Asrock Trx40 creator audio not work?
Hi i try use google to fix Asrock Trx40 creator audio problem but seems not fix to now ?
using kernel 5.11 & 5.12 not any help.
  $ inxi -Fx
    System:    Host: mz-trx1 Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.3
    Machine:   Type: Desktop Mobo: ASRock model: TRX40 Creator serial: <superuser required> UEFI: American Megatrends v: P1.70
               date: 05/29/2020
    Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX Anywhere 2S charge: 55% (should be ignored)
               status: Discharging
    CPU:       Info: 32-Core (4-Die) model: AMD Ryzen Threadripper 3970X bits: 64 type: MT MCP MCM arch: Zen 2 rev: 0 cache:
               L2: 16 MiB
               flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 473835
               Speed: 3600 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 3600 2: 2058 3: 2200 4: 2199 5: 2198
               6: 2197 7: 2199 8: 2198 9: 2199 10: 2199 11: 2199 12: 2196 13: 3649 14: 2200 15: 2195 16: 2194 17: 2199 18: 2198
               19: 2193 20: 2196 21: 2199 22: 2199 23: 2197 24: 2054 25: 2160 26: 2199 27: 3592 28: 2057 29: 3597 30: 2056
               31: 2199 32: 2196 33: 2199 34: 2200 35: 2199 36: 2201 37: 2200 38: 2198 39: 2199 40: 2199 41: 2198 42: 2198
               43: 2200 44: 2983 45: 2198 46: 2201 47: 2200 48: 2201 49: 2199 50: 2196 51: 2197 52: 2199 53: 2195 54: 2194
               55: 2198 56: 2199 57: 2199 58: 2200 59: 2194 60: 2199 61: 2198 62: 2199 63: 2199 64: 2199
    Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon Pro WX 7100] driver: amdgpu v: kernel bus-ID: 01:00.0
               Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon Pro WX 5100] driver: amdgpu v: kernel bus-ID: 21:00.0
               Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1: 3840x2160~60Hz
               2: 3840x2160~60Hz
               OpenGL: renderer: AMD Radeon Pro WX 7100 Graphics (POLARIS10 DRM 3.40.0 5.11.10-1-MANJARO LLVM 11.1.0)
               v: 4.6 Mesa 21.0.1 direct render: Yes
    Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] driver: snd_hda_intel v: kernel
               bus-ID: 01:00.1
               Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] driver: snd_hda_intel v: kernel
               bus-ID: 21:00.1
               Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio driver: snd_hda_intel v: kernel bus-ID: 23:00.4
               Device-4: Generic USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-5:2
               Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
               Sound Server-4: PipeWire v: 0.3.24 running: no
    Network:   Device-1: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion] vendor: ASRock driver: atlantic v: kernel
               port: 6000 bus-ID: 45:00.0
               IF: enp69s0 state: down mac: a8:a1:59:60:08:17
               Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 6000 bus-ID: 46:00.0
               IF: wlp70s0 state: down mac: 52:6b:bf:47:e7:ca
               Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel port: c000 bus-ID: 47:00.0
               IF: enp71s0 state: up speed: 1000 Mbps duplex: full mac: a8:a1:59:60:08:19
    Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 7-6:3
    Drives:    Local Storage: total: 18.19 TiB used: 216.17 GiB (1.2%)
               ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket Q size: 3.64 TiB temp: 29.9 C
               ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket Q size: 3.64 TiB temp: 33.9 C
               ID-3: /dev/nvme2n1 vendor: Sabrent model: Rocket Q size: 3.64 TiB temp: 35.9 C
               ID-4: /dev/sda vendor: Samsung model: SSD 850 EVO 4TB size: 3.64 TiB
               ID-5: /dev/sdb vendor: Samsung model: SSD 860 EVO 4TB size: 3.64 TiB
    Partition: ID-1: / size: 335.36 GiB used: 7.64 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p8
               ID-2: /boot/efi size: 96 MiB used: 31.8 MiB (33.1%) fs: vfat dev: /dev/nvme0n1p1
    Swap:      Alert: No swap data was found.
    Sensors:   System Temperatures: cpu: 51.1 C mobo: 0 C
               GPU: device: amdgpu temp: 51.0 C fan: 1111 device: amdgpu temp: 62.0 C fan: 1198
    Info:      Processes: 814 Uptime: 16m Memory: 125.71 GiB used: 4.22 GiB (3.4%) Init: systemd Compilers: gcc: N/A
               Packages: 1195 Shell: Bash v: 5.1.0 inxi: 3.3.04
$pacmd list-cards
    3 card(s) available.
        index: 0
            driver: <module-alsa-card.c>
            owner module: 6
            properties:
                    alsa.card = "0"
                    alsa.card_name = "HDA ATI HDMI"
                    alsa.long_card_name = "HDA ATI HDMI at 0xe6160000 irq 199"
                    device.bus_path = "pci-0000:01:00.1"
                    sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0"
                    device.bus = "pci"
                    device.vendor.id = "1002"
                    device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                    device.product.id = "aaf0"
                    device.product.name = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
                    device.string = "0"
                    device.description = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
                    module-udev-detect.discovered = "1"
                    device.icon_name = "audio-card-pci"
            profiles:
                    output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
                    output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
                    output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
                    output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
                    output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
                    output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
                    output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
                    output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
                    output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
                    output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
                    output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
                    output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
                    output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: unknown)
                    output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: unknown)
                    off: Off (priority 0, available: unknown)
            active profile: <output:hdmi-stereo-extra4>
            sinks:
                    alsa_output.pci-0000_01_00.1.hdmi-stereo-extra4/#0: Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 5)
            sources:
                    alsa_output.pci-0000_01_00.1.hdmi-stereo-extra4.monitor/#0: Monitor of Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 5)
            ports:
                    hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
                            properties:
                    hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
                            properties:
                    hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
                            properties:
                    hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
                            properties:
                    hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: yes)
                            properties:
                                    device.product.name = "PHL BDM4350"
                    hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: yes)
                            properties:
        index: 1
            owner module: 7
            properties:
                    alsa.card = "1"
                    alsa.long_card_name = "HDA ATI HDMI at 0xc2360000 irq 201"
                    device.bus_path = "pci-0000:21:00.1"
                    sysfs.path = "/devices/pci0000:20/0000:20:03.1/0000:21:00.1/sound/card1"
                    device.bus = "pci"
                    device.string = "1"
            profiles:
                    output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
                    output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
                    output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
                    output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
                    output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
                    output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
            active profile: <off>
            ports:
                            properties:
                            properties:
                            properties:
                            properties:
                    hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
                            properties:
                    hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
                            properties:
        index: 2
            owner module: 9
            properties:
                    alsa.card = "3"
                    alsa.card_name = "ALC1220-VB-DT"
                    alsa.long_card_name = "Realtek-ALC1220-VB-Desktop"
                    alsa.driver_name = "snd_usb_audio"
                    device.bus_path = "pci-0000:48:00.3-usb-0:5:1.0"
                    sysfs.path = "/devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:48:00.3/usb9/9-5/9-5:1.0/sound/card3"
                    udev.id = "usb-Generic_USB_Audio-00"
                    device.bus = "usb"
                    device.vendor.id = "26ce"
                    device.vendor.name = "Generic"
                    device.product.id = "0a01"
                    device.product.name = "USB Audio"
                    device.serial = "Generic_USB_Audio"
                    device.string = "3"
                    device.description = "USB Audio"
                    device.icon_name = "audio-card-usb"
            profiles:
                    HiFi: Default Alsa Profile (priority 8000, available: no)
            ports:
                    [Out] SPDIF: S/PDIF Out (priority 200, latency offset 0 usec, available: unknown)
                            properties:
                    [Out] Headphones: Front Headphones (priority 300, latency offset 0 usec, available: no)
                            properties:
                    [Out] Speaker: Speakers (priority 100, latency offset 0 usec, available: yes)
                            properties:
                    [In] Mic2: Front Microphone (priority 300, latency offset 0 usec, available: no)
                            properties:
                    [In] Mic1: Microphone (priority 200, latency offset 0 usec, available: no)
                            properties:
                    [In] Line: Line In (priority 100, latency offset 0 usec, available: no)
                        properties:
Nice :slight_smile:
when install pavucontrol-qt in configuration section :slight_smile:
when enable profile it go to work (but not stable) and when restart PC must do active again !
Welcome to Manjaro forum
This motherboard has a few hardware scans from other Linux users – https://linux-hardware.org/?id=usb:26ce-0a01
Most of the data scans do not include audio information, but the scan for 3b1961ec14 - Arch Rolling has data about audio devices and settings
Motherboard has dual audio codecs and a headphone amplifier
ASRock > TRX40 Creator
7.1 CH HD Audio (Realtek ALC4050H+ALC1220)
NE5532 Premium Headset Amplifier for Front Panel Audio Connector
ALC4050H splits audio to ALC1220 for surround sound channels and capture inputs and NE5532 analog amplifier for headphone output
The combined audio devices are detected as a USB device
index: 2
            properties:
                    alsa.card = "3"
There are only 2 possible profiles available for PulseAudio Off and HiFi
        profiles:
PulseAudio will avoid using the HiFi profile because it is detected as not available
But it might be possible to make the Profile available by turning on inputs and outputs in ALSA
( Ports shown as unavailable:no in PulseAudio)
Please post response to this command to show ALSA controls
amixer -c3
amixer -c3
Invalid card number.
Usage: amixer [command]
Please post response to this command to show detailed ALSA information
sudo alsa-info.sh --upload
http://alsa-project.org/db/?f=1d98729a73aaa95aec0093de1f5fa4ad2a54fdfe
The final section of ALSA data !!ALSA/HDA dmesg is showing a Linux boot option to blacklist the main audio driver - modprobe.blacklist=snd_hda_intel
So ALSA is unable to detect the onboard audio correctly
[ 11.631152] snd_hda_intel 0000:23:00.4: no codecs found!
I suggest you remove this GRUB boot option (and update GRUB)
then reboot system and check if audio is detected and working better
hi
i think is not my problem , via some reason (using 2nd gpu & and gpu builtin sound in vfio ) i disable amdgpu & snd_hda_intel in boot via grub and after set vfio driver for specific device (2nd gpu and her sound !) load module : before login
modprobe snd-hda-intel
modprobe amdgpu
then snd-hda-intel load true
note for sure again back grub to default
but no any change in motherboard sound …
:frowning:
Linux Kernel was patched for audio on TRX40 motherboards in January
210783 – Support Realtek ALC1220 USB audio device 0b05:1918 for ASUS PRIME TRX40 PRO-S motherboard
and there was a fix for alsa-ucm-conf to deal with the unfamiliar 8 channel device
Add initial support for Realtek ALC1220 TRX40 motherboards
If the HiFi profile works for audio playback when selected manually in PulseAudio controls, this command should also change the profile
pacmd set-card-profile alsa_card.usb-Generic_USB_Audio-00 HiFi
Thx nikgnomic
  1. seems your link show this is fix in kernel 5.11 and i use kernel 5.11 bot not problem fix.
2.for me not clear alsa must patched to trx40 motherboard work ??
and if question is yes can help me to done it ?
3.yes ```
this work but how dot it permanently ?
The Links were to show the kernel and ALSA patches that are already included in your system
The Pulseaudio data shows that the Hifi Profile and the Ports from alsa-ucm-conf are in place
The command suggested to is only a temporary fix to get audio working again when audio resets to Off
PulseAudio will continue to switch to Off because the HiFi profile is shown as available: no
If the Hifi profile is changed so it is detected as available:yes or available:unknown then PulseAudio will not try to switch away from the working profile
Try this to adjust PulseAudio configuration
(previously suggested in this forum post - #15 by philm)
Open Pulseaudio configuration file for analog-outputs in a text editor
sudo nano /usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
find this section:
[Element Desktop Speaker]
switch = off
volume = off
change it to this:
switch = on
volume = on
save changes Ctrl + O and exit nano Ctrl + X
Then reboot system and check the Pulseaudio Profile and Ports in pacmd list-cards
set not any help :frowning:
2 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = “1”
alsa.card_name = “HDA ATI HDMI”
alsa.long_card_name = “HDA ATI HDMI at 0xe6160000 irq 199”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:01:00.1”
sysfs.path = “/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1”
device.bus = “pci”
device.vendor.id = “1002”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD/ATI]”
device.product.id = “aaf0”
device.product.name = “Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]”
device.string = “1”
device.description = “Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
profiles:
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: unknown)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: unknown)
active profile: output:hdmi-stereo-extra5
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra5/#1: Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 6)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra5.monitor/#1: Monitor of Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 6)
ports:
properties:
device.icon_name = “video-display”
properties:
properties:
properties:
properties:
device.product.name = “PHL BDM4350”
properties:
index: 1
owner module: 8
properties:
alsa.card = “0”
alsa.card_name = “ALC1220-VB-DT”
alsa.long_card_name = “Realtek-ALC1220-VB-Desktop”
alsa.driver_name = “snd_usb_audio”
device.bus_path = “pci-0000:48:00.3-usb-0:5:1.0”
sysfs.path = “/devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:48:00.3/usb9/9-5/9-5:1.0/sound/card0”
udev.id = “usb-Generic_USB_Audio-00”
device.bus = “usb”
device.vendor.id = “26ce”
device.vendor.name = “Generic”
device.product.id = “0a01”
device.product.name = “USB Audio”
device.serial = “Generic_USB_Audio”
device.string = “0”
device.description = “USB Audio”
device.icon_name = “audio-card-usb”
profiles:
active profile:
ports:
[Out] SPDIF: S/PDIF Out (priority 100, latency offset 0 usec, available: unknown)
properties:
                    properties:
            [Out] Speaker: Speakers (priority 200, latency offset 0 usec, available: yes)
                    properties:
                    properties:
                    properties:
                    properties:
