version 7.1.4 r165100 (interface 0x00340001)
[Sat Nov 23 14:55:37 2024] VBoxNetAdp: Successfully started.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Coldplug All udev Devices.
[Sat Nov 23 14:55:37 2024] VBoxNetFlt: Successfully started.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load/Save OS Random Seed.
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Load Kernel Modules.
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Apply Kernel Variables...
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Create System Users.
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Create Static Device Nodes in /dev...
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Apply Kernel Variables.
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting CLI Netfilter Manager...
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished Create Static Device Nodes in /dev.
[Sat Nov 23 14:55:37 2024] systemd[1]: Reached target Preparation for Local File Systems.
[Sat Nov 23 14:55:37 2024] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Journal Service...
[Sat Nov 23 14:55:37 2024] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[Sat Nov 23 14:55:37 2024] systemd[1]: Finished CLI Netfilter Manager.
[Sat Nov 23 14:55:37 2024] systemd-journald[463]: Collecting audit messages is disabled.
[Sat Nov 23 14:55:37 2024] systemd[1]: Started Journal Service.
[Sat Nov 23 14:55:37 2024] input: Intel HID events as /devices/platform/INTC1070:00/input/input18
[Sat Nov 23 14:55:37 2024] intel-hid INTC1070:00: platform supports 5 button array
[Sat Nov 23 14:55:37 2024] Consider using thermal netlink events interface
[Sat Nov 23 14:55:37 2024] input: Intel HID 5 button array as /devices/platform/INTC1070:00/input/input19
[Sat Nov 23 14:55:37 2024] intel_pmc_core INT33A1:00:  initialized
[Sat Nov 23 14:55:37 2024] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
[Sat Nov 23 14:55:37 2024] caller igen6_probe+0x15e/0x7c0 [igen6_edac] mapping multiple BARs
[Sat Nov 23 14:55:37 2024] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[Sat Nov 23 14:55:37 2024] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[Sat Nov 23 14:55:37 2024] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[Sat Nov 23 14:55:37 2024] EDAC igen6 MC0: ADDR 0x7fffffffe0
[Sat Nov 23 14:55:37 2024] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[Sat Nov 23 14:55:37 2024] EDAC igen6 MC1: ADDR 0x7fffffffe0
[Sat Nov 23 14:55:37 2024] EDAC igen6: v2.5.1
[Sat Nov 23 14:55:37 2024] mc: Linux media interface: v0.10
[Sat Nov 23 14:55:37 2024] input: PC Speaker as /devices/platform/pcspkr/input/input20
[Sat Nov 23 14:55:37 2024] ACPI: bus type thunderbolt registered
[Sat Nov 23 14:55:37 2024] mousedev: PS/2 mouse device common for all mice
[Sat Nov 23 14:55:37 2024] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[Sat Nov 23 14:55:37 2024] i801_smbus 0000:00:1f.4: enabling device (0001 -> 0003)
[Sat Nov 23 14:55:37 2024] Adding 9227464k swap on /dev/nvme0n1p3.  Priority:-2 extents:1 across:9227464k SS
[Sat Nov 23 14:55:37 2024] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[Sat Nov 23 14:55:37 2024] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[Sat Nov 23 14:55:37 2024] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[Sat Nov 23 14:55:37 2024] idma64 idma64.0: Found Intel integrated DMA 64-bit
[Sat Nov 23 14:55:37 2024] videodev: Linux video capture interface: v2.00
[Sat Nov 23 14:55:37 2024] Creating 1 MTD partitions on "0000:00:1f.5":
[Sat Nov 23 14:55:37 2024] 0x000000000000-0x000002000000 : "BIOS"
[Sat Nov 23 14:55:37 2024] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[Sat Nov 23 14:55:37 2024] idma64 idma64.1: Found Intel integrated DMA 64-bit
[Sat Nov 23 14:55:37 2024] Bluetooth: Core ver 2.22
[Sat Nov 23 14:55:37 2024] NET: Registered PF_BLUETOOTH protocol family
[Sat Nov 23 14:55:37 2024] Bluetooth: HCI device and connection manager initialized
[Sat Nov 23 14:55:37 2024] Bluetooth: HCI socket layer initialized
[Sat Nov 23 14:55:37 2024] Bluetooth: L2CAP socket layer initialized
[Sat Nov 23 14:55:37 2024] Bluetooth: SCO socket layer initialized
[Sat Nov 23 14:55:37 2024] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[Sat Nov 23 14:55:37 2024] idma64 idma64.2: Found Intel integrated DMA 64-bit
[Sat Nov 23 14:55:37 2024] intel-lpss 0000:00:1e.2: enabling device (0004 -> 0006)
[Sat Nov 23 14:55:37 2024] idma64 idma64.3: Found Intel integrated DMA 64-bit
[Sat Nov 23 14:55:37 2024] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[Sat Nov 23 14:55:37 2024] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[Sat Nov 23 14:55:37 2024] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[Sat Nov 23 14:55:37 2024] intel_rapl_msr: PL4 support detected.
[Sat Nov 23 14:55:37 2024] intel_rapl_common: Found RAPL domain package
[Sat Nov 23 14:55:37 2024] intel_rapl_common: Found RAPL domain core
[Sat Nov 23 14:55:37 2024] intel_rapl_common: Found RAPL domain uncore
[Sat Nov 23 14:55:37 2024] intel_rapl_common: Found RAPL domain psys
[Sat Nov 23 14:55:37 2024] input: ASUE140D:00 04F3:31B9 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input21
[Sat Nov 23 14:55:37 2024] input: ASUE140D:00 04F3:31B9 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input22
[Sat Nov 23 14:55:37 2024] input: ASUE140D:00 04F3:31B9 Keyboard as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input23
[Sat Nov 23 14:55:38 2024] hid-generic 0018:04F3:31B9.0009: input,hidraw8: I2C HID v1.00 Mouse [ASUE140D:00 04F3:31B9] on i2c-ASUE140D:00
[Sat Nov 23 14:55:38 2024] iTCO_vendor_support: vendor-support=0
[Sat Nov 23 14:55:38 2024] asus_wmi: ASUS WMI generic driver loaded
[Sat Nov 23 14:55:38 2024] usbcore: registered new device driver r8152-cfgselector
[Sat Nov 23 14:55:38 2024] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [xe])
[Sat Nov 23 14:55:38 2024] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[Sat Nov 23 14:55:38 2024] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[Sat Nov 23 14:55:38 2024] RAPL PMU: hw unit of domain package 2^-14 Joules
[Sat Nov 23 14:55:38 2024] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[Sat Nov 23 14:55:38 2024] RAPL PMU: hw unit of domain psys 2^-14 Joules
[Sat Nov 23 14:55:38 2024] dw-apb-uart.2: ttyS4 at MMIO 0x4017002000 (irq = 16, base_baud = 6250000) is a 16550A
[Sat Nov 23 14:55:38 2024] Using default CPU limits. Please report if these are not correct.
[Sat Nov 23 14:55:38 2024] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[Sat Nov 23 14:55:38 2024] Intel(R) Wireless WiFi driver for Linux
[Sat Nov 23 14:55:38 2024] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[Sat Nov 23 14:55:38 2024] proc_thermal_pci 0000:00:04.0: enabling device (0000 -> 0002)
[Sat Nov 23 14:55:38 2024] cryptd: max_cpu_qlen set to 1000
[Sat Nov 23 14:55:38 2024] intel_rapl_common: Found RAPL domain package
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x80400 wfpm id 0x80000020
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: PCI dev 51f0/0094, rev=0x370, rfid=0x2010d000
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: loaded firmware version 89.6b44fa0b.0 so-a0-gf-a0-89.ucode op_mode iwlmvm
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver btusb
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Device revision is 0
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Secure boot is enabled
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: OTP lock is enabled
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: API lock is enabled
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Debug lock is disabled
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: DSM reset method type: 0x00
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Boot Address: 0x100800
[Sat Nov 23 14:55:38 2024] Bluetooth: hci0: Firmware Version: 91-33.24
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Adding DSD properties for 10431E02
[Sat Nov 23 14:55:38 2024] pps_core: LinuxPPS API ver. 1 registered
[Sat Nov 23 14:55:38 2024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Using extra _DSD properties, bypassing _DSD in ACPI
[Sat Nov 23 14:55:38 2024] AES CTR mode by8 optimization enabled
[Sat Nov 23 14:55:38 2024] PTP clock support registered
[Sat Nov 23 14:55:38 2024] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[Sat Nov 23 14:55:38 2024] usb 3-8: Found UVC 1.00 device USB2.0 FHD UVC WebCam (3277:0010)
[Sat Nov 23 14:55:38 2024] asus_wmi: Initialization: 0x1
[Sat Nov 23 14:55:38 2024] asus_wmi: SFUN value: 0x21
[Sat Nov 23 14:55:38 2024] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[Sat Nov 23 14:55:38 2024] r8152-cfgselector 2-3.4: reset SuperSpeed USB device number 4 using xhci_hcd
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Cirrus Logic CS35L41 (35a40), Revision: B2
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Adding DSD properties for 10431E02
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Using extra _DSD properties, bypassing _DSD in ACPI
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Reset line busy, assuming shared reset
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Cirrus Logic CS35L41 (35a40), Revision: B2
[Sat Nov 23 14:55:38 2024] Serial bus multi instantiate pseudo device driver CSC3551:00: Instantiated 2 SPI devices.
[Sat Nov 23 14:55:38 2024] asus_wmi: Failed to set throttle thermal policy (retval): 0x0
[Sat Nov 23 14:55:38 2024] asus_wmi: Failed to set default thermal profile
[Sat Nov 23 14:55:38 2024] asus-nb-wmi asus-nb-wmi: probe with driver asus-nb-wmi failed with error -5
[Sat Nov 23 14:55:38 2024] r8152 2-3.4:1.0 eth0: v1.12.13
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver r8152
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver cdc_ether
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver r8153_ecm
[Sat Nov 23 14:55:38 2024] intel_tcc_cooling: TCC Offset locked
[Sat Nov 23 14:55:38 2024] fbcon: Taking over console
[Sat Nov 23 14:55:38 2024] Console: switching to colour frame buffer device 180x56
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [xe])
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: loaded PNVM version 16611aa6
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3: base HW address: 10:a5:1d:96:ee:6b
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: NHLT device BT(0) detected, ssp_mask 0x4
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: BT link detected in NHLT tables: 0x4
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware paths/files for ipc type 0:
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3:  Firmware file:     intel/sof/sof-adl.ri
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3:  Topology file:     intel/sof-tplg/sof-hda-generic-2ch.tplg
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:1
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver uvcvideo
[Sat Nov 23 14:55:38 2024] usbcore: registered new interface driver snd-usb-audio
[Sat Nov 23 14:55:38 2024] systemd-journald[463]: Received client request to flush runtime journal.
[Sat Nov 23 14:55:38 2024] r8152 2-3.4:1.0 enp0s13f0u3u4: renamed from eth0
[Sat Nov 23 14:55:38 2024] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:1
[Sat Nov 23 14:55:38 2024] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[Sat Nov 23 14:55:38 2024] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02.wmfw: format 3 timestamp 0x6128e16b
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe Daylight Time
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02-spkid0-l0.bin: v0.43.1
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: DSP1: spk-prot: C:\Users\tyang\Desktop\Product Setting\SmartAMP\ASUS\ASUS_Zenbook\UX3402\Tuning Release\220304\ASUS_
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Firmware Loaded - Type: spk-prot, Gain: 17
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: CS35L41 Bound - SSID: 10431E02, BST: 1, VSPK: 1, CH: L, FW EN: 1, SPKID: 0
[Sat Nov 23 14:55:38 2024] snd_hda_codec_realtek ehdaudio0D0: bound spi1-CSC3551:00-cs35l41-hda.0 (ops cs35l41_hda_comp_ops [snd_hda_scodec_cs35l41])
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02.wmfw: format 3 timestamp 0x6128e16b
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe Daylight Time
[Sat Nov 23 14:55:38 2024] input: ASUE140D:00 04F3:31B9 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input24
[Sat Nov 23 14:55:38 2024] input: ASUE140D:00 04F3:31B9 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input25
[Sat Nov 23 14:55:38 2024] input: ASUE140D:00 04F3:31B9 Keyboard as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-18/i2c-ASUE140D:00/0018:04F3:31B9.0009/input/input26
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-10431e02-spkid0-r0.bin: v0.43.1
[Sat Nov 23 14:55:38 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: DSP1: spk-prot: C:\Users\tyang\Desktop\Product Setting\SmartAMP\ASUS\ASUS_Zenbook\UX3402\Tuning Release\220304\ASUS_
[Sat Nov 23 14:55:39 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Firmware Loaded - Type: spk-prot, Gain: 17
[Sat Nov 23 14:55:39 2024] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: CS35L41 Bound - SSID: 10431E02, BST: 1, VSPK: 1, CH: R, FW EN: 1, SPKID: 0
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0: bound spi1-CSC3551:00-cs35l41-hda.1 (ops cs35l41_hda_comp_ops [snd_hda_scodec_cs35l41])
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0:    mono: mono_out=0x0
[Sat Nov 23 14:55:39 2024] snd_hda_codec_realtek ehdaudio0D0:    inputs:
[Sat Nov 23 14:55:39 2024] hid-multitouch 0018:04F3:31B9.0009: input,hidraw8: I2C HID v1.00 Mouse [ASUE140D:00 04F3:31B9] on i2c-ASUE140D:00
[Sat Nov 23 14:55:39 2024] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[Sat Nov 23 14:55:39 2024] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input27
[Sat Nov 23 14:55:39 2024] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input28
[Sat Nov 23 14:55:39 2024] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input29
[Sat Nov 23 14:55:39 2024] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input30
[Sat Nov 23 14:55:39 2024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Sat Nov 23 14:55:39 2024] Bluetooth: BNEP filters: protocol multicast
[Sat Nov 23 14:55:39 2024] Bluetooth: BNEP socket layer initialized
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Waiting for firmware download to complete
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Firmware loaded in 1504526 usecs
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Waiting for device to boot
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Device booted in 15715 usecs
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-0041.ddc
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Applying Intel DDC parameters completed
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Firmware timestamp 2024.33 buildtype 1 build 81755
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Firmware SHA1: 0xd028ffe4
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Fseq status: Success (0x00)
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Fseq executed: 00.00.02.41
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[Sat Nov 23 14:55:39 2024] Bluetooth: MGMT ver 1.23
[Sat Nov 23 14:55:39 2024] NET: Registered PF_QIPCRTR protocol family
[Sat Nov 23 14:55:39 2024] NET: Registered PF_ALG protocol family
[Sat Nov 23 14:55:39 2024] Bluetooth: hci0: No such LE device 28:6f:40:42:e8:06 (0x0)
[Sat Nov 23 14:55:39 2024] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[Sat Nov 23 14:55:39 2024] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[Sat Nov 23 14:55:39 2024] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[Sat Nov 23 14:55:39 2024] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[Sat Nov 23 14:55:39 2024] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[Sat Nov 23 14:55:40 2024] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[Sat Nov 23 14:55:40 2024] fs-verity: sha256 using implementation "sha256-ni"
[Sat Nov 23 14:55:40 2024] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[Sat Nov 23 14:55:42 2024] ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
[Sat Nov 23 14:55:44 2024] wlo1: authenticate with 28:d1:27:4e:71:53 (local address=10:a5:1d:96:ee:6b)
[Sat Nov 23 14:55:44 2024] wlo1: send auth to 28:d1:27:4e:71:53 (try 1/3)
[Sat Nov 23 14:55:44 2024] wlo1: authenticated
[Sat Nov 23 14:55:44 2024] wlo1: associate with 28:d1:27:4e:71:53 (try 1/3)
[Sat Nov 23 14:55:44 2024] wlo1: RX AssocResp from 28:d1:27:4e:71:53 (capab=0x111 status=0 aid=2)
[Sat Nov 23 14:55:44 2024] wlo1: associated
[Sat Nov 23 14:55:44 2024] wlo1: Limiting TX power to 27 (30 - 3) dBm as advertised by 28:d1:27:4e:71:53
[Sat Nov 23 14:55:44 2024] rfkill: input handler disabled
[Sat Nov 23 14:55:46 2024] Initializing XFRM netlink socket
[Sat Nov 23 14:55:48 2024] Bluetooth: RFCOMM TTY layer initialized
[Sat Nov 23 14:55:48 2024] Bluetooth: RFCOMM socket layer initialized
[Sat Nov 23 14:55:48 2024] Bluetooth: RFCOMM ver 1.11
[Sat Nov 23 14:55:56 2024] rfkill: input handler enabled
[Sat Nov 23 14:55:58 2024] rfkill: input handler disabled
[Sat Nov 23 14:55:58 2024] block nvme0n1: No UUID available providing old NGUID
[Sat Nov 23 14:56:02 2024] warning: `gnome-shell' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Are you on Testing or Unstable branch? Your user profile says Testing, but kernel 6.12.1 hasn’t reached Testing, which currently has 6.12.0-1 in the repos:
mbn info linux612 -q
Branch         : unstable
Version        : 6.12.1-2
Repository     : core
Build Date     : Sat 23 Nov 2024 20:21:40
Packager       : Manjaro Build Server <build@manjaro.org>
Branch         : testing
Version        : 6.12.0-1
Repository     : core
Build Date     : Mon 18 Nov 2024 13:08:48
Branch         : stable
Version        : 6.12.0rc2-2
Repository     : core
Build Date     : Tue 08 Oct 2024 22:09:33
If you have moved to Unstable branch, could you please update your profile via Forum Profile Preferences?
Yep asus_wmi is buggy on 6.12 I saw this as well on 6.11:
[    8.346994] asus_wmi: failed to register LPS0 sleep handler in asus-wmi
I may think the kernel developers will fix this as they do for other boards they don´t use asus_wmi
Please check with https://asus-linux.org/ community. They also maintain their own kernel sources here: Activity · asus-linux / asus-linux patchwork · GitLab
Seems there were no changes made to the asus-nb-wmi in 6.12 cycle: History for drivers/platform/x86/asus-nb-wmi.c - torvalds/linux · GitHub
Found this
Currently looking into this bug. Most likely [pkg-upd] 6.12.1-3 (107eeb66) · Commits · Packages / core / linux612 · GitLab will fix it. You can download it from here when the CI finished to produce the packages: Releases · manjaro-kernels/linux612 · GitHub
loaded the latest 6.13.0rc0-1 works great glad you found the fix so fast
Thanks :slight_smile:
