Hello ARM community.
Archlinux ARM finalized migrating the community to extra repository.We updated kernels, KDE and other mobile related goodies for you.
Get the lastest SoftMaker Office with ChatGPT buillt-in. You will find our Special Offer here!
Update Announcement
Some highlights:
- RasberryPi kernel got updated to 6.4
- Linux-Firmware got renewed
- We synced the plymouth package with our x64 branch
- Blender got updated to 3.6.0
- The usual KDE-git updates
End Of Life kernels (will be removed from repo soon):
linux60(EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Thu Jun 29 17:04:15 CEST 2023)
- arm-testing core aarch64: 16 new and 16 removed package(s)
- arm-testing extra aarch64: 170 new and 166 removed package(s)
- arm-testing kde-unstable aarch64: 149 new and 148 removed package(s)
:: Different overlay package(s) in repository core aarch64
PACKAGE 2023.06.26 2023.06.30
linux-rpi4-mainline 6.3.9-1 6.4.0-1
linux-rpi4-mainline-headers 6.3.9-1 6.4.0-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20230404.2e92a49f-1 20230625.ee91452d-1
iproute2 6.3.0-2 6.4.0-1
linux-firmware 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-bnx2x 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-liquidio 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-marvell 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-mellanox 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-nfp 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-qcom 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-qlogic 20230404.2e92a49f-1 20230625.ee91452d-1
linux-firmware-whence 20230404.2e92a49f-1 20230625.ee91452d-1
procps-ng 3.3.17-1 4.0.3-1
util-linux 2.39-10 2.39.1-1
util-linux-libs 2.39-10 2.39.1-1
:: Different overlay package(s) in repository extra aarch64
snapd 2.60-1 2.60-2
topgrade 11.0.2-2 12.0.0-1
plymouth - 22.02.122-14
:: Different sync package(s) in repository extra aarch64
acorn 1:8.8.2-1 1:8.9.0-1
algol68g 3.1.9-2 3.2.0-1
algol68g-doc 3.1.9-2 3.2.0-1
apitrace 11.1-1 11.1-2
awxkit 22.3.0-1 22.4.0-1
bacon 2.8.1-1 2.10.0-1
bash-language-server 4.10.0-1 4.10.1-1
blender 17:3.5.1-8 17:3.6.0-1
bmake 20230601-1 20230622-1
bottom 0.9.2-1 0.9.3-1
cargo-nextest 0.9.53-1 0.9.54-1
cargo-release 0.24.10-1 0.24.11-1
chromium 114.0.5735.133-1 114.0.5735.198-1
chuck 1.4.2.0-1 1.5.0.3-1
cinnamon 5.8.2-1 5.8.3-1
cocogitto 5.4.0-1 5.4.0-2
cppcheck 2.10.3-2 2.11-1
dolt 1.6.1-1 1.7.0-1
elixir 1.14.0-1 1.15.0-1
erlang 26.0.1-2 26.0.1-3
erlang-unixodbc 26.0.1-2 26.0.1-3
esbuild 0.18.6-1 0.18.9-1
freetype2 2.13.0-1 2.13.1-1
freetype2-demos 2.13.0-1 2.13.1-1
freetype2-docs 2.13.0-1 2.13.1-1
gegl 0.4.44-3 0.4.46-1
gfold 4.3.3-1 4.4.0-1
giac 1.9.0.53-1 1.9.0.57-1
gimp-plugin-gmic 3.2.5-2 3.2.6-1
glab 1.30.0-1 1.31.0-1
global 6.6.9-1 6.6.10-1
gpxsee 13.2-1 13.4-1
grim 1.4.0-3 1.4.1-1
home-assistant 1:2023.6.2-1 1:2023.6.3-1
jupyter-server 2.6.0-1 2.7.0-1
kernelshark 2.2.0-1 2.2.1-1
libsynctex 2023.66984-10 2023.66984-12
lxqt-session 1.3.0-1 1.3.0-3
mame 0.255-1 0.256-1
mame-tools 0.255-1 0.256-1
man-pages-cs 4.18.1-1 4.19.0-1
man-pages-da 4.18.1-1 4.19.0-1
man-pages-de 4.18.1-1 4.19.0-1
man-pages-el 4.18.1-1 4.19.0-1
man-pages-es 4.18.1-1 4.19.0-1
man-pages-fi 4.18.1-1 4.19.0-1
man-pages-fr 4.18.1-1 4.19.0-1
man-pages-hu 4.18.1-1 4.19.0-1
man-pages-id 4.18.1-1 4.19.0-1
man-pages-it 4.18.1-1 4.19.0-1
man-pages-mk 4.18.1-1 4.19.0-1
man-pages-nb 4.18.1-1 4.19.0-1
man-pages-nl 4.18.1-1 4.19.0-1
man-pages-pl 4.18.1-1 4.19.0-1
man-pages-pt_br 4.18.1-1 4.19.0-1
man-pages-ro 4.18.1-1 4.19.0-1
man-pages-ru 4.18.1-1 4.19.0-1
man-pages-sr 4.18.1-1 4.19.0-1
man-pages-sv 4.18.1-1 4.19.0-1
man-pages-uk 4.18.1-1 4.19.0-1
man-pages-vi 4.18.1-1 4.19.0-1
mercurial 6.4.4-1 6.4.5-1
meson-python 0.13.1-2 0.13.2-1
nemo 5.8.2-1 5.8.3-1
nodejs 20.3.0-1 20.3.1-1
normaliz 3.10.0-1 3.10.1-1
nushell 0.81.0-1 0.82.0-1
nyxt 3.2.1-1 3.3.0-1
opam 2.1.4-1 2.1.5-1
opencl-clhpp 2.0.16-1 2023.04.17-1
opencl-headers 2:2022.09.30-1 2:2023.04.17-2
openexr 3.1.8-1 3.1.9-1
openfortivpn 1.20.4-1 1.20.5-1
ostree 2023.4-1 2023.4-2
passt 2023_06_03.429e1a7-1 2023_06_25.32660ce-1
pnpm 8.6.4-1 8.6.5-2
podofo 0.10.0-3 0.10.0-4
pop-icon-theme3.3.0.r12.6bca69f05e-13.3.0.r14.3126c6a3f6-1
prusa-slicer 2.3.3-2 2.6.0-1
pyright 1.1.315-1 1.1.316-1
python-big-o 0.10.2-2 0.11.0-1
python-cachetools 5.3.0-2 5.3.1-1
python-cairocffi 1.4.0-4 1.5.0-1
python-cvxpy 1.3.1-1 1.3.2-1
python-frozendict 1:2.3.4-2 1:2.3.8-1
python-jaraco.path 3.4.1-1 3.5.0-1
python-pdm-backend 2.1.0-1 2.1.1-1
python-rpy2 3.5.12-1 3.5.13-1
python-rtmidi 1.5.3-1 1.5.4-1
python-sphinx_rtd_theme 1.2.2-1 1.2.2-2
python-txtorcon 23.0.0-1 23.5.0-1
python-wsgi-intercept 1.11.0-2 -
qt6-declarative 6.5.1-1 6.5.1-2
release-plz 0.3.14-1 0.3.15-1
repo 2.33-2 2.34.1-1
rssguard 4.3.4-1 4.4.0-1
rssguard-lite 4.3.4-1 4.4.0-1
ruby-async-pool 0.3.12-2 0.4.0-1
ruby-async-websocket 0.25.0-1 0.25.1-1
ruby-console 1.16.2-2 1.17.0-1
ruby-markly 0.8.0-1 0.8.1-1
ruby-maxitest 4.4.1-1 4.5.0-1
ruby-net-http-persistent 4.0.1-1 4.0.2-1
ruby-protocol-http 0.24.1-1 0.24.3-1
ruby-protocol-rack 0.2.4-2 0.2.5-1
ruby-protocol-websocket 0.11.0-1 0.11.1-1
scrcpy 2.0-1 2.1-1
serverless 3.32.2-1 3.33.0-1
superslicer 1:2.4.58.2-1 1:2.4.58.5-6
texlive-basic 2023.66594-14 2023.66594-15
texlive-bibtexextra 2023.66594-14 2023.66594-15
texlive-bin 2023.66984-10 2023.66984-12
texlive-binextra 2023.66594-14 2023.66594-15
texlive-context 2023.66594-14 2023.66594-15
texlive-doc 2023.66594-14 2023.66594-15
texlive-fontsextra 2023.66594-14 2023.66594-15
texlive-fontsrecommended 2023.66594-14 2023.66594-15
texlive-fontutils 2023.66594-14 2023.66594-15
texlive-formatsextra 2023.66594-14 2023.66594-15
texlive-games 2023.66594-14 2023.66594-15
texlive-humanities 2023.66594-14 2023.66594-15
texlive-langarabic 2023.66594-14 2023.66594-15
texlive-langchinese 2023.66594-14 2023.66594-15
texlive-langcjk 2023.66594-14 2023.66594-15
texlive-langcyrillic 2023.66594-14 2023.66594-15
texlive-langczechslovak 2023.66594-14 2023.66594-15
texlive-langenglish 2023.66594-14 2023.66594-15
texlive-langeuropean 2023.66594-14 2023.66594-15
texlive-langfrench 2023.66594-14 2023.66594-15
texlive-langgerman 2023.66594-14 2023.66594-15
texlive-langgreek 2023.66594-14 2023.66594-15
texlive-langitalian 2023.66594-14 2023.66594-15
texlive-langjapanese 2023.66594-14 2023.66594-15
texlive-langkorean 2023.66594-14 2023.66594-15
texlive-langother 2023.66594-14 2023.66594-15
texlive-langpolish 2023.66594-14 2023.66594-15
texlive-langportuguese 2023.66594-14 2023.66594-15
texlive-langspanish 2023.66594-14 2023.66594-15
texlive-latex 2023.66594-14 2023.66594-15
texlive-latexextra 2023.66594-14 2023.66594-15
texlive-latexrecommended 2023.66594-14 2023.66594-15
texlive-luatex 2023.66594-14 2023.66594-15
texlive-mathscience 2023.66594-14 2023.66594-15
texlive-meta 2023.66594-14 2023.66594-15
texlive-metapost 2023.66594-14 2023.66594-15
texlive-music 2023.66594-14 2023.66594-15
texlive-pictures 2023.66594-14 2023.66594-15
texlive-plaingeneric 2023.66594-14 2023.66594-15
texlive-pstricks 2023.66594-14 2023.66594-15
texlive-publishers 2023.66594-14 2023.66594-15
texlive-xetex 2023.66594-14 2023.66594-15
typos 1.15.5-1 1.15.7-1
vue-language-server 1.8.1-1 1.8.2-1
vulkan-headers 1:1.3.253-1 1:1.3.255-1
vulkan-html-docs 1:1.3.253-1 1:1.3.255-1
vulkan-icd-loader 1.3.251-1 1.3.255-1
vulkan-tools 1.3.245-1 1.3.255-1
vulkan-validation-layers 1.3.250.0-1 1.3.250.0-2
weechat 3.8-3 4.0.0-1
xed 3.4.1-1 3.4.2-1
xterm 382-1 383-1
xtrabackup 8.0.33_27-1 8.0.33_27-2
yuzu 1474-1 1478-1
cargo-binstall - 1.0.0-1
podofo-tools - 0.10.0-4
ruby-fiber-annotation - 0.2.0-1
slicer-udev - 2.6.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
ark23.04.2.r5101.g17a58dd9-123.04.2.r5102.g02f54b53-1
attica5.107.0.r909.g3f5526f-15.107.0.r915.gc77c91e-1
blinken23.04.2.r746.gddfb4c6-123.04.2.r747.gab41349-1
bluedevil1:5.27.6.r2622.gce26976a-11:5.27.6.r2623.g6534269f-1
bluez-qt5.107.0.r749.gd2e98c6-15.107.0.r753.g5b4fb2c-1
breeze5.27.6.r2637.g0f4bf11a-15.27.6.r2638.gfe1f859b-1
breeze-icons5.107.0.r1971.gf109a662-15.107.0.r1989.g5012e7cc-1
cervisia23.04.2.r1786.g6951b32-123.04.2.r1787.g44cc193-1
discover5.27.6.r9354.gfea9b8c21-15.27.6.r9355.gfb753a09a-1
dolphin23.04.2.r7433.gefd4d76a3-123.04.2.r7435.g683992c80-1
dragon23.04.2.r1206.gb01ff54-123.04.2.r1207.g3f53d92-1
drkonqi5.27.6.r938.g41aac9dd-15.27.6.r940.g477224e6-1
extra-cmake-modules5.107.0.r3566.gc0012a40-15.107.0.r3602.g9dbca443-1
ffmpegthumbs23.04.2.r265.g47ed489-123.04.2.r266.g5b74fd6-1
itinerary23.04.2.r2788.gcfc0ca63-123.04.2.r2790.geb858cfb-1
juk23.04.2.r3269.g385c2796-123.04.2.r3270.g2c852b71-1
k3b1:23.04.2.r7011.g6d02b0e4d-11:23.04.2.r7013.g553ce2ca1-1
kactivities5.107.0.r1433.g325c0b9a-15.107.0.r1439.gb2dab3dc-1
kactivities-stats5.107.0.r438.g3ec5f87-15.107.0.r440.g96daeaf-1
kaddressbook23.04.2.r6425.g9379bd14-123.04.2.r6426.g34789ae4-1
kalarm23.04.2.r8409.g12c52f6a-123.04.2.r8410.g3a74e3f2-1
kalgebra23.04.2.r2167.ga472af1-123.04.2.r2170.g8f208bd-1
kalzium23.04.2.r4520.g70674cc0-123.04.2.r4521.g968d4bc5-1
kate23.04.2.r20765.g6e128ada1-123.04.2.r20769.ge00f3cca0-1
kauth5.107.0.r569.g25bb768-15.107.0.r570.g3153725-1
kblocks23.04.2.r833.g9ca0c68-123.04.2.r834.geb6d108-1
kbounce23.04.2.r935.gc8b23ba-123.04.2.r936.ge2089a4-1
kcalendarcore5.107.0.r1376.gaaccfb3b9-15.107.0.r1384.gb8b9eaa86-1
kconfig5.107.0.r1087.g65868ddf-15.107.0.r1134.g9b8f7d9a-1
kcoreaddons5.107.0.r1722.g08b8e683-15.107.0.r1828.g6680699e-1
kcrash5.107.0.r477.g737f253-15.107.0.r479.gc5c7143-1
kcron23.04.2.r913.g8f705b1-123.04.2.r920.g5f50dc5-1
kdbusaddons5.107.0.r486.ge5e6a88-15.107.0.r490.ge91a110-1
kdeclarative5.107.0.r1153.g527ff100-15.107.0.r1192.g8be520ba-1
kdeconnect23.04.2.r3875.g3018b3bf-123.04.2.r3878.gbeb7e94c-1
kded5.107.0.r504.g0e5e885-15.107.0.r519.gae779e4-1
kdenetwork-filesharing23.04.2.r1099.g80f1bcf-123.04.2.r1100.g9fdeda3-1
kdenlive23.04.2.r18256.g5d4dcff9b-123.04.2.r18258.g78fa4aa78-1
kdepim-addons23.04.2.r5288.g7cf5d84a6-123.04.2.r5290.g785724810-1
kdepim-runtime23.04.2.r15967.g1dc14f311-123.04.2.r15974.g50fd25e48-1
kdesdk-thumbnailers23.04.2.r137.gfbffb45-123.04.2.r138.g41218ba-1
kfilemetadata5.107.0.r982.gf07ec5f-15.107.0.r983.g8d923df-1
kget23.04.2.r3379.gbe0fadfe-123.04.2.r3382.gc3ce3aff-1
kglobalaccel5.107.0.r666.g5cba8e4-15.107.0.r670.g49f8e10-1
kgoldrunner23.04.2.r1387.g63456ea-123.04.2.r1389.g26350b1-1
kguiaddons5.107.0.r543.g6111a0c-15.107.0.r556.g2e53692-1
khelpcenter23.04.2.r2907.g1dfa9df9-123.04.2.r2908.g8d863530-1
kholidays1:5.107.0.r1135.g80d7c87-11:5.107.0.r1140.ga51df0e-1
ki18n5.107.0.r652.gb2ab2e8-15.107.0.r657.g05e469b-1
kidletime5.107.0.r401.gce3d595-15.107.0.r406.gd4bf10b-1
kig23.04.2.r3353.g4bf9dfe9-123.04.2.r3354.g243a0c22-1
kimageformats5.107.0.r491.g5522781-15.107.0.r501.g9c579fc-1
kinfocenter5.27.6.r2396.g7d454417-15.27.6.r2397.gfc2ede77-1
kio5.107.0.r6218.g9b100d48d-15.107.0.r6221.ga4701f587-1
kirigami-addons1:0.8.0.r61.g118636f-11:0.8.0.r70.g053bcd5-1
kirigami25.107.0.r3730.g40a0db92-15.107.0.r3880.g673e5aa1-1
kitemmodels5.107.0.r652.g9d48152-15.107.0.r656.gb0a03c6-1
kitemviews5.107.0.r441.gdb405c3-15.107.0.r445.gf9fb5a1-1
kitinerary23.04.2.r2996.ga02092d8-123.04.2.r2998.g35bcee45-1
kleopatra23.04.2.r7339.g63fa5681-123.04.2.r7342.ga897e1cf-1
kmail23.04.2.r27061.gc0d961769-123.04.2.r27063.ga84242f7d-1
kmailtransport23.04.2.r1943.g99346e1-123.04.2.r1944.g7d81199-1
kmplot23.04.2.r1600.gce9f3c3-123.04.2.r1601.g01e4623-1
knotifications5.107.0.r831.gb88442c-15.107.0.r852.gf06bbd6-1
kolf23.04.2.r1610.ga897a73-123.04.2.r1614.g4643634-1
kollision23.04.2.r613.gede66e7-123.04.2.r614.g15c118a-1
kolourpaint23.04.2.r2541.g71675158-123.04.2.r2542.ga68f6b04-1
konqueror23.04.2.r15475.ge4798cc75-123.04.2.r15480.gc9b1b76e9-1
konquest23.04.2.r1024.ga1f4ba1-123.04.2.r1025.gaf9de57-1
konsole23.04.2.r9101.g66a177f79-123.04.2.r9103.g640e4fe66-1
konversation23.04.2.r9313.g7d2ff5e4-123.04.2.r9316.g2feb1c08-1
kopete23.04.2.r16579.gddd1c887b-123.04.2.r16580.gc17c2513e-1
kpat23.04.2.r2769.g0e9d28fb-123.04.2.r2771.g1f3c02e4-1
kpeople5.107.0.r1442.g6a6a9c2-15.107.0.r1443.ga9987d9-1
kplotting5.107.0.r354.g218840a-15.107.0.r356.g037c7ee-1
kpmcore23.04.2.r1381.ga4569dd-123.04.2.r1382.gd8634de-1
kpublictransport23.04.2.r2193.g7d2a6192-123.04.2.r2221.g2b043635-1
krdc23.04.2.r1725.g9759115-123.04.2.r1726.g13f952a-1
kreversi23.04.2.r1362.g413fbb2-123.04.2.r1363.g797a9b9-1
krfb23.04.2.r1581.g6efc119-123.04.2.r1582.g54f0f51-1
kruler23.04.2.r856.g3bcaef0-123.04.2.r857.g6f5b723-1
krunner5.107.0.r831.g992d1ed-15.107.0.r920.g982588f-1
ksanecore r722.gc3ee59f-1 r722.gc3ee59f-2
kscreen5.27.6.r1738.g1af4742-15.27.6.r1739.ge2db7d7-1
kservice5.107.0.r1123.g32a35af7-15.107.0.r1164.g636cf906-1
kshisen23.04.2.r1349.g399b42e-123.04.2.r1350.g0147bf4-1
ksirk23.04.2.r1147.g5e90014-123.04.2.r1148.gb9cb5a7-1
ksnakeduel23.04.2.r933.g5ea85a9-123.04.2.r934.gad0d174-1
ksquares23.04.2.r661.g80e7816-123.04.2.r662.gf0db962-1
ksudoku23.04.2.r1206.gafbf8b2-123.04.2.r1207.g3ef531d-1
ksystemlog23.04.2.r863.ga035e07-123.04.2.r864.g95a1ed8-1
kteatime23.04.2.r835.ga8fcf31-123.04.2.r836.g6d78fe6-1
ktimer23.04.2.r599.gceff6a9-123.04.2.r600.g42c6934-1
ktorrent23.04.2.r3047.g7fa43d43-123.04.2.r3048.gc80bdf5d-1
ktouch23.04.2.r2283.gc7c1bef3-123.04.2.r2284.g3062790a-1
ktuberling23.04.2.r1166.g511454e-123.04.2.r1167.g2c929ed-1
kturtle23.04.2.r1279.g4dbce64-123.04.2.r1280.g7605bc6-1
kubrick23.04.2.r496.g64f3606-123.04.2.r497.g331937e-1
kunitconversion5.107.0.r530.g9a4beaf-15.107.0.r539.g35945d3-1
kwalletmanager23.04.2.r1470.g0d1ec83-123.04.2.r1471.ge3f65dc-1
kwave23.04.2.r3888.g6d069812-123.04.2.r3889.gbd1cbe18-1
kwayland5.107.0.r1215.g0d90bd7-15.107.0.r1222.g1d10730-1
kweathercore 0.7.r43.gdd42862-1 0.7.r43.gdd42862-2
kwidgetsaddons5.107.0.r1106.gbac6c4f4-15.107.0.r1135.g650a3c76-1
kwindowsystem5.107.0.r775.g131f7b6-15.107.0.r791.g1f05aec-1
kwordquiz23.04.2.r1325.gad920cf-123.04.2.r1326.g989ec0c-1
kwrite23.04.2.r20765.g6e128ada1-123.04.2.r20769.ge00f3cca0-1
kxmlgui5.107.0.r1013.ge9f6d741-15.107.0.r1015.g27c4db27-1
layer-shell-qt5.27.6.r79.gd610813-15.27.6.r96.gd6aeaef-1
lokalize23.04.2.r2095.g174f6679-123.04.2.r2097.g01c0e629-1
lskat23.04.2.r938.gcdc8ba1-123.04.2.r941.g4936a24-1
mailimporter23.04.2.r630.gaa3a3e6-123.04.2.r631.g7f2f2a9-1
messagelib23.04.2.r7177.g3e35cd358-123.04.2.r7178.gcd412f8f7-1
minuet23.04.2.r702.gd4e1049-123.04.2.r703.g898d2fe-1
modemmanager-qt5.107.0.r585.gdb21d1d-15.107.0.r590.g886e27d-1
neochat23.01.0.r484.g6f5d88cf6-123.01.0.r488.g116c88868-1
networkmanager-qt5.107.0.r1195.gc744a32-15.107.0.r1195.gdbadafa-1
okular23.04.2.r10154.g034397dae-123.04.2.r10158.gae857ec3a-1
oxygen-icons1:5.107.0.r5.gbff159d-11:5.107.0.r5.gbff159d-2
oxygen-icons-svg1:5.107.0.r5.gbff159d-11:5.107.0.r5.gbff159d-2
palapeli23.04.2.r1401.gb1e67ed-123.04.2.r1402.gdc934b5-1
parley23.04.2.r4627.gfef26699-123.04.2.r4628.gca4436e0-1
partitionmanager23.04.2.r1817.g0509684-123.04.2.r1818.gaec8f02-1
pim-sieve-editor23.04.2.r1791.g0925257-123.04.2.r1792.g75f58e0-1
plasma-desktop5.27.6.r10279.gfc570c6f1-15.27.6.r10281.g159326d79-1
plasma-dialer23.01.0.r99.g6961335-123.01.0.r101.g3c60b88-1
plasma-mobile5.27.6.r2236.g403351ea4-15.27.6.r2237.g6caf07f99-1
plasma-mobile-nm5.27.6.r3627.g7b028ded-15.27.6.r3628.g0587020d-1
plasma-nm5.27.6.r3627.g7b028ded-15.27.6.r3628.g0587020d-1
plasma-pa5.27.6.r1245.g91dcf51-15.27.6.r1246.g815fc00-1
plasma-wayland-protocols1.4.0.r1074.g6e08d9c-11.4.0.r1074.g6e08d9c-2
plasma-wayland-session5.27.5.r13472.g4f8eea909-15.27.5.r13474.g8395a9532-1
plasma-workspace5.27.5.r13472.g4f8eea909-15.27.5.r13474.g8395a9532-1
plasmatube23.01.0.r113.g20012cd-123.01.0.r114.g0438e67-1
prison5.107.0.r432.ge3ba8f5-15.107.0.r448.geaf598d-1
pulseaudio-qt 1.3.0.r27.g0f6f784-1 1.3.0.r27.g0f6f784-2
qqc2-desktop-style5.107.0.r754.g1589093-15.107.0.r782.g1239a6f-1
sddm0.19.0.r235.ga9a664d-10.19.0.r239.g387674c-2
solid5.107.0.r907.g9794634-15.107.0.r915.g41eaa14-1
sonnet5.107.0.r801.g68c3001-15.107.0.r821.g0813006-1
step23.04.2.r1345.ga0b8d22-123.04.2.r1346.gb982c97-1
svgpart23.04.2.r291.g6152b3e-123.04.2.r292.g547d585-1
sweeper23.04.2.r653.gc767ca1-123.04.2.r654.g0d25808-1
syntax-highlighting5.107.0.r2159.ga272eebe-15.107.0.r2238.gb68b5db7-1
telepathy-kde-accounts-kcm23.04.2.r1272.g7df6ecb-123.04.2.r1273.g7eff28f-1
telepathy-kde-contact-runner23.04.2.r296.gf84e602-123.04.2.r297.g43cab6e-1
threadweaver5.107.0.r574.gd1c9d47-15.107.0.r586.g5fd681f-1
umbrello23.04.2.r8683.g8079282ce-123.04.2.r8684.g10c78715b-1
kcolorscheme -5.104.0.r122.gb44b1e1-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
