Hello ARM community,
this is just a small overlay packages update. Archlinux ARM is preparing a bigger update soon.
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Update Announcement
Some highlights:
- Some Kernels got renewed
- pinephone and pinephone-pro
- Rasberry Pi4
- Pamac-Dev got more updates to GTK4 to be more mobile friendly
- callaudiod got renewed to 0.1.8
- chatty is now at 0.7.3
- The usual KDE-git updates
End Of Life kernels (will be removed from repo soon):
linux60
(EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy
packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes (Thu May 4 07:18:02 CEST 2023)
- arm-testing core aarch64: 10 new and 10 removed package(s)
- arm-testing kde-unstable aarch64: 379 new and 379 removed package(s)
- arm-testing extra aarch64: 4 new and 4 removed package(s)
- arm-testing community aarch64: 8 new and 7 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023.05.04 2023.05.16
callaudiod 0.1.7-1 0.1.8-1
chatty 0.7.2-2 0.7.3-1
code 1.77.3-1 1.78.1-1
qt5-virtualkeyboard-bigscreen 5.15.8-3 5.15.9-1
sofia-sip 1.13.14-1 1.13.15-1
topgrade 11.0.2-1 11.0.2-2
warp 0.5.3-2 0.5.4-1
python-cec - 0.2.8.r3.g227c69b-4
:: Different overlay package(s) in repository core aarch64
linux-pinephone 6.1.21-1 6.1.28-1
linux-pinephone-headers 6.1.21-1 6.1.28-1
linux-pinephonepro 6.2.12-1 6.2.15-1
linux-pinephonepro-headers 6.2.12-1 6.2.15-1
linux-rpi4 6.1.27-1 6.1.28-1
linux-rpi4-headers 6.1.27-1 6.1.28-1
linux-rpi4-mainline 6.3.1-1 6.3.2-1
linux-rpi4-mainline-headers 6.3.1-1 6.3.2-1
linux-rpi4-rc 6.3.rc7-1 6.4.rc1-1
linux-rpi4-rc-headers 6.3.rc7-1 6.4.rc1-1
:: Different overlay package(s) in repository extra aarch64
pamac-cli-dev 11.0.0rc-2 11.0.0rc-3
pamac-gnome-integration-dev 11.0.0rc-2 11.0.0rc-3
pamac-gtk-dev 11.0.0rc-2 11.0.0rc-3
snapd 2.59.1-1 2.59.4-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi23.04.0.r13065.g964acc87f-123.04.1.r13068.g04871cbcb-1
akonadi-calendar23.04.0.r2357.ga199a8b-123.04.1.r2360.ga805549-1
akonadi-calendar-tools23.04.0.r1041.g16646ff-123.04.0.r1044.gcfbf3f0-1
akonadi-contacts23.04.0.r3464.g59b38e0c-123.04.1.r3469.g403eec0d-1
akonadi-import-wizard23.04.0.r1932.g143f3e1-123.04.1.r1935.gd61f2ee-1
akonadi-mime23.04.0.r1869.g58dd562-123.04.1.r1870.g13a5a9d-1
akonadi-notes23.04.0.r1166.g4c985c0-123.04.1.r1167.g415c48d-1
akonadi-search23.04.0.r1387.g38d2313-123.04.1.r1389.ge0fa7b6-1
akonadiconsole23.04.0.r1737.g31dc8d1-123.04.0.r1739.g558f78a-1
akregator23.04.0.r6714.g80cf7a9b-123.04.0.r6718.g37645d06-1
alligator23.01.0.r43.g7e35b90-123.01.0.r44.g4bc96af-1
analitza23.04.0.r2393.g58206c7b-123.04.1.r2394.ge44a273c-1
angelfish23.01.0.r94.gcf2d90f-123.01.0.r95.g2d1ba46-1
ark23.04.0.r5064.g086f4b00-123.04.0.r5074.gdea5f491-1
artikulate23.04.0.r1515.gc0e4b1d-123.04.1.r1517.g54ec555-1
attica5.105.0.r902.g5c7863f-15.105.0.r907.g38f4516-1
audiocd-kio23.04.0.r1201.gae4f29d-123.04.1.r1202.gca4351f-1
aura-browser5.26.0.r230.gb290a64-15.26.0.r233.g9e1e9ba-1
baloo5.105.0.r3206.gbf994cdb-15.105.0.r3218.ga36f0117-1
baloo-widgets23.04.0.r861.g5ed51d4-123.04.1.r872.gd14801d-1
blinken23.04.0.r735.g542dac0-123.04.1.r736.ga09eef1-1
bluedevil1:5.27.4.r2603.g3406c4b0-11:5.27.5.r2606.g00e968dc-1
bluez-qt5.105.0.r741.g2ba724b-15.105.0.r746.g1961443-1
bomber23.04.0.r631.gf8b3d04-123.04.1.r632.g6044764-1
bovo23.04.0.r852.g80ac421-123.04.1.r853.g581f959-1
breeze5.27.4.r2623.gb4472710-15.27.5.r2625.g2b3a7b2b-1
breeze-grub5.27.4.r11.g63136a9-15.27.5.r11.g63136a9-1
breeze-gtk5.27.4.r514.g177ba74-15.27.5.r515.g95a3743-1
breeze-icons5.105.0.r1966.g60eaeb80-15.105.0.r1968.gdcd416de-1
buho 2.2.2.r18.ge2bd084-1 2.2.2.r26.g4d1c8d9-1
calendarsupport23.04.0.r844.gf27d928-123.04.0.r846.g8fbd7a8-1
calindori23.01.0.r23.g28c2e50-123.01.0.r24.g2d221a2-1
cantor23.04.0.r3573.gd582d63f-123.04.0.r3583.gb6c88e8d-1
cervisia23.04.0.r1769.g1ac16ab-123.04.0.r1772.g9d9f211-1
discover5.27.4.r9309.ge8858b0eb-15.27.5.r9317.gc9d1f794a-1
dolphin23.04.0.r7392.g8e85fbb70-123.04.1.r7398.gdb98dabc7-1
dolphin-plugins23.04.0.r751.g61a1287-123.04.0.r753.g9d74160-1
dragon23.04.0.r1182.g70330fa-123.04.1.r1188.gda7e927-1
drkonqi5.27.4.r924.gae60cfc0-15.27.5.r927.g3a317b94-1
elisa23.04.0.r3286.gbebeece6-123.04.1.r3303.g5c260019-1
elisa-qtmm23.04.0.r3286.gbebeece6-123.04.1.r3303.g5c260019-1
eventviews23.04.0.r1019.g5e1b4eb-123.04.0.r1021.g467e50f-1
extra-cmake-modules5.105.0.r3564.ge5439e34-15.105.0.r3565.g1a480286-1
ffmpegthumbs23.04.0.r261.gebbad9e-123.04.1.r262.g945a606-1
filelight23.04.0.r1395.g10394b5-123.04.0.r1396.geec18da-1
frameworkintegration5.105.0.r676.g41a733d-15.105.0.r678.g83cf0a8-1
granatier23.04.0.r1046.g6e0f823-123.04.1.r1048.g355407d-1
grantlee-editor23.04.0.r936.g53d72e0-123.04.0.r938.gf84a196-1
grantleetheme23.04.0.r500.g761c8a3-123.04.1.r502.gf847b4d-1
gwenview23.04.0.r7130.gb6906b9a-123.04.1.r7135.g77657cb8-1
incidenceeditor23.04.0.r1042.geee1580-123.04.1.r1045.g4028f02-1
index-fm 2.2.2.r59.g577bcff-1 2.2.2.r62.g23ce0c9-1
itinerary23.04.0.r2579.g68c22dd0-123.04.0.r2633.g3bf4fc99-1
juk23.04.0.r3259.gb67574ef-123.04.1.r3260.gb6efd8d2-1
k3b1:23.04.0.r6984.gceedc7206-11:23.04.1.r6990.ge2a226785-1
kaccounts-integration23.04.0.r1358.gd634630-123.04.1.r1359.g16d89ae-1
kaccounts-providers23.04.0.r439.g0cb60fd-123.04.1.r440.g89fc9f6-1
kactivities5.105.0.r1427.gc58b1bcf-15.105.0.r1431.g29a51f82-1
kactivities-stats5.105.0.r432.g063ab45-15.105.0.r436.g3e8609f-1
kactivitymanagerd5.27.4.r1459.gb2421511-15.27.5.r1459.gb2421511-1
kaddressbook23.04.0.r6406.gfcd7ddc3-123.04.1.r6413.g14bba738-1
kajongg23.04.0.r4413.gbaed8eb0-123.04.1.r4414.g6c12331b-1
kalarm23.04.0.r8326.gf56f8fcc-123.04.0.r8329.g3c42fd0c-1
kalgebra23.04.0.r2156.g06e1d7c-123.04.1.r2158.gb992b47-1
kalk23.01.0.r43.g89c255a-123.01.0.r45.gf1af779-1
kalzium23.04.0.r4508.gc000cd51-123.04.0.r4509.g685f9d9a-1
kamera23.04.0.r824.g84ef5c1-123.04.1.r825.g22355d1-1
kamoso23.04.0.r1551.g01ecdbf-123.04.0.r1553.g98406dc-1
kanagram23.04.0.r1400.g35dd9e6-123.04.1.r1403.g401ac60-1
kapidox5.105.0.r587.g5c01721-15.105.0.r589.gb884670-1
kapman23.04.0.r726.g8bbab4c-123.04.1.r728.g1b0d6c3-1
kapptemplate23.04.0.r1055.g2c5906e-123.04.0.r1059.g03485fd-1
karchive5.105.0.r665.g678af1d-15.105.0.r668.gebc1ca2-1
kasts23.01.0.r139.gbeabd5e-123.01.0.r147.g5ae6ff6-1
kate23.04.0.r20646.g3fd67b80d-123.04.0.r20680.g55b596f8c-1
katomic23.04.0.r1040.g034e8e2-123.04.1.r1043.g6f3f3d9-1
kauth5.105.0.r561.g8bad52a-15.105.0.r563.g8990bc7-1
kbackup23.04.0.r539.g8c2312c-123.04.0.r540.gb378796-1
kblackbox23.04.0.r841.g9154823-123.04.1.r843.gef3b3b6-1
kblocks23.04.0.r819.g103e90a-123.04.1.r822.gc4a6567-1
kbookmarks5.105.0.r528.g95f3c7b-15.105.0.r530.g9bcc610-1
kbounce23.04.0.r926.g829758e-123.04.1.r928.g099bd20-1
kbreakout23.04.0.r995.g06a921f-123.04.1.r996.ga458365-1
kbruch23.04.0.r951.g501b5d6-123.04.1.r953.g11b32ee-1
kcachegrind23.04.0.r1264.g18536e5-123.04.0.r1270.gdc5f7bf-1
kcachegrind-common23.04.0.r1264.g18536e5-123.04.0.r1270.gdc5f7bf-1
kcalc23.04.0.r1727.g3280379-123.04.0.r1730.g9aee9d4-1
kcalendarcore5.105.0.r1372.g08b57a74e-15.105.0.r1374.gf8fb585ec-1
kcalutils23.04.0.r1078.g31a2935af-123.04.1.r1080.g466f20a4a-1
kcharselect23.04.0.r619.g1803e8e-123.04.0.r620.ge08eef4-1
kclock23.01.0.r65.ge4801ad-123.01.0.r66.g9e7b46c-1
kcmutils5.105.0.r741.g2cdf2b89-15.105.0.r745.gc6f6e917-1
kcodecs5.105.0.r500.ge4bdd25-15.105.0.r502.g20fc6c2-1
kcolorchooser23.04.0.r332.ga153c93-123.04.1.r333.gc8f8a13-1
kcompletion5.105.0.r562.g035dd83-15.105.0.r564.g1f663dd-1
kconfig5.105.0.r1075.g258dea3a-15.105.0.r1077.g82ff64e5-1
kconfigwidgets5.105.0.r896.ga8b3f63d-15.105.0.r904.g58f42362-1
kcontacts1:5.105.0.r3425.g85657221-11:5.105.0.r3427.g6970564f-1
kcoreaddons5.105.0.r1706.g5e463b12-15.105.0.r1710.g946d2145-1
kcrash5.105.0.r473.g10725e1-15.105.0.r475.g6a03982-1
kdav1:5.105.0.r1403.g842e750-11:5.105.0.r1405.g59a902a-1
kdbusaddons5.105.0.r478.gde8dbf4-15.105.0.r480.gaf3996e-1
kde-cli-tools5.27.4.r2118.gdf77b0f-15.27.5.r2122.gf0ff383-1
kde-dev-utils23.04.0.r650.gd9168eb-123.04.0.r651.g950b557-1
kde-gtk-config5.27.4.r975.gc917dbf-15.27.5.r976.g3aee121-1
kdebugsettings23.04.0.r1150.g0316aa2-123.04.0.r1236.g0777854-1
kdeclarative5.105.0.r1142.g1896cc2e-15.105.0.r1144.g33f73402-1
kdeconnect23.04.0.r3797.g37e984fe-123.04.0.r3803.g5107529f-1
kdecoration5.27.4.r341.gb1b8467-15.27.5.r342.g11148fb-1
kded5.105.0.r500.g907237a-15.105.0.r502.g08a1e25-1
kdeedu-data23.04.0.r22.g793df3b-123.04.1.r22.g793df3b-1
kdegraphics-mobipocket23.04.0.r290.g16b2e58-123.04.1.r290.g16b2e58-1
kdegraphics-thumbnailers23.04.0.r295.g3da9b35-123.04.1.r295.g3da9b35-1
kdelibs4support5.105.0.r1195.g035d8676-15.105.0.r1198.g2524f615-1
kdenlive23.04.0.r17973.gf832e7599-123.04.0.r18037.gbaad50a29-1
kdepim-addons23.04.0.r5251.g70b5f8340-123.04.0.r5263.gdce90fbee-1
kdepim-runtime23.04.0.r15894.g8c7b288c4-123.04.1.r15907.g4ce84164a-1
kdeplasma-addons5.27.4.r9375.g6c0b511bd-15.27.5.r9385.gb39e9a068-1
kdesignerplugin5.105.0.r406.gc8bcad1-15.105.0.r409.gfd7d9b3-1
kdesu5.105.0.r570.g42fac11-15.105.0.r573.g0ca6382-1
kdf23.04.0.r970.g8c0e464-123.04.0.r971.ga52672c-1
kdialog23.04.0.r1350.g242b3699b-123.04.0.r1351.g45e31cc6d-1
kdiamond23.04.0.r793.g12c5e41-123.04.1.r795.g86f666d-1
kdnssd5.105.0.r409.g54052bd-15.105.0.r411.gefd2922-1
kdoctools5.105.0.r730.gdbd1dfc-15.105.0.r733.gc194f3b-1
kemoticons5.105.0.r444.g3bff9a9-15.105.0.r446.g7452924-1
keysmith23.01.0.r54.g5669095-123.01.0.r58.gfa154e1-1
kfilemetadata5.105.0.r956.g5fc8cb6-15.105.0.r959.g9ed7b8e-1
kfind23.04.0.r2813.g97733d93b-123.04.0.r2816.g0ed3a6533-1
kfloppy23.04.0.r869.g89fd369-123.04.0.r871.g954453d-1
kfourinline23.04.0.r1104.ged1fafd-123.04.1.r1105.g91cc913-1
kgamma55.27.4.r529.ge5cedaa-15.27.5.r530.g44c6582-1
kgeography23.04.0.r1249.g2892675-123.04.1.r1251.gb68d035-1
kget23.04.0.r3363.g805c4e18-123.04.0.r3365.gcd6384d3-1
kglobalaccel5.105.0.r657.g8407466-15.105.0.r659.gc8dbc93-1
kgoldrunner23.04.0.r1373.g068bd10-123.04.1.r1374.g4b09fb4-1
kguiaddons5.105.0.r538.g668d88d-15.105.0.r540.g650f79e-1
khangman23.04.0.r1691.g1e62255-123.04.1.r1695.ge754745-1
khelpcenter23.04.0.r2887.g8670bbd1-123.04.0.r2889.g9e0f4ca8-1
kholidays1:5.105.0.r1126.g08f70a2-11:5.105.0.r1130.g13de634-1
khotkeys5.27.4.r2241.gce248f8-15.27.5.r2242.gdc4684e-1
khtml5.105.0.r674.g9b56ffd-15.105.0.r676.g68cd676-1
ki18n5.105.0.r643.g8a2d740-15.105.0.r645.gf30af47-1
kiconthemes5.105.0.r696.g2b01638-15.105.0.r698.g1d1e8c8-1
kidentitymanagement23.04.0.r4001.g4d0a0ce8-123.04.1.r4004.gbcd9895c-1
kidletime5.105.0.r397.g8f69599-15.105.0.r399.g7438782-1
kig23.04.0.r3333.gea855071-123.04.1.r3334.g2876231c-1
kigo23.04.0.r652.g0549dc8-123.04.1.r655.gc893da4-1
killbots23.04.0.r869.g8eab9c1-123.04.1.r870.g483f166-1
kimageformats5.105.0.r483.g9b1fafe-15.105.0.r484.g1477031-1
kimagemapeditor23.04.0.r578.g9687c57-123.04.1.r580.ga5d5bd3-1
kimap23.04.0.r1296.g01830e7-123.04.1.r1298.g2c78875-1
kinfocenter5.27.4.r2375.gef8d88e1-15.27.5.r2380.gf2d80e27-1
kinit5.105.0.r500.gc320ded-15.105.0.r502.ga56dc6d-1
kio5.105.0.r6167.g864eb892f-15.105.0.r6173.gd0fbbcafa-1
kio-extras23.04.0.r7566.g9830eb892-123.04.0.r7567.gae294430a-1
kio-gdrive23.04.0.r720.g2b0776c-123.04.0.r721.g4602a32-1
kirigami-addons1:0.8.0.r21.g94311fe-11:0.8.0.r22.g82af282-1
kirigami-gallery23.04.0.r343.g29fa7a5-123.04.0.r346.g23d1473-1
kirigami25.105.0.r3691.ge55e4f07-15.105.0.r3698.gd570546c-1
kiriki23.04.0.r529.g66f6dbc-123.04.1.r530.g1c11c4a-1
kitemmodels5.105.0.r643.gbf82e31-15.105.0.r647.ge201568-1
kitemviews5.105.0.r434.g649a12e-15.105.0.r436.g88265ef-1
kiten23.04.0.r1278.g2913a94-123.04.1.r1279.ga3bbc8a-1
kitinerary23.04.0.r2858.g3fdf5747-123.04.1.r2874.g7f41efc1-1
kjobwidgets5.105.0.r483.g1f13887-15.105.0.r485.gef9a82c-1
kjs5.105.0.r393.ge799b2c-15.105.0.r395.g42fda2b-1
kjsembed5.105.0.r379.g44b076d-15.105.0.r381.ge0a7a91-1
kjumpingcube23.04.0.r913.g11828b2-123.04.1.r914.ge87795e-1
kldap23.04.0.r1087.g74656cb-123.04.1.r1089.g0eccfcb-1
kleopatra23.04.0.r7258.g0bb08ff5-123.04.0.r7270.gcf36db24-1
klettres23.04.0.r1044.g12db9c8-123.04.1.r1045.gf29e783-1
klickety23.04.0.r771.g115a577-123.04.1.r772.g573553a-1
klines23.04.0.r889.ga19a862-123.04.1.r890.g15bad9e-1
kmag23.04.0.r810.gfc788c0-123.04.1.r815.gfad2e00-1
kmahjongg23.04.0.r1654.g4c40019-123.04.1.r1658.gdfe953d-1
kmail23.04.0.r26956.gcbe91c178-123.04.0.r26998.g5fc3ba493-1
kmail-account-wizard23.04.0.r980.g0c086ef-123.04.0.r983.g7d43e25-1
kmailtransport23.04.0.r1929.g8b221f8-123.04.1.r1933.gc5fa0bd-1
kmbox23.04.0.r652.gf8ed6ba-123.04.1.r653.gf9238bc-1
kmediaplayer5.105.0.r339.g3ef28eb-15.105.0.r341.g67ec887-1
kmenuedit5.27.4.r1177.geec6f90-15.27.5.r1178.gaffbf3c-1
kmime23.04.0.r1624.g75ee3a3-123.04.1.r1626.g5bf5c27-1
kmines23.04.0.r1840.gf2f7b1c-123.04.1.r1842.ge3804e0-1
kmix23.04.0.r2543.g06c20b73-123.04.0.r2552.g6283c579-1
kmousetool23.04.0.r513.g4dc5eb8-123.04.1.r519.gf6d6139-1
kmouth23.04.0.r825.g3818689-123.04.1.r826.gf76be7c-1
kmplot23.04.0.r1583.ga72eb0d-123.04.0.r1584.g71e93c3-1
knavalbattle23.04.0.r1509.ga54c5fc-123.04.1.r1511.g00ebea7-1
knetwalk23.04.0.r781.gf7ff41f-123.04.1.r785.g85583ef-1
knewstuff5.105.0.r1541.gc05c655e-15.105.0.r1547.gf1c325fd-1
knights23.04.0.r1238.ga797fbc-123.04.1.r1239.g14d3de5-1
knotes23.04.0.r3898.gc3f2bcae-123.04.0.r3903.gfa756d09-1
knotifications5.105.0.r822.g3936841-15.105.0.r824.g398329e-1
knotifyconfig5.105.0.r444.g648596a-15.105.0.r446.g21a01c2-1
koko23.01.0.r29.gde5840f-123.01.0.r30.gdf664a4-1
kolf23.04.0.r1599.geea7bfc-123.04.1.r1600.ga381d36-1
kollision23.04.0.r602.g51221ef-123.04.1.r603.gf5dab7c-1
kolourpaint23.04.0.r2526.g3efb14b3-123.04.1.r2527.gc8a9f137-1
kompare23.04.0.r1266.g84642d1-123.04.0.r1270.g3a27d83-1
kongress23.01.0.r24.g7f469d5-123.01.0.r29.g63d9250-1
konqueror23.04.0.r15424.gd7d99c336-123.04.0.r15437.g2ba2529f6-1
konquest23.04.0.r1015.g4fc7540-123.04.1.r1016.g4be48fa-1
konsole23.04.0.r9019.gc031331ba-123.04.0.r9035.g67af0219b-1
kontact23.04.0.r5760.g068169ef-123.04.0.r5763.gba0495c7-1
kontactinterface23.04.0.r787.g9b977fc-123.04.1.r789.g8a7242a-1
kontrast23.04.0.r313.g9e99066-123.04.1.r314.g2bc9c2b-1
konversation23.04.0.r9288.g2194c48e-123.04.0.r9291.g88a5ec27-1
kopeninghours23.04.0.r389.g95ae7c7-123.04.1.r389.g95ae7c7-1
korganizer23.04.0.r12126.g9e2dc2f4c-123.04.0.r12129.gd394fdee4-1
kosmindoormap23.04.0.r994.ga5d41c8-123.04.1.r1005.gcb4d4a7-1
kpackage5.105.0.r841.g5e8795b-15.105.0.r843.g242f732-1
kparts5.105.0.r699.gbc5037f-15.105.0.r701.g0d2da3c-1
kpat23.04.0.r2750.g95430742-123.04.1.r2752.g546fd24e-1
kpeople5.105.0.r1434.ge3ed0d0-15.105.0.r1437.gb580f22-1
kpimtextedit23.04.0.r1867.gc1fdf45-123.04.1.r1870.ga595eea-1
kpipewire5.27.4.r273.gfb3d4cd-15.27.5.r274.gc21da54-1
kpkpass23.04.0.r347.gb4139c4-123.04.1.r348.ge38d0dd-1
kplotting5.105.0.r348.ga1e5e15-15.105.0.r352.gd2163cd-1
kpmcore23.04.0.r1371.g4468ff1-123.04.1.r1371.g4468ff1-1
kpty5.105.0.r432.ga253c42-15.105.0.r434.gc5a5cd8-1
kpublictransport23.04.0.r2156.g3ebeceb9-123.04.1.r2173.g6683e1d4-1
kqtquickcharts23.04.0.r78.g22ff9c9-123.04.1.r78.g22ff9c9-1
kquickcharts5.105.0.r555.g404a54e-15.105.0.r559.g6e14520-1
krdc23.04.0.r1712.g13ad899-123.04.0.r1717.gbbd66ea-1
krecorder23.01.0.r27.gd288ce6-123.01.0.r28.gf1ebb15-1
kreversi23.04.0.r1348.g52004a3-123.04.1.r1349.g8c4cf0c-1
krfb23.04.0.r1572.gafc2e1f-123.04.0.r1573.ge6d86a9-1
kross5.105.0.r411.ge7d3beb-15.105.0.r414.ga2b01ff-1
kruler23.04.0.r848.gd791639-123.04.1.r849.g378ae8c-1
krunner5.105.0.r818.g1ac3308-15.105.0.r827.gac96cc6-1
kscreen5.27.4.r1727.g631b30e-15.27.5.r1729.g224e40c-1
kscreenlocker5.27.4.r1090.g8613bce-15.27.5.r1092.g88db859-1
kservice5.105.0.r1113.g1c8b5acb-15.105.0.r1116.g89733741-1
kshisen23.04.0.r1337.gf2d606a-123.04.1.r1338.g4f948c8-1
ksirk23.04.0.r1133.g70f9c00-123.04.1.r1135.ga194b07-1
ksmtp23.04.0.r528.g6274573-123.04.1.r529.g5da1d7f-1
ksnakeduel23.04.0.r924.g030d141-123.04.1.r926.gdf6b084-1
kspaceduel23.04.0.r736.gec5f94b-123.04.1.r737.gfeced39-1
ksquares23.04.0.r650.g2964602-123.04.1.r654.g48d9697-1
ksshaskpass5.27.4.r269.ge79fc6d-15.27.5.r271.ge895a20-1
ksudoku23.04.0.r1194.g34642c1-123.04.1.r1197.g2fbaa3f-1
ksysguard5.27.4.r3593.g2c18f3bd-15.27.5.r3593.g2c18f3bd-1
ksystemlog23.04.0.r847.gd0ddd41-123.04.0.r849.g4a20a40-1
ksystemstats5.27.4.r297.g2566c15-15.27.5.r298.ga68f612-1
kteatime23.04.0.r824.gea35f74-123.04.0.r828.g2f8a546-1
ktextaddons r458.g448647c-1 r469.gf1a9014-1
ktexteditor5.105.0.r3820.g225bbe57-15.105.0.r3825.g44f8143f-1
ktextwidgets5.105.0.r524.g1c1e199-15.105.0.r526.gc2138d8-1
ktimer23.04.0.r591.g3ef0155-123.04.0.r593.g508c5dd-1
ktnef23.04.0.r812.g4228969-123.04.1.r813.gb855a1e-1
ktorrent23.04.0.r2980.g3f6859e2-123.04.0.r2984.g5608f13e-1
ktouch23.04.0.r2263.gfd32846-123.04.1.r2264.gcc9c125-1
ktrip23.01.0.r21.g844aee8-123.01.0.r23.g3f8fb9d-1
ktuberling23.04.0.r1158.g0c61d10-123.04.1.r1159.g4f28dbd-1
kturtle23.04.0.r1267.g286f2a3-123.04.1.r1270.gfa199dd-1
kubrick23.04.0.r485.g5b803f3-123.04.1.r486.g7cd4713-1
kunitconversion5.105.0.r516.g7a51ef5-15.105.0.r522.ge929e92-1
kwallet5.105.0.r1254.g4e4c04c-15.105.0.r1260.g4a493f8-1
kwallet-pam5.27.4.r291.g6f24746-15.27.5.r292.g34fd7b8-1
kwalletmanager23.04.0.r1457.g099447a-123.04.0.r1459.g1fe9f64-1
kwave23.04.0.r3875.g847a1153-123.04.0.r3879.gb8347476-1
kwayland5.105.0.r1209.gd26f62d-15.105.0.r1211.g771bc6f-1
kwayland-integration5.27.4.r232.g171b566-15.27.5.r233.g012a81d-1
kweather23.01.0.r37.g3ed1eb1-123.01.0.r38.g0476be6-1
kwidgetsaddons5.105.0.r1089.g408cb1c8-15.105.0.r1092.g5d92f81e-1
kwin5.27.4.r24207.gd69225826b-15.27.5.r24213.g50bf526fbf-1
kwindowsystem5.105.0.r768.g5fe5b23-15.105.0.r770.gcd48ca2-1
kwordquiz23.04.0.r1302.g4916ece-123.04.0.r1308.g2e677a8-1
kwrite23.04.0.r20646.g3fd67b80d-123.04.0.r20680.g55b596f8c-1
kwrited5.27.4.r533.gb06a3a1-15.27.5.r534.gfdef56f-1
kxmlgui5.105.0.r1000.g46fe43c2-15.105.0.r1002.gcd83e1ec-1
kxmlrpcclient5.105.0.r525.g2ab625314-15.105.0.r527.g471b1dcfe-1
layer-shell-qt5.27.4.r77.gb2dcb1a-15.27.5.r78.gdebc455-1
libakonadi23.04.0.r13065.g964acc87f-123.04.1.r13068.g04871cbcb-1
libgravatar23.04.0.r515.gbb2c061-123.04.1.r517.g44bd10b-1
libkcddb23.04.0.r840.gb8ca1e6-123.04.1.r840.gb8ca1e6-1
libkcompactdisc23.04.0.r435.g1767993-123.04.1.r435.g1767993-1
libkdcraw23.04.0.r1160.g580849c-123.04.1.r1160.g580849c-1
libkdegames23.04.0.r2332.g668af9d2-123.04.1.r2333.gb9b5b128-1
libkdepim23.04.0.r999.gb2aa541-123.04.1.r1003.g760cc96-1
libkeduvocdocument23.04.0.r1851.g140658a-123.04.1.r1851.g140658a-1
libkexiv223.04.0.r840.ga7e8d31-123.04.1.r840.ga7e8d31-1
libkipi23.04.0.r1288.g2d3a742-123.04.1.r1289.g8cacdbb-1
libkleo23.04.0.r1506.gef72140-123.04.1.r1508.gebdb1e8-1
libkmahjongg23.04.0.r530.gdc8e2ae-123.04.1.r530.gdc8e2ae-1
libkomparediff223.04.0.r399.g3fc35e5-123.04.1.r402.ga0d7eab-1
libksane23.04.0.r654.gb9a8d72-123.04.1.r654.gb9a8d72-1
libkscreen5.27.4.r1786.g67a5998-15.27.5.r1787.g3fdebd3-1
libksieve23.04.0.r1902.g1d65bfa4-123.04.1.r1905.g1a08a171-1
libksysguard5.27.4.r2598.gcc95acd-15.27.5.r2610.gb12476df-1
libktorrent23.04.0.r600.gd827b2e-123.04.1.r601.g9d4f5bc-1
lokalize23.04.0.r1978.g79a2053c-123.04.0.r1983.g26c6476b-1
lskat23.04.0.r930.gbcbe4e1-123.04.1.r932.gd123407-1
mailcommon23.04.0.r1484.g3a0c69e-123.04.1.r1486.g82105d5-1
mailimporter23.04.0.r623.gb39ff22-123.04.1.r625.gc635b39-1
markdownpart23.04.0.r203.g2c27d42-123.04.0.r205.g754f057-1
maui-clip 2.2.2.r17.g905deff-1 2.2.2.r20.gab7e741-1
maui-nota 2.2.2.r38.gd13b073-1 2.2.2.r39.gd192ed6-1
mauikit2.2.2.r95.g0dc8ffdd-12.2.2.r106.g4d1cbff6-1
mauikit-accounts 2.2.2.r29.gb951022-1 2.2.2.r30.g840df2c-1
mauiman r62.6576a2f-1 r63.0d216a4-1
mbox-importer23.04.0.r647.g325b511-123.04.0.r648.gcda0c79-1
messagelib23.04.0.r7109.g8ac588b20-123.04.1.r7117.gb6e4e2cbb-1
milou5.27.4.r823.g49ef949-15.27.5.r824.g9ef6729-1
minuet23.04.0.r692.g1b24566-123.04.1.r694.g8b01adb-1
modemmanager-qt5.105.0.r579.g5aaa43e-15.105.0.r583.g15210d7-1
networkmanager-qt5.105.0.r1187.ge96dbec-15.105.0.r1192.g6746699-1
okular23.04.0.r10072.gac3ba488f-123.04.1.r10087.g0741ff3ef-1
oxygen5.27.4.r4582.geb92542f-15.27.5.r4584.gafd77905-1
palapeli23.04.0.r1387.g241371f-123.04.1.r1390.g7251eba-1
parley23.04.0.r4614.gea7bbc5f-123.04.1.r4616.g98ae6bcf-1
partitionmanager23.04.0.r1802.ga330aaa-123.04.0.r1805.g0de62b7-1
picmi23.04.0.r636.g42f2077-123.04.1.r637.ga2249fd-1
pim-data-exporter23.04.0.r2913.gc6a9c6bc-123.04.0.r2918.ge4601407-1
pim-sieve-editor23.04.0.r1776.g94a62cd-123.04.0.r1782.g7581052-1
pimcommon23.04.0.r2104.g789c736a-123.04.0.r2107.g15164c32-1
plank-player5.26.0.r184.g580aae5-15.26.0.r185.geb2b894-1
plasma-bigscreen5.26.0.r687.g7e8b9c1-15.26.0.r689.geef4ce2-1
plasma-browser-integration5.27.4.r1446.g51fed428-15.27.5.r1448.g5475e588-1
plasma-camera 1.0.r170.ga31c77f-1 1.0.r171.g6e10ded-1
plasma-desktop5.27.4.r10230.g1ff99949a-15.27.5.r10235.g4ec00ddab-1
plasma-dialer23.01.0.r87.g114f3c4-123.01.0.r88.gbc546ec-1
plasma-disks5.27.4.r345.gc7f943d-15.27.5.r349.g564fd4d-1
plasma-firewall5.27.4.r732.g06eb076-15.27.5.r734.gce6a300-1
plasma-framework5.105.0.r16637.g5d68c2488-15.105.0.r16640.g3ac38514e-1
plasma-integration5.27.4.r656.g6f39fa9-15.27.5.r659.ga7b61f4-1
plasma-mobile5.27.4.r2224.g0d81cde14-15.27.5.r2225.g29e301b18-1
plasma-mobile-nm5.27.4.r3602.g2757fbbe-15.27.5.r3608.g78b4246c-1
plasma-nano5.27.4.r246.gc5d68b4-15.27.5.r246.gc5d68b4-1
plasma-nm5.27.4.r3602.g2757fbbe-15.27.5.r3608.g78b4246c-1
plasma-pa5.27.4.r1226.g7ac6b7c-15.27.5.r1229.g37cc0ab-1
plasma-phonebook23.01.0.r51.g6971cc5-123.01.0.r52.gf417120-1
plasma-sdk5.27.4.r2504.gb9986081-15.27.5.r2511.gec5c029e-1
plasma-systemmonitor5.27.4.r732.gc9209a0-15.27.5.r734.g2b1a0ba-1
plasma-thunderbolt5.27.4.r231.g5f3dc37-15.27.5.r231.g5f3dc37-1
plasma-vault5.27.4.r446.g65a1446-15.27.5.r447.ga2c4277-1
plasma-wayland-session5.27.4.r13397.g9c5331c3f-15.27.5.r13411.gc09da5100-1
plasma-workspace5.27.4.r13397.g9c5331c3f-15.27.5.r13411.gc09da5100-1
plasma-workspace-wallpapers5.27.4.r433.ge4139cb-15.27.5.r434.g5f1bd28-1
plasmatube23.01.0.r85.g2257af9-123.01.0.r86.g042bbdb-1
polkit-kde-agent5.27.4.r580.g6f413a9-15.27.5.r581.gfca3eec-1
powerdevil5.27.4.r2717.gb7ab824b-15.27.5.r2722.gf06ba744-1
print-manager23.04.0.r1269.g397af85-123.04.0.r1271.g3551d5e-1
prison5.105.0.r426.g6b234bc-15.105.0.r430.g04618a3-1
purpose5.105.0.r1117.gcbe49f70-15.105.0.r1120.g3a9ccdc7-1
python-cec 0.2.8.r3.g227c69b-3 -
python-uinput 0.11.2.r0.gbefe94a-6 -
qcachegrind23.04.0.r1264.g18536e5-123.04.0.r1270.gdc5f7bf-1
qmlkonsole23.01.0.r78.gcd3beb0-123.01.0.r79.g05cfb47-1
qqc2-breeze-style5.27.4.r262.g752f863-15.27.5.r262.g752f863-1
qqc2-desktop-style5.105.0.r750.g10a998e-15.105.0.r752.g1b58ce5-1
rocs23.04.0.r3186.ged5f2676-123.04.0.r3187.g53612ffa-1
sddm-kcm5.27.4.r759.g60629c8-15.27.5.r763.gc89ac3b-1
signon-kwallet-extension23.04.0.r85.g2d8eb31-123.04.1.r85.g2d8eb31-1
solid5.105.0.r895.gf7d96bd-15.105.0.r898.ge7ba72e-1
sonnet5.105.0.r790.gce2f882-15.105.0.r792.g6a1eb7d-1
spacebar23.01.0.r55.g4453778-123.01.0.r64.g7bdd3c8-1
spectacle23.04.0.r1721.g54f4468-123.04.1.r1736.ga17c65c-1
step23.04.0.r1331.g8fbc9ee-123.04.1.r1332.gce865da-1
svgpart23.04.0.r282.gf81113f-123.04.1.r283.gcc9520b-1
sweeper23.04.0.r641.ga85e661-123.04.0.r642.gac40886-1
syndication5.105.0.r899.gacd1511-15.105.0.r907.g9985c2c-1
syntax-highlighting5.105.0.r2138.g15a521d9-15.105.0.r2143.ge26de1a7-1
systemsettings5.27.4.r2891.ga5ef6197-15.27.5.r2894.g38d110ed-1
telepathy-kde-accounts-kcm23.04.0.r1262.gc8c2a2f-123.04.0.r1263.g81b6a31-1
telepathy-kde-approver23.04.0.r333.g9709f8e-123.04.0.r334.ga4da65a-1
telepathy-kde-auth-handler23.04.0.r314.g7bbd357-123.04.0.r315.g6b8fbee-1
telepathy-kde-common-internals23.04.0.r2071.g9357606-123.04.1.r2072.gb372c03-1
telepathy-kde-contact-list23.04.0.r1132.gf97dbde-123.04.0.r1133.g70b8e1d-1
telepathy-kde-desktop-applets23.04.0.r1035.ga814daf-123.04.0.r1036.g20ac4c7-1
telepathy-kde-integration-module23.04.0.r434.g31764a3-123.04.0.r435.ge4cfaa6-1
telepathy-kde-send-file23.04.0.r267.ge1f3203-123.04.0.r268.g73b67c5-1
telepathy-kde-text-ui23.04.0.r2101.gf2f67ea5-123.04.0.r2102.g9aa8a83c-1
threadweaver5.105.0.r568.g2a600a4-15.105.0.r572.g63fa0be-1
tokodon23.02.0.r231.g778dfdd-123.02.0.r265.g512867f-1
umbrello23.04.0.r8671.g82b4d7533-123.04.0.r8674.g7133f8007-1
vakzination23.01.0.r67.gae62eb8-123.01.0.r69.g7789914-1
vvave 2.2.2.r53.gf4964b4-1 2.2.2.r56.g0e075c5-1
xdg-desktop-portal-kde5.27.4.r701.g6a61445-15.27.5.r703.g975b47c-1
yakuake23.04.0.r951.ga282e18-123.04.0.r952.g9600725-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in Testing Updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
