I am having an annoying problem on my laptop Asus Rog G551VW.
I have noise starts when I use my headphones.
My laptop has one input for both sound and microphone.
I spent the last two days to find a proper solution.
It’s sensible to mention that I faced this problem across the most famous distros.
Let me list all solutions that I tried recently, whereas I should mention that on a fresh installation the noise in the headphones doesn’t disappear at all whether in reboot or suspend.
Solution #1 (pop_os 21.04/ manjaro 21.1.6 lts-kernel)
Summary
Add
options snd-hda-intel model=
alc668-headset enable=1 index=0
In
/etc/modprobe.d/alsa-base.conf
and reboot.
Observation
1- No noise sound on startup.
2- The noise return when suspending, to solve the problem I must reboot/shutdown.
Solution #2 (pop_os 21.04/ manjaro 21.1.6 lts-kernel)
Summary
Add
options snd-hda-intel power_save=0
In
and reboot
See
cat /sys/module/snd_hda_intel/parameters/power_save
=> 0
Observation
Solution #3 (pop_os 21.04/ manjaro 21.1.6 lts-kernel)
Summary
Add
To
/etc/modprobe.d/alsa-base.conf and reboot
Set laptop to suspend
Run
sudo alsa force-reload
pulseaudio -k
Observation
2-The noise return when suspend. When run sudo alsa force-reload
the noise disappear, maybe you need to run that command many time.
3- This solution does not work on manjaro, when you run it "sudo: alsa: command not found".
Info
Laptop model: Asus Rog G551VW/Optimus (NVIDIA/Intel)
Sound Card: HDA Intel PCH
Chip Name: Realtek ALC668
OS: manjaro 21.1.6 lts-kernel
More Info
inxi -Fazy
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a03d9cab-b854-4ad0-b95c-c9687419c013 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: G551VW v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G551VW v: 1.0 serial: <filter>
UEFI: American Megatrends v: G551VW.303 date: 04/19/2019
ID-1: BAT0 charge: 23.4 Wh (95.1%) condition: 24.6/56.2 Wh (43.8%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 355
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 6 MiB
bogomips: 41621
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:139b class-ID: 0302
Device-3: Chicony HD WebCam (Asus N-series) type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 04f2:b3fd class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
bus-ID: 1-9:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.03 TiB used: 10.07 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: RBU-SMSM151S3128GD1
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 02.5 scheme: GPT
ID-1: / raw-size: 118.74 GiB size: 116.32 GiB (97.96%)
used: 10.07 GiB (8.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 42.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 245 Uptime: 1h 29m wakeups: 5620 Memory: 15.5 GiB
used: 2.78 GiB (17.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1204 lib: 329 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
So, I think the problem is because of ALSA. The solution #3 works but on arch-based distros the command sudo alsa force-reload
does not work at all.
