Manjaro Linux 64-Bit, XFCE-Version 4.16
Hello,
on my Asus ROG G750JS i can’t disable my touchpad by using Fn+F9.
I can only disable the touch function in the mouse-/touchpad settings.
is there a fix for this know?
greetings from germany
Heiko
Hello,
Heiko
I’ve personally had this same issue on every single laptop I’ve owned while using Linux. So I don’t know if it’s solvable for you or not.
You can probably assign that key via a shortcut or something to do:
Hello
To do what? With witch script ein can disable the Touchpad?
Greetings Heiko
To give you a script, we need to have a full inxi
output, but if you’re running xorg
you can:
xinput list
and then:
xinput list-props NN
where NN
is the number that the list
command gave you for your touchpad and then:
xinput set-prop NN MM 0
where MM
is the number for the Device Enabled
setting and 0
to disable it.
[heiko@heiko-g750js ~]$ inxi -F
Host: heiko-g750js Kernel: 5.9.16-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: G750JS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
ID-1: BAT0 charge: 71.4 Wh (99.4%) condition: 71.8/77.0 Wh (93.3%)
volts: 14.8 min: 14.8
Info: Quad Core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
L2: 6 MiB
Speed: 938 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 938 2: 1526
3: 1151 4: 1530 5: 971 6: 1477 7: 1381 8: 1554
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: intel resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.4
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
IF: wlp3s0 state: down mac: e2:46:60:7a:5e:27
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 40:16:7e:11:a1:29
Device-1: IMC Networks BCM20702A0 type: USB driver: btusb
Local Storage: total: 1.6 TiB used: 605.56 GiB (37.0%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
ID-1: / size: 233.43 GiB used: 87.93 GiB (37.7%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sdb1
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 254 Uptime: 3d 2h 20m Memory: 30.82 GiB used: 1.89 GiB (6.1%)
Shell: Bash inxi: 3.3.03
xinput will not found.
Greetings from
Heiko
I can’t help you then and you need someone with more in-depth XFCE knowledge.
