Hi I have recently installed and using Manjaro with DE XFCE.4.16 on my ASUS TUF Gaming FX705DT laptop. I do not have windows installed on this laptop, and only using Manjaro as my primary OS. After installing Manjaro I noticed my back-lit keyboard’s RGB backlight is not working. Need help on this issue.
I am fairly new to linux so any help and guidance will be much appreciated.
Below are few details about my system:
bios version I am using is 316, which is the latest one as per asus support page.
hwinfo --short
cpu:
AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx, 1875 MHz
keyboard:
/dev/input/event4 AT Translated Set 2 keyboard
mouse:
/dev/input/mice [Maxxter] Optical Gaming Mouse [Xtrem]
monitor:
NV173FHM-N49 LCD Monitor
graphics card:
nVidia TU117M [GeForce GTX 1650 Mobile / Max-Q]
ATI Picasso
usb controller:
AMD Raven USB 3.1
AMD Raven USB 3.1
bios:
BIOS
bridge:
AMD Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
AMD Raven/Raven2 Device 24: Function 3
AMD Raven/Raven2 PCIe GPP Bridge [6:0]
AMD Raven/Raven2 Device 24: Function 1
AMD FCH LPC Bridge
AMD Raven/Raven2 Device 24: Function 6
AMD Raven/Raven2 Root Complex
AMD Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
AMD Raven/Raven2 Device 24: Function 4
AMD Raven/Raven2 Device 24: Function 2
AMD Raven/Raven2 Device 24: Function 0
AMD Raven/Raven2 Device 24: Function 7
AMD Raven/Raven2 Device 24: Function 5
hub:
Linux Foundation 2.0 root hub
Linux Foundation 3.0 root hub
memory:
Main Memory
bluetooth:
IMC Networks Bluetooth Radio
unknown:
FPU
DMA controller
PIC
Keyboard controller
AMD Raven/Raven2 IOMMU
AMD Family 17h (Models 10h-1fh) Platform Security Processor
AMD FCH SMBus Controller
sudo dmesg | grep asus
[ 9.668939] asus_wmi: ASUS WMI generic driver loaded
[ 9.674948] asus_wmi: Initialization: 0x1
[ 9.675112] asus_wmi: BIOS WMI version: 8.1
[ 9.675280] asus_wmi: SFUN value: 0x4a0061
[ 9.675290] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 9.675294] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 9.848999] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input14
sudo systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-backlight@backlight:acpi_video0.service loaded failed failed Load/Save Screen Backlight Brightness of backlight:acpi_video0
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
Thanks in advance!
