Following on from here,
I have run a cable to the desktop so I now have internet. Now I just need to get the right driver for the ASUS PCE-ax58BT.
Results of inxi -Farz
if it helps.
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=23238af6-3417-4894-978c-42762b2cbe70 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X470-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 4602 date: 03/07/2019
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2534 high: 3700 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2055
3: 2200 4: 2200 5: 2200 6: 2200 7: 3700 8: 3700 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 3200 15: 2200 16: 3700 bogomips: 118220
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DVI-D-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2 bus-ID: 09:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 53.0 C
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: BenQ xl2411t serial: <filter>
built: 2013 res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 16.0.6 DRM 3.54 6.6.26-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:5 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci1 rfk-id: 1 state: up address: see --recommends
Device-2: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:8771
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 2.11 TiB used: 586.31 GiB (27.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 40.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 22.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD3200AVVS-14L2B0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5000 serial: <filter>
fw-rev: 3A01 scheme: GPT
ID-1: / raw-size: 216.91 GiB size: 212.44 GiB (97.94%)
used: 24.97 GiB (11.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
System Temperatures: cpu: 39.4 C mobo: 35.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 0 case-3: 0 gpu: amdgpu
fan: 238
Power: 12v: 10.19 5v: N/A 3.3v: N/A vbat: N/A gpu: amdgpu watts: 30.02
Packages: pm: pacman pkgs: 1166 libs: 370 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Memory: total: 32 GiB available: 31.27 GiB used: 2.51 GiB (8.0%)
Processes: 366 Power: uptime: 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
