Hello,
After installing manjaro on ASUS TUF Dash F15 FX517ZM I am facing a problem. I am unable to change the keyboard animation from breathing to static. I also tried asusctl, but i found out that FX517ZM is not supported. Is there any other way to get rid of this annoying animation? Thank you in advance for the answer.
Welcome to Manjaro! ![:smiling_face_with_three_hearts: :smiling_face_with_three_hearts:](https://forum.manjaro.org/images/emoji/twitter/smiling_face_with_three_hearts.png?v=12)
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already for your problem in the forum ? (Wisdom lies in asking → listening → reading
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
