Hello ARM community.
We updated kernels, updated Calamares to Qt6 framework and had some python packages updated.
Update Announcement
Some highlights:
- Some Kernels got updated
- Mostly RasberryPi 4 & 5
- We finally were able to update Calamares to Qt6
- nginx 1.26.0
- our inhouse Breath theme got the new Wallpaper of 24.0 release
- some python updates
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Mon Apr 29 02:25:07 CEST 2024)
- arm-testing core aarch64: 25 new and 25 removed package(s)
- arm-testing extra aarch64: 176 new and 162 removed package(s)
:: Different overlay package(s) in repository core aarch64
PACKAGE 2024-04-24 2024-05-06
linux 6.7.9-1 6.8.9-1
linux-headers 6.7.9-1 6.8.9-1
linux-lts 6.1.81-1 6.1.88-1
linux-lts-headers 6.1.81-1 6.1.88-1
linux-opi 6.6.16-1 6.6.30-4
linux-opi-headers 6.6.16-1 6.6.30-4
linux-rc 6.7.rc8-1 6.9.rc5-1
linux-rc-headers 6.7.rc8-1 6.9.rc5-1
linux-rpi4 6.6.28-1 6.6.30-1
linux-rpi4-headers 6.6.28-1 6.6.30-1
linux-rpi4-mainline 6.8.7-1 6.8.9-1
linux-rpi4-mainline-headers 6.8.7-1 6.8.9-1
linux-rpi4-rc 6.9.rc5-1 6.9.rc6-1
linux-rpi4-rc-headers 6.9.rc5-1 6.9.rc6-1
linux-rpi5 6.6.28-1 6.6.30-1
linux-rpi5-headers 6.6.28-1 6.6.30-1
linux-rpi5-mainline 6.8.7-1 6.8.9-1
linux-rpi5-mainline-headers 6.8.7-1 6.8.9-1
linux-rpi5-rc 6.9.rc5-1 6.9.rc6-1
linux-rpi5-rc-headers 6.9.rc5-1 6.9.rc6-1
raspberrypi-bootloader 20240418-1 20240503-1
raspberrypi-bootloader-x 20240418-1 20240503-1
rpi-overlays 20240418-1 20240429-1
uboot-opi-zero3 v2023.10-2 v2024.01-2
:: Different sync package(s) in repository core aarch64
libarchive 3.7.3-1 3.7.3-3
:: Different overlay package(s) in repository extra aarch64
amazfish 2.2.4-1 2.2.8-2
breath-wallpapers 24.0.0-2 24.0.0-3
calamares 3.2.62-17.1 3.3.6-1
chatty 0.8.2-1 0.8.3-1
gnome-initial-setup-mobile 44.0-2 46.0-1
libsocialcache 0.1.7-1 0.1.7-2
lipstick-glacier-home 1.0.3-1 1.0.3-2
maliit-nemo-keyboard 0.102.1-1 0.106-1
megapixels 1.8.1-2 1.8.2-1
nemo-qml-plugin-configuration 0.2.8-1 0.2.8-2
nemo-qml-plugin-dbus 2.1.34-1 2.1.35-2
nemo-qml-plugin-thumbnailer 1.0.9-1 1.0.9-2
phosh-antispam 3.4-1 3.5-1
plasma6-themes-breath 24.0.0-2 24.0.0-3
plasma6-themes-breath-extra 24.0.0-2 24.0.0-3
plasma6-themes-breath-migration 24.0.0-2 24.0.0-3
raspberrypi-utils 20240415-1 20240424-1
sddm-breath-theme 24.0.0-2 24.0.0-3
sensorfw 0.14.8-1 0.14.8-2
uwe5622-firmware 2022.04-4 2024.01-1
vvmplayer 2.5-1 2.6-1
mlite6 - 0.4.3-2
nemo-qml-plugin-dbus5 - 2.1.35-1
presage2-lang-de_DE - 22.01.01-1
presage2-lang-en_US - 22.01.01-1
presage2-lang-es_ES - 22.01.01-1
presage2-lang-et_EE - 22.01.01-1
presage2-lang-fi_FI - 22.01.01-1
presage2-lang-hu_HU - 22.01.01-1
presage2-lang-ru_RU - 22.01.01-1
presage2-lang-sv_SE - 22.01.01-1
:: Different sync package(s) in repository extra aarch64
aliyun-cli 3.0.202-1 3.0.203-1
aom 3.8.2-1 3.9.0-1
aom-docs 3.8.2-1 3.9.0-1
apache 2.4.58-1 2.4.59-1
appstream 1.0.2-1 1.0.3-1
appstream-qt 1.0.2-1 1.0.3-1
appstream-qt5 1.0.2-1 1.0.3-1
argocd 2.10.1-1 2.10.8-1
argyllcms 3.1.0-1 3.2.0-1
buildkit 0.13.1-1 0.13.2-1
cargo-deb 2.1.0-1 2.1.1-1
cargo-nextest 0.9.67-1 0.9.70-1
cargo-release 0.25.6-1 0.25.7-1
cargo-show-asm 0.2.32-1 0.2.34-1
cargo-spellcheck 0.13.2-1 0.14.0-1
cargo-zigbuild 0.18.3-1 0.18.4-1
chromium 124.0.6367.60-1 124.0.6367.91-1
composer 2.7.3-1 2.7.4-1
containerd 1.7.15-1 1.7.16-1
dagger 0.9.7-1 0.11.1-1
dark-reader 4.9.83-1 4.9.84-1
docker-compose 2.26.1-1 2.27.0-1
dolt 1:1.35.10-1 1:1.35.11-1
eza 0.18.11-1 0.18.13-1
fcitx5 5.1.8-1 5.1.9-1
fcitx5-anthy 5.1.3-1 5.1.4-1
fcitx5-bamboo 1.0.4-1 1.0.5-1
fcitx5-chewing 5.1.1-1 5.1.2-1
fcitx5-gtk 5.1.2-1 5.1.3-1
fcitx5-hangul 5.1.2-1 5.1.3-1
fcitx5-kkc 5.1.2-1 5.1.3-1
fcitx5-libthai 5.1.2-1 5.1.3-1
fcitx5-lua 5.0.12-1 5.0.13-1
fcitx5-pinyin-zhwiki 1:0.2.4.20240210-1 1:0.2.4.20240426-1
fcitx5-qt 5.1.5-4 5.1.6-1
firefox-dark-reader 4.9.83-1 4.9.84-1
firefox-tree-style-tab 4.0.13-1 4.0.14-1
flint 3.1.2-1 3.1.3-1
freerdp 2:3.5.0-1 2:3.5.1-1
gauche 0.9.14-1 0.9.15-1
geos 3.12.0-1 3.12.1-1
gifski 1.14.4-1 1.32.0-1
gitlab-exporter 0.5.1-1 0.5.2-1
gitlab-pages 16.11.0-1 16.11.1-1
glab 1.39.0-1 1.40.0-1
gmt 6.4.0-5 6.5.0-1
gmt-doc 6.4.0-5 6.5.0-1
gnome-control-center 46.0.1-2 46.1-2
gum 0.13.0-1 0.14.0-1
haveged 1.9.18-1 1.9.18-2
hawkeye 5.4.0-1 5.5.1-1
hexedit 1.6-1 1.6-2
hugo 0.125.3-1 0.125.4-1
hurl 4.2.0-1 4.3.0-1
jmol 16.2.7-1 16.2.9-1
js115 115.4.0-2 115.10.0-1
jsmol 16.2.7-1 16.2.9-1
kservice5 5.115.0-1 5.115.0-2
lapce 0.3.1-1 0.4.0-1
libavif 1.0.4-2 1.0.4-3
libmediainfo 24.03-1 24.04-1
libunrar 1:7.0.7-1 1:7.0.8-1
libupnp 1.14.19-1 1.14.19-2
lnav 0.12.0-1 0.12.2-2
lychee 0.14.3-2 0.15.0-1
mame 0.264-1 0.265-1
mame-tools 0.264-1 0.265-1
mediainfo-gui 24.03-1 24.04-1
mod_passenger 6.0.20-1 6.0.20-2
neomutt 20240416-1 20240425-1
nextcloud-client 2:3.13.0-1 2:3.13.0-2
nginx 1.24.0-3 1.26.0-2
nginx-mod-auth-pam 1.5.5-1 1.5.5-2
nginx-mod-brotli 1:1.0.0rc-7 1:1.0.0rc-8
nginx-mod-cache_purge 2.5.3-2 2.5.3-3
nginx-mod-echo 0.62-6 0.62-7
nginx-mod-geoip2 3.4-3 3.4-4
nginx-mod-headers-more 0.37-1 0.37-2
nginx-mod-memc 0.20-1 0.20-2
nginx-mod-modsecurity 1:1.0.3-4 1:1.0.3-5
nginx-mod-naxsi 1.4-1 1.4-2
nginx-mod-ndk 0.33+0.3.3-6 0.33+0.3.3-7
nginx-mod-njs 0.8.4-1 0.8.4-2
nginx-mod-passenger 6.0.20-1 6.0.20-2
nginx-mod-redis 0.3.9-12 0.3.9-13
nginx-mod-redis2 0.15-12 0.15-13
nginx-mod-set-misc 0.33+0.3.3-6 0.33+0.3.3-7
nginx-mod-srcache 0.33-2 0.33-3
nginx-mod-vts 0.2.2-1 0.2.2-2
nginx-src 1.24.0-3 1.26.0-2
nsd 4.8.0-1 4.9.1-1
openpgp-card-tools 0.10.0-2 0.10.1-1
passt 2024_04_05.954589b-1 2024_04_26.d03c4e2-1
perl-devel-cover 1.40-2 1.42-1
perl-mozilla-ca 20231213-1 20240313-1
pixi 0.20.0-1 0.20.1-1
powerdns-recursor 5.0.3-2 5.0.4-1
pymol 3.0.0-1 3.0.0-3
pyqt-builder 1.16.1-1 1.16.2-1
pyright 1.1.359-1 1.1.360-1
python-django-allauth 0.61.1-1 0.62.0-1
python-fastparquet 0.8.1-1 2024.2.0-1
python-fiona 1.9.5-2 1.9.6-1
python-inflect 7.2.0-1 7.2.1-1
python-ipycanvas 0.13.1-2 0.13.2-1
python-mako 1.3.2-1 1.3.3-1
python-numba 0.59.0-1 0.59.1-1
python-pycrdt-websocket 0.12.7-1 0.13.0-1
python-pydantic 2.7.0-1 2.7.1-1
python-pydantic-core 1:2.18.1-1 1:2.18.2-1
python-pyphen 0.14.0-2 0.15.0-1
python-rtree 1.0.1-3 1.1.0-1
python-ruff 0.4.1-1 0.4.2-1
rime-pinyin-zhwiki 1:0.2.4.20240210-1 1:0.2.4.20240426-1
rqbit 5.6.0-1 5.6.1-1
rqbit-desktop 5.6.0-1 5.6.1-1
rye 0.32.0-1 0.33.0-1
sequoia-sq 0.34.0-1 0.35.0-1
slirp4netns 1.2.3-1 1.3.0-1
slumber 0.18.0-1 1.0.0-1
stylelint 16.3.1-2 16.4.0-1
thunderbird-dark-reader 4.9.83-1 4.9.84-1
tipp10 3.3.1-1 3.3.2-1
tracker3 3.7.1-2 3.7.2-1
tracker3-docs 3.7.1-2 3.7.2-1
tracker3-miners 3.7.1-2 3.7.2-1
trivy 0.50.2-1 0.50.4-1
ttf-input 20220502-2 20220502-3
twitch-tui 2.6.6-2 2.6.7-1
v2ray-geoip 202404180039-1 202404250042-1
xcb-imdkit 1.0.7-1 1.0.8-1
xjadeo 0.8.13-1 0.8.14-1
xmrig 6.21.2-1 6.21.3-1
xonsh 0.15.1-1 0.16.0-1
yazi 0.2.4-1 0.2.5-1
yq 3.4.1-1 3.4.2-1
zola 0.18.0-1 0.18.0-2
cargo-wizard - 0.2.2-2
python-httpx-ws - 0.6.0-1
python-sqlite-anyio - 0.2.0-1
rustic - 0.7.0-2
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
