there’s a text artifact in the tray below the clock - it looks like it reads “wallchan:com” or similar - i suppose it might be from an old widget, such as redshift
how do i get rid of it? i can’t do anything with it in edit mode
It looks like it’s a text on your wallpaper.
Seconded. It’s showing through the taskbar transparency, I imagine…
you guys are right - it is on the wallpaper
the problem is that the ‘opaque’ setting for the task manager doesn’t stay set; it always revers to ‘translucent’
Then you need to use an updated plasma style.
