Hi
I have a problem on my Asus TUF Gaming FX705GD.
I can’t control my CPU fan. Let me explain, the Fn+F5 key work but for some reason, the CPU fan become overfast with 35-40 temperature. I have to manually press Fn+F5 key to stop it but after a few minute, the CPU fan re-become overfast.
I don’t know what is the problem.
[axeln@axel-tufgamingfx705gd ~]$ inxi -Fazy
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=f95d6bd2-a05c-4ca3-b04a-731e3119bf1b ro quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.dmic_detect=0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX705GD_FX705GD v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX705GD v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX705GD.306 date: 05/25/2020
ID-1: BAT0 charge: 48.0 Wh condition: 53.5/64.1 Wh (83%) volts: 16.0/15.6
model: Simplo SDI ICR18650 type: Li-ion serial: <filter> status: Discharging
cycles: 41
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 8 MiB
bogomips: 36812
Speed: 900 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-11:3 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: fbdev alternate: intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 6000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000
bus ID: 03:00.0 chip ID: 10ec:8168
Local Storage: total: 1.03 TiB used: 295.06 GiB (28.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3128GJ
size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: E8FK11.C temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0J
ID-1: / raw size: 44.06 GiB size: 43.12 GiB (97.86%) used: 21.01 GiB (48.7%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 45.9 MiB (17.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw size: 455.31 GiB size: 447.16 GiB (98.21%)
used: 274 GiB (61.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 41.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Processes: 284 Uptime: 17m wakeups: 1 Memory: 7.63 GiB
used: 3.93 GiB (51.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1804 lib: 524 flatpak: 0 Shell: Bash
v: 5.1.0 running in: konsole inxi: 3.2.02
I have trying : fancontrol (with sensors-detect and pwmconfig) : https://wiki.archlinux.org/index.php/Fan_speed_control => same issue
and on arch wiki https://wiki.archlinux.org/index.php/Fan_speed_control#asus-nb-wmi but fancontrol not work and on the asus-nb-wmi section, the command to control fan don’t work.
I have tried too asus_fanmode on https://github.com/leonmaxx/asus_fanmode => same issue
Switching kernel (5.10, 5.9, 5.4 lts) => same issue
But nothing work.
I don’t know if it’s related but when I play a video game and I quit it, the CPU and GPU fans stay overfast even when the temperature drops to 35 ° C. I have to either restart the PC or put it to sleep and then wake it up.
Someone can help me ?
PS : my bios is up to date
