Hello,
I’m using a ASUS Vivobook K3500P. I instsalled i3 full version on it. Everything works just fine. However, when I close my lid, the wifi can not seem to reconnect. It seems as if NetworkManager is unavailable. When I run
systemctl status NetworkManager
It shows me an active running proccess. But the laptop itself cannot connect to wifi. If I try to restsrt NetworkManager, the system freezes, or the terminal freezes. If I try to start nmtui
, the terminal freezes. I tried using gnome-control-center
, but after the closed lit, it can’t find the wifi.
Has anyone experienced similiar issues?
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0bc2a3ac-5895-4aa2-95c5-df6b878d82c0 rw quiet
cryptdevice=UUID=849b94ba-eb49-4fcf-8d5c-407fd07a8915:luks-849b94ba-eb49-4fcf-8d5c-407fd07a8915
root=/dev/mapper/luks-849b94ba-eb49-4fcf-8d5c-407fd07a8915 apparmor=1
security=apparmor
resume=/dev/mapper/luks-9a399da5-3bf2-4b12-9387-a994bccb04d6
udev.log_priority=3
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X3500PH_K3500PH
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X3500PH v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X3500PH.206 date: 09/13/2021
ID-1: BAT0 charge: 11.7 Wh (18.3%) condition: 64.1/63.0 Wh (101.7%)
volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 2
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 732 high: 1128 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 509 2: 1128 3: 948 4: 926
5: 767 6: 559 7: 511 8: 514 bogomips: 52856
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 bus-ID: 0000:01:00.0 chip-ID: 10de:1f9d class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel bus-ID: 0000:2e:00.0
chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 16.1 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 33.9 C scheme: GPT
ID-1: / raw-size: 459.79 GiB size: 451.5 GiB (98.20%) used: 16.09 GiB (3.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-849b94ba-eb49-4fcf-8d5c-407fd07a8915
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-9a399da5-3bf2-4b12-9387-a994bccb04d6
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 264 Uptime: 1h 15m wakeups: 7065 Memory: 15.31 GiB
used: 2.66 GiB (17.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1098
lib: 299 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.19
try a different kernel, for example the 5.18 and see if it happens with it too
That is perfectly normal. By default it suspend on lid close and everything goes sleeping. You can change this behavior at
- /etc/systemd/logind.conf
- /etc/systemd/sleep.conf
