Arming ConditionNeedsUpdate
I’m running KDE unstable on an RPI-5.
I just ran:
sudo pacman -Syu
There was one package to update, “raspberrypi-utils-20241118-1”.
The installation has stopped with the notification:
(2/2) Arming ConditionNeedsUpdate…
and has not completed.
Is this a problem?
No problem here on XFCE:
Packages (1) raspberrypi-utils-20241118-1
Total Installed Size:  1.25 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) reinstalling raspberrypi-utils               [######################] 100%
(1/4) Reloading device manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Refreshing PackageKit...
(4/4) Checking which packages need to be rebuilt
[ray@jellyfin packages]$
Didn’t get to
Refreshing PackageKit…
Should I just CTRL-C and hope for the best?
Looks like yours had 2/2 while mine had 2/4 processes to do at that point. I have more stuff installed than you do. I would try CTRL-C and and re-install the package and see if the process will complete.
Oops. Now I get:
error: failed to synchronize all databases (unable to lock database)
How do I get out of this situation?
sudo rm /var/lib/pacman/db.lck
Thanks. Now it gives “there is nothing to do”.
I also checked the list of packages, and the updated package is there. Thanks for your help.
Packagekit is actively buggy as well as a security problem.
You should probably not have anything related to it installed.
