[ARM Testing Update] 2025-08-26 - Firmware, KDE Gear 25.08.0, Python, XFCE
Hello ARM community.
here is another update, after the non-annouced one from 2024-08-14. This time of 862 packages to our testing branch. It is recommended to check the troubleshoots from x86-64 and tips and tricks people gave there.
To been able to push packages further to stable branch we need more maintainers and testers for Manjaro ARM. So if you own ARM SBCs or devices like Pine64 Pinebooks or Phones you can contact us. Only together we can ensure that the set of packages is stable enough for wider usage.
Update Announcement
Some highlights:
  • Linux-Firmware
  • KDE Gear 25.08.0
  • Python and some XFCE
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Tue Aug 19 16:30:06 CEST 2025)
  • arm-testing core aarch64: 34 new and 34 removed package(s)
  • arm-testing extra aarch64: 828 new and 838 removed package(s)
A detailed list of packages can be found here.
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
:arrow_right: 2024-04-24
Calendar does not launch
  • If you have gnome-calendar-mobile installed, please run the following to replace it:
    • sudo pacamn -S gnome-calendar
Pinephone Pro: Phosh: App windows not rendered correctly
  • Problem: After updating gtk4 from 1:4.12.5-1 to 1:4.14.3-1, if you open an app (like settings), then go to a submenu (i.e. Mobile Network → Acess Point Names), somewhere during that process you will get either a black screen, or partially rendered windows, making the interface unusable.
  • Workaround: set the default renderer to OpenGL with the following, followed by a reboot:
echo "export GSK_RENDERER=gl"|sudo tee /etc/profile.d/gsk-renderer-gl.sh
Chatty >=0.8.2 No message notification if contact list is empty
  • Problem: Notifications are not generated on PinephonePro (bisected, issue reported upstream)
  • Workaround: make sure there is at least one contact in your contacts list, or downgrade to 0.8.1
2024-01-29
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
– Arch Linux - News: Making dbus-broker our default D-Bus daemon
In some cases, however it is better to keep the legacy way. Here are some examples: Dbus-broker warnings
Firefox no longer honors gtk font size settings in user interface. Solved by setting about:config browser.display.os-zoom-behavior to 0 (zero)
2023-12-20
Pinephone Pro: Phosh: volume constantly changes
  • Problem: PKGBUILD for uboot-pinephonepro introduced a number of regressions, the most noticeable of which is constant volume changes. Issue reported here.
2023-11-16
Changes in JDK / JRE 21 packages may require manual intervention
2023-11-02 - Frederik Schwan
We are introducing a change in JDK/JRE packages of our distro. This is triggered from the way a JRE is build in modern versions of Java (>9). We are introducing this change in Java 21.
To sum it up instead of having JDK and JRE packages coexist in the same system we will be making them conflict. The JDK variant package includes the runtime environment to execute Java applications so if one needs compilation and runtime of Java they need only the JDK package in the future. If, on the other hand, they need just runtime of Java then JRE (or jre-headless) will work.
This will (potentially) require a manual user action during upgrade:
  • If you have both JDK and JRE installed you can manually install the JDK with pacman -Sy jdk-openjdk && pacman -Su and this removes the JRE related packages.
  • If you have both JRE and JRE-headless you will need to choose one of them and install it manually since they would conflict each other now.
  • If you only have one of the JDK/JRE/JRE-headless pacman should resolve dependencies normally and no action is needed.
At the moment this is only valid for the upcoming JDK 21 release.
– Arch Linux - News: Incoming changes in JDK / JRE 21 packages may require manual intervention
2023-09-10
Display doesn't load on PinePhone Pro running KDE Plasma
  • Problem: Failed to start Simple Desktop Display Manager
  • Workaround: (none known yet)
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in.
Fix Fixed in version 4.0.0-1 of mobile-config-firefox released with Manjaro testing on April 14, 2023
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Previous testing threads:
nice to read an official post
Enjoy !
Everything working smoothly on my Pinebook Pro. Thank you for the update.
Hi there,
@philm,
No updates since a while in the testing and unstable branch. May it be possible to have latest updates push into ARM branches ?
Wish You well
