There are dedicated left and right buttons above the touchpad area, which are not working in my Asus Expertbook. xinput list shows a Touchpad and a Mouse entry as well (see below).
According to evtest, Touchpad works fine but there is no output for the Mouse events, when I click on the dedicated buttons.
Thanks for the support!
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ASUE1201:00 04F3:3148 Mouse id=10 [slave pointer (2)]
⎜ ↳ ASUE1201:00 04F3:3148 Touchpad id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=13 [slave keyboard (3)]
↳ Asus WMI hotkeys id=12 [slave keyboard (3)]
↳ USB2.0 HD UVC WebCam: USB2.0 HD id=9 [slave keyboard (3)]
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a5d23537-b4c3-4a6f-8c82-f873b8296de8 rw quiet apparmor=1
security=apparmor resume=UUID=9f60eed5-2e00-41bd-8712-eb972f4f3300
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK P2451FA_P2451FA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: P2451FA v: 1.0 serial: <superuser required>
UEFI: ASUSTeK v: P2451FA.303 date: 10/20/2020
ID-1: BAT0 charge: 43.5 Wh (100.0%) condition: 43.5/48.0 Wh (90.7%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 46
RAM: total: 15.47 GiB used: 5.37 GiB (34.7%)
RAM Report:
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
IF: eno2 state: down mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 51.63 GiB (10.8%)
model: MZVLQ512HALU-00000 size: 476.94 GiB block-size: physical: 512 B
rev: FXV7101Q temp: 29.9 C scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 23.6 GiB (48.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a5d23537-b4c3-4a6f-8c82-f873b8296de8
label: NO_LABEL uuid: 1CC4-8442
ID-3: /home raw-size: 416.43 GiB size: 408.83 GiB (98.17%)
used: 28.03 GiB (6.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 598be76d-f16b-43e3-adbf-e904bc926990
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9f60eed5-2e00-41bd-8712-eb972f4f3300
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:6 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-4:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-5:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-4: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C pch: 38.0 C mobo: N/A
Processes: 284 Uptime: 1d 10m wakeups: 3 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1429
lib: 384 flatpak: 0 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.15
