Hello ARM community.
We updated kernels, renewed KDE Plasma, KDE Gear and offer other related goodies for you. Pamac is now fully adaptive and we have a new release of Phosh. Systemd offers now the Blue Screen of Death!
Update Announcement
Some highlights:
- Some Kernels got updated
- Linux-Firmware got updated
- Pamac 11.7.0 got now fully ported to libadwaita 1.4
- it is now fully adaptive and works with phosh
- libpamac fixed the offline updates in 11.6.3
- Gnome 45 is now supported
- KDE Plasma 5.27.10
- KDE Gear got updated to 23.08.4
- Phosh 0.33.0
- Systemd is now at 255
- Cinnamon got updated to 6.0
- GNOME 45.2
- Firefox is at 120.0.1 and Thunderbird is at 115.5.1
- LibreOffice got updated to 7.6.3
- Maui got renewed to 3.0.2
- LibreOffice got updated to 7.6.4 and 7.5.9
- PipeWire got its first major release and got updated to 1.0.0
- QEMU is at 8.1.3
- The usual python and KDE-git updates (which moved to Qt6)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all itβs dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Sat Dec 9 07:46:24 CET 2023)
- arm-testing core aarch64: 78 new and 83 removed package(s)
- arm-testing extra aarch64: 2136 new and 2133 removed package(s)
- arm-testing kde-unstable aarch64: 336 new and 324 removed package(s)
A full list of all package changes can be found here.
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
