So, sorry for having done it before. I’m not used to all of this
Here is the inxi --full --verbosity=7 --filter --no-host output as asked by “How to provide good information in your posts” :
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Detachable System: ASUSTeK product: T101HA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: T101HA v: 1.0 serial: <filter>
UEFI: American Megatrends v: T101HA.304 date: 06/05/2017
ID-1: BATC charge: 19.5 Wh condition: 28.7/31.6 Wh (91%) volts: 3.9/3.8
model: Intel SR 1 SR Real Battery type: Li-ion serial: <filter>
status: Discharging cycles: 29
RAM: total: 3.68 GiB used: 955.7 MiB (25.4%)
RAM Report:
Topology: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP
arch: Airmont rev: 4 L2 cache: 1024 KiB bogomips: 11524
Speed: 480 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 509 2: 1109
3: 480 4: 480
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b0
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics (CHV) v: 4.6 Mesa 20.1.8
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
Imaging Unit
driver: N/A bus ID: 00:03.0 chip ID: 8086:22b8
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel port: f000 bus ID: 01:00.0
chip ID: 168c:0042
Local Storage: total: 58.24 GiB used: 7.69 GiB (13.2%)
ID-1: /dev/mmcblk0 model: DF4064 size: 58.24 GiB serial: <filter> rev: 0x8
scheme: GPT
ID-1: / size: 56.79 GiB used: 7.69 GiB (13.5%) fs: ext4
dev: /dev/mmcblk0p2 label: N/A uuid: a9ccd26c-f160-45b1-b922-1f9edbeff75c
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/mmcblk0p1 label: N/A uuid: C93B-8760
Hub: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-3:2 info: IMC Networks type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 13d3:3501
Device-2: 1-4:4 info: ASUSTek ASUS HID Device type: Keyboard,Mouse
driver: asus,hid-multitouch,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 0b05:183d
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 256 Uptime: 37m Init: systemd v: 246 Compilers: gcc: N/A
Packages: 1169 pacman: 1165 snap: 4 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
Here is the the full dmesg :
[ 0.000000] microcode: microcode updated early to revision 0x411, date = 2019-04-23
[ 0.000000] Linux version 5.8.11-1-MANJARO (builder@4970a884831b) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Wed Sep 23 14:35:40 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=a9ccd26c-f160-45b1-b922-1f9edbeff75c rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000008ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001effffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000001f000000-0x00000000201fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000075df5fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000075df6000-0x0000000075e25fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000075e26000-0x000000007614afff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007614b000-0x0000000076e31fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000076e32000-0x000000007780bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007780c000-0x000000007789cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007789d000-0x0000000077ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000feafffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed03000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed06000-0x00000000fed06fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed08000-0x00000000fed09fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fedbffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.40 by American Megatrends
[ 0.000000] efi: ESRT=0x77808018 ACPI=0x7618f000 ACPI 2.0=0x7618f000 SMBIOS=0x77162000 SMBIOS 3.0=0x77161000
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. T101HA/T101HA, BIOS T101HA.304 06/05/2017
[ 0.000000] tsc: Detected 1440.000 MHz processor
[ 0.000051] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000057] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000077] last_pfn = 0x180000 max_arch_pfn = 0x400000000
[ 0.000086] MTRR default type: uncachable
[ 0.000088] MTRR fixed ranges enabled:
[ 0.000092] 00000-9FFFF write-back
[ 0.000095] A0000-FFFFF write-protect
[ 0.000098] MTRR variable ranges enabled:
[ 0.000102] 0 base 000000000 mask F80000000 write-back
[ 0.000105] 1 base 07C000000 mask FFC000000 uncachable
[ 0.000109] 2 base 07B000000 mask FFF000000 uncachable
[ 0.000112] 3 base 07A800000 mask FFF800000 uncachable
[ 0.000115] 4 base 100000000 mask F80000000 write-back
[ 0.000118] 5 base 07A400000 mask FFFC00000 uncachable
[ 0.000120] 6 disabled
[ 0.000122] 7 disabled
[ 0.000250] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000391] total RAM covered: 4004M
[ 0.001553] Found optimal setting for mtrr clean up
[ 0.001556] gran_size: 64K chunk_size: 128M num_reg: 6 lose cover RAM: 0G
[ 0.001695] e820: update [mem 0x7a400000-0xffffffff] usable ==> reserved
[ 0.001705] last_pfn = 0x78000 max_arch_pfn = 0x400000000
[ 0.010998] esrt: Reserving ESRT space from 0x0000000077808018 to 0x0000000077808050.
[ 0.011023] check: Scanning 1 areas for low memory corruption
[ 0.013518] Secure boot could not be determined
[ 0.013522] RAMDISK: [mem 0x3672d000-0x3738dfff]
[ 0.013540] ACPI: Early table checksum verification disabled
[ 0.013548] ACPI: RSDP 0x000000007618F000 000024 (v02 _ASUS_)
[ 0.013558] ACPI: XSDT 0x000000007618F0A8 0000D4 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013573] ACPI: FACP 0x00000000761A92D0 00010C (v05 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013587] ACPI: DSDT 0x000000007618F210 01A0BD (v02 _ASUS_ Notebook 01072009 INTL 20120913)
[ 0.013597] ACPI: FACS 0x0000000076E31F80 000040
[ 0.013605] ACPI: APIC 0x00000000761A93E0 000084 (v03 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013614] ACPI: FPDT 0x00000000761A9468 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013623] ACPI: FIDT 0x00000000761A94B0 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013632] ACPI: MCFG 0x00000000761A9550 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.013641] ACPI: SSDT 0x00000000761A9590 0040AF (v01 DptfTb DptfTab 00001000 INTL 20120913)
[ 0.013651] ACPI: SSDT 0x00000000761AD640 000654 (v01 CpuDpf CpuDptf 00001000 INTL 20120913)
[ 0.013662] ACPI: SSDT 0x00000000761ADC98 000058 (v01 LowPM LowPwrM 00001000 INTL 20120913)
[ 0.013671] ACPI: UEFI 0x00000000761ADCF0 000042 (v01 _ASUS_ Notebook 00000000 00000000)
[ 0.013680] ACPI: SSDT 0x00000000761ADD38 000024 (v01 UsbCTb UsbCTab 00001000 INTL 20120913)
[ 0.013688] ACPI: HPET 0x00000000761ADD60 000038 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.013697] ACPI: SSDT 0x00000000761ADD98 000763 (v01 PmRef CpuPm 00003000 INTL 20120913)
[ 0.013706] ACPI: SSDT 0x00000000761AE500 000290 (v01 PmRef Cpu0Tst 00003000 INTL 20120913)
[ 0.013715] ACPI: SSDT 0x00000000761AE790 00017A (v01 PmRef ApTst 00003000 INTL 20120913)
[ 0.013725] ACPI: LPIT 0x00000000761AE910 000104 (v01 _ASUS_ Notebook 00000005 MSFT 0100000D)
[ 0.013736] ACPI: BCFG 0x00000000761AEA18 000139 (v01 INTEL BATTCONF 00000001 INTL 00000000)
[ 0.013744] ACPI: PRAM 0x00000000761AEB58 000030 (v01 00000001 00000000)
[ 0.013753] ACPI: BGRT 0x00000000761AEB88 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.013762] ACPI: CSRT 0x00000000761AEBC0 00014C (v00 INTEL LANFORDC 00000005 MSFT 0100000D)
[ 0.013770] ACPI: TPM2 0x00000000761AED10 000034 (v03 Tpm2Tabl 00000001 AMI 00000000)
[ 0.013779] ACPI: WDAT 0x00000000761AED48 000104 (v01 00000000 00000000)
[ 0.013789] ACPI: MSDM 0x0000000075E22F18 000055 (v03 _ASUS_ Notebook 00000000 ASUS 00000001)
[ 0.013811] ACPI: Local APIC address 0xfee00000
[ 0.013924] No NUMA configuration found
[ 0.013927] Faking a node at [mem 0x0000000000000000-0x000000017fffffff]
[ 0.013938] NODE_DATA(0) allocated [mem 0x17fffb000-0x17fffefff]
[ 0.014011] Zone ranges:
[ 0.014013] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.014019] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.014022] Normal [mem 0x0000000100000000-0x000000017fffffff]
[ 0.014026] Device empty
[ 0.014029] Movable zone start for each node
[ 0.014031] Early memory node ranges
[ 0.014034] node 0: [mem 0x0000000000001000-0x000000000008efff]
[ 0.014037] node 0: [mem 0x0000000000090000-0x000000000009dfff]
[ 0.014039] node 0: [mem 0x0000000000100000-0x000000001effffff]
[ 0.014042] node 0: [mem 0x0000000020200000-0x0000000075df5fff]
[ 0.014044] node 0: [mem 0x0000000075e26000-0x000000007614afff]
[ 0.014047] node 0: [mem 0x000000007789d000-0x0000000077ffffff]
[ 0.014049] node 0: [mem 0x0000000100000000-0x000000017fffffff]
[ 0.014392] Zeroed struct page in unavailable ranges: 10726 pages
[ 0.014396] Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
[ 0.014401] On node 0 totalpages: 1005082
[ 0.014404] DMA zone: 64 pages used for memmap
[ 0.014406] DMA zone: 22 pages reserved
[ 0.014409] DMA zone: 3996 pages, LIFO batch:0
[ 0.014496] DMA32 zone: 7450 pages used for memmap
[ 0.014498] DMA32 zone: 476798 pages, LIFO batch:63
[ 0.025201] Normal zone: 8192 pages used for memmap
[ 0.025203] Normal zone: 524288 pages, LIFO batch:63
[ 0.036982] Reserving Intel graphics memory at [mem 0x7ad00000-0x7ecfffff]
[ 0.037882] ACPI: PM-Timer IO Port: 0x408
[ 0.037889] ACPI: Local APIC address 0xfee00000
[ 0.037907] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.037910] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.037912] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.037915] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.037941] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-114
[ 0.037947] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.037952] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.037957] ACPI: IRQ0 used by override.
[ 0.037960] ACPI: IRQ9 used by override.
[ 0.037967] Using ACPI (MADT) for SMP configuration information
[ 0.037971] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.037994] e820: update [mem 0x74b04000-0x74b17fff] usable ==> reserved
[ 0.038020] TSC deadline timer available
[ 0.038023] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.038109] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.038115] PM: hibernation: Registered nosave memory: [mem 0x0008f000-0x0008ffff]
[ 0.038121] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.038123] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.038129] PM: hibernation: Registered nosave memory: [mem 0x1f000000-0x201fffff]
[ 0.038135] PM: hibernation: Registered nosave memory: [mem 0x74b04000-0x74b17fff]
[ 0.038141] PM: hibernation: Registered nosave memory: [mem 0x75df6000-0x75e25fff]
[ 0.038147] PM: hibernation: Registered nosave memory: [mem 0x7614b000-0x76e31fff]
[ 0.038149] PM: hibernation: Registered nosave memory: [mem 0x76e32000-0x7780bfff]
[ 0.038151] PM: hibernation: Registered nosave memory: [mem 0x7780c000-0x7789cfff]
[ 0.038157] PM: hibernation: Registered nosave memory: [mem 0x78000000-0x7acfffff]
[ 0.038160] PM: hibernation: Registered nosave memory: [mem 0x7ad00000-0x7ecfffff]
[ 0.038162] PM: hibernation: Registered nosave memory: [mem 0x7ed00000-0xdfffffff]
[ 0.038164] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xe3ffffff]
[ 0.038166] PM: hibernation: Registered nosave memory: [mem 0xe4000000-0xfe9fffff]
[ 0.038168] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfeafffff]
[ 0.038170] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfebfffff]
[ 0.038172] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.038174] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
[ 0.038176] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
[ 0.038178] PM: hibernation: Registered nosave memory: [mem 0xfed02000-0xfed02fff]
[ 0.038181] PM: hibernation: Registered nosave memory: [mem 0xfed03000-0xfed03fff]
[ 0.038183] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed05fff]
[ 0.038185] PM: hibernation: Registered nosave memory: [mem 0xfed06000-0xfed06fff]
[ 0.038188] PM: hibernation: Registered nosave memory: [mem 0xfed07000-0xfed07fff]
[ 0.038190] PM: hibernation: Registered nosave memory: [mem 0xfed08000-0xfed09fff]
[ 0.038192] PM: hibernation: Registered nosave memory: [mem 0xfed0a000-0xfed1bfff]
[ 0.038194] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1cfff]
[ 0.038196] PM: hibernation: Registered nosave memory: [mem 0xfed1d000-0xfed7ffff]
[ 0.038199] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedbffff]
[ 0.038201] PM: hibernation: Registered nosave memory: [mem 0xfedc0000-0xfedfffff]
[ 0.038203] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.038205] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff9fffff]
[ 0.038207] PM: hibernation: Registered nosave memory: [mem 0xffa00000-0xffffffff]
[ 0.038212] [mem 0x7ed00000-0xdfffffff] available for PCI devices
[ 0.038215] Booting paravirtualized kernel on bare hardware
[ 0.038225] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.050832] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.051787] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[ 0.051814] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[ 0.051817] pcpu-alloc: [0] 0 1 2 3
[ 0.051897] Built 1 zonelists, mobility grouping on. Total pages: 989354
[ 0.051900] Policy zone: Normal
[ 0.051904] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=a9ccd26c-f160-45b1-b922-1f9edbeff75c rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.053492] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.054213] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.054303] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[ 0.110140] Memory: 3789888K/4020328K available (14339K kernel code, 1504K rwdata, 4684K rodata, 1644K init, 2976K bss, 230440K reserved, 0K cma-reserved)
[ 0.110157] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[ 0.110625] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.110667] Kernel/User page tables isolation: enabled
[ 0.110715] ftrace: allocating 40307 entries in 158 pages
[ 0.142568] ftrace: allocated 158 pages with 5 groups
[ 0.142897] rcu: Preemptible hierarchical RCU implementation.
[ 0.142900] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.142903] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.142905] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.142907] Trampoline variant of Tasks RCU enabled.
[ 0.142909] Rude variant of Tasks RCU enabled.
[ 0.142911] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.142913] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.154326] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.154992] Console: colour dummy device 80x25
[ 0.155001] printk: console [tty0] enabled
[ 0.155068] ACPI: Core revision 20200528
[ 0.155564] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.155597] APIC: Switch to symmetric I/O mode setup
[ 0.157342] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.172272] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x14c1baf3789, max_idle_ns: 440795266465 ns
[ 0.172282] Calibrating delay loop (skipped), value calculated using timer frequency.. 2881.00 BogoMIPS (lpj=4800000)
[ 0.172290] pid_max: default: 32768 minimum: 301
[ 0.179083] LSM: Security Framework initializing
[ 0.179103] Yama: becoming mindful.
[ 0.179169] AppArmor: AppArmor initialized
[ 0.179244] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.179269] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.180051] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.180059] process: using mwait in idle threads
[ 0.180067] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
[ 0.180070] Last level dTLB entries: 4KB 256, 2MB 16, 4MB 16, 1GB 0
[ 0.180078] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.180083] Spectre V2 : Mitigation: Full generic retpoline
[ 0.180085] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.180088] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.180093] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.180099] MDS: Mitigation: Clear CPU buffers
[ 0.180521] Freeing SMP alternatives memory: 32K
[ 0.182936] smpboot: CPU0: Intel(R) Atom(TM) x5-Z8350 CPU @ 1.44GHz (family: 0x6, model: 0x4c, stepping: 0x4)
[ 0.183436] Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, 8-deep LBR, full-width counters, Intel PMU driver.
[ 0.183452] ... version: 3
[ 0.183456] ... bit width: 40
[ 0.183458] ... generic registers: 2
[ 0.183461] ... value mask: 000000ffffffffff
[ 0.183463] ... max period: 0000007fffffffff
[ 0.183465] ... fixed-purpose events: 3
[ 0.183467] ... event mask: 0000000700000003
[ 0.183628] rcu: Hierarchical SRCU implementation.
[ 0.185477] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.185608] smp: Bringing up secondary CPUs ...
[ 0.185743] x86: Booting SMP configuration:
[ 0.185747] .... node #0, CPUs: #1 #2 #3
[ 0.193005] smp: Brought up 1 node, 4 CPUs
[ 0.193005] smpboot: Max logical packages: 1
[ 0.193005] smpboot: Total of 4 processors activated (11524.00 BogoMIPS)
[ 0.193479] devtmpfs: initialized
[ 0.193479] x86/mm: Memory block size: 128MB
[ 0.195810] PM: Registering ACPI NVS region [mem 0x0008f000-0x0008ffff] (4096 bytes)
[ 0.195810] PM: Registering ACPI NVS region [mem 0x7614b000-0x76e31fff] (13529088 bytes)
[ 0.196702] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.196702] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.196702] pinctrl core: initialized pinctrl subsystem
[ 0.196702] PM: RTC time: 09:17:52, date: 2020-10-10
[ 0.196702] thermal_sys: Registered thermal governor 'fair_share'
[ 0.196702] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.196702] thermal_sys: Registered thermal governor 'step_wise'
[ 0.196702] thermal_sys: Registered thermal governor 'user_space'
[ 0.196702] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.198955] NET: Registered protocol family 16
[ 0.198955] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.198955] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.198955] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.198955] audit: initializing netlink subsys (disabled)
[ 0.199023] audit: type=2000 audit(1602321472.043:1): state=initialized audit_enabled=0 res=1
[ 0.199622] cpuidle: using governor ladder
[ 0.199622] cpuidle: using governor menu
[ 0.199622] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.199622] ACPI: bus type PCI registered
[ 0.199622] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.199622] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.199622] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.199622] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000) (size reduced!)
[ 0.199622] PCI: Using configuration type 1 for base access
[ 0.200055] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.206334] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.212675] ACPI: Added _OSI(Module Device)
[ 0.212679] ACPI: Added _OSI(Processor Device)
[ 0.212681] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.212683] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.212687] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.212690] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.212693] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.286095] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.291749] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PCI0.I2C7.BATC (20200528/dspkginit-438)
[ 0.292195] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PCI0.I2C7.BATC (20200528/dspkginit-438)
[ 0.292219] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PCI0.I2C3.TIDR (20200528/dspkginit-438)
[ 0.301080] ACPI: Dynamic OEM Table Load:
[ 0.301099] ACPI: SSDT 0xFFFF968C3B7DF000 00059C (v01 PmRef Cpu0Ist 00003000 INTL 20120913)
[ 0.306763] ACPI: Dynamic OEM Table Load:
[ 0.306777] ACPI: SSDT 0xFFFF968C3ACB8400 0003A5 (v01 PmRef Cpu0Cst 00003001 INTL 20120913)
[ 0.312365] ACPI: Dynamic OEM Table Load:
[ 0.312380] ACPI: SSDT 0xFFFF968C3AF97A00 00015F (v01 PmRef ApIst 00003000 INTL 20120913)
[ 0.316798] ACPI: Dynamic OEM Table Load:
[ 0.316811] ACPI: SSDT 0xFFFF968C3AF68600 00008D (v01 PmRef ApCst 00003000 INTL 20120913)
[ 0.326935] ACPI: Interpreter enabled
[ 0.327008] ACPI: (supports S0 S4 S5)
[ 0.327012] ACPI: Using IOAPIC for interrupt routing
[ 0.327135] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.331910] ACPI: Power Resource [P12T] (off)
[ 0.332082] ACPI: Power Resource [P12A] (off)
[ 0.335457] ACPI: Power Resource [ID3C] (on)
[ 0.339926] ACPI: Power Resource [USBC] (on)
[ 0.359619] ACPI: Power Resource [CLK3] (on)
[ 0.359789] ACPI: Power Resource [CLK4] (on)
[ 0.373286] ACPI: Power Resource [CLK2] (on)
[ 0.373454] ACPI: Power Resource [CLK0] (on)
[ 0.373615] ACPI: Power Resource [CLK1] (on)
[ 0.373794] ACPI: Power Resource [CLK4] (on)
[ 0.374181] ACPI: Power Resource [P28T] (off)
[ 0.374329] ACPI: Power Resource [P18D] (off)
[ 0.375569] ACPI: Power Resource [CLK0] (on)
[ 0.375749] ACPI: Power Resource [CLK1] (on)
[ 0.397061] ACPI: Power Resource [P28X] (off)
[ 0.397232] ACPI: Power Resource [P18X] (off)
[ 0.397388] ACPI: Power Resource [P12X] (off)
[ 0.397556] ACPI: Power Resource [P28P] (off)
[ 0.397715] ACPI: Power Resource [P18P] (off)
[ 0.397894] ACPI: Power Resource [P19X] (off)
[ 0.398057] ACPI: Power Resource [P06X] (off)
[ 0.398244] ACPI: Power Resource [P18T] (off)
[ 0.398408] ACPI: Power Resource [P3P3] (off)
[ 0.398601] ACPI: Power Resource [P28W] (off)
[ 0.398770] ACPI: Power Resource [P18W] (off)
[ 0.398939] ACPI: Power Resource [P12W] (off)
[ 0.399098] ACPI: Power Resource [P33W] (off)
[ 0.399259] ACPI: Power Resource [P33X] (off)
[ 0.411923] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.411944] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.413200] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapabil-ity LTR DPC]
[ 0.413205] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.413265] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.415757] PCI host bridge to bus 0000:00
[ 0.415765] pci_bus 0000:00: root bus resource [io 0x0070-0x0077]
[ 0.415771] pci_bus 0000:00: root bus resource [io 0x0000-0x006f window]
[ 0.415775] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7 window]
[ 0.415778] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.415784] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.415788] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.415792] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[ 0.415796] pci_bus 0000:00: root bus resource [mem 0x20000000-0x201fffff window]
[ 0.415799] pci_bus 0000:00: root bus resource [mem 0x7ad00001-0x7ed00000 window]
[ 0.415803] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.415809] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.415841] pci 0000:00:00.0: [8086:2280] type 00 class 0x060000
[ 0.416941] pci 0000:00:02.0: [8086:22b0] type 00 class 0x030000
[ 0.416976] pci 0000:00:02.0: reg 0x10: [mem 0x90000000-0x90ffffff 64bit]
[ 0.416993] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.417006] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.417048] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.417623] pci 0000:00:03.0: [8086:22b8] type 00 class 0x048000
[ 0.417648] pci 0000:00:03.0: reg 0x10: [mem 0x91000000-0x913fffff]
[ 0.418263] pci 0000:00:0a.0: [8086:22d8] type 00 class 0x000000
[ 0.418299] pci 0000:00:0a.0: reg 0x10: [mem 0x91a3a000-0x91a3afff]
[ 0.419113] pci 0000:00:0b.0: [8086:22dc] type 00 class 0x118000
[ 0.419147] pci 0000:00:0b.0: reg 0x10: [mem 0x91a39000-0x91a39fff 64bit]
[ 0.419858] pci 0000:00:14.0: [8086:22b5] type 00 class 0x0c0330
[ 0.419901] pci 0000:00:14.0: reg 0x10: [mem 0x91a00000-0x91a0ffff 64bit]
[ 0.420023] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.420721] pci 0000:00:1a.0: [8086:2298] type 00 class 0x108000
[ 0.420755] pci 0000:00:1a.0: reg 0x10: [mem 0x91900000-0x919fffff]
[ 0.420770] pci 0000:00:1a.0: reg 0x14: [mem 0x91800000-0x918fffff]
[ 0.420880] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ 0.421585] pci 0000:00:1c.0: [8086:22c8] type 01 class 0x060400
[ 0.423626] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.424796] pci 0000:00:1f.0: [8086:229c] type 00 class 0x060100
[ 0.426576] pci 0000:01:00.0: [168c:0042] type 00 class 0x028000
[ 0.427169] pci 0000:01:00.0: reg 0x10: [mem 0x91600000-0x917fffff 64bit]
[ 0.429200] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.431281] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.431372] pci 0000:00:1c.0: bridge window [mem 0x91600000-0x917fffff]
[ 0.452156] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 11 12) *0, disabled.
[ 0.452498] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.452821] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.453147] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.453467] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.453789] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.454115] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.454433] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.482340] dw_dmac INTL9C60:00: Missing DT data
[ 0.499336] dw_dmac INTL9C60:00: DesignWare DMA Controller, 8 channels
[ 0.515650] dw_dmac INTL9C60:01: Missing DT data
[ 0.532686] dw_dmac INTL9C60:01: DesignWare DMA Controller, 8 channels
[ 0.533228] iommu: Default domain type: Translated
[ 0.533271] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.533271] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.533271] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.533271] vgaarb: loaded
[ 0.533271] SCSI subsystem initialized
[ 0.533281] libata version 3.00 loaded.
[ 0.533281] ACPI: bus type USB registered
[ 0.533281] usbcore: registered new interface driver usbfs
[ 0.533281] usbcore: registered new interface driver hub
[ 0.533281] usbcore: registered new device driver usb
[ 0.678960] random: fast init done
[ 0.814132] pps_core: LinuxPPS API ver. 1 registered
[ 0.814136] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.814149] PTP clock support registered
[ 0.814179] EDAC MC: Ver: 3.0.0
[ 0.814540] Registered efivars operations
[ 0.816037] NetLabel: Initializing
[ 0.816041] NetLabel: domain hash size = 128
[ 0.816042] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.816085] NetLabel: unlabeled traffic allowed by default
[ 0.816090] PCI: Using ACPI for IRQ routing
[ 0.818193] PCI: pci_cache_line_size set to 64 bytes
[ 0.818563] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.818570] e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
[ 0.818574] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.818577] e820: reserve RAM buffer [mem 0x1f000000-0x1fffffff]
[ 0.818580] e820: reserve RAM buffer [mem 0x74b04000-0x77ffffff]
[ 0.818583] e820: reserve RAM buffer [mem 0x75df6000-0x77ffffff]
[ 0.818588] e820: reserve RAM buffer [mem 0x7614b000-0x77ffffff]
[ 0.820707] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.820718] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.822457] clocksource: Switched to clocksource tsc-early
[ 0.873656] VFS: Disk quotas dquot_6.6.0
[ 0.873704] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.874102] AppArmor: AppArmor Filesystem Enabled
[ 0.874227] pnp: PnP ACPI init
[ 0.874764] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.874771] system 00:00: [io 0x0400-0x047f] could not be reserved
[ 0.874776] system 00:00: [io 0x0500-0x05fe] has been reserved
[ 0.874795] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.875079] pnp 00:01: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.877852] system 00:02: [io 0x0240-0x0259] has been reserved
[ 0.877871] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.891545] system 00:03: [mem 0x91a37000-0x91a37fff] has been reserved
[ 0.891552] system 00:03: [mem 0x91a35000-0x91a35fff] has been reserved
[ 0.891557] system 00:03: [mem 0x91a24000-0x91a24fff] has been reserved
[ 0.891562] system 00:03: [mem 0x91a22000-0x91a22fff] has been reserved
[ 0.891566] system 00:03: [mem 0x91a20000-0x91a20fff] has been reserved
[ 0.891571] system 00:03: [mem 0x91a1e000-0x91a1efff] has been reserved
[ 0.891575] system 00:03: [mem 0x91a1c000-0x91a1cfff] has been reserved
[ 0.891580] system 00:03: [mem 0x91a1a000-0x91a1afff] has been reserved
[ 0.891585] system 00:03: [mem 0x91a18000-0x91a18fff] has been reserved
[ 0.891590] system 00:03: [mem 0x91a33000-0x91a33fff] has been reserved
[ 0.891594] system 00:03: [mem 0x91a31000-0x91a31fff] has been reserved
[ 0.891599] system 00:03: [mem 0x91a2f000-0x91a2ffff] has been reserved
[ 0.891604] system 00:03: [mem 0x91a2d000-0x91a2dfff] has been reserved
[ 0.891608] system 00:03: [mem 0x91a2b000-0x91a2bfff] has been reserved
[ 0.891613] system 00:03: [mem 0x91a29000-0x91a29fff] has been reserved
[ 0.891618] system 00:03: [mem 0x91a27000-0x91a27fff] has been reserved
[ 0.891622] system 00:03: [mem 0x91a25000-0x91a25fff] has been reserved
[ 0.891638] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.891824] system 00:04: [mem 0xe0000000-0xefffffff] could not be reserved
[ 0.891830] system 00:04: [mem 0xfea00000-0xfeafffff] has been reserved
[ 0.891836] system 00:04: [mem 0xfed01000-0xfed01fff] has been reserved
[ 0.891840] system 00:04: [mem 0xfed03000-0xfed03fff] has been reserved
[ 0.891844] system 00:04: [mem 0xfed06000-0xfed06fff] has been reserved
[ 0.891848] system 00:04: [mem 0xfed08000-0xfed09fff] has been reserved
[ 0.891853] system 00:04: [mem 0xfed80000-0xfedbffff] could not be reserved
[ 0.891858] system 00:04: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 0.891862] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.891877] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.892607] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.895711] pnp: PnP ACPI: found 6 devices
[ 0.906729] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.906934] NET: Registered protocol family 2
[ 0.907380] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.907493] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.907771] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.907980] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.908387] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.908453] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.908729] NET: Registered protocol family 1
[ 0.908744] NET: Registered protocol family 44
[ 0.908775] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.908847] pci 0000:00:1c.0: bridge window [mem 0x91600000-0x917fffff]
[ 0.909013] pci_bus 0000:00: resource 4 [io 0x0070-0x0077]
[ 0.909018] pci_bus 0000:00: resource 5 [io 0x0000-0x006f window]
[ 0.909022] pci_bus 0000:00: resource 6 [io 0x0078-0x0cf7 window]
[ 0.909028] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.909032] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.909036] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.909040] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[ 0.909044] pci_bus 0000:00: resource 11 [mem 0x20000000-0x201fffff window]
[ 0.909049] pci_bus 0000:00: resource 12 [mem 0x7ad00001-0x7ed00000 window]
[ 0.909053] pci_bus 0000:00: resource 13 [mem 0x80000000-0xdfffffff window]
[ 0.909058] pci_bus 0000:01: resource 1 [mem 0x91600000-0x917fffff]
[ 0.909574] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.910386] PCI: CLS 64 bytes, default 64
[ 0.910550] Trying to unpack rootfs image as initramfs...
[ 1.268465] Freeing initrd memory: 12676K
[ 1.268474] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.268478] software IO TLB: mapped [mem 0x6f30e000-0x7330e000] (64MB)
[ 1.268611] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x14c1baf3789, max_idle_ns: 440795266465 ns
[ 1.268668] clocksource: Switched to clocksource tsc
[ 1.268943] check: Scanning for low memory corruption every 60 seconds
[ 1.270182] Initialise system trusted keyrings
[ 1.270210] Key type blacklist registered
[ 1.270386] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 1.274268] zbud: loaded
[ 1.297118] Key type asymmetric registered
[ 1.297122] Asymmetric key parser 'x509' registered
[ 1.297149] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.297308] io scheduler mq-deadline registered
[ 1.297311] io scheduler kyber registered
[ 1.297394] io scheduler bfq registered
[ 1.299346] pcieport 0000:00:1c.0: PME: Signaling with IRQ 116
[ 1.300325] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.300675] efifb: probing for efifb
[ 1.300738] efifb: showing boot graphics
[ 1.302099] efifb: framebuffer at 0x80000000, using 4032k, total 4032k
[ 1.302103] efifb: mode is 800x1280x32, linelength=3200, pages=1
[ 1.302104] efifb: scrolling: redraw
[ 1.302108] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.302275] fbcon: Deferring console take-over
[ 1.302299] fb0: EFI VGA frame buffer device
[ 1.302329] intel_idle: MWAIT substates: 0x33000020
[ 1.302334] intel_idle: v0.5.1 model 0x4C
[ 1.302930] intel_idle: Local APIC timer is reliable in all C-states
[ 1.303197] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.303273] ACPI: Power Button [PWRB]
[ 1.303379] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 1.303439] ACPI: Sleep Button [SLPB]
[ 1.303570] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[ 1.303631] ACPI: Lid Switch [LID]
[ 1.303768] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 1.306097] ACPI: Power Button [PWRF]
[ 1.316234] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.316238] ACPI: Thermal Zone [TZ00] (0 C)
[ 1.317642] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.317948] 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.326511] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.326514] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 1.331242] usbcore: registered new interface driver usbserial_generic
[ 1.331257] usbserial: USB Serial support registered for generic
[ 1.332029] rtc_cmos 00:05: registered as rtc0
[ 1.332217] rtc_cmos 00:05: setting system clock to 2020-10-10T09:17:54 UTC (1602321474)
[ 1.332279] rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram
[ 1.332572] intel_pstate: Intel P-state driver initializing
[ 1.334552] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.334902] ashmem: initialized
[ 1.335995] drop_monitor: Initializing network drop monitor service
[ 1.336374] NET: Registered protocol family 10
[ 1.366064] Segment Routing with IPv6
[ 1.366068] RPL Segment Routing with IPv6
[ 1.366129] NET: Registered protocol family 17
[ 1.368542] microcode: sig=0x406c4, pf=0x1, revision=0x411
[ 1.368848] microcode: Microcode Update Driver: v2.2.
[ 1.368858] IPI shorthand broadcast: enabled
[ 1.368879] sched_clock: Marking stable (1368006148, 827947)->(1373874650, -5040555)
[ 1.369465] registered taskstats version 1
[ 1.369503] Loading compiled-in X.509 certificates
[ 1.388221] Loaded X.509 cert 'Build time autogenerated kernel key: ff68ef670fabf1756b3d6cdb3b04b014942c1fd2'
[ 1.392889] zswap: loaded using pool zstd/z3fold
[ 1.394212] Key type ._fscrypt registered
[ 1.394214] Key type .fscrypt registered
[ 1.394216] Key type fscrypt-provisioning registered
[ 1.394337] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.436713] i2c_designware 808622C1:06: I2C bus managed by PUNIT
[ 1.452493] PM: Magic number: 8:448:272
[ 1.453391] RAS: Correctable Errors collector initialized.
[ 1.468423] Freeing unused decrypted memory: 2040K
[ 1.469926] Freeing unused kernel image (initmem) memory: 1644K
[ 1.470306] Write protecting the kernel read-only data: 22528k
[ 1.472916] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.474674] Freeing unused kernel image (rodata/data gap) memory: 1460K
[ 1.551565] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.551846] x86/mm: Checking user space page tables
[ 1.623722] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.623736] Run /init as init process
[ 1.623738] with arguments:
[ 1.623740] /init
[ 1.623741] with environment:
[ 1.623743] HOME=/
[ 1.623744] TERM=linux
[ 1.623746] BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
[ 2.206751] sdhci: Secure Digital Host Controller Interface driver
[ 2.206755] sdhci: Copyright(c) Pierre Ossman
[ 2.226100] battery: ACPI: Battery Slot [BATC] (battery present)
[ 2.230130] mmc0: SDHCI controller on ACPI [80860F14:00] using ADMA
[ 2.252879] mmc1: SDHCI controller on ACPI [80860F14:03] using ADMA
[ 2.265590] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.265607] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 2.266809] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081509810
[ 2.267040] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 2.267555] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 2.267560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.267563] usb usb1: Product: xHCI Host Controller
[ 2.267566] usb usb1: Manufacturer: Linux 5.8.11-1-MANJARO xhci-hcd
[ 2.267569] usb usb1: SerialNumber: 0000:00:14.0
[ 2.268008] hub 1-0:1.0: USB hub found
[ 2.268043] hub 1-0:1.0: 7 ports detected
[ 2.270744] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.270756] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.270767] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 2.270917] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 2.270922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.270925] usb usb2: Product: xHCI Host Controller
[ 2.270928] usb usb2: Manufacturer: Linux 5.8.11-1-MANJARO xhci-hcd
[ 2.270931] usb usb2: SerialNumber: 0000:00:14.0
[ 2.271263] hub 2-0:1.0: USB hub found
[ 2.271295] hub 2-0:1.0: 6 ports detected
[ 2.338055] mmc0: new HS200 MMC card at address 0001
[ 2.346052] mmcblk0: mmc0:0001 DF4064 58.2 GiB
[ 2.346358] mmcblk0boot0: mmc0:0001 DF4064 partition 1 4.00 MiB
[ 2.346707] mmcblk0boot1: mmc0:0001 DF4064 partition 2 4.00 MiB
[ 2.347074] mmcblk0rpmb: mmc0:0001 DF4064 partition 3 4.00 MiB, chardev (242:0)
[ 2.357400] mmcblk0: p1 p2
[ 2.599586] usb 1-3: new full-speed USB device number 2 using xhci_hcd
[ 2.740793] usb 1-3: New USB device found, idVendor=13d3, idProduct=3501, bcdDevice= 0.01
[ 2.740811] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.865920] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 2.867018] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.039162] usb 1-4: New USB device found, idVendor=0b05, idProduct=183d, bcdDevice= 0.09
[ 3.039180] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.039191] usb 1-4: Product: ASUS HID Device
[ 3.039201] usb 1-4: Manufacturer: ASUS Tech Inc.
[ 3.631546] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.650943] systemd[1]: Detected architecture x86-64.
[ 3.692205] systemd[1]: Set hostname to <minibus-t101ha>.
[ 4.649440] systemd[1]: /usr/lib/systemd/system/gdm.service:28: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 4.720887] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.727393] systemd[1]: Created slice system-getty.slice.
[ 4.729029] systemd[1]: Created slice system-modprobe.slice.
[ 4.730361] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.731959] systemd[1]: Created slice User and Session Slice.
[ 4.732429] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.732729] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.733811] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.733968] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.734040] systemd[1]: Reached target Login Prompts.
[ 4.734201] systemd[1]: Reached target Remote File Systems.
[ 4.734273] systemd[1]: Reached target Slices.
[ 4.734374] systemd[1]: Reached target Swap.
[ 4.734802] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.735324] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 4.736812] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.744644] systemd[1]: Listening on Process Core Dump Socket.
[ 4.745427] systemd[1]: Listening on Journal Audit Socket.
[ 4.746032] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.746663] systemd[1]: Listening on Journal Socket.
[ 4.747342] systemd[1]: Listening on udev Control Socket.
[ 4.747836] systemd[1]: Listening on udev Kernel Socket.
[ 4.752580] systemd[1]: Mounting Huge Pages File System...
[ 4.757464] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.762513] systemd[1]: Mounting Kernel Debug File System...
[ 4.767704] systemd[1]: Mounting Kernel Trace File System...
[ 4.774633] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 4.779828] systemd[1]: Starting Load AppArmor profiles...
[ 4.784516] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.788939] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.794771] systemd[1]: Starting Load Kernel Module drm...
[ 4.797716] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.797925] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 4.806564] systemd[1]: Starting Journal Service...
[ 4.824735] systemd[1]: Starting Load Kernel Modules...
[ 4.828304] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.828574] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 4.832469] systemd[1]: Starting Coldplug All udev Devices...
[ 4.842572] Linux agpgart interface v0.103
[ 4.843425] systemd[1]: Mounted Huge Pages File System.
[ 4.844208] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.844770] systemd[1]: Mounted Kernel Debug File System.
[ 4.845230] systemd[1]: Mounted Kernel Trace File System.
[ 4.845699] systemd[1]: Mounted Temporary Directory (/tmp).
[ 4.845884] random: lvm: uninitialized urandom read (4 bytes read)
[ 4.847781] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.860099] systemd[1]: Finished Load Kernel Modules.
[ 4.861001] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 4.864626] systemd[1]: Mounting Kernel Configuration File System...
[ 4.873737] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.877936] systemd[1]: Starting Apply Kernel Variables...
[ 4.905805] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.906570] systemd[1]: Mounted Kernel Configuration File System.
[ 4.907081] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 4.914825] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 4.918157] systemd[1]: Starting Load/Save Random Seed...
[ 4.918486] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 4.927873] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.930524] systemd[1]: Finished Apply Kernel Variables.
[ 4.943763] systemd[1]: Starting CLI Netfilter Manager...
[ 4.968042] systemd[1]: modprobe@drm.service: Succeeded.
[ 4.969431] systemd[1]: Finished Load Kernel Module drm.
[ 5.011042] systemd[1]: Finished CLI Netfilter Manager.
[ 5.027003] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 5.034184] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 5.266993] systemd[1]: Finished Coldplug All udev Devices.
[ 5.462970] audit: type=1400 audit(1602321478.630:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=268 comm="apparmor_parser"
[ 5.776469] audit: type=1400 audit(1602321478.943:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=275 comm="apparmor_parser"
[ 5.780323] audit: type=1400 audit(1602321478.946:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=275 comm="apparmor_parser"
[ 5.920387] systemd[1]: Started Journal Service.
[ 5.925690] audit: type=1130 audit(1602321479.086:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" host-name=? addr=? terminal=? res=success'
[ 6.484768] audit: type=1130 audit(1602321479.650:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" host-name=? addr=? terminal=? res=success'
[ 6.492186] audit: type=1130 audit(1602321479.656:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.504878] audit: type=1130 audit(1602321479.666:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.878995] random: crng init done
[ 6.916167] audit: type=1130 audit(1602321480.083:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" host-name=? addr=? terminal=? res=success'
[ 7.072376] ACPI: AC Adapter [ADP1] (off-line)
[ 7.159383] 8086228A:00: ttyS1 at MMIO 0x91a21000 (irq = 39, base_baud = 2764800) is a 16550A
[ 7.174401] mc: Linux media interface: v0.10
[ 7.176218] 8086228A:01: ttyS2 at MMIO 0x91a1f000 (irq = 40, base_baud = 2764800) is a 16550A
[ 7.215756] input: Intel HID events as /devices/pci0000:00/INT33D5:00/input/input4
[ 7.283616] videodev: Linux video capture interface: v2.00
[ 7.310725] atomisp_gmin_platform: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.318233] hid: raw HID events driver (C) Jiri Kosina
[ 7.359043] atomisp_ov2680: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.417808] i2c_hid i2c-SIS0457:00: supply vdd not found, using dummy regulator
[ 7.418088] i2c_hid i2c-SIS0457:00: supply vddl not found, using dummy regulator
[ 7.432470] ov2680 i2c-OVTI2680:00: gmin: power management provided via Dollar Cove TI PMIC (i2c addr 0x5e)
[ 7.432501] ov2680 i2c-OVTI2680:00: gmin_subdev_add: ACPI path is \_SB.PCI0.I2C3.CAM1
[ 7.432702] ov2680 i2c-OVTI2680:00: didn't found _DSM entry for 'ClkSrc'
[ 7.433353] ov2680 i2c-OVTI2680:00: Failed to find EFI variable OVTI2680:00_ClkSrc
[ 7.433358] ov2680 i2c-OVTI2680:00: ClkSrc: using default (1)
[ 7.433530] ov2680 i2c-OVTI2680:00: found _DSM entry for 'CsiPort': 0
[ 7.433681] ov2680 i2c-OVTI2680:00: found _DSM entry for 'CsiLanes': 1
[ 7.433836] ov2680 i2c-OVTI2680:00: will handle gpio0 via ACPI
[ 7.434517] ov2680 i2c-OVTI2680:00: Failed to find EFI gmin variable gmin_V1P8GPIO
[ 7.434522] ov2680 i2c-OVTI2680:00: V1P8GPIO: using default (-1)
[ 7.435105] ov2680 i2c-OVTI2680:00: Failed to find EFI gmin variable gmin_V2P8GPIO
[ 7.435109] ov2680 i2c-OVTI2680:00: V2P8GPIO: using default (-1)
[ 7.435156] ov2680 i2c-OVTI2680:00: Will use CLK4 (pmc_plt_clk_4)
[ 7.525702] ov2680 i2c-OVTI2680:00: camera pdata: port: 0 lanes: 1 order: 00000002
[ 7.526275] ov2680 i2c-OVTI2680:00: sensor_revision id = 0x2680, rev= 0
[ 7.539118] ov2680 i2c-OVTI2680:00: register atomisp i2c module type 1
[ 7.547620] proc_thermal 0000:00:0b.0: enabling device (0000 -> 0002)
[ 7.550824] intel_ish_ipc 0000:00:0a.0: enabling device (0000 -> 0002)
[ 7.570670] proc_thermal 0000:00:0b.0: Creating sysfs group for PROC_THERMAL_PCI
[ 7.651988] audit: type=1400 audit(1602321480.806:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=285 comm="apparmor_parser"
[ 7.654826] audit: type=1400 audit(1602321480.816:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=285 comm="apparmor_parser"
[ 7.724332] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 7.808597] i8042: PNP: No PS/2 controller found.
[ 7.836115] intel_sst_acpi 808622A8:00: LPE base: 0x91400000 size:0x200000
[ 7.836121] intel_sst_acpi 808622A8:00: IRAM base: 0x914c0000
[ 7.836163] intel_sst_acpi 808622A8:00: DRAM base: 0x91500000
[ 7.836174] intel_sst_acpi 808622A8:00: SHIM base: 0x91540000
[ 7.836186] intel_sst_acpi 808622A8:00: Mailbox base: 0x91544000
[ 7.836195] intel_sst_acpi 808622A8:00: DDR base: 0x20000000
[ 7.838916] intel_sst_acpi 808622A8:00: Got drv data max stream 25
[ 7.859064] cryptd: max_cpu_qlen set to 1000
[ 7.996158] rt5645 i2c-10EC3270:00: Detected ASUS T101HA platform
[ 7.996175] rt5645 i2c-10EC3270:00: supply avdd not found, using dummy regulator
[ 7.996236] rt5645 i2c-10EC3270:00: supply cpvdd not found, using dummy regulator
[ 8.113020] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.127745] SSE version of gcm_enc/dec engaged.
[ 8.155283] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.173454] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.1.auto/input/input6
[ 8.182819] input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.2.auto/input/input7
[ 8.326193] atomisp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.373927] **********************************************************
[ 8.373929] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.373931] ** **
[ 8.373932] ** trace_printk() being used. Allocating extra memory. **
[ 8.373934] ** **
[ 8.373936] ** This means that this is a DEBUG kernel and it is **
[ 8.373937] ** unsafe for production use. **
[ 8.373938] ** **
[ 8.373939] ** If you see this message and you are not debugging **
[ 8.373940] ** the kernel, report this immediately to your vendor! **
[ 8.373942] ** **
[ 8.373943] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 8.373944] **********************************************************
[ 8.411867] atomisp-isp2 0000:00:03.0: Detected Cherrytrail version 54 (ISP2401) on T101HA
[ 8.411881] atomisp-isp2 0000:00:03.0: enabling device (0000 -> 0002)
[ 8.427128] atomisp-isp2 0000:00:03.0: ISP HPLL frequency base = 1600 MHz
[ 8.427229] atomisp-isp2 0000:00:03.0: Direct firmware load for shisp_2401a0_v21.bin failed with error -2
[ 8.427237] atomisp-isp2 0000:00:03.0: atomisp: Error -2 while requesting firmware shisp_2401a0_v21.bin
[ 8.428181] atomisp-isp2: probe of 0000:00:03.0 failed with error -2
[ 8.449653] input: chtdc_ti_pwrbtn as /devices/pci0000:00/808622C1:06/i2c-6/i2c-INT33F5:00/chtdc_ti_pwrbtn/input/input8
[ 8.620590] intel_rapl_common: Found RAPL domain package
[ 8.620596] intel_rapl_common: Found RAPL domain core
[ 8.814052] ath10k_pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.825295] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 9.006364] input: SIS0457:00 0457:11ED Touchscreen as /devices/pci0000:00/808622C1:05/i2c-5/i2c-SIS0457:00/0018:0457:11ED.0001/input/input9
[ 9.095786] hid-generic 0018:0457:11ED.0001: input,hidraw0: I2C HID v1.00 Device [SIS0457:00 0457:11ED] on i2c-SIS0457:00
[ 9.097477] intel-spi intel-spi: w25q64dw (8192 Kbytes)
[ 9.110059] ath10k_pci 0000:01:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 1a3b:2a51
[ 9.110066] ath10k_pci 0000:01:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 9.111191] ath10k_pci 0000:01:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 9.151640] Creating 1 MTD partitions on "intel-spi":
[ 9.151650] 0x000000000000-0x000000800000 : "BIOS"
[ 9.235755] ath10k_pci 0000:01:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 9.302490] input: SIS0457:00 0457:11ED as /devices/pci0000:00/808622C1:05/i2c-5/i2c-SIS0457:00/0018:0457:11ED.0001/input/input11
[ 9.312379] hid-multitouch 0018:0457:11ED.0001: input,hidraw0: I2C HID v1.00 Device [SIS0457:00 0457:11ED] on i2c-SIS0457:00
[ 9.333750] ath10k_pci 0000:01:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 9.420416] ath: EEPROM regdomain: 0x6a
[ 9.420420] ath: EEPROM indicates we should expect a direct regpair map
[ 9.420424] ath: Country alpha2 being used: 00
[ 9.420426] ath: Regpair used: 0x6a
[ 9.496447] loop: module loaded
[ 9.554591] cht-bsw-rt5645 cht-bsw-rt5645: snd-soc-dummy-dai <-> media-cpu-dai mapping ok
[ 9.555109] cht-bsw-rt5645 cht-bsw-rt5645: snd-soc-dummy-dai <-> deepbuffer-cpu-dai mapping ok
[ 9.569153] cht-bsw-rt5645 cht-bsw-rt5645: rt5645-aif1 <-> ssp2-port mapping ok
[ 9.578426] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 9.636107] ath10k_pci 0000:01:00.0 wlp1s0: renamed from wlan0
[ 9.669351] input: chtrt5645 Headset as /devices/pci0000:00/808622A8:00/cht-bsw-rt5645/sound/card0/input13
[ 9.728416] ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=2
[ 9.777269] hid-generic 001F:8087:0AC2.0002: hidraw1: <UNKNOWN> HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 9.780103] mousedev: PS/2 mouse device common for all mice
[ 9.793797] hid-generic 001F:8087:0AC4.0003: hidraw2: <UNKNOWN> HID v2.00 Device [hid-ishtp 8087:0AC4] on
[ 10.201522] checking generic (80000000 3f0000) vs hw (90000000 1000000)
[ 10.201528] checking generic (80000000 3f0000) vs hw (80000000 10000000)
[ 10.201531] fb0: switching to inteldrmfb from EFI VGA
[ 10.205168] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 10.205454] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 10.219715] i915 0000:00:02.0: vgaarb: changed VGA decodes: oldde-codes=io+mem,decodes=io+mem:owns=io+mem
[ 10.223482] i915 0000:00:02.0: [drm] Using SoC PWM for LCD backlight control
[ 10.299891] [drm] Initialized i915 1.6.0 20200515 for 0000:00:02.0 on minor 0
[ 10.302648] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 10.311327] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
[ 10.315432] i915 0000:00:02.0: [drm] HDaudio controller not detected, using LPE audio instead
[ 10.322900] fbcon: i915drmfb (fb0) is primary device
[ 10.322905] fbcon: Deferring console take-over
[ 10.322912] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 10.435389] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=0 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input15
[ 10.436455] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input16
[ 10.437095] input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input17
[ 10.587054] kauditd_printk_skb: 29 callbacks suppressed
[ 10.587058] audit: type=1130 audit(1602321483.753:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.631263] audit: type=1101 audit(1602321483.796:42): pid=559 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.631276] audit: type=1103 audit(1602321483.796:43): pid=559 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 10.631284] audit: type=1006 audit(1602321483.796:44): pid=559 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=2 res=1
[ 10.677480] audit: type=1105 audit(1602321483.843:45): pid=559 uid=0 auid=120 ses=2 subj==unconfined msg='op=PAM:session_open gran-tors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.725973] audit: type=1334 audit(1602321483.893:46): prog-id=11 op=LOAD
[ 10.725985] audit: type=1334 audit(1602321483.893:47): prog-id=11 op=UNLOAD
[ 10.979228] audit: type=1130 audit(1602321484.146:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.167548] audit: type=1130 audit(1602321484.330:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.199162] audit: type=1105 audit(1602321484.363:50): pid=507 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_open gran-tors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=minibus-t101ha addr=? terminal=/dev/tty1 res=success'
[ 11.345487] Bluetooth: Core ver 2.22
[ 11.348357] NET: Registered protocol family 31
[ 11.348363] Bluetooth: HCI device and connection manager initialized
[ 11.348373] Bluetooth: HCI socket layer initialized
[ 11.348378] Bluetooth: L2CAP socket layer initialized
[ 11.348395] Bluetooth: SCO socket layer initialized
[ 11.362602] input: ASUS Tech Inc. ASUS HID Device as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:0B05:183D.0004/input/input18
[ 11.419550] hid-generic 0003:0B05:183D.0004: input,hidraw1: USB HID v1.10 Keyboard [ASUS Tech Inc. ASUS HID Device ] on usb-0000:00:14.0-4/input0
[ 11.429408] hid-generic 0003:0B05:183D.0005: ignoring exceeding usage max
[ 11.434682] input: ASUS Tech Inc. ASUS HID Device as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0B05:183D.0005/input/input19
[ 11.435103] input: ASUS Tech Inc. ASUS HID Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0B05:183D.0005/input/input20
[ 11.490351] input: ASUS Tech Inc. ASUS HID Device as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0B05:183D.0005/input/input21
[ 11.491043] input: ASUS Tech Inc. ASUS HID Device System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0B05:183D.0005/input/input22
[ 11.493809] hid-generic 0003:0B05:183D.0005: input,hiddev0,hidraw2: USB HID v1.10 Device [ASUS Tech Inc. ASUS HID Device ] on usb-0000:00:14.0-4/input1
[ 11.496653] usbcore: registered new interface driver btusb
[ 11.501810] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[ 11.501816] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[ 11.560727] input: ASUS Tech Inc. ASUS HID Device Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:0B05:183D.0006/input/input23
[ 11.561147] input: ASUS Tech Inc. ASUS HID Device Touchpad as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:0B05:183D.0006/input/input24
[ 11.562430] hid-multitouch 0003:0B05:183D.0006: input,hiddev1,hidraw3: USB HID v1.10 Mouse [ASUS Tech Inc. ASUS HID Device ] on usb-0000:00:14.0-4/input2
[ 11.562775] usbcore: registered new interface driver usbhid
[ 11.562778] usbhid: USB HID core driver
[ 11.562935] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[ 11.587238] asus_wmi: ASUS WMI generic driver loaded
[ 11.609023] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.609028] Bluetooth: BNEP filters: protocol multicast
[ 11.609038] Bluetooth: BNEP socket layer initialized
[ 11.642463] input: ASUS Tech Inc. ASUS HID Device as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:0B05:183D.0004/input/input25
[ 11.699416] asus 0003:0B05:183D.0004: input,hidraw1: USB HID v1.10 Keyboard [ASUS Tech Inc. ASUS HID Device ] on usb-0000:00:14.0-4/input0
[ 11.862570] asus 0003:0B05:183D.0005: ignoring exceeding usage max
[ 11.866109] input: ASUS Tech Inc. ASUS HID Device as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:0B05:183D.0005/input/input26
[ 11.922826] asus 0003:0B05:183D.0005: input,hiddev0,hidraw2: USB HID v1.10 Device [ASUS Tech Inc. ASUS HID Device ] on usb-0000:00:14.0-4/input1
[ 12.101795] NET: Registered protocol family 38
[ 16.526722] kauditd_printk_skb: 4 callbacks suppressed
[ 16.526735] audit: type=1131 audit(1602321489.693:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.656249] audit: type=1334 audit(1602321491.823:56): prog-id=12 op=LOAD
[ 18.656569] audit: type=1334 audit(1602321491.823:57): prog-id=13 op=LOAD
[ 19.599268] audit: type=1130 audit(1602321492.763:58): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.153301] audit: type=1334 audit(1602321493.320:59): prog-id=14 op=LOAD
[ 20.153424] audit: type=1334 audit(1602321493.320:60): prog-id=15 op=LOAD
[ 20.626980] audit: type=1130 audit(1602321493.793:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.022379] audit: type=1131 audit(1602321494.186:62): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.238806] audit: type=1130 audit(1602321494.403:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.476373] intel_sst_acpi 808622A8:00: FW Version 01.0b.02.02
[ 21.687527] audit: type=1130 audit(1602321494.853:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.887283] rfkill: input handler disabled
[ 22.050789] audit: type=1130 audit(1602321495.216:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.089561] Bluetooth: RFCOMM TTY layer initialized
[ 22.089576] Bluetooth: RFCOMM socket layer initialized
[ 22.089596] Bluetooth: RFCOMM ver 1.11
[ 23.889812] audit: type=1130 audit(1602321497.056:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.979947] wlp1s0: authenticate with 12:13:31:5b:3e:a7
[ 31.014964] wlp1s0: send auth to 12:13:31:5b:3e:a7 (try 1/3)
[ 31.016303] wlp1s0: authenticated
[ 31.022561] wlp1s0: associate with 12:13:31:5b:3e:a7 (try 1/3)
[ 31.024155] wlp1s0: RX AssocResp from 12:13:31:5b:3e:a7 (capab=0x11 status=0 aid=5)
[ 31.029858] wlp1s0: associated
[ 31.030366] ath: EEPROM regdomain: 0x817c
[ 31.030369] ath: EEPROM indicates we should expect a country code
[ 31.030371] ath: doing EEPROM country->regdmn map search
[ 31.030373] ath: country maps to regdmn code: 0x37
[ 31.030375] ath: Country alpha2 being used: IT
[ 31.030376] ath: Regpair used: 0x37
[ 31.030379] ath: regdomain 0x817c dynamically updated by country element
[ 31.118921] wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 12:13:31:5b:3e:a7
[ 31.120309] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[ 32.448358] audit: type=1130 audit(1602321505.613:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.548414] audit: type=1130 audit(1602321505.713:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.635204] audit: type=1130 audit(1602321505.800:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.266045] audit: type=1100 audit(1602321513.433:70): pid=1034 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication gran-tors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="minibus" exe="/usr/lib/gdm-session-worker" hostname=minibus-t101ha addr=? terminal=/dev/tty1 res=success'
[ 40.275679] audit: type=1101 audit(1602321513.440:71): pid=1034 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="minibus" exe="/usr/lib/gdm-session-worker" hostname=minibus-t101ha addr=? terminal=/dev/tty1 res=success'
[ 40.284715] audit: type=1103 audit(1602321513.450:72): pid=1034 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred gran-tors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="minibus" exe="/usr/lib/gdm-session-worker" hostname=minibus-t101ha addr=? terminal=/dev/tty1 res=success'
[ 40.329550] audit: type=1006 audit(1602321513.496:73): pid=1034 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 40.439319] audit: type=1130 audit(1602321513.603:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.470984] audit: type=1101 audit(1602321513.636:75): pid=1040 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="minibus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.471173] audit: type=1103 audit(1602321513.636:76): pid=1040 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="minibus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 40.471529] audit: type=1006 audit(1602321513.636:77): pid=1040 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 40.511243] audit: type=1105 audit(1602321513.676:78): pid=1040 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open gran-tors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="minibus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.537833] audit: type=1334 audit(1602321513.703:79): prog-id=16 op=LOAD
[ 41.385785] rfkill: input handler enabled
[ 42.533049] fuse: init (API version 7.31)
[ 48.570659] kauditd_printk_skb: 5 callbacks suppressed
[ 48.570664] audit: type=1130 audit(1602321521.736:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.606043] rfkill: input handler disabled
[ 54.011330] audit: type=1131 audit(1602321527.176:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 80.954141] audit: type=1131 audit(1602321554.120:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.017877] audit: type=1131 audit(1602321554.183:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.032765] audit: type=1334 audit(1602321554.200:89): prog-id=13 op=UNLOAD
[ 81.032784] audit: type=1334 audit(1602321554.200:90): prog-id=12 op=UNLOAD
[ 81.229033] audit: type=1131 audit(1602321554.393:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" host-name=? addr=? terminal=? res=success'
[ 81.292830] audit: type=1334 audit(1602321554.460:92): prog-id=10 op=UNLOAD
[ 81.292842] audit: type=1334 audit(1602321554.460:93): prog-id=9 op=UNLOAD
[ 179.730703] audit: type=1130 audit(1602321652.896:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 182.920416] audit: type=1100 audit(1602321656.086:95): pid=1887 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 182.926016] audit: type=1101 audit(1602321656.093:96): pid=1887 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 182.926986] audit: type=1110 audit(1602321656.093:97): pid=1887 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 182.935415] audit: type=1105 audit(1602321656.100:98): pid=1887 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 182.952727] i2c /dev entries driver
[ 182.958249] audit: type=1106 audit(1602321656.123:99): pid=1887 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 182.959444] audit: type=1104 audit(1602321656.126:100): pid=1887 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 193.757682] audit: type=1101 audit(1602321666.923:101): pid=1906 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 193.758412] audit: type=1110 audit(1602321666.923:102): pid=1906 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 193.770837] audit: type=1105 audit(1602321666.936:103): pid=1906 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 193.781162] audit: type=1106 audit(1602321666.946:104): pid=1906 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 193.781213] audit: type=1104 audit(1602321666.946:105): pid=1906 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 197.901187] audit: type=1101 audit(1602321671.066:106): pid=1913 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 197.901773] audit: type=1110 audit(1602321671.066:107): pid=1913 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 197.911463] audit: type=1105 audit(1602321671.076:108): pid=1913 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 197.919307] audit: type=1106 audit(1602321671.086:109): pid=1913 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 197.919345] audit: type=1104 audit(1602321671.086:110): pid=1913 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 210.027113] audit: type=1131 audit(1602321683.193:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 328.954485] audit: type=1130 audit(1602321802.120:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 332.868235] audit: type=1100 audit(1602321806.033:113): pid=2099 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 332.874049] audit: type=1101 audit(1602321806.040:114): pid=2099 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 332.874792] audit: type=1110 audit(1602321806.040:115): pid=2099 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 332.884819] audit: type=1105 audit(1602321806.050:116): pid=2099 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 332.894052] audit: type=1106 audit(1602321806.060:117): pid=2099 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 332.894084] audit: type=1104 audit(1602321806.060:118): pid=2099 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 339.158247] audit: type=1101 audit(1602321812.323:119): pid=2117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="minibus" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 339.158923] audit: type=1110 audit(1602321812.323:120): pid=2117 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 339.171147] audit: type=1105 audit(1602321812.336:121): pid=2117 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
Since it is kinda long, I’ll highlight the red parts of the terminal and a NOTICE NOTICE NOTICE thing that showed up there:
[ 8.373931] ** **
[ 8.373934] ** **
[ 8.373938] ** **
[ 8.373942] ** **
Here it is the inxi -Fazy output as asked by Pobrn:
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=a9ccd26c-f160-45b1-b922-1f9edbeff75c rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Detachable System: ASUSTeK product: T101HA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: T101HA v: 1.0 serial: <filter>
UEFI: American Megatrends v: T101HA.304 date: 06/05/2017
ID-1: BATC charge: 19.1 Wh condition: 28.7/31.6 Wh (91%) volts: 3.9/3.8
model: Intel SR 1 SR Real Battery type: Li-ion serial: <filter>
status: Discharging cycles: 29
Topology: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP
arch: Airmont family: 6 model-id: 4C (76) stepping: 4 microcode: 411
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11524
Speed: 545 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 575 2: 543 3: 480
4: 480
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b0
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics (CHV) v: 4.6 Mesa 20.1.8
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
Imaging Unit
driver: N/A alternate: atomisp bus ID: 00:03.0 chip ID: 8086:22b8
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel port: f000 bus ID: 01:00.0
chip ID: 168c:0042
Local Storage: total: 58.24 GiB used: 7.69 GiB (13.2%)
ID-1: /dev/mmcblk0 model: DF4064 size: 58.24 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 0x8 scheme: GPT
ID-1: / raw size: 57.95 GiB size: 56.79 GiB (98.00%) used: 7.69 GiB (13.5%)
fs: ext4 dev: /dev/mmcblk0p2
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 262 Uptime: 48m Memory: 3.68 GiB used: 987.3 MiB (26.2%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: 1169 pacman: 1165
lib: 314 flatpak: 0 snap: 4 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.05
Here is the ls /dev/video* output:
zsh: no matches found: /dev/video*
Here is the lspci output:
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 36)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 36)
00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit (rev ff)
00:0a.0 Non-VGA unclassified device: Intel Corporation Device 22d8 (rev 36)
00:0b.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller (rev 36)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 36)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 36)
00:1c.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1 (rev 36)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 36)
01:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
