[ARM Testing Update] 2023-06-09 - Kernels, Apple Silicon, Mobile, KDE-git
Hello ARM community.
Archlinux ARM is still migrating to the community to extra repo merge since 2 weeks now. So no upstream updates in this one. However we updated kernels, firmwares and other mobile related goodies for you.
Update Announcement
Some highlights:
  • Some Kernels got renewed
  • Apple-Silicon packages got renewed to the latest issued by Asahi Linux. Graphic stack got improved a lot. However, our installer is still internal
  • Some of the mobile support packages got updated
  • The usual KDE-git updates
End Of Life kernels (will be removed from repo soon):
  • linux60 (EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Fri May 19 13:30:34 CEST 2023)
  • arm-testing community aarch64: 19 new and 19 removed package(s)
  • arm-testing core aarch64: 16 new and 15 removed package(s)
  • arm-testing extra aarch64: 1 new and 1 removed package(s)
  • arm-testing kde-unstable aarch64: 124 new and 124 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2023.05.31           2023.06.09
               apple-silicon-configs           20221206-1           20230517-1
                     asahi-fwextract            0.5pre2-3              0.5.4-1
                       asahi-scripts           20221206-1           20230606-2
                           bitwarden           2023.5.0-1           2023.5.0-2
                                code             1.78.2-1             1.79.0-1
                            electron             23.1.2-1             23.3.6-1
                          electron20            20.3.11-1                    -
                          electron21             21.4.2-1             21.4.4-1
                          electron22             22.3.2-1            22.3.12-1
                         gnome-calls               44.1-2               44.1-3
                  gnome-shell-mobile44.0+r283+g034144c20-144.1+r326+g9b7df11f1-1
             mesa-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
       mesa-apple-silicon-edge-debug 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                       mutter-mobile44.0+r88+g780aadd4e-244.1+r191+g5e72de83d-1
                               phosh             0.28.0-10.28.0+13+g31896512-1
                      phosh-antispam              3.2.0-2              3.3.0-1
                         vakzination            23.01.0-1            23.01.0-2
    vulkan-swrast-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                        wire-desktop          3.30.3018-1          3.31.3060-1
                          electron24                    -             24.5.0-1
:: Different overlay package(s) in repository core aarch64
                 linux-apple-silicon                6.2-1                6.3-1
            linux-apple-silicon-edge                6.2-1                6.3-1
         linux-apple-silicon-headers                6.2-1                6.3-1
                     linux-pinephone              6.3.5-1              6.3.6-1
             linux-pinephone-headers              6.3.5-1              6.3.6-1
                  linux-pinephonepro              6.3.5-1              6.3.6-1
          linux-pinephonepro-headers              6.3.5-1              6.3.6-1
                          linux-rpi4             6.1.31-1             6.1.32-1
                  linux-rpi4-headers             6.1.31-1             6.1.32-1
                 linux-rpi4-mainline              6.3.5-1              6.3.6-1
         linux-rpi4-mainline-headers              6.3.5-1              6.3.6-1
                       linux-rpi4-rc            6.4.rc4-1            6.4.rc5-1
               linux-rpi4-rc-headers            6.4.rc4-1            6.4.rc5-1
                                m1n1              1.2.6-1              1.2.9-1
                 uboot-apple-silicon            2023.01-1            2023.04-1
                    uboot-odroid-n2l                    -            2023.04-1
:: Different overlay package(s) in repository extra aarch64
                               snapd             2.59.5-1             2.59.5-2
:: Different overlay package(s) in repository kde-unstable aarch64
                        akonadi-mime23.04.1.r1873.gae00608-123.04.1.r1874.gf4c29c4-1
                      akonadiconsole23.04.0.r1747.g17f7951-123.04.0.r1748.gb566587-1
                           akregator23.04.0.r6725.g3b691ed9-123.04.0.r6726.g5325284a-1
                                 ark23.04.0.r5088.g2a7f46b3-123.04.0.r5090.g5033a623-1
                         audiocd-kio23.04.1.r1206.ge338398-123.04.1.r1208.g061a22c-1
                               baloo5.106.0.r3244.geafae07a-15.106.0.r3245.g9755144d-1
                           bluedevil1:5.27.5.r2612.ge033d939-11:5.27.5.r2613.gb31f376a-1
                                buho  3.0.0.r5.gec42169-1  3.0.0.r6.ga4c2c66-1
                              cantor23.04.1.r3600.g19ed0b66-123.04.1.r3601.g9c3c6952-1
                            cervisia23.04.0.r1778.g9b84f0b-123.04.0.r1779.gefbddbb-1
                            discover5.27.5.r9333.gc4c0ad257-15.27.5.r9334.g6e746505b-1
                             dolphin23.04.1.r7416.ge5abe2c67-123.04.1.r7417.gbb08c70a9-1
                              dragon23.04.1.r1194.g8f5664a-123.04.1.r1196.g94b6111-1
                             drkonqi5.27.5.r930.g8cb1aea1-15.27.5.r931.g9c42ce25-1
                               elisa23.04.1.r3313.g2ebf6bd6-123.04.1.r3320.g8d11cf2f-1
                          elisa-qtmm23.04.1.r3313.g2ebf6bd6-123.04.1.r3320.g8d11cf2f-1
                           filelight23.04.0.r1408.g2f2b5a1-123.04.0.r1410.g253b29d-1
                            gwenview23.04.1.r7161.ga483380d-123.04.1.r7164.g47e8bdb0-1
                     incidenceeditor23.04.1.r1050.g7b9c8a1-123.04.1.r1051.g7c3d773-1
                           itinerary23.04.0.r2712.g01b4fc49-123.04.0.r2714.g266bd2fc-1
                                 juk23.04.1.r3265.g77d80714-123.04.1.r3266.gf840340e-1
                                 k3b1:23.04.1.r6998.g1cf60e813-11:23.04.1.r6999.g329361b61-1
                   kactivitymanagerd5.27.5.r1462.g861f9de-15.27.5.r1463.gd454806-1
                        kaddressbook23.04.1.r6417.g5c6a2248-123.04.1.r6418.g3c81c34c-1
                             kajongg23.04.1.r4419.gdcdf2ee5-123.04.1.r4420.g419236d2-1
                              kalarm23.04.0.r8339.g365a6581-123.04.0.r8393.g18a71dbe-1
                             kalzium23.04.1.r4512.ge103ed83-123.04.1.r4516.g80a9ab41-1
                               kasts23.01.0.r165.gb1d8d47-123.01.0.r166.gf3e5314-1
                                kate23.04.0.r20721.gd208dfe5a-123.04.0.r20725.g946285e9f-1
                          kbookmarks5.106.0.r535.g5dd2497-15.106.0.r536.g60642fc-1
                         kcachegrind23.04.0.r1278.g5cbbd88-123.04.0.r1279.g6886de0-1
                  kcachegrind-common23.04.0.r1278.g5cbbd88-123.04.0.r1279.g6886de0-1
                            kcmutils5.106.0.r752.g861104da-15.106.0.r753.g4cffd2db-1
                             kconfig5.106.0.r1082.g1b47e6c3-15.106.0.r1083.g3c6d59de-1
                           kcontacts1:5.106.0.r3432.g80b99ae8-11:5.106.0.r3433.g729e4154-1
                       kde-cli-tools5.27.5.r2130.ge8132be-15.27.5.r2132.g77db7e9-1
                       kde-dev-utils23.04.0.r663.g74eae5a-123.04.0.r666.g0d5e900-1
                      kdebugsettings23.04.0.r1367.g2b9cccc-123.04.0.r1368.gba99146-1
                          kdeconnect23.04.0.r3842.gdf9be7e6-123.04.0.r3846.g144a60b5-1
                            kdenlive23.04.0.r18149.gc00260e0d-123.04.0.r18178.g2192766fa-1
                       kdepim-addons23.04.0.r5271.g0cc67708c-123.04.0.r5272.g9f5ee3de1-1
                      kdepim-runtime23.04.1.r15928.gea73e40e2-123.04.1.r15929.ge2729f0ab-1
                    kdeplasma-addons5.27.5.r9399.gb86d9f13b-15.27.5.r9401.gdeff16fd2-1
                             kdialog23.04.0.r1365.g0fe2062c1-123.04.0.r1366.g0832b04ba-1
                      keditbookmarks23.04.0.r2838.ga35a913a2-123.04.0.r2839.gdddb7ac98-1
                            keysmith23.01.0.r64.gb6f41d9-123.01.0.r65.ge941e7e-1
                       kfilemetadata5.106.0.r973.g7c395e2-15.106.0.r975.g1131c16-1
                               kfind23.04.0.r2820.g86338ab1e-123.04.0.r2821.g789620dbc-1
                             kfloppy23.04.0.r874.g96209b6-123.04.0.r875.gf2f65d2-1
                                kget23.04.0.r3369.g22d0c200-123.04.0.r3370.g179d7f65-1
                         khelpcenter23.04.0.r2896.g2d2d1f04-123.04.0.r2897.g2a13d034-1
                               khtml5.106.0.r682.g121f508-15.106.0.r683.g14a5880-1
                                 kig23.04.1.r3343.g58ce31b1-123.04.1.r3344.gfa593a44-1
                                kigo23.04.1.r659.ge608c95-123.04.1.r660.gd1de2ff-1
                         kinfocenter5.27.5.r2383.g18c0d4d0-15.27.5.r2385.g107b1dd7-1
                                 kio5.106.0.r6191.g0e6c01e0c-15.106.0.r6194.gd54b5656a-1
                          kio-extras23.04.0.r7573.g6950463ed-123.04.0.r7574.g51e9df236-1
                     kirigami-addons1:0.8.0.r47.g3604f34-11:0.8.0.r49.gcf3d908-1
                           kirigami25.106.0.r3710.g21106c6e-15.106.0.r3713.g74155121-1
                              kiriki23.04.1.r533.g282d39b-123.04.1.r534.g7e28ff1-1
                          kitinerary23.04.1.r2949.gc43adca3-123.04.1.r2957.gf62f9635-1
                           kleopatra23.04.0.r7300.ge249c30e-123.04.0.r7301.g5fe11e2e-1
                           kmahjongg23.04.1.r1664.g1390305-123.04.1.r1665.g515b2d5-1
                               kmail23.04.0.r27005.g05f2056d5-123.04.0.r27027.g53f672fb8-1
                      kmailtransport23.04.1.r1937.g588a092-123.04.1.r1938.g5961f5b-1
                          kmousetool23.04.1.r523.g55db80d-123.04.1.r524.g2d95fcf-1
                           knewstuff5.106.0.r1552.g5bf8c87f-15.106.0.r1553.ge2a91237-1
                              knotes23.04.0.r3917.gc00720f7-123.04.0.r3918.gb55dded6-1
                         kolourpaint23.04.1.r2534.g3c112dc4-123.04.1.r2535.g66311f8b-1
                             kompare23.04.0.r1285.geebb3f3-123.04.0.r1286.gf7d0085-1
                           konqueror23.04.0.r15448.g3e8624be9-123.04.0.r15449.gcd33005af-1
                             konsole23.04.0.r9075.g95bcf2e0a-123.04.0.r9080.g051cab71c-1
                              kopete23.04.0.r16568.g7b7a0f0c9-123.04.0.r16569.g134ed26ef-1
                             kpmcore23.04.1.r1374.g992174e-123.04.1.r1375.g6640766-1
                    kpublictransport23.04.1.r2179.g231e3f02-123.04.1.r2180.g8b7136a5-1
                             kshisen23.04.1.r1342.g1117378-123.04.1.r1343.gc44c7f9-1
                               ksirk23.04.1.r1141.g8fb1bae-123.04.1.r1142.gf1b7179-1
                            kteatime23.04.0.r831.g5c745f8-123.04.0.r832.g1a85fd8-1
                         ktextaddons      r481.g1030c42-1      r482.g0370101-1
                         ktexteditor5.106.0.r3833.gd8abfb98-15.106.0.r3834.gf3e43910-1
                               ktnef23.04.1.r816.g405852e-123.04.1.r817.g04882d2-1
                            ktorrent23.04.0.r2990.g519d9ec6-123.04.0.r2992.gccc8655e-1
                              ktouch23.04.1.r2269.gd0a1621-123.04.1.r2271.gaf75d6b5-1
                               ktrip23.01.0.r26.g1befab2-123.01.0.r29.g82fecb7-1
                             kturtle23.04.1.r1273.gb6e55e2-123.04.1.r1274.g0ebcf61-1
                             kubrick23.04.1.r490.ge5163ce-123.04.1.r491.gb6c8628-1
                               kwave23.04.0.r3882.g8e97359f-123.04.0.r3883.g2a03ba6d-1
                                kwin5.27.5.r24236.g5a9cfe174a-15.27.5.r24238.g4624503a7c-1
                           kwordquiz23.04.1.r1319.g5ffc9f9-123.04.1.r1320.g73a22e3-1
                              kwrite23.04.0.r20721.gd208dfe5a-123.04.0.r20725.g946285e9f-1
                             kxmlgui5.106.0.r1006.g52234202-15.106.0.r1007.gb507bcd9-1
                            libkcddb23.04.1.r850.g0c12974-123.04.1.r851.ga26e08a-1
                         libkdegames23.04.1.r2335.g052d0506-123.04.1.r2336.gd8f0a978-1
                             libkleo23.04.1.r1528.g7f9e67d-123.04.1.r1529.gb6f9d1e-1
                           libksieve23.04.1.r1911.gb2d65ed4-123.04.1.r1912.g9c6669e6-1
                            lokalize23.04.0.r2041.gf1d105e8-123.04.0.r2042.g8fbd5973-1
                              marble23.04.1.r13685.g579881495-123.04.1.r13687.g22fdac47d-1
                       marble-common23.04.1.r13685.g579881495-123.04.1.r13687.g22fdac47d-1
                           marble-qt23.04.1.r13685.g579881495-123.04.1.r13687.g22fdac47d-1
                mauikit-filebrowsing 2.2.2.r53.g41625fa-1 2.2.2.r54.g0550cee-1
                          messagelib23.04.1.r7166.g516798438-123.04.1.r7167.g6314f6c91-1
                             neochat23.01.0.r424.gb5c781212-123.01.0.r431.g9e78ab332-1
                              okular23.04.1.r10109.g57f5c6933-123.04.1.r10111.gef7e0ca29-1
                              oxygen5.27.5.r4586.g91d4055f-15.27.5.r4587.ge99fc48e-1
                      plasma-desktop5.27.5.r10256.g344a69a38-15.27.5.r10259.g3fb604dff-1
                     plasma-firewall5.27.5.r737.g4a94a16-15.27.5.r738.g4be5574-1
                    plasma-mobile-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                           plasma-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                           plasma-pa5.27.5.r1235.g5a5d6b8-15.27.5.r1236.g6282ef8-1
                    plasma-phonebook23.01.0.r65.g93c377b-123.01.0.r69.g4c89eef-1
                          plasma-sdk5.27.5.r2514.gcb01a3dc-15.27.5.r2515.g86d760ce-1
                        plasma-vault5.27.5.r451.gf48f354-15.27.5.r452.gc5577ab-1
              plasma-wayland-session5.27.5.r13443.g6de6467f1-15.27.5.r13449.g9d18e0821-1
                    plasma-workspace5.27.5.r13443.g6de6467f1-15.27.5.r13449.g9d18e0821-1
                          powerdevil5.27.5.r2737.gb6aea53e-15.27.5.r2738.g02d13197-1
                         qcachegrind23.04.0.r1278.g5cbbd88-123.04.0.r1279.g6886de0-1
                            spacebar23.01.0.r69.g1c98873-123.01.0.r70.gb07b3fa-1
                           spectacle23.04.1.r1759.g862d435-123.04.1.r1760.gf038fc6-1
                 syntax-highlighting5.106.0.r2149.gb1306e94-15.106.0.r2150.gef98ada2-1
          telepathy-kde-accounts-kcm23.04.0.r1266.g8bb97ee-123.04.0.r1267.g06f990b-1
                         vakzination23.01.0.r73.g6038668-123.01.0.r74.g7ce6f4c-1
                               vvave  3.0.0.r7.g6f9bed1-1  3.0.0.r8.g26b46cd-1
              xdg-desktop-portal-kde5.27.5.r708.gbc247f6-15.27.5.r709.g9053e1f-1
                             yakuake23.04.0.r969.g89321fe-123.04.0.r970.gb23b734-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
:arrow_right: 2023-05-31
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Ethernet and Wifi not working right on kernel 6.1.2+ on some devices
Some devices have been reported to not have properly working ethernet and wifi after the update to kernel 6.1.2 and above.
Fix: Kernel 6.1.5-2 and above should have working ethernet and wifi again.
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in.
Fix Fixed in version 4.0.0-1 of mobile-config-firefox released with Manjaro testing on April 14, 2023
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Added some more packages:
                             PACKAGE          arm-testing         arm-unstable
                          callaudiod              0.1.9-1              0.1.9-2
                       mutter-mobile44.1+r191+g5e72de83d-144.1+r191+g5e72de83d-2.0
                     linux-pinephone              6.3.6-1              6.3.7-1
             linux-pinephone-headers              6.3.6-1              6.3.7-1
                  linux-pinephonepro              6.3.6-1              6.3.7-1
          linux-pinephonepro-headers              6.3.6-1              6.3.7-1
                             akonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                    akonadi-calendar23.04.1.r2364.g2c16022-123.04.2.r2364.g2c16022-1
              akonadi-calendar-tools23.04.0.r1047.g7a009d5-123.04.2.r1050.g9ba89ef-1
                    akonadi-contacts23.04.1.r3474.gc4e5f229-123.04.2.r3474.gc4e5f229-1
               akonadi-import-wizard23.04.1.r1941.g5abcbc9-123.04.2.r1941.g5abcbc9-1
                        akonadi-mime23.04.1.r1874.gf4c29c4-123.04.2.r1874.gf4c29c4-1
                       akonadi-notes23.04.1.r1169.gb451bbe-123.04.2.r1169.gb451bbe-1
                      akonadi-search23.04.1.r1395.gc9cd29c-123.04.2.r1397.gfd9883c-1
                      akonadiconsole23.04.0.r1748.gb566587-123.04.2.r1748.gb566587-1
                           akregator23.04.0.r6726.g5325284a-123.04.2.r6726.g5325284a-1
                            analitza23.04.1.r2396.gb2b30fe1-123.04.2.r2396.gb2b30fe1-1
                                 ark23.04.0.r5090.g5033a623-123.04.2.r5090.g5033a623-1
                          artikulate23.04.1.r1522.g9344e4f-123.04.2.r1522.g9344e4f-1
                         audiocd-kio23.04.1.r1208.g061a22c-123.04.2.r1208.g061a22c-1
                       baloo-widgets23.04.1.r878.g2e8ea3c-123.04.2.r878.g2e8ea3c-1
                             blinken23.04.1.r740.g6d13ea0-123.04.2.r740.g6d13ea0-1
                              bomber23.04.1.r636.g7e6e493-123.04.2.r636.g7e6e493-1
                                bovo23.04.1.r857.ga9f1dbe-123.04.2.r857.ga9f1dbe-1
                              breeze5.27.5.r2628.g5d279205-15.27.5.r2629.g4afc46e7-1
                     calendarsupport23.04.0.r849.gde62582-123.04.2.r849.gde62582-1
                              cantor23.04.1.r3601.g9c3c6952-123.04.2.r3603.gdbbd804e-1
                            cervisia23.04.0.r1779.gefbddbb-123.04.2.r1779.gefbddbb-1
                            discover5.27.5.r9334.g6e746505b-15.27.5.r9335.g725681901-1
                             dolphin23.04.1.r7417.gbb08c70a9-123.04.2.r7417.gbb08c70a9-1
                     dolphin-plugins23.04.0.r760.gb6391fd-123.04.2.r761.g1abd322-1
                              dragon23.04.1.r1196.g94b6111-123.04.2.r1196.g94b6111-1
                               elisa23.04.1.r3320.g8d11cf2f-123.04.2.r3320.g8d11cf2f-1
                          elisa-qtmm23.04.1.r3320.g8d11cf2f-123.04.2.r3320.g8d11cf2f-1
                          eventviews23.04.0.r1026.g54d1d27-123.04.2.r1028.gdd65a38-1
                        ffmpegthumbs23.04.1.r263.g8a8b7c2-123.04.2.r263.g8a8b7c2-1
                           filelight23.04.0.r1410.g253b29d-123.04.2.r1410.g253b29d-1
                           granatier23.04.1.r1051.g5e93a6c-123.04.2.r1051.g5e93a6c-1
                     grantlee-editor23.04.0.r941.gb634afb-123.04.2.r941.gb634afb-1
                       grantleetheme23.04.1.r504.g1f1c47b-123.04.2.r504.g1f1c47b-1
                     incidenceeditor23.04.1.r1051.g7c3d773-123.04.2.r1051.g7c3d773-1
                           itinerary23.04.0.r2714.g266bd2fc-123.04.2.r2715.gae36bdb6-1
                                 juk23.04.1.r3266.gf840340e-123.04.2.r3266.gf840340e-1
                                 k3b1:23.04.1.r6999.g329361b61-11:23.04.2.r6999.g329361b61-1
               kaccounts-integration23.04.1.r1364.gbf22267-223.04.2.r1364.gbf22267-1
                 kaccounts-providers23.04.1.r443.g3e40fe3-123.04.2.r443.g3e40fe3-1
                        kaddressbook23.04.1.r6418.g3c81c34c-123.04.2.r6420.gbc60dd46-1
                             kajongg23.04.1.r4420.g419236d2-123.04.2.r4422.g451e34a3-1
                              kalarm23.04.0.r8393.g18a71dbe-123.04.2.r8395.g124644f6-1
                            kalgebra23.04.1.r2162.g0ded608-123.04.2.r2162.g0ded608-1
                             kalzium23.04.1.r4516.g80a9ab41-123.04.2.r4516.g80a9ab41-1
                              kamera23.04.1.r828.gd491cfd-123.04.2.r828.gd491cfd-1
                              kamoso23.04.0.r1557.ga018c91-123.04.2.r1557.ga018c91-1
                            kanagram23.04.1.r1406.gbc68a1f-123.04.2.r1406.gbc68a1f-1
                              kapman23.04.1.r734.gc63a2da-123.04.2.r734.gc63a2da-1
                        kapptemplate23.04.0.r1063.g5fded2a-123.04.2.r1063.g5fded2a-1
                               kasts23.01.0.r166.gf3e5314-123.01.0.r168.g21952c6-1
                                kate23.04.0.r20725.g946285e9f-123.04.2.r20730.geefd3ba2d-1
                             katomic23.04.1.r1046.g9ed1b51-123.04.2.r1046.g9ed1b51-1
                             kbackup23.04.0.r544.g81bfeb6-123.04.2.r544.g81bfeb6-1
                           kblackbox23.04.1.r846.gb0bfda4-123.04.2.r847.gdc37f08-1
                             kblocks23.04.1.r826.g2447c84-123.04.2.r826.g2447c84-1
                             kbounce23.04.1.r932.gc80ffc9-123.04.2.r932.gc80ffc9-1
                           kbreakout23.04.1.r999.gbfe0cbd-123.04.2.r999.gbfe0cbd-1
                              kbruch23.04.1.r956.g4a4b7e8-123.04.2.r956.g4a4b7e8-1
                         kcachegrind23.04.0.r1279.g6886de0-123.04.2.r1281.gbf373a0-1
                  kcachegrind-common23.04.0.r1279.g6886de0-123.04.2.r1281.gbf373a0-1
                               kcalc23.04.0.r1736.ga499fae-123.04.2.r1736.ga499fae-1
                           kcalutils23.04.1.r1084.gf8302135f-123.04.2.r1084.gf8302135f-1
                         kcharselect23.04.0.r625.g019cf4f-123.04.2.r625.g019cf4f-1
                              kclock23.01.0.r72.g6533949-123.01.0.r74.g352cc69-1
                            kcmutils5.106.0.r753.g4cffd2db-15.106.0.r754.g9772c61d-1
                       kcolorchooser23.04.1.r337.gde9049d-123.04.2.r337.gde9049d-1
                               kcron23.04.0.r907.g9637eb7-123.04.2.r907.g9637eb7-1
                       kde-cli-tools5.27.5.r2132.g77db7e9-15.27.5.r2133.g1787873-1
                     kde-dev-scripts23.04.0.r4182.gbd504fa-123.04.2.r4182.gbd504fa-1
                       kde-dev-utils23.04.0.r666.g0d5e900-123.04.2.r666.g0d5e900-1
                      kdebugsettings23.04.0.r1368.gba99146-123.04.2.r1368.gba99146-1
                          kdeconnect23.04.0.r3846.g144a60b5-123.04.2.r3849.g4ef7c262-1
                         kdeedu-data23.04.1.r22.g793df3b-123.04.2.r22.g793df3b-1
              kdegraphics-mobipocket23.04.1.r290.g16b2e58-123.04.2.r290.g16b2e58-1
            kdegraphics-thumbnailers23.04.1.r295.g3da9b35-123.04.2.r297.g9dbad70-1
                     kdelibs4support5.106.0.r1205.g6356e0ee-15.106.0.r1206.ga4526feb-1
              kdenetwork-filesharing23.04.0.r1094.gdc7ac35-123.04.2.r1094.gdc7ac35-1
                            kdenlive23.04.0.r18178.g2192766fa-123.04.2.r18192.g6154d791d-1
                       kdepim-addons23.04.0.r5272.g9f5ee3de1-123.04.2.r5272.g9f5ee3de1-1
                      kdepim-runtime23.04.1.r15929.ge2729f0ab-123.04.2.r15929.ge2729f0ab-1
                    kdesdk-kioslaves23.04.0.r505.g1f7909e-123.04.2.r505.g1f7909e-1
                 kdesdk-thumbnailers23.04.0.r133.g989c6a3-123.04.2.r135.gbc52836-1
                                 kdf23.04.0.r976.g86e7b91-123.04.2.r976.g86e7b91-1
                             kdialog23.04.0.r1366.g0832b04ba-123.04.2.r1366.g0832b04ba-1
                            kdiamond23.04.1.r798.gcc46502-123.04.2.r799.g7596172-1
                      keditbookmarks23.04.0.r2839.gdddb7ac98-123.04.2.r2841.ga0c18fdc0-1
                       kfilemetadata5.106.0.r975.g1131c16-15.106.0.r976.g53923f5-1
                               kfind23.04.0.r2821.g789620dbc-123.04.2.r2821.g789620dbc-1
                             kfloppy23.04.0.r875.gf2f65d2-123.04.2.r875.gf2f65d2-1
                         kfourinline23.04.1.r1108.g0461ef3-123.04.2.r1108.g0461ef3-1
                          kgeography23.04.1.r1255.g7d31981-123.04.2.r1255.g7d31981-1
                                kget23.04.0.r3370.g179d7f65-123.04.2.r3370.g179d7f65-1
                        kglobalaccel5.106.0.r663.g659f251-15.106.0.r664.gc538ad5-1
                         kgoldrunner23.04.1.r1380.g1aa9eee-123.04.2.r1382.gb59d5d2-1
                            khangman23.04.1.r1700.g5d32616-123.04.2.r1700.g5d32616-1
                         khelpcenter23.04.0.r2897.g2a13d034-123.04.2.r2899.ge7acf8e8-1
                            khotkeys5.27.5.r2245.g85c7f71-15.27.5.r2246.gb2a103e-1
                         kiconthemes5.106.0.r702.ga973b2a-15.106.0.r703.gcc16d7d-1
                 kidentitymanagement23.04.1.r4007.g36e0f760-123.04.2.r4008.gcb17bd07-1
                                 kig23.04.1.r3344.gfa593a44-123.04.2.r3345.g046a3f87-1
                                kigo23.04.1.r660.gd1de2ff-123.04.2.r660.gd1de2ff-1
                            killbots23.04.1.r873.ge3deff6-123.04.2.r875.gdec0ee7-1
                     kimagemapeditor23.04.1.r584.ge06fa84-123.04.2.r586.g0bf89e6-1
                               kimap23.04.1.r1301.ge04dd9b-123.04.2.r1301.ge04dd9b-1
                         kinfocenter5.27.5.r2385.g107b1dd7-15.27.5.r2386.g8d0d365c-1
                                 kio5.106.0.r6194.gd54b5656a-15.106.0.r6196.g811fae761-1
                          kio-extras23.04.0.r7574.g51e9df236-123.04.2.r7575.g0680a0462-1
                          kio-gdrive23.04.0.r725.g39de711-123.04.2.r725.g39de711-1
                    kirigami-gallery23.04.0.r353.gb960590-123.04.2.r353.gb960590-1
                              kiriki23.04.1.r534.g7e28ff1-123.04.2.r534.g7e28ff1-1
                         kitemmodels5.106.0.r649.g736563f-15.106.0.r650.g0952af4-1
                               kiten23.04.1.r1286.g11f5f88-123.04.2.r1286.g11f5f88-1
                          kitinerary23.04.1.r2957.gf62f9635-123.04.2.r2957.gf62f9635-1
                        kjumpingcube23.04.1.r917.gcd4e342-123.04.2.r917.gcd4e342-1
                               kldap23.04.1.r1092.g385db87-123.04.2.r1092.g385db87-1
                           kleopatra23.04.0.r7301.g5fe11e2e-123.04.2.r7308.g8cbe0a3d-1
                            klettres23.04.1.r1050.ga7614e7-123.04.2.r1050.ga7614e7-1
                            klickety23.04.1.r775.g8f86b24-123.04.2.r775.g8f86b24-1
                              klines23.04.1.r893.g05309f8-123.04.2.r894.g7c56c56-1
                                kmag23.04.1.r819.gc83e844-123.04.2.r819.gc83e844-1
                           kmahjongg23.04.1.r1665.g515b2d5-123.04.2.r1665.g515b2d5-1
                               kmail23.04.0.r27027.g53f672fb8-123.04.2.r27037.g58218c12c-1
                kmail-account-wizard23.04.0.r985.ge4a7cf5-123.04.2.r985.ge4a7cf5-1
                      kmailtransport23.04.1.r1938.g5961f5b-123.04.2.r1938.g5961f5b-1
                               kmbox23.04.1.r653.gf9238bc-123.04.2.r653.gf9238bc-1
                           kmenuedit5.27.5.r1180.g3ed6ce1-15.27.5.r1181.g0e27bea-1
                               kmime23.04.1.r1629.ga926427-123.04.2.r1629.ga926427-1
                              kmines23.04.1.r1845.g02b3b61-123.04.2.r1845.g02b3b61-1
                                kmix23.04.0.r2556.g2f7272a2-123.04.2.r2582.g1d516924-1
                          kmousetool23.04.1.r524.g2d95fcf-123.04.2.r524.g2d95fcf-1
                              kmouth23.04.1.r829.g82e5da8-123.04.2.r830.gdd57bdd-1
                              kmplot23.04.1.r1593.g76d6ade-123.04.2.r1594.gf6720cc-1
                        knavalbattle23.04.1.r1514.gde963e6-123.04.2.r1514.gde963e6-1
                            knetwalk23.04.1.r788.g017a27e-123.04.2.r788.g017a27e-1
                           knewstuff5.106.0.r1553.ge2a91237-15.106.0.r1554.gb67db719-1
                             knights23.04.1.r1243.ga2b1ca6-123.04.2.r1243.ga2b1ca6-1
                              knotes23.04.0.r3918.gb55dded6-123.04.2.r3918.gb55dded6-1
                                kolf23.04.1.r1604.gce02248-123.04.2.r1604.gce02248-1
                           kollision23.04.1.r606.ga16e446-123.04.2.r606.ga16e446-1
                         kolourpaint23.04.1.r2535.g66311f8b-123.04.2.r2536.g4b279d88-1
                             kompare23.04.0.r1286.gf7d0085-123.04.2.r1287.g4bce7f2-1
                           konqueror23.04.0.r15449.gcd33005af-123.04.2.r15452.g4cd673089-1
                            konquest23.04.1.r1021.gc3687c4-123.04.2.r1021.gc3687c4-1
                             konsole23.04.0.r9080.g051cab71c-123.04.2.r9082.g73d067991-1
                             kontact23.04.0.r5767.g2c999500-123.04.2.r5767.g2c999500-1
                    kontactinterface23.04.1.r791.gfca2805-123.04.2.r791.gfca2805-1
                            kontrast23.04.1.r319.gfd12f26-123.04.2.r319.gfd12f26-1
                        konversation23.04.0.r9297.g2379a978-123.04.2.r9297.g2379a978-1
                       kopeninghours23.04.1.r391.gfae8220-123.04.2.r391.gfae8220-1
                              kopete23.04.0.r16569.g134ed26ef-123.04.2.r16570.ga053f12a8-1
                          korganizer23.04.0.r12137.g194a9f057-123.04.2.r12137.g194a9f057-1
                       kosmindoormap23.04.1.r1010.g90a71f2-123.04.2.r1010.g90a71f2-1
                                kpat23.04.1.r2756.g24dba31f-123.04.2.r2756.g24dba31f-1
                        kpimtextedit23.04.1.r1874.g5c1eaaa-123.04.2.r1901.ge91a512-1
                             kpkpass23.04.1.r348.ge38d0dd-123.04.2.r348.ge38d0dd-1
                             kpmcore23.04.1.r1375.g6640766-123.04.2.r1375.g6640766-1
                    kpublictransport23.04.1.r2180.g8b7136a5-123.04.2.r2180.g8b7136a5-1
                      kqtquickcharts23.04.1.r78.g22ff9c9-123.04.2.r78.g22ff9c9-1
                                krdc23.04.0.r1721.g4d6fa90-123.04.2.r1721.g4d6fa90-1
                            kreversi23.04.1.r1353.gd7e11ea-123.04.2.r1353.gd7e11ea-1
                                krfb23.04.0.r1578.gf2fc9ca-123.04.2.r1578.gf2fc9ca-1
                  kross-interpreters23.04.0.r725.gdef2cfe-123.04.2.r725.gdef2cfe-1
                              kruler23.04.1.r852.g9b1eff8-123.04.2.r852.g9b1eff8-1
                             kshisen23.04.1.r1343.gc44c7f9-123.04.2.r1343.gc44c7f9-1
                               ksirk23.04.1.r1142.gf1b7179-123.04.2.r1142.gf1b7179-1
                               ksmtp23.04.1.r532.g0b9c77f-123.04.2.r532.g0b9c77f-1
                          ksnakeduel23.04.1.r929.g2ef8918-123.04.2.r929.g2ef8918-1
                          kspaceduel23.04.1.r740.gfb3d585-123.04.2.r740.gfb3d585-1
                            ksquares23.04.1.r658.g090ed62-123.04.2.r658.g090ed62-1
                             ksudoku23.04.1.r1202.g30027d1-123.04.2.r1203.ge15bbbe-1
                          ksystemlog23.04.0.r855.g7139f9e-123.04.2.r856.g17b7432-1
                            kteatime23.04.0.r832.g1a85fd8-123.04.2.r832.g1a85fd8-1
                         ktextaddons      r482.g0370101-1      r483.g85d7867-1
                              ktimer23.04.0.r596.g5430a02-123.04.2.r596.g5430a02-1
                               ktnef23.04.1.r817.g04882d2-123.04.2.r817.g04882d2-1
                            ktorrent23.04.0.r2992.gccc8655e-123.04.2.r2994.g1b0408e0-1
                              ktouch23.04.1.r2271.gaf75d6b5-123.04.2.r2273.gd2d25550-1
                               ktrip23.01.0.r29.g82fecb7-123.01.0.r30.g0122db5-1
                          ktuberling23.04.1.r1163.g9378253-123.04.2.r1163.g9378253-1
                             kturtle23.04.1.r1274.g0ebcf61-123.04.2.r1274.g0ebcf61-1
                             kubrick23.04.1.r491.gb6c8628-123.04.2.r491.gb6c8628-1
                      kwalletmanager23.04.0.r1464.g6a4a01b-123.04.2.r1464.g6a4a01b-1
                               kwave23.04.0.r3883.g2a03ba6d-123.04.2.r3883.g2a03ba6d-1
                            kwayland5.106.0.r1212.g25e86ba-15.106.0.r1213.g6f31cb0-1
                      kwidgetsaddons5.106.0.r1097.g64c59987-15.106.0.r1098.ga70ee848-1
                                kwin5.27.5.r24238.g4624503a7c-15.27.5.r24241.g3cf71114cb-1
                           kwordquiz23.04.1.r1320.g73a22e3-123.04.2.r1320.g73a22e3-1
                              kwrite23.04.0.r20725.g946285e9f-123.04.2.r20730.geefd3ba2d-1
                          libakonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                         libgravatar23.04.1.r519.gb7fcd18-123.04.2.r519.gb7fcd18-1
                            libkcddb23.04.1.r851.ga26e08a-123.04.2.r851.ga26e08a-1
                     libkcompactdisc23.04.1.r437.g16014b8-123.04.2.r437.g16014b8-1
                           libkdcraw23.04.1.r1160.g580849c-123.04.2.r1160.g580849c-1
                         libkdegames23.04.1.r2336.gd8f0a978-123.04.2.r2336.gd8f0a978-1
                           libkdepim23.04.1.r1005.g73e26e7-123.04.2.r1005.g73e26e7-1
                  libkeduvocdocument23.04.1.r1857.g1f4c062-123.04.2.r1857.g1f4c062-1
                           libkexiv223.04.1.r843.g68c21bb-123.04.2.r843.g68c21bb-1
                            libkgapi23.04.1.r1575.ge3db7440-123.04.2.r1575.ge3db7440-1
                             libkipi23.04.1.r1289.g8cacdbb-123.04.2.r1289.g8cacdbb-1
                             libkleo23.04.1.r1529.gb6f9d1e-123.04.2.r1530.gdfe3d6b-1
                        libkmahjongg23.04.1.r532.g735eefe-123.04.2.r532.g735eefe-1
                     libkomparediff223.04.1.r406.ge391412-123.04.2.r406.ge391412-1
                            libksane23.04.1.r657.g70a8a78-123.04.2.r657.g70a8a78-1
                           libksieve23.04.1.r1912.g9c6669e6-123.04.2.r1912.g9c6669e6-1
                         libktorrent23.04.1.r604.g5eb5b48-123.04.2.r604.g5eb5b48-1
                            lokalize23.04.0.r2042.g8fbd5973-123.04.2.r2042.g8fbd5973-1
                               lskat23.04.1.r935.g9ea5ee9-123.04.2.r935.g9ea5ee9-1
                          mailcommon23.04.1.r1490.g5da6718-123.04.2.r1491.g3eaf59e-1
                        mailimporter23.04.1.r628.g18495f3-123.04.2.r628.g18495f3-1
                              marble23.04.1.r13687.g22fdac47d-123.04.2.r13688.gc59f6e9c3-1
                       marble-common23.04.1.r13687.g22fdac47d-123.04.2.r13688.gc59f6e9c3-1
                           marble-qt23.04.1.r13687.g22fdac47d-123.04.2.r13688.gc59f6e9c3-1
                        markdownpart23.04.0.r208.g3c2e1ad-123.04.2.r208.g3c2e1ad-1
                             mauikit 3.0.0.r5.gf252a3be-1 3.0.0.r6.g41bf0289-1
                       mbox-importer23.04.0.r651.g97d40f2-123.04.2.r651.g97d40f2-1
                          messagelib23.04.1.r7167.g6314f6c91-123.04.2.r7168.gee6a11b8f-1
                              minuet23.04.1.r700.gfe37472-123.04.2.r700.gfe37472-1
                             neochat23.01.0.r431.g9e78ab332-123.01.0.r446.g7c75a2fd0-1
                              okular23.04.1.r10111.gef7e0ca29-123.04.2.r10118.gd78752ea3-1
                              oxygen5.27.5.r4587.ge99fc48e-15.27.5.r4588.g4b77ceb9-1
                            palapeli23.04.1.r1396.g8e47257-123.04.2.r1396.g8e47257-1
                              parley23.04.1.r4622.g5ab4330b-123.04.2.r4622.g5ab4330b-1
                    partitionmanager23.04.0.r1810.g58e6465-123.04.2.r1810.g58e6465-1
                               picmi23.04.1.r640.gcf33236-123.04.2.r640.gcf33236-1
                   pim-data-exporter23.04.0.r2921.gfe05d2a1-123.04.2.r2921.gfe05d2a1-1
                    pim-sieve-editor23.04.0.r1786.gca81f38-123.04.2.r1786.gca81f38-1
                           pimcommon23.04.0.r2111.ge11b2f04-123.04.2.r2112.g65d25789-1
                       plasma-camera  1.0.r173.g9972dc5-1  1.0.r175.gaa98c44-1
                      plasma-desktop5.27.5.r10259.g3fb604dff-15.27.5.r10260.g30bf5d7d7-1
                       plasma-mobile5.27.5.r2229.g8de183099-15.27.5.r2231.g5f81c766d-1
                          plasma-sdk5.27.5.r2515.g86d760ce-15.27.5.r2517.gfd4eb174-1
                plasma-systemmonitor5.27.5.r736.g4a23fb6-15.27.5.r738.g009565c-1
              plasma-wayland-session5.27.5.r13449.g9d18e0821-15.27.5.r13450.g3672104c7-1
                    plasma-workspace5.27.5.r13449.g9d18e0821-15.27.5.r13450.g3672104c7-1
                          powerdevil5.27.5.r2738.g02d13197-15.27.5.r2741.g7740e71c-1
                               poxml23.04.0.r290.ge730008-123.04.2.r290.ge730008-1
                       print-manager23.04.0.r1280.g3f40324-123.04.2.r1280.g3f40324-1
                         qcachegrind23.04.0.r1279.g6886de0-123.04.2.r1281.gbf373a0-1
                                rocs23.04.1.r3193.g2e016f81-123.04.2.r3193.g2e016f81-1
                                sddm0.19.0.r230.g9a07cf0-10.19.0.r231.g40250a6-1
            signon-kwallet-extension23.04.1.r85.g2d8eb31-123.04.2.r85.g2d8eb31-1
                           spectacle23.04.1.r1760.gf038fc6-123.04.2.r1761.g8e3afdd-1
                                step23.04.1.r1338.g8d3252b-123.04.2.r1338.g8d3252b-1
                             svgpart23.04.1.r286.g152c942-123.04.2.r286.g152c942-1
                             sweeper23.04.0.r645.g61bef39-123.04.2.r645.g61bef39-1
          telepathy-kde-accounts-kcm23.04.0.r1267.g06f990b-123.04.2.r1267.g06f990b-1
              telepathy-kde-approver23.04.0.r336.ge5115f0-123.04.2.r336.ge5115f0-1
          telepathy-kde-auth-handler23.04.0.r317.gfbadbdc-123.04.2.r317.gfbadbdc-1
               telepathy-kde-call-ui23.04.0.r483.gc3f00a3-123.04.2.r483.gc3f00a3-1
      telepathy-kde-common-internals23.04.1.r2075.g4f5cb39-123.04.2.r2075.g4f5cb39-1
          telepathy-kde-contact-list23.04.0.r1137.g995a78f-123.04.2.r1137.g995a78f-1
        telepathy-kde-contact-runner23.04.0.r295.g52d80fe-123.04.2.r295.g52d80fe-1
       telepathy-kde-desktop-applets23.04.0.r1038.ge6891d9-123.04.2.r1038.ge6891d9-1
  telepathy-kde-filetransfer-handler23.04.0.r257.gacf7572-123.04.2.r257.gacf7572-1
    telepathy-kde-integration-module23.04.0.r438.gd9df304-123.04.2.r438.gd9df304-1
             telepathy-kde-send-file23.04.0.r270.gf28ca8f-123.04.2.r270.gf28ca8f-1
               telepathy-kde-text-ui23.04.0.r2106.g5f3cd61d-123.04.2.r2106.g5f3cd61d-1
                            umbrello23.04.0.r8678.ga686a0a74-123.04.2.r8679.gde006014d-1
                             yakuake23.04.0.r970.gb23b734-123.04.2.r970.gb23b734-1
                    zeroconf-ioslave23.04.0.r394.gd86416e-123.04.2.r394.gd86416e-1
