[ARM Testing Update] 2023-06-18 - Kernels, KODI, KDE_git
Hello ARM community.
Archlinux ARM is still migrating to the community to extra repo merge since 2 weeks now. So no upstream updates in this one. However we updated kernels, firmwares and other mobile related goodies for you.
Update Announcement
Some highlights:
  • Some Kernels got renewed
  • KODI-RPI got updated
  • The usual KDE-git updates
End Of Life kernels (will be removed from repo soon):
  • linux60 (EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Fri May 19 13:30:34 CEST 2023)
  • arm-testing community aarch64: 12 new and 11 removed package(s)
  • arm-testing core aarch64: 16 new and 16 removed package(s)
  • arm-testing extra aarch64: 3 new and 4 removed package(s)
  • arm-testing kde-unstable aarch64: 251 new and 251 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2023.06.09           2023.06.18
                                code             1.79.0-1             1.79.2-1
                            electron             23.3.6-1             25.1.1-1
                          electron22            22.3.12-1            22.3.13-1
                          electron24             24.5.0-1             24.5.1-1
                        kodi-rpi-git21.x.63013.f02e604e5e-121.x.63310.39b05a2abd-1
                    kodi-rpi-git-dev21.x.63013.f02e604e5e-121.x.63310.39b05a2abd-1
           kodi-rpi-git-eventclients21.x.63013.f02e604e5e-121.x.63310.39b05a2abd-1
    kodi-rpi-git-tools-texturepacker21.x.63013.f02e604e5e-121.x.63310.39b05a2abd-1
            radxa-zero2-post-install           20220207-1           20230612-1
                                vvmd               0.15-1               0.16-1
                           vvmplayer              2.3.0-1              2.3.1-1
                          electron23                    -             23.3.7-1
:: Different overlay package(s) in repository core aarch64
                               linux              6.3.7-1              6.3.8-1
                       linux-headers              6.3.7-1              6.3.8-1
                           linux-opi             6.1.31-1             6.1.33-1
                   linux-opi-headers             6.1.31-1             6.1.33-1
                     linux-pinephone              6.3.7-1              6.3.8-1
             linux-pinephone-headers              6.3.7-1              6.3.8-1
                  linux-pinephonepro              6.3.7-1              6.3.8-1
          linux-pinephonepro-headers              6.3.7-1              6.3.8-1
                            linux-rc            6.4.rc4-1            6.4.rc6-1
                    linux-rc-headers            6.4.rc4-1            6.4.rc6-1
                          linux-rpi4             6.1.32-1             6.1.34-1
                  linux-rpi4-headers             6.1.32-1             6.1.34-1
                 linux-rpi4-mainline              6.3.6-1              6.3.8-1
         linux-rpi4-mainline-headers              6.3.6-1              6.3.8-1
                       linux-rpi4-rc            6.4.rc5-1            6.4.rc6-1
               linux-rpi4-rc-headers            6.4.rc5-1            6.4.rc6-1
:: Different overlay package(s) in repository extra aarch64
                      libwireplumber           0.4.13-0.1           0.4.14-0.1
                     manjaro-starter             0.31.8-1             0.31.9-1
                    wireplumber-docs           0.4.13-0.1                    -
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi23.04.2.r13076.g84e914c45-123.04.2.r13079.gaf9403068-1
                    akonadi-calendar23.04.2.r2364.g2c16022-123.04.2.r2366.g6cf1d61-1
              akonadi-calendar-tools23.04.2.r1050.g9ba89ef-123.04.2.r1052.g4f9d587-1
                    akonadi-contacts23.04.2.r3474.gc4e5f229-123.04.2.r3475.g6f666112-1
               akonadi-import-wizard23.04.2.r1941.g5abcbc9-123.04.2.r1942.g6df1321-1
                      akonadiconsole23.04.2.r1748.gb566587-123.04.2.r1750.ga5bd055-1
                           akregator23.04.2.r6726.g5325284a-123.04.2.r6729.g55d74842-1
                           alligator23.01.0.r48.ga25df58-123.01.0.r51.g11621a6-1
                                 ark23.04.2.r5090.g5033a623-123.04.2.r5094.ga2ba6cf6-1
                              attica5.106.0.r908.g50b609d-15.107.0.r909.g3f5526f-1
                         audiocd-kio23.04.2.r1208.g061a22c-123.04.2.r1215.g8c4c434-1
                        aura-browser5.26.0.r235.g9d1b5ad-15.26.0.r238.g22ef08a-1
                               baloo5.106.0.r3245.g9755144d-15.106.0.r3246.ge02d6bc1-1
                       baloo-widgets23.04.2.r878.g2e8ea3c-123.04.2.r885.g827bd7d-1
                             blinken23.04.2.r740.g6d13ea0-123.04.2.r741.gd0ea5e4-1
                           bluedevil1:5.27.5.r2613.gb31f376a-11:5.27.5.r2615.g8acbae49-1
                            bluez-qt5.106.0.r747.gbe9d3f1-15.107.0.r749.gd2e98c6-1
                              bomber23.04.2.r636.g7e6e493-123.04.2.r637.gd931567-1
                                bovo23.04.2.r857.ga9f1dbe-123.04.2.r858.gdd76cec-1
                              breeze5.27.5.r2629.g4afc46e7-15.27.5.r2630.ge13be530-1
                        breeze-icons5.106.0.r1969.gb641fb7f-15.107.0.r1970.g046a3b85-1
                                buho  3.0.0.r6.ga4c2c66-1 3.0.0.r10.g5c8c6f5-1
                     calendarsupport23.04.2.r849.gde62582-123.04.2.r850.gaa43893-1
                            cervisia23.04.2.r1779.gefbddbb-123.04.2.r1780.g7d70f55-1
                            discover5.27.5.r9335.g725681901-15.27.5.r9341.ge27fe8a1a-1
                             dolphin23.04.2.r7417.gbb08c70a9-123.04.2.r7424.g9c614949d-1
                     dolphin-plugins23.04.2.r761.g1abd322-123.04.2.r764.gffcbab5-1
                              dragon23.04.2.r1196.g94b6111-123.04.2.r1199.ga33d80e-1
                             drkonqi5.27.5.r931.g9c42ce25-15.27.5.r934.gaa439b77-1
                               elisa23.04.2.r3320.g8d11cf2f-123.04.2.r3326.gd69d4c54-1
                          elisa-qtmm23.04.2.r3320.g8d11cf2f-123.04.2.r3326.gd69d4c54-1
                          eventviews23.04.2.r1028.gdd65a38-123.04.2.r1029.gdb4009f-1
                 extra-cmake-modules5.106.0.r3565.g1a480286-15.107.0.r3566.gc0012a40-1
                           filelight23.04.2.r1410.g253b29d-123.04.2.r1411.gee8d2c9-1
                frameworkintegration5.106.0.r679.ga8be18c-15.107.0.r680.gb495ce9-1
                           granatier23.04.2.r1051.g5e93a6c-123.04.2.r1053.g9f28a7a-1
                     grantlee-editor23.04.2.r941.gb634afb-123.04.2.r942.g83d225f-1
                           itinerary23.04.2.r2715.gae36bdb6-123.04.2.r2748.gee848824-1
                                 k3b1:23.04.2.r6999.g329361b61-11:23.04.2.r7003.g14824734e-1
                         kactivities5.106.0.r1432.g4d7dae2f-15.107.0.r1433.g325c0b9a-1
                   kactivities-stats5.106.0.r437.g5441925-15.107.0.r438.g3ec5f87-1
                        kaddressbook23.04.2.r6420.gbc60dd46-123.04.2.r6421.g58e09eef-1
                             kajongg23.04.2.r4422.g451e34a3-123.04.2.r4425.gc2e680e6-1
                              kalarm23.04.2.r8395.g124644f6-123.04.2.r8402.gd330294b-1
                            kalgebra23.04.2.r2162.g0ded608-123.04.2.r2163.g3705622-1
                              kamera23.04.2.r828.gd491cfd-123.04.2.r837.g8b8578d-1
                              kamoso23.04.2.r1557.ga018c91-123.04.2.r1558.g0ba43fc-1
                            kanagram23.04.2.r1406.gbc68a1f-123.04.2.r1408.g5d54b8e-1
                             kapidox5.106.0.r589.gb884670-15.107.0.r590.gae10c4d-1
                              kapman23.04.2.r734.gc63a2da-123.04.2.r735.g7b10d18-1
                        kapptemplate23.04.2.r1063.g5fded2a-123.04.2.r1064.gcda18f5-1
                            karchive5.106.0.r675.gc484b5f-15.107.0.r678.g39ed6aa-1
                               kasts23.01.0.r168.g21952c6-123.01.0.r173.gee099f2-1
                                kate23.04.2.r20730.geefd3ba2d-123.04.2.r20745.gae2f208c3-1
                             katomic23.04.2.r1046.g9ed1b51-123.04.2.r1048.g69c5984-1
                               kauth5.106.0.r567.g3b6793b-15.107.0.r568.ge2d0097-1
                           kblackbox23.04.2.r847.gdc37f08-123.04.2.r852.gd61efb6-1
                             kblocks23.04.2.r826.g2447c84-123.04.2.r830.g6dccb11-1
                          kbookmarks5.106.0.r536.g60642fc-15.107.0.r537.gd1c9216-1
                             kbounce23.04.2.r932.gc80ffc9-123.04.2.r933.gecbccd3-1
                           kbreakout23.04.2.r999.gbfe0cbd-123.04.2.r1000.gc1481cf-1
                              kbruch23.04.2.r956.g4a4b7e8-123.04.2.r957.gafacbee-1
                               kcalc23.04.2.r1736.ga499fae-123.04.2.r1738.gb95eb4a-1
                       kcalendarcore5.106.0.r1375.g781e67cb4-15.107.0.r1376.gaaccfb3b9-1
                         kcharselect23.04.2.r625.g019cf4f-123.04.2.r626.g208d76f-1
                              kclock23.01.0.r74.g352cc69-123.01.0.r78.g36c1ab9-1
                            kcmutils5.106.0.r754.g9772c61d-15.107.0.r756.g0ca5d2a5-1
                             kcodecs5.106.0.r505.gbf9dc26-15.107.0.r506.g5eeee35-1
                       kcolorchooser23.04.2.r337.gde9049d-123.04.2.r338.gdbbca57-1
                         kcompletion5.106.0.r567.g4f8ccff-15.107.0.r568.g02e2528-1
                             kconfig5.106.0.r1083.g3c6d59de-15.107.0.r1084.g4c3cd07d-1
                      kconfigwidgets5.106.0.r912.g1420686c-15.107.0.r914.g61022016-1
                           kcontacts1:5.106.0.r3433.g729e4154-11:5.107.0.r3435.g80b7516a-1
                         kcoreaddons5.106.0.r1713.gdfeae760-15.107.0.r1716.ga0b3f907-1
                              kcrash5.106.0.r476.g59e89a5-15.107.0.r477.g737f253-1
                               kcron23.04.2.r907.g9637eb7-123.04.2.r908.g119d524-1
                                kdav1:5.106.0.r1409.g7135b71-11:5.107.0.r1410.gf010aae-1
                         kdbusaddons5.106.0.r484.ge3a526c-15.107.0.r485.g8b304ac-1
                     kde-dev-scripts23.04.2.r4182.gbd504fa-123.04.2.r4187.g3e60e9b-1
                       kde-dev-utils23.04.2.r666.g0d5e900-123.04.2.r670.g1a8f586-1
                      kdebugsettings23.04.2.r1368.gba99146-123.04.2.r1371.g1af9c07-1
                        kdeclarative5.106.0.r1149.gd579d6f7-15.107.0.r1151.g2afe8124-1
                          kdeconnect23.04.2.r3849.g4ef7c262-123.04.2.r3860.g7ca8b7bf-1
                                kded5.106.0.r503.g1c2ce2f-15.107.0.r504.g0e5e885-1
                     kdelibs4support5.106.0.r1206.ga4526feb-15.107.0.r1207.g78cfedff-1
                            kdenlive23.04.2.r18192.g6154d791d-123.04.2.r18216.g75878510a-1
                       kdepim-addons23.04.2.r5272.g9f5ee3de1-123.04.2.r5277.g97a5289c1-1
                      kdepim-runtime23.04.2.r15929.ge2729f0ab-123.04.2.r15943.g309e8d4ad-1
                    kdeplasma-addons5.27.5.r9401.gdeff16fd2-15.27.5.r9404.g3f672fe4a-1
                 kdesdk-thumbnailers23.04.2.r135.gbc52836-123.04.2.r136.g8f5c177-1
                     kdesignerplugin5.106.0.r414.g0b7c0c8-15.107.0.r415.g13dfdbd-1
                               kdesu5.106.0.r577.g7c7dfb1-15.107.0.r578.g8f5a809-1
                                 kdf23.04.2.r976.g86e7b91-123.04.2.r977.g1a709b8-1
                             kdialog23.04.2.r1366.g0832b04ba-123.04.2.r1367.g30874ab69-1
                              kdnssd5.106.0.r414.g13a3f95-15.107.0.r415.gc814b3b-1
                           kdoctools5.106.0.r736.geb4a560-15.107.0.r738.g0f64f69-1
                      keditbookmarks23.04.2.r2841.ga0c18fdc0-123.04.2.r2844.g5043cde77-1
                          kemoticons5.106.0.r447.ge12b6f5-15.107.0.r448.gad74777-1
                            keysmith23.01.0.r65.ge941e7e-123.01.0.r68.g1fb93f8-1
                       kfilemetadata5.106.0.r976.g53923f5-15.107.0.r980.g6a2ceef-1
                               kfind23.04.2.r2821.g789620dbc-123.04.2.r2822.gc264fa51f-1
                             kgamma55.27.5.r534.gd80bc76-15.27.5.r535.gd8138cc-1
                          kgeography23.04.2.r1255.g7d31981-123.04.2.r1256.gad15a3b-1
                                kget23.04.2.r3370.g179d7f65-123.04.2.r3372.gffc8b143-1
                        kglobalaccel5.106.0.r664.gc538ad5-15.107.0.r665.g65a12ec-1
                          kguiaddons5.106.0.r541.g6e21ce7-15.107.0.r543.g6111a0c-1
                         khelpcenter23.04.2.r2899.ge7acf8e8-123.04.2.r2901.gc11aaac8-1
                           kholidays1:5.106.0.r1133.g7c0e652-11:5.107.0.r1134.g946b451-1
                               khtml5.106.0.r683.g14a5880-15.107.0.r684.g1f2e9e2-1
                               ki18n5.106.0.r650.gbf8d37a-15.107.0.r651.g5af836d-1
                         kiconthemes5.106.0.r703.gcc16d7d-15.107.0.r704.gd673c5e-1
                           kidletime5.106.0.r400.gabb6a51-15.107.0.r401.gce3d595-1
                                 kig23.04.2.r3345.g046a3f87-123.04.2.r3346.gdc41bb5d-1
                            killbots23.04.2.r875.gdec0ee7-123.04.2.r876.g1025959-1
                       kimageformats5.106.0.r491.g5522781-15.107.0.r491.g5522781-1
                     kimagemapeditor23.04.2.r586.g0bf89e6-123.04.2.r587.g6a3ba1a-1
                         kinfocenter5.27.5.r2386.g8d0d365c-15.27.5.r2389.ga353348d-1
                               kinit5.106.0.r507.g997aa90-15.107.0.r508.gd0700b5-1
                                 kio5.106.0.r6196.g811fae761-15.107.0.r6203.g1b432118a-1
                          kio-extras23.04.2.r7575.g0680a0462-123.04.2.r7579.gc4466754a-1
                     kirigami-addons1:0.8.0.r49.gcf3d908-11:0.8.0.r51.g8594b93-1
                           kirigami25.106.0.r3713.g74155121-15.107.0.r3718.g9b9026a7-1
                              kiriki23.04.2.r534.g7e28ff1-123.04.2.r535.gee68a94-1
                         kitemmodels5.106.0.r650.g0952af4-15.107.0.r652.g9d48152-1
                          kitemviews5.106.0.r439.g65a60e6-15.107.0.r440.gaf6b2f7-1
                               kiten23.04.2.r1286.g11f5f88-123.04.2.r1288.g9878aa8-1
                          kitinerary23.04.2.r2957.gf62f9635-123.04.2.r2971.g6c469fd0-1
                         kjobwidgets5.106.0.r488.g19c44b6-15.107.0.r490.g528b880-1
                                 kjs5.106.0.r396.g5c2b216-15.107.0.r397.g1c2d172-1
                            kjsembed5.106.0.r385.gd6329a2-15.107.0.r387.g3e9d07c-1
                        kjumpingcube23.04.2.r917.gcd4e342-123.04.2.r918.gd76874a-1
                               kldap23.04.2.r1092.g385db87-123.04.2.r1093.gc77abbb-1
                           kleopatra23.04.2.r7308.g8cbe0a3d-123.04.2.r7321.g349e93a6-1
                            klettres23.04.2.r1050.ga7614e7-123.04.2.r1054.gfd4a3a7-1
                            klickety23.04.2.r775.g8f86b24-123.04.2.r779.g66c1101-1
                              klines23.04.2.r894.g7c56c56-123.04.2.r896.gab6677a-1
                           kmahjongg23.04.2.r1665.g515b2d5-123.04.2.r1669.g18557ae-1
                               kmail23.04.2.r27037.g58218c12c-123.04.2.r27042.g351002905-1
                      kmailtransport23.04.2.r1938.g5961f5b-123.04.2.r1939.gaa454b3-1
                        kmediaplayer5.106.0.r342.gbfcef6b-15.107.0.r343.gf6ac5ec-1
                               kmime23.04.2.r1629.ga926427-123.04.2.r1630.g1b1768c-1
                              kmines23.04.2.r1845.g02b3b61-123.04.2.r1850.g4173535-1
                                kmix23.04.2.r2582.g1d516924-123.04.2.r2612.gaed3e08b-1
                            knetwalk23.04.2.r788.g017a27e-123.04.2.r789.gad06a86-1
                           knewstuff5.106.0.r1554.gb67db719-15.107.0.r1558.g2b8b5c1a-1
                              knotes23.04.2.r3918.gb55dded6-123.04.2.r3919.gfff71f72-1
                      knotifications5.106.0.r827.ga3da946-15.107.0.r829.gf79d967-1
                       knotifyconfig5.106.0.r449.g6060c27-15.107.0.r450.gbaf90a1-1
                           kollision23.04.2.r606.ga16e446-123.04.2.r610.gd1a074b-1
                         kolourpaint23.04.2.r2536.g4b279d88-123.04.2.r2537.gaa921f53-1
                             kompare23.04.2.r1287.g4bce7f2-123.04.2.r1288.gd327c0c-1
                           konqueror23.04.2.r15452.g4cd673089-123.04.2.r15460.g9e5e5e28b-1
                             konsole23.04.2.r9082.g73d067991-123.04.2.r9092.g09237ee02-1
                             kontact23.04.2.r5767.g2c999500-123.04.2.r5773.gb9f9421e-1
                            kontrast23.04.2.r319.gfd12f26-123.04.2.r323.gb2d2c6a-1
                        konversation23.04.2.r9297.g2379a978-123.04.2.r9301.g177119c4-1
                              kopete23.04.2.r16570.ga053f12a8-123.04.2.r16572.gbb0cbe7ba-1
                            kpackage5.106.0.r848.g16f8ca2-15.107.0.r850.g4b183a1-1
                              kparts5.106.0.r707.gfac4423-15.107.0.r709.g1899f22-1
                                kpat23.04.2.r2756.g24dba31f-123.04.2.r2764.g40a2cbb9-1
                             kpeople5.106.0.r1440.g3c88090-15.107.0.r1441.g242a39e-1
                           kpipewire5.27.5.r277.gf09dca0-15.27.5.r278.g79d839a-1
                           kplotting5.106.0.r353.g828304b-15.107.0.r354.g218840a-1
                             kpmcore23.04.2.r1375.g6640766-123.04.2.r1377.g64950ee-1
                                kpty5.106.0.r437.g83d9774-15.107.0.r438.gf057be6-1
                        kquickcharts5.106.0.r560.ge4bcc10-15.107.0.r561.gdf8d171-1
                           krecorder23.01.0.r33.g28686dd-123.01.0.r36.g3d9bcb4-1
                            kreversi23.04.2.r1353.gd7e11ea-123.04.2.r1359.g6b90f1f-1
                               kross5.106.0.r417.g55f6204-15.107.0.r418.ge67caf8-1
                             krunner5.106.0.r829.gbb1f9c8-15.107.0.r830.geeba5c2-1
                             kscreen5.27.5.r1735.g91c0440-15.27.5.r1736.g4614c0e-1
                            kservice5.106.0.r1119.g5cb60b29-15.107.0.r1122.g7dd74be7-1
                             kshisen23.04.2.r1343.gc44c7f9-123.04.2.r1345.gde8511e-1
                          ksnakeduel23.04.2.r929.g2ef8918-123.04.2.r930.g42933f8-1
                          kspaceduel23.04.2.r740.gfb3d585-123.04.2.r742.gb72c390-1
                          ksystemlog23.04.2.r856.g17b7432-123.04.2.r858.g82763e4-1
                            kteatime23.04.2.r832.g1a85fd8-123.04.2.r833.g7548ff8-1
                         ktexteditor5.106.0.r3834.gf3e43910-15.107.0.r3835.gdba7f35c-1
                        ktextwidgets5.106.0.r530.ga9dd186-15.107.0.r532.gc067005-1
                               ktnef23.04.2.r817.g04882d2-123.04.2.r818.gb375d0d-1
                            ktorrent23.04.2.r2994.g1b0408e0-123.04.2.r3036.gacd8fb26-1
                              ktouch23.04.2.r2273.gd2d25550-123.04.2.r2279.g9e219ec0-1
                          ktuberling23.04.2.r1163.g9378253-123.04.2.r1164.g23adc02-1
                     kunitconversion5.106.0.r528.g7b21c5f-15.107.0.r529.g1f536b7-1
                             kwallet5.106.0.r1266.g1a4135d-15.107.0.r1268.g6576af9-1
                      kwalletmanager23.04.2.r1464.g6a4a01b-123.04.2.r1467.ge547b8f-1
                            kwayland5.106.0.r1213.g6f31cb0-15.107.0.r1214.ged1b9b4-1
                            kweather23.01.0.r43.g1c185f7-123.01.0.r46.g44c0bdb-1
                      kwidgetsaddons5.106.0.r1098.ga70ee848-15.107.0.r1102.gf210eef0-1
                                kwin5.27.5.r24241.g3cf71114cb-15.27.5.r24247.g887ed2ff80-1
                       kwindowsystem5.106.0.r773.gfd518aa-15.107.0.r774.g17a80d3-1
                           kwordquiz23.04.2.r1320.g73a22e3-123.04.2.r1321.g1d76ddf-1
                              kwrite23.04.2.r20730.geefd3ba2d-123.04.2.r20745.gae2f208c3-1
                             kxmlgui5.106.0.r1007.gb507bcd9-15.107.0.r1009.g8f816d6e-1
                       kxmlrpcclient5.106.0.r530.g4eef45859-15.107.0.r532.gcfadc1c50-1
                          libakonadi23.04.2.r13076.g84e914c45-123.04.2.r13079.gaf9403068-1
                            libkcddb23.04.2.r851.ga26e08a-123.04.2.r853.g1ff6a67-1
                          libkscreen5.27.5.r1793.g6dd959b-15.27.5.r1794.g56f0286-1
                         libktorrent23.04.2.r604.g5eb5b48-123.04.2.r605.gbe31880-1
                            lokalize23.04.2.r2042.g8fbd5973-123.04.2.r2077.g040102a3-1
                               lskat23.04.2.r935.g9ea5ee9-123.04.2.r936.g981acda-1
                              marble23.04.2.r13688.gc59f6e9c3-123.04.2.r13690.ga405b4904-1
                       marble-common23.04.2.r13688.gc59f6e9c3-123.04.2.r13690.ga405b4904-1
                           marble-qt23.04.2.r13688.gc59f6e9c3-123.04.2.r13690.ga405b4904-1
                           maui-clip  3.0.0.r3.g0fe9803-1  3.0.0.r6.ga3d0b8b-1
                            maui-pix  3.0.0.r8.ga57afe4-1 3.0.0.r10.g09b3fa3-1
                mauikit-filebrowsing 2.2.2.r54.g0550cee-1 2.2.2.r55.gcded899-1
                          messagelib23.04.2.r7168.gee6a11b8f-123.04.2.r7171.g90773faa9-1
                     modemmanager-qt5.106.0.r584.gb38b562-15.107.0.r585.gdb21d1d-1
                             neochat23.01.0.r446.g7c75a2fd0-123.01.0.r461.g25f9c7e12-1
                   networkmanager-qt5.106.0.r1193.gca94264-15.107.0.r1194.gf26d162-1
                              okular23.04.2.r10118.gd78752ea3-123.04.2.r10135.ga5e15d7c6-1
                        oxygen-icons1:5.106.0.r5.gbff159d-11:5.107.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.106.0.r5.gbff159d-11:5.107.0.r5.gbff159d-1
                            palapeli23.04.2.r1396.g8e47257-123.04.2.r1397.g04d75f0-1
                              parley23.04.2.r4622.g5ab4330b-123.04.2.r4623.g96314f62-1
                    partitionmanager23.04.2.r1810.g58e6465-123.04.2.r1813.g3c57dfe-1
                               picmi23.04.2.r640.gcf33236-123.04.2.r641.gc319f24-1
                   pim-data-exporter23.04.2.r2921.gfe05d2a1-123.04.2.r2924.gaaa8bc64-1
                           pimcommon23.04.2.r2112.g65d25789-123.04.2.r2113.g56dd97c5-1
                    plasma-bigscreen5.26.0.r691.g6a0f5dd-15.26.0.r698.g2c16ffe-1
                      plasma-desktop5.27.5.r10260.g30bf5d7d7-15.27.5.r10268.g44101b5cb-1
                       plasma-dialer23.01.0.r92.g22e92a2-123.01.0.r97.gdbe0ecb-1
                    plasma-framework5.106.0.r16647.gff3792f86-15.107.0.r16654.g19251d243-1
                    plasma-mobile-nm5.27.5.r3617.gdf2d73b9-15.27.5.r3619.g68667c5d-1
                           plasma-nm5.27.5.r3617.gdf2d73b9-15.27.5.r3619.g68667c5d-1
                           plasma-pa5.27.5.r1236.g6282ef8-15.27.5.r1237.g9c84c32-1
                    plasma-phonebook23.01.0.r69.g4c89eef-123.01.0.r70.gf7cd355-1
                          plasma-sdk5.27.5.r2517.gfd4eb174-15.27.5.r2519.ga1d354d3-1
                plasma-systemmonitor5.27.5.r738.g009565c-15.27.5.r741.g329fd4f-1
              plasma-wayland-session5.27.5.r13450.g3672104c7-15.27.5.r13458.g1ab5a7ada-1
                    plasma-workspace5.27.5.r13450.g3672104c7-15.27.5.r13458.g1ab5a7ada-1
                          plasmatube23.01.0.r92.g62e27e4-123.01.0.r95.g38e6c0e-1
                          powerdevil5.27.5.r2741.g7740e71c-15.27.5.r2742.gb8d0843b-1
                       print-manager23.04.2.r1280.g3f40324-123.04.2.r1285.gbc15707-1
                              prison5.106.0.r431.g15d7ad4-15.107.0.r432.ge3ba8f5-1
                             purpose5.106.0.r1126.g79345b2f-15.107.0.r1127.ga547c564-1
                          qmlkonsole23.01.0.r88.gf62407e-123.01.0.r91.g79a2d7b-1
                  qqc2-desktop-style5.106.0.r753.gb32fe71-15.107.0.r754.g1589093-1
                            sddm-kcm5.27.5.r765.g1b1faf6-15.27.5.r766.gd8ca15e-1
                               solid5.106.0.r903.g2dc6206-15.107.0.r905.gdb5bd7c-1
                              sonnet5.106.0.r796.g540d5b7-15.107.0.r798.gf77e2c5-1
                            spacebar23.01.0.r70.gb07b3fa-123.01.0.r75.g95beae9-1
                           spectacle23.04.2.r1761.g8e3afdd-123.04.2.r1770.g0c174d0-1
                             sweeper23.04.2.r645.g61bef39-123.04.2.r650.ge05931f-1
                         syndication5.106.0.r908.g03c68e6-15.107.0.r909.ga187df2-1
                 syntax-highlighting5.106.0.r2150.gef98ada2-15.107.0.r2155.g3e3649b5-1
                      systemsettings5.27.5.r2900.gc8809c27-15.27.5.r2903.ga058d2ee-1
                        threadweaver5.106.0.r573.g04f888f-15.107.0.r574.gd1c9d47-1
                         vakzination23.01.0.r74.g7ce6f4c-123.01.0.r77.g58bbfe8-1
              xdg-desktop-portal-kde5.27.5.r709.g9053e1f-15.27.5.r711.gd569d88-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
wiki post
Added some more packages:
                             PACKAGE           2023.06.18           2023.06.19
             mesa-apple-silicon-edge 23.2.0_pre20230606-1 23.2.0_pre20230615-1
       mesa-apple-silicon-edge-debug 23.2.0_pre20230606-1 23.2.0_pre20230615-1
    vulkan-swrast-apple-silicon-edge 23.2.0_pre20230606-1 23.2.0_pre20230615-1
                 linux-apple-silicon                6.3-1                6.3-2
            linux-apple-silicon-edge                6.3-1                6.3-2
         linux-apple-silicon-headers                6.3-1                6.3-2
                          artikulate23.04.2.r1522.g9344e4f-123.04.2.r1523.g4c0fd97-1
                              cantor23.04.2.r3603.gdbbd804e-123.04.2.r3604.gb550b045-1
                             dolphin23.04.2.r7424.g9c614949d-123.04.2.r7425.g7f3967cf3-1
                           itinerary23.04.2.r2748.gee848824-123.04.2.r2758.g4f24e781-1
                              kalarm23.04.2.r8402.gd330294b-123.04.2.r8403.gc9737659-1
                              kamera23.04.2.r837.g8b8578d-123.04.2.r839.g58ebaaa-1
                                kate23.04.2.r20745.gae2f208c3-123.04.2.r20748.g9105c3ec6-1
                     kde-dev-scripts23.04.2.r4187.g3e60e9b-123.04.2.r4188.g2f5d516-1
                          kdeconnect23.04.2.r3860.g7ca8b7bf-123.04.2.r3861.g4ee2d03c-1
                            kdenlive23.04.2.r18216.g75878510a-123.04.2.r18230.g54bf12816-1
                      kdepim-runtime23.04.2.r15943.g309e8d4ad-123.04.2.r15944.g4869141a1-1
                                 kdf23.04.2.r977.g1a709b8-123.04.2.r979.g93f37f4-1
                            kdiamond23.04.2.r799.g7596172-123.04.2.r800.g0234e66-1
                               kfind23.04.2.r2822.gc264fa51f-123.04.2.r2823.ga2083c781-1
                             kfloppy23.04.2.r875.gf2f65d2-123.04.2.r876.g1a48702-1
                         kfourinline23.04.2.r1108.g0461ef3-123.04.2.r1109.g2a10b25-1
                            khangman23.04.2.r1700.g5d32616-123.04.2.r1701.g624d0f9-1
                         khelpcenter23.04.2.r2901.gc11aaac8-123.04.2.r2902.gc7e955a3-1
                                 kig23.04.2.r3346.gdc41bb5d-123.04.2.r3348.g3ad06176-1
                                kigo23.04.2.r660.gd1de2ff-123.04.2.r661.g5047b1e-1
                            killbots23.04.2.r876.g1025959-123.04.2.r877.g46583b5-1
                     kimagemapeditor23.04.2.r587.g6a3ba1a-123.04.2.r588.g52013fa-1
                                 kio5.107.0.r6203.g1b432118a-15.107.0.r6204.g41c85d476-1
                          kio-extras23.04.2.r7579.gc4466754a-123.04.2.r7580.ge51ce6c3c-1
                          kitinerary23.04.2.r2971.g6c469fd0-123.04.2.r2973.g6280cd7c-1
                           kleopatra23.04.2.r7321.g349e93a6-123.04.2.r7322.gd877b915-1
                kmail-account-wizard23.04.2.r985.ge4a7cf5-123.04.2.r986.g3a8a24e-1
                             konsole23.04.2.r9092.g09237ee02-123.04.2.r9093.gfd819564a-1
                             krunner5.107.0.r830.geeba5c2-15.107.0.r831.g992d1ed-1
                            ktorrent23.04.2.r3036.gacd8fb26-123.04.2.r3037.g68d4b00e-1
                                kwin5.27.5.r24247.g887ed2ff80-15.27.5.r24248.ge720f69288-1
                              kwrite23.04.2.r20745.gae2f208c3-123.04.2.r20748.g9105c3ec6-1
                            lokalize23.04.2.r2077.g040102a3-123.04.2.r2078.g9c3d3094-1
                              marble23.04.2.r13690.ga405b4904-123.04.2.r13691.g5d20c020b-1
                       marble-common23.04.2.r13690.ga405b4904-123.04.2.r13691.g5d20c020b-1
                           marble-qt23.04.2.r13690.ga405b4904-123.04.2.r13691.g5d20c020b-1
                             neochat23.01.0.r461.g25f9c7e12-123.01.0.r466.g5552cd60f-1
                   networkmanager-qt5.107.0.r1194.gf26d162-15.107.0.r1195.gc744a32-1
                              okular23.04.2.r10135.ga5e15d7c6-123.04.2.r10137.g0c383d8cf-1
                    plasma-bigscreen5.26.0.r698.g2c16ffe-15.26.0.r699.g0fd78ca-1
                    plasma-framework5.107.0.r16654.g19251d243-15.107.0.r16656.gcd713c344-1
                plasma-systemmonitor5.27.5.r741.g329fd4f-15.27.5.r742.gf0ec38b-1
                          plasmatube23.01.0.r95.g38e6c0e-123.01.0.r101.g70a9d37-1
          telepathy-kde-accounts-kcm23.04.2.r1267.g06f990b-123.04.2.r1268.g17a41cf-1
               telepathy-kde-text-ui23.04.2.r2106.g5f3cd61d-123.04.2.r2107.gec991efb-1
              xdg-desktop-portal-kde5.27.5.r711.gd569d88-15.27.5.r712.gbc18648-1
Hi @philm,
Now that archlinuxarm has uploaded new upstream packages (just check), does this means we can expect Manjaro-Arm to update upstream Gnome packages soon on Unstable and then to Testing?
Thanks.
