Hi folks,
I got gifted this asus that is one of the 2 in 1 laptops and since it was awful out of the box with W10 I managed to install manjaro on it. Heard online that the Gnome version was the one with best touch support so I went with it.
Back to the matter… Touchscreen on Manjaro gnome version mostly works, but there are things that don’t really work like they should I guess.
I’m refearing to various things I’ve noticed.
Since I can’t really address a specific problem I’ll describe the situations I’ll provide screenshot of all of them to make it clear.
There are 4 things I noticed:
Keyboard on screen doesn’t type in lockscreen login thing. It’s weird cause in mozilla search bar this keyboard on screen work, same thing with typing with it on terminal. Keyboard on screen also doesn’t type in the search bar of the app menu of gnome. -
In the File Explorer when you hold on screen with your finger to let the hold on menu appear, it appears but as soon as you raise your finger to click an option, it disappers. -
Touch tapping doesn’t work as intended if file explorer is put into “show files as a list” mode. It’s almost impossible to enter folder with the double tap. Sometime after 8-9 tap it may let you enter in the folder that is highlighted by the green bar. -
Last thing is about mozilla, it doesn’t let you scroll with your finger as you would usually do. You have to use the scroll bar to the right, otherwise if you don’t use that and try to scroll with your finger you highlight text.FIXED BY INSTALLING UNGOOGLED-CHROMIUM
Since I have no idea of what info should I provide, here’s the standard inxi --full --verbosity=7 --filter --no-host :
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Detachable System: ASUSTeK product: T101HA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: T101HA v: 1.0 serial: <filter>
UEFI: American Megatrends v: T101HA.304 date: 06/05/2017
ID-1: BATC charge: 14.3 Wh condition: 28.7/31.6 Wh (91%) volts: 4.0/3.8
model: Intel SR 1 SR Real Battery type: Li-ion serial: <filter>
status: Charging cycles: 29
RAM: total: 3.68 GiB used: 957.0 MiB (25.4%)
RAM Report:
Topology: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP
arch: Airmont rev: 4 L2 cache: 1024 KiB bogomips: 11524
Speed: 480 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 547 2: 480
3: 480 4: 480
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b0
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics (CHV) v: 4.6 Mesa 20.1.8
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
Imaging Unit
driver: N/A bus ID: 00:03.0 chip ID: 8086:22b8
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel port: f000 bus ID: 01:00.0
chip ID: 168c:0042
Local Storage: total: 58.24 GiB used: 7.81 GiB (13.4%)
ID-1: /dev/mmcblk0 model: DF4064 size: 58.24 GiB serial: <filter> rev: 0x8
scheme: GPT
ID-1: / size: 56.79 GiB used: 7.81 GiB (13.8%) fs: ext4
dev: /dev/mmcblk0p2 label: N/A uuid: a9ccd26c-f160-45b1-b922-1f9edbeff75c
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/mmcblk0p1 label: N/A uuid: C93B-8760
Hub: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2 info: IMC Networks type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 13d3:3501
Device-2: 1-4:3 info: ASUSTek ASUS HID Device type: Keyboard,Mouse
driver: asus,hid-multitouch,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 0b05:183d
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 277 Uptime: 1h 38m Init: systemd v: 246 Compilers: gcc: N/A
Packages: 1169 pacman: 1165 snap: 4 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
Of course, if any other info is needed I’ll provide that asap.
