New user to this distro! As the title suggests my wireless adapter is not being detected on my computer while on Manjaro. However, it runs perfectly fine when I am on Windows. I am rather confused as to what to do, and I would greatly appreciate some help on what to do. Thank you.
Hi!
Go to manjaro settings/hardware and check if there any driver for your dongle.
If not, you need to now what chip uses the usb wifi. Run inxi -N to figure it out
Hello visone!
Thank you for responding so quickly! I’ve ran the snippet that you suggested, and here are the specs.
ASUSTek USB-AC56 802.11a/b/gn/ac Wireless Adapter [Realtek RTL8812AU]
type: USB driver: usb-network.
Quick question where would I go under the settings or the hardware to check for the drivers?
I checked the hardware configurations and I did not find the drivers or the dongle for the wireless usb. Where would I go to install rtl8812au-dkms from AUR repos? Would this be in the Konsole? Thank you for your help!
Hi!
Go to the update manager aplications, preferences, enable AUR. Then you can search that driver from the package manager or from terminal.
Package manager
Search the package and install it
Terminal
Update your system and Install AUR helper sudo pacman -Syu yay
I guess I’m still having some trouble. I was able to enable AUR, but I’m still having some trouble. The search function is not able to find any of the relevant drivers, and when I tried typing in the first snippet into the terminal I errors. This is frustrating.
